Expand SD card partition size
Posted: Sun Nov 25, 2012 5:21 pm
by Reason2doubt
I got my PI up and running a few days ago and was successfully installing Libre Office on it when it suddenly ran out of space. I knew this was an error as i have a 16GB card installed so was a bit confused. I read around google and found some pages to help expand the usable space on the SD card:
I used this topic: http://elsmorian.com/post/23366148056/b ... y-pi-setup
But i seem to be running into issues after typing in "sudo fdisk -uc /dev/mmcblk0" as I don't get the same command line everyone else does.
Instead I get this list of options:
I can't seem to progress to the next step of displaying the partition table (by typing in "p") - maybe this is because I am misunderstanding where the command line is on the Raspbian “wheezy” image I downloaded onto it, i'm just not sure.
If anyone can help me out I would greatly appreciate it.
Re: Expand SD card partition size
Posted: Sun Nov 25, 2012 8:01 pm
by bgirardot
You do not mention what version or what distro you are running but it looks like a raspbian distro.
You should be able to type:
sudo raspi-config
and select "expand root partition"
and then reboot, it will take a few minutes on reboot to expand the partition to fill the card.
Posted: Sun Nov 25, 2012 9:39 pm
by Reason2doubt
Hi, thanks I found it eventually using the raspi-config menu as you explained.
