lingon
Re: USB redux
Mon Dec 09, 2013 5:33 am
gsh wrote:Does the problem still occur if you remove the external hub?
I disconnected the hub and now the uptime has been almost nine days without the USB/ethernet disconnection problem occuring. So yes it looks like that the problem is related to the hub.
Is this a known problem?
Is there some workaround for this problem?
Re: USB redux
Mon Dec 09, 2013 7:40 am
If you already have the latest firmware (which has a lot of USB fixes), then probably buying a a decent hub?
thradtke
Re: USB redux
Mon Dec 09, 2013 9:33 am
jamesh wrote:If you already have the latest firmware (which has a lot of USB fixes), then probably buying a a decent hub?
Would you mind recommending one or two that comply to the current USB driver?
Rocket Scientist.
gsh
Re: USB redux
Mon Dec 09, 2013 9:36 am
It's quite possible that the problem is you've got a hub with a single transaction translator (this is the thing that converts USB2 to USB 1 for things like keyboard and mouse's etc.
You can check by doing lsusb -v to output the information and look for the hub descriptor (there will be at least three hubs, the first is the root hub, then the 9512 hub then your external one. The 9512 should have TT PER PORT and SINGLE TT interfaces...)
Gordon Hollingworth PhD
Raspberry Pi - Director of Software Engineering
Re: USB redux
Mon Dec 09, 2013 9:39 am
All the ones I've tried have just worked, but they are just cheapo ones. Most should indeed just work.
scrishton
Re: USB redux
Mon Dec 09, 2013 9:42 am
Yes please, let us all know what hub will work. I have bought and tried quite a few and none of them work entirely correctly. Even the ones CPC / Farnell sell in their Raspberry Pi sections. The Pimoroni one looks interesting, but I'm not sure it will fit in the space I have available.
Simon R.
Re: USB redux
Mon Dec 09, 2013 9:47 am
Simon R.
As above, I don't know since all the ones I have tried have worked fine. But then I only use them for attaching USB HD's and keyboards, so nothing unusual.
dom
Re: USB redux
Mon Dec 09, 2013 1:07 pm
thradtke wrote:Would you mind recommending one or two that comply to the current USB driver?
http://www.raspberrypi.org/archives/4803
scrishton
Re: USB redux
Mon Dec 09, 2013 1:16 pm
But it's only four port. How about a seven port hub?
Re: USB redux
Mon Dec 09, 2013 1:58 pm
Google.
MaxK1
Re: USB redux
Mon Dec 09, 2013 2:32 pm
Adafruit sells a 7 port (powered) USB hub that isn't a 3+4 that _seems_ to work well (Manhattan) Microcenter also has it. But I can't throw every combination of USB devices at it and state that it "absolutely just works" for everything that has a USB 2.0 sticker on it. And since it only has a 5V/2A supply, you can't expect it to power anything/everything you throw at it.
You are in a maze of twisty little passages, all alike.
When General Failure and Major Disaster get together, Private Parts usually suffers.
gsh
Re: USB redux
Mon Dec 09, 2013 2:46 pm
That sounds like the right sort of product, the 3+4 ones are a bit of a cheap out, although they should work as long as they have TT per port
Gordon
thradtke
Re: USB redux
scrishton wrote:But it's only four port. How about a seven port hub?
Searching for "Multi-TT" hubs results in e.g. http://www.ayagroup.com/product.php?productid=16951
Hope that's a good one. Gordon?
Rocket Scientist.
lingon
Re: USB redux
Wed Dec 11, 2013 7:55 pm
gsh wrote:It's quite possible that the problem is you've got a hub with a single transaction translator (this is the thing that converts USB2 to USB 1 for things like keyboard and mouse's etc.
The seven port USB hub that I use consists of two 4 port hubs connected together:
Bus 001 Device 006: ID 05e3:0608 Genesys Logic, Inc. USB-2.0 4-Port HUB
bDeviceProtocol 1 Single TT
Bus 001 Device 007: ID 05e3:0608 Genesys Logic, Inc. USB-2.0 4-Port HUB
So unfortunately each 4 port hub has a Single TT. Do you think that the mouse and keyboard would work better if they are connected to ports that are not on the same internal hub?
Why is it that if I have the mouse and keyboard on the hub on ports that are on the same internal hub that they work for a while, but sooner or later the USB and ethernet connections on the Raspberry Pi will crash?
Bus 001 Device 002: ID 0424:9512 Standard Microsystems Corp.
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               2.00
  bDeviceClass            9 Hub
  bDeviceSubClass         0 Unused
  bDeviceProtocol         2 TT per port
  bMaxPacketSize0        64
  idVendor           0x0424 Standard Microsystems Corp.
  idProduct          0x9512
  bcdDevice            2.00
  iManufacturer           0
  iProduct                0
  iSerial                 0
  bNumConfigurations      1
  Configuration Descriptor:
    bLength                 9
    bDescriptorType         2
    wTotalLength           41
    bNumInterfaces          1
    bConfigurationValue     1
    iConfiguration          0
    bmAttributes         0xe0
      Self Powered
      Remote Wakeup
    MaxPower                2mA
    Interface Descriptor:
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           1
      bInterfaceClass         9 Hub
      bInterfaceSubClass      0 Unused
      bInterfaceProtocol      1 Single TT
      iInterface              0
      Endpoint Descriptor:
        bLength                 7
        bDescriptorType         5
        bEndpointAddress     0x81  EP 1 IN
        bmAttributes            3
          Transfer Type            Interrupt
          Synch Type               None
          Usage Type               Data
        wMaxPacketSize     0x0001  1x 1 bytes
        bInterval              12
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       1
      bNumEndpoints           1
      bInterfaceProtocol      2 TT per port
      iInterface              0
        bLength                 7
        bDescriptorType         5
        bmAttributes            3
          Synch Type               None
          Usage Type               Data
        bInterval              12
Hub Descriptor:
  bLength               9
  bDescriptorType      41
  nNbrPorts             3
  wHubCharacteristic 0x000d
    Per-port power switching
    Compound device
    Per-port overcurrent protection
    TT think time 8 FS bits
  bPwrOn2PwrGood       50 * 2 milli seconds
  bHubContrCurrent      1 milli Ampere
  DeviceRemovable    0x02
  PortPwrCtrlMask    0xff
 Hub Port Status:
   Port 1: 0000.0503 highspeed power enable connect
   Port 2: 0000.0503 highspeed power enable connect
   Port 3: 0000.0303 lowspeed power enable connect
Device Qualifier (for other device speed):
  bLength                10
  bDescriptorType         6
  bcdUSB               2.00
  bDeviceClass            9 Hub
  bDeviceProtocol         0 Full speed (or root) hub
  bMaxPacketSize0        64
Device Status:     0x0001
  Self Powered
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               2.00
  bDeviceClass            9 Hub
  bMaxPacketSize0        64
  idVendor           0x1d6b Linux Foundation
  idProduct          0x0002 2.0 root hub
  bcdDevice            3.10
  iManufacturer           3 Linux 3.10.19+ dwc_otg_hcd
  iProduct                2 DWC OTG Controller
  iSerial                 1 bcm2708_usb
    bLength                 9
    bDescriptorType         2
    wTotalLength           25
    bNumInterfaces          1
    iConfiguration          0
    bmAttributes         0xe0
      Self Powered
      Remote Wakeup
    MaxPower                0mA
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           1
      bInterfaceProtocol      0 Full speed (or root) hub
      iInterface              0
        bLength                 7
        bDescriptorType         5
        bmAttributes            3
          Synch Type               None
          Usage Type               Data
        wMaxPacketSize     0x0004  1x 4 bytes
        bInterval              12
Hub Descriptor:
  bLength               9
  bDescriptorType      41
  nNbrPorts             1
  wHubCharacteristic 0x0008
    Ganged power switching
  bPwrOn2PwrGood        1 * 2 milli seconds
  bHubContrCurrent      0 milli Ampere
  DeviceRemovable    0x00
 Hub Port Status:
  Self Powered
Bus 001 Device 008: ID 046d:c016 Logitech, Inc. Optical Wheel Mouse
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               2.00
  bDeviceClass            0 (Defined at Interface level)
  bDeviceSubClass         0
  bDeviceProtocol         0
  bMaxPacketSize0         8
  idVendor           0x046d Logitech, Inc.
  idProduct          0xc016 Optical Wheel Mouse
  bcdDevice            3.40
  iManufacturer           1 Logitech
  iProduct                2 Optical USB Mouse
  iSerial                 0
    bLength                 9
    bDescriptorType         2
    wTotalLength           34
    bNumInterfaces          1
    iConfiguration          0
    bmAttributes         0xa0
      (Bus Powered)
      Remote Wakeup
    MaxPower              100mA
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           1
      bInterfaceClass         3 Human Interface Device
      bInterfaceSubClass      1 Boot Interface Subclass
      bInterfaceProtocol      2 Mouse
      iInterface              0
        HID Device Descriptor:
          bLength                 9
          bDescriptorType        33
          bcdHID               1.10
          bCountryCode            0 Not supported
          bNumDescriptors         1
          bDescriptorType        34 Report
          wDescriptorLength      52
         Report Descriptors:
           ** UNAVAILABLE **
        bLength                 7
        bDescriptorType         5
        bmAttributes            3
          Synch Type               None
          Usage Type               Data
        bInterval              10
Device Status:     0x0000
  (Bus Powered)
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               2.00
  bDeviceClass          255 Vendor Specific Class
  bDeviceSubClass         0
  bDeviceProtocol         1
  bMaxPacketSize0        64
  idProduct          0xec00
  bcdDevice            2.00
  iManufacturer           0
  iProduct                0
  iSerial                 0
    bLength                 9
    bDescriptorType         2
    wTotalLength           39
    bNumInterfaces          1
    iConfiguration          0
    bmAttributes         0xe0
      Self Powered
      Remote Wakeup
    MaxPower                2mA
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           3
      bInterfaceClass       255 Vendor Specific Class
      bInterfaceProtocol    255
      iInterface              0
        bLength                 7
        bDescriptorType         5
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        wMaxPacketSize     0x0200  1x 512 bytes
        bInterval               0
        bLength                 7
        bDescriptorType         5
        bEndpointAddress     0x02  EP 2 OUT
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        bInterval               0
        bLength                 7
        bDescriptorType         5
        bEndpointAddress     0x83  EP 3 IN
        bmAttributes            3
          Synch Type               None
          Usage Type               Data
        wMaxPacketSize     0x0010  1x 16 bytes
        bInterval               4
  bLength                10
  bDescriptorType         6
  bcdUSB               2.00
  bDeviceSubClass         0
  bDeviceProtocol         1
  bMaxPacketSize0        64
  Self Powered
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               2.00
  bDeviceClass            9 Hub
  bMaxPacketSize0        64
  idVendor           0x05e3 Genesys Logic, Inc.
  idProduct          0x0608 USB-2.0 4-Port HUB
  bcdDevice           77.64
  iManufacturer           0
  iProduct                1 USB2.0 Hub
  iSerial                 0
    bLength                 9
    bDescriptorType         2
    wTotalLength           25
    bNumInterfaces          1
    iConfiguration          0
    bmAttributes         0xe0
      Self Powered
      Remote Wakeup
    MaxPower              100mA
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           1
      iInterface              0
        bLength                 7
        bDescriptorType         5
        bmAttributes            3
          Synch Type               None
          Usage Type               Data
        bInterval              12
Hub Descriptor:
  bLength               9
  bDescriptorType      41
  nNbrPorts             4
  wHubCharacteristic 0x00e0
    Ganged overcurrent protection
    TT think time 32 FS bits
    Port indicators
  bHubContrCurrent    100 milli Ampere
 Hub Port Status:
   Port 1: 0000.0100 power
   Port 2: 0000.0100 power
   Port 3: 0000.0100 power
   Port 4: 0000.0503 highspeed power enable connect
  bLength                10
  bDescriptorType         6
  bcdUSB               2.00
  bDeviceClass            9 Hub
  bMaxPacketSize0        64
  Self Powered
Bus 001 Device 005: ID 04ca:0050 Lite-On Technology Corp.
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               1.10
  bDeviceSubClass         0
  bDeviceProtocol         0
  bMaxPacketSize0         8
  idVendor           0x04ca Lite-On Technology Corp.
  idProduct          0x0050
  bcdDevice            1.03
  iManufacturer           1 Lite-On Technology Corp.
