Page 1 of 2
no /dev/sdxx
Posted: Sat Nov 24, 2012 7:53 am
by ryql
I am following an article to build a NAS with my raspberry pi.
I am at a point where I have to mount the usb hard drives but there is no /dev/sda1 etc in the /dev directory. Any help would be appreciated. Thank You
Re: no /dev/sdxx
Posted: Sat Nov 24, 2012 10:47 am
by drgeoff
ryql wrote:I am following an article to build a NAS with my raspberry pi.
Hmm! Does 'dmesg' return anything relevant after you plug the drive in?
(Just in case you are not aware: The USB sockets on a RPi do not supply enough power for a hard disk. You must use a self powered drive or a powered USB hub.)
Re: no /dev/sdxx
Posted: Sat Nov 24, 2012 2:59 pm
by ryql
dmesg does not show anything relevant and I am using a dual hard drive case that plugs into AC.
The sdxx does not show up in /dev and it should.
Re: no /dev/sdxx
Posted: Sat Nov 24, 2012 3:10 pm
by drgeoff
ryql wrote:dmesg does not show anything relevant and I am using a dual hard drive case that plugs into AC.
dmesg should have some lines about the USB drive being plugged in.
I assume you have checked the drive case and USB cable working with another computer.
Re: no /dev/sdxx
Posted: Sat Nov 24, 2012 5:05 pm
by ryql
The hard drives work on my PC.
What am I supposed to see in dmesg?
I see a lot of usb stuff but the only thing I recognize is my keyboard.
Re: no /dev/sdxx
Posted: Sat Nov 24, 2012 5:52 pm
by drgeoff
ryql wrote:The hard drives work on my PC.
Several lines like this:
[92151.590453] usb 1-1.2: new high-speed USB device number 7 using dwc_otg
[92151.701858] usb 1-1.2: New USB device found, idVendor=0e79, idProduct=1106
[92151.712390] usb 1-1.2: New USB device strings: Mfr=56, Product=63, SerialNumber=85
[92151.726157] usb 1-1.2: Product: PMA400 USB2.0 Adapter
[92151.734897] usb 1-1.2: Manufacturer: ARCHOS
[92151.742715] usb 1-1.2: SerialNumber: DEF10AE1EB3D
[92151.770313] scsi2 : usb-storage 1-1.2:1.0
[92152.771367] scsi 2:0:0:0: Direct-Access HTC42603 0G7AT00 PQ: 0 ANSI: 0
[92152.792024] sd 2:0:0:0: [sda] 58605120 512-byte logical blocks: (30.0 GB/27.9 GiB)
[92152.821436] sd 2:0:0:0: [sda] Write Protect is off
[92152.829026] sd 2:0:0:0: [sda] Mode Sense: 33 00 00 00
[92152.840334] sd 2:0:0:0: [sda] Write cache: disabled, read cache: enabled, doesn't support DPO or FUA
[92153.190901] sda: sda1 sda2
[92153.207070] sd 2:0:0:0: [sda] Attached SCSI disk
If you issue the dmesg command a short time after plugging in the USB drive, the corresponding lines should be the at the very end of the output.
Re: no /dev/sdxx
Posted: Sat Nov 24, 2012 5:57 pm
by ryql
I see similar usb lines but no sda stuff.
Re: no /dev/sdxx
Posted: Sat Nov 24, 2012 6:05 pm
by drgeoff
ryql wrote:I see similar usb lines but no sda stuff.
Can you post what you do see?
Re: no /dev/sdxx
Posted: Sat Nov 24, 2012 7:06 pm
by ryql
I plugged in a flash drive and I can see /dev/sda and /dev/sda1.
I am unsure how to mount the flash drive.
I tried mount -t /dev/sda1 /mnt/disk1
I got a message saying must specify file type so I tried the above with msdos added after the -t
I have worked with unix and Linux for several years but have been away from it for a couple of years.
I feel like a rookie. I was trying to post my dmesg. I saved it as a text file.
Re: no /dev/sdxx
Posted: Sat Nov 24, 2012 7:54 pm
by drgeoff
ryql wrote:I plugged in a flash drive and I can see /dev/sda and /dev/sda1.
Try
mount -t vfat /dev/sda1 /mnt/disk1
(The /mnt/disk1 needs to exist before the mount command is issued.)
