Sir
My Raspberrypi2's ip and gateway cannot be remove from it interface ...all information below....please help to solve.......
i want to remove 192.168.137.48 and set 192.168.0.106 .. my router's configuration has been changed to 192.168.0.1 as gateway address..
ifconfig -a
eth0 Link encap:Ethernet HWaddr b8:27:eb:b7:cb:1c
inet addr:192.168.137.48 Bcast:192.168.137.255 Mask:255.255.255.0
inet6 addr: fe80::ba27:ebff:feb7:cb1c/64 Scope:Link
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:101 errors:0 dropped:0 overruns:0 frame:0
TX packets:187 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:8366 (8.1 KiB) TX bytes:72437 (70.7 KiB)
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
inet6 addr: ::1/128 Scope:Host
UP LOOPBACK RUNNING MTU:65536 Metric:1
RX packets:137 errors:0 dropped:0 overruns:0 frame:0
TX packets:137 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:13070 (12.7 KiB) TX bytes:13070 (12.7 KiB
# interfaces(5) file used by ifup(8) and ifdown(8)
# Please note that this file is written to be used with dhcpcd
# For static IP, consult /etc/dhcpcd.conf and 'man dhcpcd.conf'
# Include files from /etc/network/interfaces.d:
source-directory /etc/network/interfaces.d
auto lo
iface lo inet loopback
auto eth0
allow-hotplug eth0
iface eth0 inet manual
auto wlan0
allow-hotplug wlan0
iface wlan0 inet manual
wpa-roam /etc/wpa_supplicant/wpa_supplicant.conf
#auto wlan1
#allow-hotplug wlan1
#iface wlan1 inet manual
#wpa-conf /etc/wpa_supplicant/wpa_supplicant.conf
interface eth0
static ip_address=192.168.0.106/24
static routers=192.168.0.1
static domain_name_servers=192.168.0.1 8.8.8.8
hostname
clientid
persistent
option rapid_commit
option domain_name_servers, domain_name, domain_search, host_name
option classless_static_routes
option ntp_servers
require dhcp_server_identifier
slaac private
nohook lookup-hostname
static domain_search=
Re: cannot remove static ip address and gateway from raspberrypi2
Did you set a static IP address on the Pi or is it getting it from the router?
First place to check is the router and see if it has a MAC address / IP reservation for the Pi.
- default_user8
What is in your dhcpcd.conf? The answer to your question is in your post, unless you set a static ip in your router configuation and somehow forgot about it.
Two heads are better than one, unless one's a goat head.
Good pointdefault_user8 wrote: ↑Tue Apr 02, 2019 4:39 pmWhat is in your dhcpcd.conf? The answer to your question is in your post, unless you set a static ip in your router configuation and somehow forgot about it.
change
to
or just delete it.. Also comment out remaining text below it too (not in my file..???) if needed you can uncomment it back but as its a list of unset options ....
#static ip_address=192.168.0.106/24
#static routers=192.168.0.1
#static domain_name_servers=192.168.0.1 8.8.8.8
- DougieLawson
- Location: A small cave in deepest darkest Basingstoke, UK
- Contact: Website Twitter
What's all that junk you've added to /etc/network/interfaces did you fail to read the rubric at the top of that file (which paraphrased says "Don't add stuff to this file.").
