FreezeTile
Pi 3B+ won't load Google-owned websites
Tue Apr 30, 2019 7:34 pm
So my Pi 3B+ has been working fine for about half a year, but recently I decided to check for updates.
There were 159 updates available, so I downlloaded them all. One of the updates was for Chromium.
Now, whenever I try to go to a Google-owned site like Google or YouTube, I get this error.
This site can’t be reached
youtube.com unexpectedly closed the connection.
Try:
Checking the connection
Checking the proxy and the firewall
ERR_CONNECTION_CLOSED
Sites not owned by Google, like eBay or raspberrypi.org, work fine with no issues.
I've even tried formatting the entire boot disk and installing a completely fresh install of Raspbian, but I still get the exact same error.
Somebody please help me, I'm at my wit's end with this...
Re: Pi 3B+ won't load Google-owned websites
Tue Apr 30, 2019 7:38 pm
Get the results from the following commands:
ip addr
ip route
ping -c3 $(ip route | awk '/default/ {print $3}')
ping -c3 8.8.8.8
ping -c3 google.com
cat /etc/resolv.conf
for i in $(awk '/nameserver/ {print $2}' /etc/resolv.conf); do ping -c3 $i; done
FreezeTile
Tue Apr 30, 2019 7:44 pm
pi@raspberrypi:~ $ ip addr
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
inet 127.0.0.1/8 scope host lo
valid_lft forever preferred_lft forever
inet6 ::1/128 scope host
2: eth0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc pfifo_fast state DOWN group default qlen 1000
link/ether b8:27:eb:3c:18:78 brd ff:ff:ff:ff:ff:ff
3: wlan0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast state UP group default qlen 1000
link/ether b8:27:eb:69:4d:2d brd ff:ff:ff:ff:ff:ff
inet 192.168.1.24/24 brd 192.168.1.255 scope global wlan0
inet6 fd84:be52:228:c900:e150:f24f:b90:9b2f/64 scope global mngtmpaddr noprefixroute dynamic
valid_lft 7019sec preferred_lft 3419sec
inet6 fe80::fa9e:55d8:e84b:276f/64 scope link
pi@raspberrypi:~ $ ip route
default via 192.168.1.1 dev wlan0 src 192.168.1.24 metric 303
192.168.1.0/24 dev wlan0 proto kernel scope link src 192.168.1.24 metric 303
pi@raspberrypi:~ $ ping -c3 $(ip route | awk '/default/ {print $3}')
PING 192.168.1.1 (192.168.1.1) 56(84) bytes of data.
64 bytes from 192.168.1.1: icmp_seq=1 ttl=64 time=2.10 ms
64 bytes from 192.168.1.1: icmp_seq=2 ttl=64 time=1.49 ms
64 bytes from 192.168.1.1: icmp_seq=3 ttl=64 time=1.46 ms
--- 192.168.1.1 ping statistics ---
3 packets transmitted, 3 received, 0% packet loss, time 2003ms
rtt min/avg/max/mdev = 1.461/1.688/2.108/0.297 ms
pi@raspberrypi:~ $ ping -c3 8.8.8.8
PING 8.8.8.8 (8.8.8.8) 56(84) bytes of data.
64 bytes from 8.8.8.8: icmp_seq=1 ttl=121 time=17.1 ms
64 bytes from 8.8.8.8: icmp_seq=2 ttl=121 time=17.6 ms
64 bytes from 8.8.8.8: icmp_seq=3 ttl=121 time=19.4 ms
--- 8.8.8.8 ping statistics ---
rtt min/avg/max/mdev = 17.187/18.086/19.454/0.989 ms
pi@raspberrypi:~ $ ping -c3 google.com
PING google.com (216.58.206.78) 56(84) bytes of data.
64 bytes from lhr35s11-in-f14.1e100.net (216.58.206.78): icmp_seq=1 ttl=54 time=20.2 ms
64 bytes from lhr35s11-in-f14.1e100.net (216.58.206.78): icmp_seq=2 ttl=54 time=17.9 ms
64 bytes from lhr35s11-in-f14.1e100.net (216.58.206.78): icmp_seq=3 ttl=54 time=17.6 ms
--- google.com ping statistics ---
rtt min/avg/max/mdev = 17.655/18.614/20.207/1.134 ms
pi@raspberrypi:~ $ cat /etc/resolv.conf
# Generated by resolvconf
domain lan
nameserver 192.168.1.1
nameserver fe80::1%wlan0
pi@raspberrypi:~ $ for i in $(awk '/nameserver/ {print $2}' /etc/resolv.conf); do ping -c3 $i; done
Tue Apr 30, 2019 7:49 pm
You missed the enter key on the last command (don't worry). But your network is OK. So the problem must be with cached data from Chromium or broken Chromium profile settings.
EDIT: I'd delete everything in ~/.cache/Chromium, logout from the desktop, log back in and retry it.
FreezeTile
Tue Apr 30, 2019 7:56 pm
How do I find /.cache/Chromium? Thanks!
Tue Apr 30, 2019 7:58 pm
That funky little tilde (~) at the front of what I posted means /home/pi/... . So it's /home/pi/.cache/Chromium.
Joel_Mckay
Wed May 01, 2019 6:27 am
If your device has a max time adjust forwards limit in NTP, and was left off too long... than SSL issues can occur.
Try running:
date
sudo service ntp stop
sudo ntpdate -s us.pool.ntp.org
sudo ntpd -gq
sudo service ntp start
sudo ntpdate -u time.nist.gov
date
Then reboot the machine to retry your SSL link... let me know if it helps... ;-)
Cheers,
J
Wed May 01, 2019 6:40 am
Try running:
date
sudo ntpd -gq
date
Cheers,
J
All of that will fail 100%.
There's no NTP installed in Raspbian by default. Time sync is done with systemd-timedatectl. Even with ntp added after there's no ntpdate any longer (replaced with ntpd -q -g).
Joel_Mckay
Wed May 01, 2019 6:49 am
And yes, 2 of the above lines will likely not work (20% fail to be exact)... depending on the image age and version.
If Stretch, has someone verified the output to check set-ntp state?
timedatectl
then tried this:
sudo timedatectl set-time "2019-05-01 01:00:00"