Re: no /dev/sdxx
Posted: Sat Nov 24, 2012 8:47 pm
by ryql
I get the same message wrong fs type bad option bad superblock on /dev/sda1
Re: no /dev/sdxx
Posted: Sat Nov 24, 2012 10:13 pm
by ryql
Finally I found a way to get my dmesg info to you. Here it is:
[ 0.000000] Initializing cgroup subsys cpu
[ 0.000000] Linux version 3.1.9+ (dc4@dc4-arm-01) (gcc version 4.5.1 (Broadcom-2708) ) #168 PREEMPT Sat Jul 14 18:56:31 BST 2012
[ 0.000000] CPU: ARMv6-compatible processor [410fb767] revision 7 (ARMv7), cr=00c5387d
[ 0.000000] CPU: VIPT nonaliasing data cache, VIPT nonaliasing instruction cache
[ 0.000000] Machine: BCM2708
[ 0.000000] Memory policy: ECC disabled, Data cache writeback
[ 0.000000] On node 0 totalpages: 49152
[ 0.000000] free_area_init_node: node 0, pgdat c05f7c4c, node_mem_map c06c8000
[ 0.000000] Normal zone: 384 pages used for memmap
[ 0.000000] Normal zone: 0 pages reserved
[ 0.000000] Normal zone: 48768 pages, LIFO batch:15
[ 0.000000] pcpu-alloc: s0 r0 d32768 u32768 alloc=1*32768
[ 0.000000] pcpu-alloc: [0] 0
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 48768
[ 0.000000] Kernel command line: dma.dmachans=0x3c bcm2708_fb.fbwidth=1824 bcm2708_fb.fbheight=984 bcm2708.boardrev=0x2 bcm2708.serial=0xa93ab410 smsc95xx.macaddr=B8:27:EB:3A:B4:10 dwc_otg.lpm_enable=0 console=ttyAMA0,115200 kgdboc=ttyAMA0,115200 console=tty1 root=/dev/mmcblk0p2 rootfstype=ext4 elevator=deadline rootwait
[ 0.000000] PID hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.000000] Dentry cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.000000] Inode-cache hash table entries: 16384 (order: 4, 65536 bytes)
[ 0.000000] Memory: 192MB = 192MB total
[ 0.000000] Memory: 187880k/187880k available, 8728k reserved, 0K highmem
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
[ 0.000000] fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
[ 0.000000] DMA : 0xffc00000 - 0xffe00000 ( 2 MB)
[ 0.000000] vmalloc : 0xcc800000 - 0xd8000000 ( 184 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xcc000000 ( 192 MB)
[ 0.000000] modules : 0xbf000000 - 0xc0000000 ( 16 MB)
[ 0.000000] .text : 0xc0008000 - 0xc05943d0 (5681 kB)
[ 0.000000] .init : 0xc0595000 - 0xc05c7000 ( 200 kB)
[ 0.000000] .data : 0xc05c8000 - 0xc05f93b8 ( 197 kB)
[ 0.000000] .bss : 0xc05f93dc - 0xc06c7504 ( 825 kB)
[ 0.000000] NR_IRQS:245
[ 0.000000] timer_set_mode: unhandled mode:1
[ 0.000000] timer_set_mode: unhandled mode:3
[ 0.000000] Console: colour dummy device 80x30
[ 0.000000] console [tty1] enabled
[ 2.813499] Calibrating delay loop... 697.95 BogoMIPS (lpj=3489792)
[ 2.872455] pid_max: default: 32768 minimum: 301
[ 2.873089] Mount-cache hash table entries: 512
[ 2.873745] Initializing cgroup subsys cpuacct
[ 2.873863] Initializing cgroup subsys devices
[ 2.873916] Initializing cgroup subsys freezer
[ 2.873958] Initializing cgroup subsys blkio
[ 2.874079] CPU: Testing write buffer coherency: ok
[ 2.874215] ftrace: allocating 14801 entries in 44 pages
[ 2.947259] hw perfevents: enabled with v6 PMU driver, 3 counters available
[ 2.949254] devtmpfs: initialized
[ 2.957029] NET: Registered protocol family 16
[ 2.958954] vc-mem: mm_vc_mem_phys_addr = 0x00000000
[ 2.959022] vc-mem: mm_vc_mem_size = 0x10000000 (256 MiB)
[ 2.959548] hw-breakpoint: found 6 breakpoint and 1 watchpoint registers.
[ 2.959622] hw-breakpoint: maximum watchpoint size is 4 bytes.
[ 2.959671] mailbox: Broadcom VideoCore Mailbox driver
[ 2.959782] bcm2708_vcio: mailbox at f200b880
[ 2.959889] bcm_power: Broadcom power driver
[ 2.959936] bcm_power_open() -> 0
[ 2.959968] bcm_power_request(0, 8)
[ 3.460664] bcm_mailbox_read -> 00000080, 0
[ 3.460712] bcm_power_request -> 0
[ 3.460744] Serial: AMBA PL011 UART driver
[ 3.460938] dev:f1: ttyAMA0 at MMIO 0x20201000 (irq = 83) is a PL011 rev3
[ 3.766743] console [ttyAMA0] enabled
[ 3.792561] bio: create slab <bio-0> at 0
[ 3.798133] SCSI subsystem initialized
[ 3.802181] usbcore: registered new interface driver usbfs
[ 3.807979] usbcore: registered new interface driver hub
[ 3.813614] usbcore: registered new device driver usb
[ 3.819771] Switching to clocksource stc
[ 3.828831] Switched to NOHz mode on CPU #0
[ 3.842539] FS-Cache: Loaded
[ 3.845939] CacheFiles: Loaded
[ 3.867510] NET: Registered protocol family 2
[ 3.872465] IP route cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 3.881039] TCP established hash table entries: 8192 (order: 4, 65536 bytes)
[ 3.888571] TCP bind hash table entries: 8192 (order: 3, 32768 bytes)
[ 3.895280] TCP: Hash tables configured (established 8192 bind 8192)
[ 3.901666] TCP reno registered
[ 3.904876] UDP hash table entries: 256 (order: 0, 4096 bytes)
[ 3.910768] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[ 3.917634] NET: Registered protocol family 1
[ 3.922993] RPC: Registered named UNIX socket transport module.
[ 3.929176] RPC: Registered udp transport module.
[ 3.933953] RPC: Registered tcp transport module.
[ 3.938682] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 3.945522] bcm2708_dma: DMA manager at cc808000
[ 3.950285] bcm2708_gpio: bcm2708_gpio_probe c05d00e0
[ 3.955957] vc-mem: Videocore memory driver
[ 3.961064] audit: initializing netlink socket (disabled)
[ 3.966627] type=2000 audit(0.780:1): initialized
[ 4.079322] VFS: Disk quotas dquot_6.5.2
[ 4.083531] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 4.091557] FS-Cache: Netfs 'nfs' registered for caching
[ 4.098272] msgmni has been set to 366
[ 4.104817] io scheduler noop registered
[ 4.108795] io scheduler deadline registered (default)
[ 4.114340] io scheduler cfq registered
[ 4.118491] BCM2708FB: registering framebuffer (1824x984@16)
[ 4.125113] bcm2708_fb_set_par info(cb8ec400) 1824x984 (1824x984), 0, 16
[ 4.135143] BCM2708FB: start = ccc00000,4d385000 width=1824, height=984, bpp=16, pitch=3648 size=3618816 success=0
[ 4.161612] Console: switching to colour frame buffer device 228x61
[ 4.209870] BCM2708FB: register framebuffer (0)
[ 4.215424] kgdb: Registered I/O driver kgdboc.
[ 4.232544] brd: module loaded
[ 4.242262] loop: module loaded
[ 4.246622] vcos: [1]: vchiq_init_state: slot_zero = 0xffd80000, is_master = 0
[ 4.254393] vcos: [1]: vchiq_init_state: called
[ 4.259907] vcos: [1]: vchiq: initialised - version 2 (min 2), device 253.0
[ 4.267994] usbcore: registered new interface driver smsc95xx
[ 4.274050] cdc_ncm: 04-Aug-2011
[ 4.277523] usbcore: registered new interface driver cdc_ncm
[ 4.283347] dwc_otg: version 2.90b 6-MAY-2010 (platform bus)
[ 4.289616] Core Release: 2.80a
[ 4.292894] Setting default values for core params
[ 4.297967] Finished setting default values for core params
[ 4.304078] cc840008 -> 1
[ 4.506841] Using Buffer DMA mode
[ 4.510281] Periodic Transfer Interrupt Enhancement - disabled
[ 4.516316] Multiprocessor Interrupt Enhancement - disabled
[ 4.522140] dwc_otg bcm2708_usb: DWC OTG Controller
[ 4.527388] dwc_otg bcm2708_usb: new USB bus registered, assigned bus number 1
[ 4.534957] dwc_otg bcm2708_usb: irq 75, io mem 0x00000000
[ 4.540648] Init: Port Power? op_state=1
[ 4.544746] Init: Power Port (0)
[ 4.548237] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 4.562002] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 4.576268] usb usb1: Product: DWC OTG Controller
[ 4.588088] usb usb1: Manufacturer: Linux 3.1.9+ dwc_otg_hcd
[ 4.600932] usb usb1: SerialNumber: bcm2708_usb
[ 4.613627] hub 1-0:1.0: USB hub found
[ 4.624413] hub 1-0:1.0: 1 port detected
[ 4.636071] Module dwc_common_port init
[ 4.636471] usbcore: registered new interface driver uas
[ 4.648838] Initializing USB Mass Storage driver...
[ 4.660864] usbcore: registered new interface driver usb-storage
[ 4.673802] USB Mass Storage support registered.
[ 4.685658] usbcore: registered new interface driver libusual
[ 4.698891] mousedev: PS/2 mouse device common for all mice
[ 4.711400] cpuidle: using governor ladder
[ 4.722403] cpuidle: using governor menu
[ 4.733632] sdhci: Secure Digital Host Controller Interface driver
[ 4.746904] sdhci: Copyright(c) Pierre Ossman
[ 4.758374] bcm_power_open() -> 1
[ 4.769006] Registered led device: mmc0::
[ 4.769504] mmc0: SDHCI controller on BCM2708_Arasan [platform] using platform's DMA
[ 4.784613] mmc0: BCM2708 SDHC host at 0x20300000 DMA 2 IRQ 77
[ 4.797629] sdhci-pltfm: SDHCI platform and OF driver helper
[ 4.811715] Registered led device: led0
[ 4.812220] usbcore: registered new interface driver usbhid
[ 4.824929] usbhid: USB HID core driver
[ 4.861116] TCP cubic registered
[ 4.893827] Initializing XFRM netlink socket
[ 4.913872] NET: Registered protocol family 17
[ 4.937021] Registering the dns_resolver key type
[ 4.949098] mmc0: new high speed SDHC card at address 0002
[ 4.974675] VFP support v0.3: implementor 41 architecture 1 part 20 variant b rev 5
[ 4.989659] mmcblk0: mmc0:0002 00000 3.70 GiB
[ 5.006021] mmcblk0: p1 p2
[ 5.039143] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[ 5.054636] VFS: Mounted root (ext4 filesystem) on device 179:2.
[ 5.069150] Freeing init memory: 200K
[ 5.113933] usb 1-1: new high speed USB device number 2 using dwc_otg
[ 5.344487] usb 1-1: New USB device found, idVendor=0424, idProduct=9512
[ 5.358373] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 5.375785] hub 1-1:1.0: USB hub found
[ 5.387042] hub 1-1:1.0: 3 ports detected
[ 5.674135] usb 1-1.1: new high speed USB device number 3 using dwc_otg
[ 5.804483] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00
[ 5.831047] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 5.854411] smsc95xx v1.0.4
[ 5.939795] smsc95xx 1-1.1:1.0: eth0: register 'smsc95xx' at usb-bcm2708_usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:3a:b4:10
[ 6.044238] usb 1-1.2: new high speed USB device number 4 using dwc_otg
[ 6.165619] usb 1-1.2: New USB device found, idVendor=0781, idProduct=5202
[ 6.185213] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 6.200145] usb 1-1.2: Product: Relay UFD
[ 6.211673] usb 1-1.2: Manufacturer: Staples
[ 6.224719] usb 1-1.2: SerialNumber: 2005284532118E71708C
[ 6.249780] scsi0 : usb-storage 1-1.2:1.0
[ 6.354248] usb 1-1.3: new low speed USB device number 5 using dwc_otg
[ 6.490764] usb 1-1.3: New USB device found, idVendor=413c, idProduct=2112
[ 6.524065] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 6.554009] usb 1-1.3: Product: Dell USB Wired Multimedia Keyboard
[ 6.583946] usb 1-1.3: Manufacturer: DELL
[ 6.609835] input: DELL Dell USB Wired Multimedia Keyboard as /devices/platform/bcm2708_usb/usb1/1-1/1-1.3/1-1.3:1.0/input/input0
[ 6.654106] generic-usb 0003:413C:2112.0001: input: USB HID v1.10 Keyboard [DELL Dell USB Wired Multimedia Keyboard] on usb-bcm2708_usb-1.3/input0
[ 6.714396] input: DELL Dell USB Wired Multimedia Keyboard as /devices/platform/bcm2708_usb/usb1/1-1/1-1.3/1-1.3:1.1/input/input1
[ 6.754073] generic-usb 0003:413C:2112.0002: input: USB HID v1.10 Device [DELL Dell USB Wired Multimedia Keyboard] on usb-bcm2708_usb-1.3/input1
[ 7.265612] scsi 0:0:0:0: Direct-Access Staples Relay UFD 1.20 PQ: 0 ANSI: 5
[ 7.310090] sd 0:0:0:0: [sda] 31266816 512-byte logical blocks: (16.0 GB/14.9 GiB)
