maha1
trouble with booting my raspberry pi 3
Fri Apr 19, 2019 2:44 am
I foolishly rolled back my firmware so that I could install MySQL using this command
sudo rpi-update f6eef32dd6388c3b04dbf462bd324d93281bf397
I rebooted my Pi
and then it didn't appear in the network scan anymore
how can i fix this without erasing the files which contain all my work
also, it would be great if i can make a copy of those files before fixing the problem, just to be in the safe side
thank you in advance
epoch1970
Re: trouble with booting my raspberry pi 3
Fri Apr 19, 2019 7:39 am
For a backup you need another computer or another SD to boot the Pi, plus a card reader.
I understand (almost never touch the stuff myself) rpi-update will mostly affect the contents of the boot partition on Raspbian.
If you Frankenstein your SD with the contents of the FAT partition in a Raspbian release image, less cmdline.txt and config.txt in order to keep your boot configuration, you should be able to boot at least to emergency mode.
Modules versions would probably be out of sync; they are in /lib/modules on the ext4 rootfs partition.
Then there is the odd chance of a firmware blob having been updated, these are in /lib/firmware IIRC.
Fri Apr 19, 2019 9:01 am
Why on earth did you run rpi-update? Don't ever run it again - it can break your system. MySQL has no dependencies on the kernel and bootcode versions.
Rolling it back on a rescue system is non-trivial. Boot another SDCard in your RPi. Mount the broken card in a USB reader.
Run this recipe.
sudo -i
umount /dev/sda1
umount /dev/sda2
or
umount /dev/sda5
umount /dev/sda6
if NOOBS
mount /dev/sda2 /mnt
mount /dev/sda1 /mnt/boot
or
mount /dev/sda6 /mnt
mount /dev/sda5 /mnt/boot
if NOOBS
mount -o bind /dev /mnt/dev
mount -o bint /sys /mnt/sys
mount -t proc /proc /mnt/proc
cd /mnt
chroot .
PRUNE_MODULES=1 SKIP_WARNING=1 rpi-update a08ece3d48c3c40bf1b501772af9933249c11c5b
exit
umount /mnt/proc
umount /mnt/sys
umount /mnt/dev
umount /mnt/boot
umount /mnt
poweroff
maha1
Thu Apr 25, 2019 6:06 am
hi again
thanks DougleLawson for replying .it was a foolish mistake ,now i get the lesson
so finally, i got my new sd card and usb adapter
i installed the rasbian image using balenaEtcher ,but as it finished installation my pc asked to format the card
i tried to open it but it showed that error 'is not accessible'
the raspberry can't read the card
so i tried to format it using cmd windows and sdcard formatter but still not working
i even tried to reinstall the image with balenaEtcher but it gives the same result
so am stuck here
any help would be appreciated
LTolledo
Thu Apr 25, 2019 6:30 am
In windows pc, after flashing image to microSD using balenaEtcher, ALWAYS IGNORE windows warnings.
Start again
Insert microSD card in windows pc microSD slot (or USB to microSD adapter) --- flash image to microSD using Etcher --- ignore windows warnings after flashing -- remove microSD card --- put microSD card to RPi -- turn on power to RPi
then follow DougieLawson's procedure... dont deviate from it.
Some people be like:
maha1
Thu Apr 25, 2019 9:25 am
actually ,that's what i did but the rpi can't read the sd card
there is no different between what happens with card sd and without it
and no green light
maha1
Thu Apr 25, 2019 8:08 pm
has anybody experienced this problem before or have any idea how to format my sd card
i really need some help :(
B.Goode
Thu Apr 25, 2019 8:41 pm
If you are going to create a bootable micro SD card for your RPi using a standard Raspberry Pi Foundation image of the Raspbian Stretch Operating System with the BalenaEtcher utility you do not need to format the card first. Any formatting you apply at that stage will be superceded/undone/overwritten when the image is 'flashed' to the card.
MrEngman
Thu Apr 25, 2019 8:42 pm
I rebooted my Pi
Why did you do this? It installs kernel 3.10.38 from Apr 2014. Years before any kernel the pi 3 will work with.
No wonder your pi 3 doesn't work.
maha1
Thu Apr 25, 2019 8:58 pm
I rebooted my Pi
actually, i'm using a new card sd not the broken one
maha1
Thu Apr 25, 2019 9:03 pm
the rpi can't read the card, that's why I'm trying to reflash it
and i tried reflashing it with Etcher again but it's not working
B.Goode
Thu Apr 25, 2019 10:05 pm
So one of the following is probably true:
The microSD card is faulty;
or the microSD card writer is faulty;
or the RPi has become faulty, independently of your original misconfiguration.
maha1
Thu Apr 25, 2019 10:16 pm
and how could i identify the problem
B.Goode
Fri Apr 26, 2019 10:20 am
The problem you are now troubleshooting is different to the one you initially presented
There is a summary of all the knowledge accumulated from these forums during the past 7 years about difficulties getting an RPi to boot, see - STICKY: Is your Pi not booting? (The Boot Problems Sticky) - viewtopic.php?f=28&t=58151
There is no 'Magic Wand' that we can wave to fix your RPi or diagnose the cause of your problem: you simply have to proceed by methodically changing one component at a time.
maha1
Thu May 02, 2019 11:50 am
thanks DougieLawson
your solution is working my raspberry is working again and i found all my files
and thanks everyone else but i gave up on the old card sd and bought a new one
unfortunately, i'm facing a new problem now
i connected my rasp pi on my laptop using ethernet, it was working but suddenly it stopped connecting
i reboot it ,it appears on mobaxterm scan interface but ssh connection is disabled .
i tried to fix this by adding ssh file to boot directory in the sd card but still not working.
Thu May 02, 2019 12:13 pm
thanks DougieLawson
Please start a new thread with this new problem.
