Regular update results in an unrecoverable crash in system... today.
The following packages will be upgraded:
libopenjp2-7 raspi-copies-and-fills
2 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
Need to get 117 kB of archives.
After this operation, 6,144 B of additional disk space will be used.
Do you want to continue? [Y/n] y
Get:1 http://archive.raspberrypi.org/debian stretch/main armhf raspi-copies-and-fills armhf 0.8 [8,520 B]
Get:2 http://mirrors.pidginhost.com/raspbian/raspbian stretch/main armhf libopenjp2-7 armhf 2.1.2-1.1+deb9u3 [108 kB]
Fetched 117 kB in 11s (10.5 kB/s)
Reading changelogs... Done
(Reading database ... 158545 files and directories currently installed.)
Preparing to unpack .../libopenjp2-7_2.1.2-1.1+deb9u3_armhf.deb ...
Unpacking libopenjp2-7:armhf (2.1.2-1.1+deb9u3) over (2.1.2-1.1+deb9u2) ...
Preparing to unpack .../raspi-copies-and-fills_0.8_armhf.deb ...
Unpacking raspi-copies-and-fills (0.8) over (0.6) ...
Setting up libopenjp2-7:armhf (2.1.2-1.1+deb9u3) ...
Setting up raspi-copies-and-fills (0.8) ...
Processing triggers for libc-bin (2.24-11+deb9u4) ...
dpkg: error processing package libc-bin (--configure):
subprocess installed post-installation script was killed by signal (Segmentation fault)
dpkg: error: error executing hook 'if { test "$DPKG_HOOK_ACTION" = add-architecture || test "$DPKG_HOOK_ACTION" = remove-architecture; } && test -x /usr/share/pkg-config-dpkghook; then /usr/share/pkg-config-dpkghook update; fi', exit code 11
Usage:
glib20.mo [OPTION…]
sh: 1: 34:ln=01: not found
sh: 1: 36:mh=00:pi=40: not found
sh: 1: 33:so=01: not found
sh: 1: 35:do=01: not found
sh: 1: 35:bd=40: not found
sh: 1: 33: not found
sh: 1: 01:cd=40: not found
sh: 1: 01:or=40: not found
sh: 1: 31: not found
sh: 1: 01:mi=00:su=37: not found
sh: 1: 41:sg=30: not found
sh: 1: 43:ca=30: not found
sh: 1: 41:tw=30: not found
sh: 1: 42:ow=34: not found
sh: 1: 42:st=37: not found
sh: 1: 44:ex=01: not found
sh: 1: 32:*.tar=01: not found
sh: 1: 31:*.tgz=01: not found
sh: 1: 31:*.arc=01: not found
sh: 1: 31:*.arj=01: not found
sh: 1: 31:*.taz=01: not found
sh: 1: 31:*.lha=01: not found
sh: 1: 31:*.lz4=01: not found
sh: 1: 31:*.lzh=01: not found
sh: 1: 31:*.lzma=01: not found
sh: 1: 31:*.tlz=01: not found
sh: 1: 31:*.txz=01: not found
sh: 1: 31:*.tzo=01: not found
sh: 1: 31:*.t7z=01: not found
sh: 1: 31:*.zip=01: not found
sh: 1: 31:*.z=01: not found
sh: 1: 31:*.Z=01: not found
sh: 1: 31:*.dz=01: not found
sh: 1: 31:*.gz=01: not found
sh: 1: 31:*.lrz=01: not found
sh: 1: 31:*.lz=01: not found
sh: 1: 31:*.lzo=01: not found
sh: 1: 31:*.xz=01: not found
sh: 1: 31:*.zst=01: not found
sh: 1: 31:*.tzst=01: not found
sh: 1: 31:*.bz2=01: not found
sh: 1: 31:*.bz=01: not found
sh: 1: 31:*.tbz=01: not found
sh: 1: 31:*.tbz2=01: not found
sh: 1: 31:*.tz=01: not found
sh: 1: 31:*.deb=01: not found
sh: 1: 31:*.rpm=01: not found
sh: 1: 31:*.jar=01: not found
sh: 1: 31:*.war=01: not found
sh: 1: 31:*.ear=01: not found
sh: 1: 31:*.sar=01: not found
sh: 1: 31:*.rar=01: not found
sh: 1: 31:*.alz=01: not found
sh: 1: 31:*.ace=01: not found
sh: 1: 31:*.zoo=01: not found
sh: 1: 31:*.cpio=01: not found
sh: 1: 31:*.7z=01: not found
sh: 1: 31:*.rz=01: not found
sh: 1: 31:*.cab=01: not found
sh: 1: 31:*.jpg=01: not found
sh: 1: 35:*.jpeg=01: not found
sh: 1: 35:*.mjpg=01: not found
sh: 1: 35:*.mjpeg=01: not found
sh: 1: 35:*.gif=01: not found
sh: 1: 35:*.bmp=01: not found
sh: 1: 35:*.pbm=01: not found
sh: 1: 35:*.pgm=01: not found
sh: 1: 35:*.ppm=01: not found
sh: 1: 35:*.tga=01: not found
sh: 1: 35:*.xbm=01: not found
sh: 1: 35:*.xpm=01: not found
sh: 1: 35:*.tif=01: not found
sh: 1: 35:*.tiff=01: not found
sh: 1: 35:*.png=01: not found
sh: 1: 35:*.svg=01: not found
sh: 1: 35:*.svgz=01: not found
sh: 1: 35:*.mng=01: not found
sh: 1: 35:*.pcx=01: not found
sh: 1: 35:*.mov=01: not found
sh: 1: 35:*.mpg=01: not found
sh: 1: 35:*.mpeg=01: not found
sh: 1: 35:*.m2v=01: not found
sh: 1: 35:*.mkv=01: not found
sh: 1: 35:*.webm=01: not found
sh: 1: 35:*.ogm=01: not found
sh: 1: 35:*.mp4=01: not found
sh: 1: 35:*.m4v=01: not found
sh: 1: 35:*.mp4v=01: not found
sh: 1: 35:*.vob=01: not found
sh: 1: 35:*.qt=01: not found
sh: 1: 35:*.nuv=01: not found
sh: 1: 35:*.wmv=01: not found
sh: 1: 35:*.asf=01: not found
sh: 1: 35:*.rm=01: not found
sh: 1: 35:*.rmvb=01: not found
sh: 1: 35:*.flc=01: not found
sh: 1: 35:*.avi=01: not found
sh: 1: 35:*.fli=01: not found
sh: 1: 35:*.flv=01: not found
sh: 1: 35:*.gl=01: not found
sh: 1: 35:*.dl=01: not found
sh: 1: 35:*.xcf=01: not found
sh: 1: 35:*.xwd=01: not found
sh: 1: 35:*.yuv=01: not found
sh: 1: 35:*.cgm=01: not found
sh: 1: 35:*.emf=01: not found
sh: 1: 35:*.ogv=01: not found
sh: 1: 35:*.ogx=01: not found
sh: 1: 35:*.aac=00: not found
sh: 1: 36:*.au=00: not found
sh: 1: 36:*.flac=00: not found
sh: 1: 36:*.m4a=00: not found
sh: 1: 36:*.mid=00: not found
sh: 1: 36:*.midi=00: not found
sh: 1: 36:*.mka=00: not found
sh: 1: 36:*.mp3=00: not found
sh: 1: 36:*.mpc=00: not found
sh: 1: 36:*.ogg=00: not found
sh: 1: 36:*.ra=00: not found
sh: 1: 36:*.wav=00: not found
sh: 1: 36:*.oga=00: not found
sh: 1: 36:*.opus=00: not found
sh: 1: 36:*.spx=00: not found
sh: 1: 36:*.xspf=00: not found
sh: 1: 36:: not found
E: Sub-process /usr/bin/dpkg returned an error code (2)
E: Problem executing scripts DPkg::Post-Invoke '/usr/bin/test -e /usr/share/dbus-1/system-services/org.freedesktop.PackageKit.service && /usr/bin/test -S /var/run/dbus/system_bus_socket && /usr/bin/gdbus call --system --dest org.freedesktop.PackageKit --object-path /org/freedesktop/PackageKit --timeout 4 --method org.freedesktop.PackageKit.StateHasChanged cache-update > /dev/null; /bin/echo > /dev/null'
E: Sub-process returned an error code
trying to reboot not working...
reboot
Failed to connect to bus: Invalid argument��vP��(��vH������vP����L`�v-=[
Tried the update in 2 machines failes both.
Hard reboot does not help... crash in booting sequence.
ANY IDEAS or HELP?
- Raspberry Pi Engineer & Forum Moderator
- Location: The unfashionable end of the western spiral arm of the Galaxy
Re: Ras3 crashes after update
Note to other users: DO NOT UPGRADE
I'm doing my best to have the update pulled ASAP.
If you can, take the card out and remove /etc/ld.so.preload . That should get you back into a working state.
Okay, the responsible package has been removed. That was a serious mistake on my behalf and I apologise. Really can't test things enough.
I hope not many others have been bitten by this.
i have no physical access to the machines, just remote access... any ideas?
Oh no, that's the worst case scenario.
If you can remove /etc/ld.so.preload, you may be able to recover it, but I had no luck trying that without taking the card out.
No luck...
If there is any ideas just post them... unfortunately machines are sitting thousands km away...
can i overwrite that file from vnc viewer somehow / transfer a working file or something like that?
or edit something else?
rm is one of the simplest things to run, so if that doesn't work, I don't think anything else will. Everything I tried resulted in corrupted memory and segfaults.