[ 7.361828] sd 0:0:0:0: [sda] Write Protect is off
[ 7.392166] sd 0:0:0:0: [sda] Mode Sense: 43 00 00 00
[ 7.394009] sd 0:0:0:0: [sda] Write cache: disabled, read cache: enabled, doesn't support DPO or FUA
[ 7.459399] sda: sda1
[ 7.495843] sd 0:0:0:0: [sda] Attached SCSI removable disk
[ 14.493444] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[ 14.878367] ### snd_bcm2835_alsa_probe c05d07a0 ############### PROBING FOR bcm2835 ALSA device (0):(1) ###############
[ 14.898079] Creating card...
[ 14.909849] Creating device/chip ..
[ 14.922932] Adding controls ..
[ 14.935081] Registering card ....
[ 14.953202] bcm2835 ALSA CARD CREATED!
[ 14.981491] ### BCM2835 ALSA driver init OK ###
[ 22.350460] smsc95xx 1-1.1:1.0: eth0: link up, 100Mbps, full-duplex, lpa 0x45E1
[ 27.194860] Adding 102396k swap on /var/swap. Priority:-1 extents:1 across:102396k SS
[ 140.347285] FAT-fs (sda1): invalid media value (0x6c)
[ 140.347316] FAT-fs (sda1): Can't find a valid FAT filesystem
Re: no /dev/sdxx
Posted: Sat Nov 24, 2012 10:23 pm
by ryql
This is my dmesg using the external usb hard drives. The previous dmesg was using the flash drive.
[ 2.814244] Calibrating delay loop... 697.95 BogoMIPS (lpj=3489792)
[ 2.873198] pid_max: default: 32768 minimum: 301
[ 2.873831] Mount-cache hash table entries: 512
[ 2.874495] Initializing cgroup subsys cpuacct
[ 2.874612] Initializing cgroup subsys devices
[ 2.874664] Initializing cgroup subsys freezer
[ 2.874706] Initializing cgroup subsys blkio
[ 2.874825] CPU: Testing write buffer coherency: ok
[ 2.874961] ftrace: allocating 14801 entries in 44 pages
[ 2.947993] hw perfevents: enabled with v6 PMU driver, 3 counters available
[ 2.949985] devtmpfs: initialized
[ 2.957765] NET: Registered protocol family 16
[ 2.959702] vc-mem: mm_vc_mem_phys_addr = 0x00000000
[ 2.959770] vc-mem: mm_vc_mem_size = 0x10000000 (256 MiB)
[ 2.960293] hw-breakpoint: found 6 breakpoint and 1 watchpoint registers.
[ 2.960367] hw-breakpoint: maximum watchpoint size is 4 bytes.
[ 2.960416] mailbox: Broadcom VideoCore Mailbox driver
[ 2.960528] bcm2708_vcio: mailbox at f200b880
[ 2.960637] bcm_power: Broadcom power driver
[ 2.960685] bcm_power_open() -> 0
[ 2.960718] bcm_power_request(0, 8)
[ 3.461413] bcm_mailbox_read -> 00000080, 0
[ 3.461461] bcm_power_request -> 0
[ 3.461494] Serial: AMBA PL011 UART driver
[ 3.461687] dev:f1: ttyAMA0 at MMIO 0x20201000 (irq = 83) is a PL011 rev3
[ 3.767489] console [ttyAMA0] enabled
[ 3.793305] bio: create slab <bio-0> at 0
[ 3.798884] SCSI subsystem initialized
[ 3.802932] usbcore: registered new interface driver usbfs
[ 3.808730] usbcore: registered new interface driver hub
[ 3.814363] usbcore: registered new device driver usb
[ 3.820531] Switching to clocksource stc
[ 3.829577] Switched to NOHz mode on CPU #0
[ 3.843292] FS-Cache: Loaded
[ 3.846688] CacheFiles: Loaded
[ 3.868281] NET: Registered protocol family 2
[ 3.873240] IP route cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 3.881817] TCP established hash table entries: 8192 (order: 4, 65536 bytes)
[ 3.889348] TCP bind hash table entries: 8192 (order: 3, 32768 bytes)
[ 3.896058] TCP: Hash tables configured (established 8192 bind 8192)
[ 3.902442] TCP reno registered
[ 3.905657] UDP hash table entries: 256 (order: 0, 4096 bytes)
[ 3.911549] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[ 3.918417] NET: Registered protocol family 1
[ 3.923784] RPC: Registered named UNIX socket transport module.
