i just bought an element14 rpi3+. When i connect it on a 3A power supply the pwr led is always red.
I use a 32GB microsd card with the latest rasbian.
The power supply and the microsd card works fine on an other raspberry.
Is there anything i can do to fix this?
Please advice
Re: no boot - always red light - rpi3b+
For a summary of all the knowledge accumulated from these forums during the past 7 years about difficulties getting an RPi to boot, see - STICKY: Is your Pi not booting? (The Boot Problems Sticky) - viewtopic.php?f=28&t=58151
The paragraph near the beginning that starts
looks as though it describes your situation.If you have a PI3B+, that, after some days or weeks of working, suddenly has stopped booting..
Thank you for the reply!
the rpi has no valid 3.3V. The output is 0.01V.
it was just taken out of the box.
Is there any fix? or i should contact with the reseller?
Which model (the other Raspberry) ?The power supply and the microsd card works fine on an other raspberry.
Self-education is, I firmly believe, the only kind of education there is - Isaac Asimov
Raspberry Pi 3 Model B+ is the new one, and the one i tested the power supply and the microsd card is Raspberry Pi Model B+ v1.2
Assuming that you had done nothing to 'provoke' this (particularly connected nothing to the GPIO connections or run it without a case on a conductive or potentially conductive surface), you should go back to the reseller and report it as DOA.
i already wrote to the reseller and i'm waiting for an answer.
i am really carefull when i'm using the raspberry, i connected nothing to the GPIO connections. i used no case but without a conductive surface. For sure not shortcut by me.
The point is how to prove it
Looks like you've just added yourself to the (growing?) list of users bit by the "RPi3B+ PMIC Abberation"
Some people be like:
