edimi
no boot - always red light - rpi3b+
Fri Mar 29, 2019 5:31 pm
i just bought an element14 rpi3+. When i connect it on a 3A power supply the pwr led is always red.
I use a 32GB microsd card with the latest rasbian.
The power supply and the microsd card works fine on an other raspberry.
Is there anything i can do to fix this?
Please advice
B.Goode
Re: no boot - always red light - rpi3b+
Fri Mar 29, 2019 5:54 pm
For a summary of all the knowledge accumulated from these forums during the past 7 years about difficulties getting an RPi to boot, see - STICKY: Is your Pi not booting? (The Boot Problems Sticky) - viewtopic.php?f=28&t=58151
The paragraph near the beginning that starts
If you have a PI3B+, that, after some days or weeks of working, suddenly has stopped booting..
looks as though it describes your situation.
edimi
Fri Mar 29, 2019 7:06 pm
Thank you for the reply!
the rpi has no valid 3.3V. The output is 0.01V.
it was just taken out of the box.
Is there any fix? or i should contact with the reseller?
B.Goode
Fri Mar 29, 2019 7:09 pm
I am just another RPi user.
I have nothing to add beyond what is written in the linked advice.
lpsw
Fri Mar 29, 2019 7:28 pm
Which model (the other Raspberry) ?
Self-education is, I firmly believe, the only kind of education there is - Isaac Asimov
edimi
Fri Mar 29, 2019 7:31 pm
Raspberry Pi 3 Model B+ is the new one, and the one i tested the power supply and the microsd card is Raspberry Pi Model B+ v1.2
pfletch101
Fri Mar 29, 2019 7:34 pm
Assuming that you had done nothing to 'provoke' this (particularly connected nothing to the GPIO connections or run it without a case on a conductive or potentially conductive surface), you should go back to the reseller and report it as DOA.
edimi
Fri Mar 29, 2019 7:40 pm
i already wrote to the reseller and i'm waiting for an answer.
i am really carefull when i'm using the raspberry, i connected nothing to the GPIO connections. i used no case but without a conductive surface. For sure not shortcut by me.
The point is how to prove it :?
LTolledo
Fri Mar 29, 2019 9:01 pm
Looks like you've just added yourself to the (growing?) list of users bit by the "RPi3B+ PMIC Abberation" :(
Some people be like:
Burngate
Sat Mar 30, 2019 10:11 am
Depends where you are, but my understanding of it is, in the EU at any rate, within 6 months of the sale, you don't have to prove anything, the supplier has to prove your wrong-doing