[ 3.929968] RPC: Registered udp transport module.
[ 3.934745] RPC: Registered tcp transport module.
[ 3.939474] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 3.946318] bcm2708_dma: DMA manager at cc808000
[ 3.951083] bcm2708_gpio: bcm2708_gpio_probe c05d00e0
[ 3.956757] vc-mem: Videocore memory driver
[ 3.961868] audit: initializing netlink socket (disabled)
[ 3.967432] type=2000 audit(0.780:1): initialized
[ 4.080129] VFS: Disk quotas dquot_6.5.2
[ 4.084339] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 4.092365] FS-Cache: Netfs 'nfs' registered for caching
[ 4.099073] msgmni has been set to 366
[ 4.105617] io scheduler noop registered
[ 4.109595] io scheduler deadline registered (default)
[ 4.115141] io scheduler cfq registered
[ 4.119292] BCM2708FB: registering framebuffer (1824x984@16)
[ 4.125911] bcm2708_fb_set_par info(cb8ec400) 1824x984 (1824x984), 0, 16
[ 4.135956] BCM2708FB: start = ccc00000,4d385000 width=1824, height=984, bpp=16, pitch=3648 size=3618816 success=0
[ 4.162419] Console: switching to colour frame buffer device 228x61
[ 4.210682] BCM2708FB: register framebuffer (0)
[ 4.216228] kgdb: Registered I/O driver kgdboc.
[ 4.233382] brd: module loaded
[ 4.243132] loop: module loaded
[ 4.247489] vcos: [1]: vchiq_init_state: slot_zero = 0xffd80000, is_master = 0
[ 4.255269] vcos: [1]: vchiq_init_state: called
[ 4.260787] vcos: [1]: vchiq: initialised - version 2 (min 2), device 253.0
[ 4.268862] usbcore: registered new interface driver smsc95xx
[ 4.274916] cdc_ncm: 04-Aug-2011
[ 4.278392] usbcore: registered new interface driver cdc_ncm
[ 4.284217] dwc_otg: version 2.90b 6-MAY-2010 (platform bus)
[ 4.290492] Core Release: 2.80a
[ 4.293767] Setting default values for core params
[ 4.298842] Finished setting default values for core params
[ 4.304941] cc840008 -> 1
[ 4.507690] Using Buffer DMA mode
[ 4.511129] Periodic Transfer Interrupt Enhancement - disabled
[ 4.517159] Multiprocessor Interrupt Enhancement - disabled
[ 4.522980] dwc_otg bcm2708_usb: DWC OTG Controller
[ 4.528234] dwc_otg bcm2708_usb: new USB bus registered, assigned bus number 1
[ 4.535803] dwc_otg bcm2708_usb: irq 75, io mem 0x00000000
[ 4.541494] Init: Port Power? op_state=1
[ 4.545591] Init: Power Port (0)
[ 4.549079] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 4.562872] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 4.577132] usb usb1: Product: DWC OTG Controller
[ 4.588964] usb usb1: Manufacturer: Linux 3.1.9+ dwc_otg_hcd
[ 4.601832] usb usb1: SerialNumber: bcm2708_usb
[ 4.614689] hub 1-0:1.0: USB hub found
[ 4.625414] hub 1-0:1.0: 1 port detected
[ 4.637065] Module dwc_common_port init
[ 4.637469] usbcore: registered new interface driver uas
[ 4.649862] Initializing USB Mass Storage driver...
[ 4.661888] usbcore: registered new interface driver usb-storage
[ 4.674821] USB Mass Storage support registered.
