last week I removed from the raspberry pi zero w the previous header pin that I had welded to put one with the longer male pins and on the other side the female pins. https://www.banggood.com/12MM-40Pin-Fem ... rehouse=CN
After doing the welding everything was fine the stalk worked, but after a while it went off. With the tester I checked if the correct voltage was coming to the 3v and 5v pins and so it was. I checked, again with the tester, if there were short circuits but nothing. So I left the raspberry pi zero w attached to the socket for a while and it suddenly came back on. I tried using two different sd cards and connecting it to a monitor via HDMI it worked. After turning it off properly, I put it back in its pibow cover and the next day I turned it back on, but it didn't work anymore. I left it attacked for an hour but nothing. So I decided to unsolder the header pin but something went wrong. In fact with the sucker the pond did not come out, so I cut the stacking header I removed the female part and in doing so I managed to remove the male pins from the back, but while I continued to some the pad of the raspberry also came out. Here is the situation now.
Now I wanted to know if you can still use it without using the gpio or if it is completely to be thrown away.
thank you very much for your help.
