pomtom44
LED Strip - Pi Zero
Sat May 18, 2019 6:40 am
Hi all
Have a interesting problem
I have a WS2811 led strip, which I am controlling from a raspberry pi zero.
I have connected it up to an external 12v power supply, and have shared the grounds
However
during testing on a short strip, i was having zero problems, but when I move to my longer strip, i start having odd issues.
I wrote a small test script to try figure out what was going on, and whenever I run the test, the middle value never lights up. the lights always turn off
It doesnt matter what values I put in the range, its always the middle show that fails.
Any ideas? and do I make sense?
Script attached below
import time
import board
import neopixel
pixel_pin = board.D18
num_pixels = 80
ORDER = neopixel.GRB
bright = 1
pixels = neopixel.NeoPixel(pixel_pin, num_pixels, brightness=bright, auto_write=False, pixel_order=ORDER)
pixels.fill((0,0,0))
pixels.show()
time.sleep(2)
for i in range(0,80):
    pixels[i] = (0,255,0)
pixels.show()
print("red")
time.sleep(2)
    pixels[i] = (255,0,0)
pixels.show()
print("Blue")
time.sleep(2)
    pixels[i] = (0,0,255)
pixels.show()
print("green")
B.Goode
Re: LED Strip - Pi Zero
Sat May 18, 2019 8:12 am
Disclaimer: I have never used a WS2811 led strip, so this is only general advice...
What happens if you swap around the order in which you test the three saturated colours? Is it always the 'middle' test, or always the (255,0,0) test?
What happens if you lower the intensity of the pixels to, say, 127? (Maybe your PSU can't deliver enough current to drive all the Blues at full power?)
pomtom44
Sat May 18, 2019 7:34 pm
if I swap the colors in the code, its always the middle one.
Red Blue Green - Blue doesnt turn on
Green REd Blue - REd doesnt turn on.
Also if I do one color at a time they all work fine.
Its only when running that cycle that they dont for some reason.
i may test on a short sectino of the strip to see if its a data limit im hitting
pomtom44
Sat May 18, 2019 11:57 pm
Ok so testing, 17 leds works fine, 18 throws an issue
wondering if its bitshift now?
The tutorial I found says you can run them on the 3.3v pi output, but other people are saying no, you have to run it on 5v for the data line.
So might track down a converter and see if that fixes my issues