[ 4.686681] usbcore: registered new interface driver libusual
[ 4.699917] mousedev: PS/2 mouse device common for all mice
[ 4.712425] cpuidle: using governor ladder
[ 4.723432] cpuidle: using governor menu
[ 4.734800] sdhci: Secure Digital Host Controller Interface driver
[ 4.747926] sdhci: Copyright(c) Pierre Ossman
[ 4.759355] bcm_power_open() -> 1
[ 4.769974] Registered led device: mmc0::
[ 4.770474] mmc0: SDHCI controller on BCM2708_Arasan [platform] using platform's DMA
[ 4.785587] mmc0: BCM2708 SDHC host at 0x20300000 DMA 2 IRQ 77
[ 4.798611] sdhci-pltfm: SDHCI platform and OF driver helper
[ 4.812721] Registered led device: led0
[ 4.813225] usbcore: registered new interface driver usbhid
[ 4.825928] usbhid: USB HID core driver
[ 4.856269] TCP cubic registered
[ 4.876407] Initializing XFRM netlink socket
[ 4.895307] NET: Registered protocol family 17
[ 4.920932] mmc0: problem reading SD Status register.
[ 4.933316] Registering the dns_resolver key type
[ 4.956801] VFP support v0.3: implementor 41 architecture 1 part 20 variant b rev 5
[ 4.974107] mmc0: new high speed SDHC card at address 0002
[ 5.005822] mmcblk0: mmc0:0002 00000 3.70 GiB
[ 5.022893] mmcblk0: p1 p2
[ 5.055031] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[ 5.070376] VFS: Mounted root (ext4 filesystem) on device 179:2.
[ 5.085137] Freeing init memory: 200K
[ 5.134704] usb 1-1: new high speed USB device number 2 using dwc_otg
[ 5.365264] usb 1-1: New USB device found, idVendor=0424, idProduct=9512
[ 5.382864] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 5.400858] hub 1-1:1.0: USB hub found
[ 5.413677] hub 1-1:1.0: 3 ports detected
[ 5.705026] usb 1-1.1: new high speed USB device number 3 using dwc_otg
[ 5.835248] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00
[ 5.851817] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 5.872965] smsc95xx v1.0.4
[ 5.940817] smsc95xx 1-1.1:1.0: eth0: register 'smsc95xx' at usb-bcm2708_usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:3a:b4:10
[ 6.064900] usb 1-1.2: new low speed USB device number 4 using dwc_otg
[ 6.201460] usb 1-1.2: New USB device found, idVendor=046d, idProduct=c063
[ 6.234723] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 6.264725] usb 1-1.2: Product: DELL USB Laser Mouse
[ 6.284740] usb 1-1.2: Manufacturer: DELL
[ 6.324181] input: DELL DELL USB Laser Mouse as /devices/platform/bcm2708_usb/usb1/1-1/1-1.2/1-1.2:1.0/input/input0
[ 6.365254] generic-usb 0003:046D:C063.0001: input: USB HID v1.10 Mouse [DELL DELL USB Laser Mouse] on usb-bcm2708_usb-1.2/input0
[ 6.485015] usb 1-1.3: new low speed USB device number 5 using dwc_otg
[ 6.621410] usb 1-1.3: New USB device found, idVendor=413c, idProduct=2112
[ 6.653634] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 6.684722] usb 1-1.3: Product: Dell USB Wired Multimedia Keyboard
[ 6.713044] usb 1-1.3: Manufacturer: DELL
[ 6.743096] input: DELL Dell USB Wired Multimedia Keyboard as /devices/platform/bcm2708_usb/usb1/1-1/1-1.3/1-1.3:1.0/input/input1
[ 6.784845] generic-usb 0003:413C:2112.0002: input: USB HID v1.10 Keyboard [DELL Dell USB Wired Multimedia Keyboard] on usb-bcm2708_usb-1.3/input0
[ 6.834810] input: DELL Dell USB Wired Multimedia Keyboard as /devices/platform/bcm2708_usb/usb1/1-1/1-1.3/1-1.3:1.1/input/input2
[ 6.868073] generic-usb 0003:413C:2112.0003: input: USB HID v1.10 Device [DELL Dell USB Wired Multimedia Keyboard] on usb-bcm2708_usb-1.3/input1
[ 14.422748] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[ 14.822088] ### snd_bcm2835_alsa_probe c05d07a0 ############### PROBING FOR bcm2835 ALSA device (0):(1) ###############
[ 14.842138] Creating card...
[ 14.854175] Creating device/chip ..
[ 14.867327] Adding controls ..
