Gess1t
[Fixed] Raspberry pi won't boot with higher resolution than 480p because of OpenGL
Sun Mar 17, 2019 8:18 pm
as i said, no way to boot with higher resolution. i can't access my desktop or shh anymore, HDMI also not working, well, the whole pi isn't working.
And because logs aren't stored in the Fat32 partition, i can't check what's the problem.
Few days before that, my raspberry was crashing non-stop had to reboot it manually.
trying to check the filesys right now
HawaiianPi
Re: Raspberry pi won't boot with higher resolution than 480p
Sun Mar 17, 2019 9:01 pm
It sounds like the OS on your SD card has become corrupt (powering down without a proper shutdown would only make that worse).
Start over with a new install of the latest Raspbian, and if that doesn't work, your SD card may have gone bad.
Also, which model Pi, and what are you using for a power supply?
Gess1t
Sun Mar 17, 2019 9:14 pm
Raspberry pi 3B+ OC at 1.55 GHz on CPU, 500 Mhz on GPU & memory.
128 MB GPU split cause i have full KMS driver enabled.
was on raspbian lite before the problem, just flashed a new raspbian img with desktop (the lastest one).
i couldn't use my raspberry without shutting it down manually.
now, i'm re-downloading everythings, ssh over the internet too, in case i can't setup VNC in time.
EDIT : Apparently, OpenGL stoped crashing my pi after i reflashed it, so it wasn't an hardware issue.