Try "LD_PRELOAD=/usr/lib/arm-linux-gnueabihf/libarmmem-v6l.so sudo rm /etc/ld.so.preload"
v6 version seems to be fine and LD_PRELOAD should take precedence over ld.so.preload, so maybe that will work.
- DougieLawson
- Location: A small cave in deepest darkest Basingstoke, UK
- Contact: Website Twitter
Wow! I'd just got to libarmmem.so being the problem when I found this thread. Only broke four out of eighteen raspberries.
I was also affected by this update, see viewtopic.php?f=28&t=235600&p=1440779.
But it still shows up on my other Raspis, is it safe to update now?
version 0.10 should be safe.
ok, all fine now.
Again, sorry about that.
- DougieLawson
No problem. You found the problem before I'd shot 16 out of 18 raspberries dead. The hardest fix was my weather station - it's out of doors and I had to dismantle the case to get the SDCard back into the slot.
The sudo rm /etc/ld.so.preload fix is easy enough.
The best thing was when I was fsck'ing one of the hard drives I found some archived SDCard images that I'd forgotten about but contain something I was looking for after my NAS had a catastrophic HD failure. "Clouds and silver linings."
raspi-copies-and-fills version 0.10 breaks the Subversion command line client with existing checkouts. I had to manually downgrade to 0.5-1 to get Subversion working again.
With 0.10 svn status --no-ignore generates a lot of this:
! S python/Make/modularity/GPIO.py
! S python/Make/modularity/MeArm.py
! S python/Make/modularity/ZeroMQ.odt
! S python/Make/modularity/ZeroMQ.pdf
! S python/Make/modularity/bar
! S python/Make/modularity/cgi-bin
! S python/Make/modularity/client1.py
! S python/Make/modularity/client2.py
! S python/Make/modularity/client3.py
! S python/Make/modularity/client_lights.py
! S python/Make/modularity/foo
! S python/Make/modularity/server1.py
! S python/Make/modularity/server2.py
! S python/Make/modularity/server3.py
! S python/Make/modularity/server_lights.py
! S python/Make/modularity/test1.py
! S python/Make/modularity/test2.py
! S python/Make/modularity/test_robot.py
! S python/Make/modularity/webserver
! S python/Make/modularity/webserver.odt
! S python/Make/modularity/webserver.pdf
! S python/Make/modularity/zmq
Having trouble reproducing this one. I checked out a random repo and ran the command you gave.pmunts wrote: ↑Wed Mar 13, 2019 8:38 amraspi-copies-and-fills version 0.10 breaks the Subversion command line client with existing checkouts. I had to manually downgrade to 0.5-1 to get Subversion working again.
If you go to 0.10 and comment out the line in /etc/ld.so.preload, does the problem go away? Do you have reliable steps to reproduce the issue?
Removing /etc/ld.so.preload cured my problem with subversionShiftPlusOne wrote: ↑Wed Mar 13, 2019 4:46 pmHaving trouble reproducing this one. I checked out a random repo and ran the command you gave.
-- Raymond
Version 0.10 also seems to break some Plex functionality.
Worked for me but I imagine there are quite a lot confused users out there who don't know about this. You might want to look into it.
Kodi devs are also reporting issues. We'll roll back. Thanks, everyone.
Hello, what exactly does this command do? I am new to Linux in general and while it fixed the problem with my Plex server, after running this command the /var/lib/plexmediaserver folder seems to have gone missing.deathkid535 wrote: ↑Wed Mar 13, 2019 11:31 pmVersion 0.10 also seems to break some Plex functionality.
Worked for me but I imagine there are quite a lot confused users out there who don't know about this. You might want to look into it.Code: Select all
I would like to add that raspi-copies-and-fills seems to also "break" Chromium in a weird way.
If i type an url into chromium and hit enter i almost always get directed to the default search engine which shows me the results for that url. This is not the case if i don't update to the latest raspi-copies-and-fills. And this update is still available today. So i would recommend to stay away from that specific package (i put it on hold via sudo apt-mark hold raspi-copies-and-fills on all my raspis).
What a mess
0.11 is out, rolling everything back to as it was in 0.6.
- davidcoton
- Contact: Website
You can take pride in this...ShiftPlusOne wrote: ↑Thu Mar 14, 2019 8:20 pmWhat a mess![]()
When your stuff breaks, it does it big time.
That's true. If nobody has to travel thousands of kilometres to fix it, why even bother.davidcoton wrote: ↑Thu Mar 14, 2019 8:58 pmYou can take pride in this...ShiftPlusOne wrote: ↑Thu Mar 14, 2019 8:20 pmWhat a mess![]()
When your stuff breaks, it does it big time.![]()