[ 14.879185] Registering card ....
[ 14.896431] bcm2835 ALSA CARD CREATED!
[ 14.925807] ### BCM2835 ALSA driver init OK ###
[ 21.883462] smsc95xx 1-1.1:1.0: eth0: link up, 100Mbps, full-duplex, lpa 0x45E1
[ 27.093292] Adding 102396k swap on /var/swap. Priority:-1 extents:1 across:102396k SS
Re: no /dev/sdxx
Posted: Sat Nov 24, 2012 10:27 pm
by JeremyF
sda1 is in fact detected...
But clearly the filesystem is corrupted or not actually FAT
Re: no /dev/sdxx
Posted: Sat Nov 24, 2012 11:22 pm
by ryql
Well, I still can't mount the drives but they are now showing up in /dev sda1 and sdb1 and sda and sdb.
I do have a workaround though. If I run the graphical interface, it detects the hard drives when I run file manager. From then on , until I reboot, I can access the drives. I installed an ftp program, so now I have a NAS through ftp. Not exactly what I had in mind but it works. I will try and fix it properly later.
Thank you very much for your help.
PS the sda1 you pointed out was from the flash drive and the flash drive is now unreadable in windows.
I have lots of flash drives so I should be ok. Thanks again. Rick
Re: no /dev/sdxx
Posted: Sat Nov 24, 2012 11:49 pm
by drgeoff
You seem to have keyboard, mouse and USB hard drive connected simultaneously, so I assume you also have a USB hub that you haven't mentioned before. Please explain exactly how all those are wired up and full details of how the RPi and the hub are powered..
Try booting without the hard drive's USB cable plugged in. After the RPi has fully booted, issue the dmesg command and note the last line. Then plug in the drive's USB cable and issue the dmesg command again. Post here the new lines that appear.
Re: no /dev/sdxx
Posted: Sun Nov 25, 2012 7:45 pm
by ryql
I do not have a usb hub installed.
IU unplugged my mouse and plugged in the hard drives.
I navigated the GUI using the keyboard.
Anyway, the problem is solved.
I used a different SD card and redid everything and it is now working about 80 percent.
I can read the drives as root but not as a regular user.
When I try to change permissions for the mount directories disk1 and disk 2
I get a message saying read only file system and the permissions do not change.
I am doing some reading.
Re: no /dev/sdxx
Posted: Sun Nov 25, 2012 8:09 pm
by aaa801
What fs are you using on the hdd's
Re: no /dev/sdxx
Posted: Sun Nov 25, 2012 10:20 pm
by ryql
I had previously formatted them NTFS but they are both blank so it doesn't matter what fs I use.
If you want me to change the fs you'll have to walk me through unless I can use fdisk.
Any help or ideas on the permissions thing? Rick
Re: no /dev/sdxx
Posted: Sun Nov 25, 2012 10:47 pm
by aaa801
Soo you just tryed to mount a ntfs drive as fat and wondered why you got bad superblock?
Mount them as ntfs.3g
Re: no /dev/sdxx
Posted: Mon Nov 26, 2012 4:41 am
by ryql
I know this is a long thread but I can now mount both hard drives. I can see them on my windows pc.
I can read them. I cannot write to them. When I try to change the permissions on the raspberry pi, using chmod, I get a message that says READONLY FILE SYSTEM!
How do I write to the drives.
I also installed ProFtp and can only log on the Pi using the user pi
I created another user called rick and gave root permissions but I cannot even log on.
Once this permissions problem is solved, I will be happy.
Rather than mock me, I could use some real help.
Re: no /dev/sdxx
Posted: Mon Nov 26, 2012 6:29 am
by itimpi
If they are formatted as NTFS, then you have to make sure you mount them as ntfs-3g if you want to be able to write to them. The simple 'ntfs' driver (without the -3g added) only supports read access.
Re: no /dev/sdxx
Posted: Mon Nov 26, 2012 8:12 am
by ryql
So I have to mount them using the command:
mount -t -ntfs-3g /dev/sda1 /mnt/disk1
Is this correct?
Re: no /dev/sdxx
Posted: Mon Nov 26, 2012 9:01 am
by RaTTuS
ryql wrote:So I have to mount them using the command:
Is this correct?
yes if you have NTFS formatted drives
Re: no /dev/sdxx
Posted: Mon Nov 26, 2012 2:09 pm
by ryql
when I try to mount the drives using ntfs-3g I get a message that says the file type does not exist.
