Davidoxo
Pi3 -flightradar24 & vnc in from iPhone
Sat May 11, 2019 8:16 pm
Help please
I’m a pi newbie new pi 3 with flightradar24 image. (Jessie) I think, all activated and runs fine. When connected to tv via hdmi can see flightradar24 status fine and if I vnc in with iPhone I can see screen exactly as it is on tv screen
If I remove hdmi and reboot and vnc in ( I do this then I move my setup to a different room where it is going to reside (no tv there) I get a different visual a slider bar that doesn’t seem to do much and no status in top corner.
I’ve read if pi is booted with no hdmi connected resolution changes???
Not sure what to do and how to fix advice please
Andyroo
Re: Pi3 -flightradar24 & vnc in from iPhone
Sat May 11, 2019 11:27 pm
Simplest way is open a terminal / console session and run
sudo raspi-config
Advanced options / Resolution
Set the size you want in there and reboot if requested.
Davidoxo
Sun May 12, 2019 6:17 pm
Any idea how I find what resolution my pi uses when it boots with hdmi to tv
Andyroo
Sun May 12, 2019 9:51 pm
It may depend on the TV and the communication between it and the Pi as part of the start up so I’m not sure how to tell.
You could try
xrandr | grep '*'
from the command line to see what it thinks.
sconemad
Mon May 13, 2019 10:22 am
Another useful command to find the current display settings is "tvservice -s".
