cbh560
TP link Archer T2U AC600 not working
Sat Apr 06, 2019 11:19 am
Hi All
I am new to the raspberry pi and have a Pi 2B. I have a TP link Archer T2U AC600 wireless adapter but can not get it to work. Can someone give any advise on how to get this working please? I have no experience with the Pi or Linux......sorry.
Andyroo
Re: TP link Archer T2U AC600 not working
Sat Apr 06, 2019 2:12 pm
In the top right of the desktop do you see a WiFi connection when the dongle is plugged in? Hovering / clicking this will show you the networks the Pi can see.
If not then the basic system does not recognise this adapter and you may have to hunt for a Pi driver or build one - not easy if you are new to Linux. What operating system do you have on the Pi and is it up to date?
Do have the Ethernet cable connection working and get internet that way?
MrEngman
Sat Apr 06, 2019 2:32 pm
Hi All
Depending on the OS you have installed you will probably need to install the wifi driver.
With the wifi dongle connected to your Pi please post the output of the two commands:-
uname -a
lsusb
cbh560
Sat Apr 06, 2019 4:05 pm
Thank you for the replies so far.
Andyroo.
I have installed the Raspbian OS through from the noobs on the Pi website. I have a connection through my wired connection but if I remove this with the wireless dongle installed I just get two red X's by the wifi icon. I have just done a fresh install and run the latest update. but still the same.
MrEngman.
The outputs you requested are as follows
uname -a =
Linux raspberrypi 4.14.98v7+ #120 smp Tue Feb12 20:27:48 GMT 2019 armv71GNU/Linux
lsusb=
Bus 001 Device 005: ID 148f:761a Ralink Technology, Corp
Bus 001 Device 004: ID 046d:c534 Logitech, Inc Unifying Receiver
Bus 001 Device 003: ID 0424:ec00 Standard Microsystems Corp SMC9514 Hub
Ethernet Adapter
Bus 001 Device 002: ID 0424:9514 Standard Standard Microsystems Corp. SMC9514 Hub
Bus 001 Device 001: ID 1d6b:0002 Linux foundation 2.0 root hub
Andyroo
Sat Apr 06, 2019 4:15 pm
This may help unless someone comes up with a better fix as it’s a bit old
https://askubuntu.com/questions/674116/ ... nk-mt7610u
The usb ID from the report is a solid match though the model is different.
swahren
Sat Apr 06, 2019 5:07 pm
No, please don't do this. The driver is available upstream since 4.19.
Reference: https://github.com/raspberrypi/linux/pull/2890
Andyroo
Sat Apr 06, 2019 5:09 pm
Even better :)
cbh560
Sat Apr 06, 2019 5:17 pm
Hi Swarhen
Thank you for your reply. Can I install this direcly on the Pi by following the link provided? Sorry, that sounds realy dim but as I previously said, I am a Pi virgin so need all the help I can get.
Sat Apr 06, 2019 5:30 pm
See next reply
Last edited by fruitoftheloom on Sat Apr 06, 2019 5:37 pm, edited 2 times in total.
adieu
MrEngman
Sat Apr 06, 2019 5:33 pm
Andyroo.
MrEngman.
uname -a =
lsusb=
Ethernet Adapter
Hi cbh560,
I have compiled drivers for the wifi module you have. You can download and install the driver for the kernel version you currently have using the following commands
wget http://downloads.fars-robotics.net/wifi-drivers/mt7610-drivers/mt7610-4.14.98-v7-1200.tar.gz
tar xzf mt7610-4.14.98-v7-1200.tar.gz
./install.sh
I also have a script at http://downloads.fars-robotics.net/wifi ... stall-wifi which when run will automatically select the right version of driver and install it.
You can download and install the script using commands
sudo wget http://downloads.fars-robotics.net/wifi-drivers/install-wifi -O /usr/bin/install-wifi
sudo chmod +x /usr/bin/install-wifi
and run the script using command
sudo install-wifi -h
to see data on how to use it.
To download and install the mt7610u driver for your current kernel you should just need to run command
sudo install-wifi
The newer kernel version 4.19.xx now has the mt7610u driver installed but as you are new to Linux and as the new kernel is still under testing it may be best to keep to the kernel version you are currently using.
MrEngman
cbh560
Sat Apr 06, 2019 8:28 pm
Hi MrEngman
I don't know what I'm doing wrong but I keep getting errors. I have copied all of your text but no success.
Andyroo
Sat Apr 06, 2019 9:15 pm
Hi MrEngman
Can you post the errors here?
MrEngman
Sat Apr 06, 2019 9:27 pm
Hi MrEngman
Would be helpful.
However, I've just noticed an error in the commands to install the driver, so the error could be due to that. I have corrected the error in my previous post which was a missing space in line
tar xzfmt7610-4.14.98-v7-1200.tar.gz
which should be
- space required between tar xzf and mt7610-4.14....
MrEngman