  iProduct                2 USB Multimedia Keyboard
  iSerial                 0
    bLength                 9
    bDescriptorType         2
    wTotalLength           59
    bNumInterfaces          2
    iConfiguration          0
    bmAttributes         0xa0
      (Bus Powered)
      Remote Wakeup
    MaxPower              100mA
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           1
      bInterfaceProtocol      1 Keyboard
      iInterface              0
          bLength                 9
          bDescriptorType        33
          bcdHID               1.10
          bNumDescriptors         1
          wDescriptorLength      65
         Report Descriptors:
           ** UNAVAILABLE **
        bLength                 7
        bDescriptorType         5
        bmAttributes            3
          Synch Type               None
          Usage Type               Data
        wMaxPacketSize     0x0008  1x 8 bytes
        bInterval              10
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        1
      bAlternateSetting       0
      bNumEndpoints           1
      bInterfaceSubClass      0 No Subclass
      bInterfaceProtocol      0 None
      iInterface              0
          bLength                 9
          bDescriptorType        33
          bcdHID               1.10
          bNumDescriptors         1
          wDescriptorLength      50
         Report Descriptors:
           ** UNAVAILABLE **
        bLength                 7
        bDescriptorType         5
        bEndpointAddress     0x82  EP 2 IN
        bmAttributes            3
          Synch Type               None
          Usage Type               Data
        wMaxPacketSize     0x0003  1x 3 bytes
        bInterval              10
  (Bus Powered)
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               2.00
  bDeviceClass            9 Hub
  bMaxPacketSize0        64
  bcdDevice           77.64
  iManufacturer           0
  iSerial                 0
    bLength                 9
    bDescriptorType         2
    wTotalLength           25
    bNumInterfaces          1
    iConfiguration          0
    bmAttributes         0xe0
      Self Powered
      Remote Wakeup
    MaxPower              100mA
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           1
      iInterface              0
        bLength                 7
        bDescriptorType         5
        bmAttributes            3
          Synch Type               None
          Usage Type               Data
        bInterval              12
Hub Descriptor:
  bLength               9
  bDescriptorType      41
  nNbrPorts             4
    Port indicators
 Hub Port Status:
   Port 4: 0000.0303 lowspeed power enable connect
  bLength                10
  bDescriptorType         6
  bcdUSB               2.00
  bDeviceClass            9 Hub
  bMaxPacketSize0        64
  Self Powered
rspitz
Re: USB redux
Thu Dec 12, 2013 4:56 pm
Which firmware version do you mean? Is it in the Raspbian repository or only accessible via rpi-update?
I ran rpi-update yesterday and now have "Linux raspi 3.10.23+ #608 PREEMPT Mon Dec 9 21:11:23 GMT 2013 armv6l GNU/Linux". I'm presently trying out if this will fix my longstandig problems with a DVB-C USB-stick.
de-shu
Re: USB redux
Fri Jan 17, 2014 1:00 pm
Is the USB fix already merged from the fiq_split branch into master? I would prefer to not downgrade to 3.8.11...
Re: USB redux
Fri Jan 17, 2014 1:17 pm
I think all known USB fixes are in the main code now. So if you update/rpi-update you will et the very latest stuff.
de-shu
Re: USB redux
Fri Jan 17, 2014 6:32 pm
Well, I'm asking because I'm having a problem that is very similar to the described here.
Also, the branch still exists, but inactive for 8 months. It's a binary branch, so I'm having issues with finding the corresponding commit to the master branch.
fabriced
Re: USB redux
Wed Jan 22, 2014 7:36 am
Dears,
I think I have the same issue. I am on 3.10.27 and was thinking split transaction issue was solved but with a bluetooth dongle I have fast failure except if I switch it to USB 1.
Is the fix commited into 3.10 branch ?
Maybe is it possible to switch only the bluetooth dongle to USB 1 but leave the others in USB 2 ?
Kind regards,
Fabrice
de-shu
Re: USB redux
Wed Jan 22, 2014 7:49 am
It seems that the fix is actually committed but does not solve the issue completely, just makes it less probable.
You can check it by running
# dmesg | grep "FIQ split fix"
thradtke
Re: USB redux
Wed Jan 22, 2014 9:13 am
Some time ago, Gordon considered an EHCI implementation in the blob. Is this still an option?
Rocket Scientist.
gsh
Re: USB redux
Wed Jan 22, 2014 9:22 am
thradtke wrote:Some time ago, Gordon considered an EHCI implementation in the blob. Is this still an option?
Well, it is but it's unlikely to fix the problems we're seeing. Basically the Synopsys module we use for USB has some limitations which mean it's very very difficult to schedule transactions exactly when you want them... That's the issue that P33M is working on at the moment he's been working on it steadily since he came to work for Raspberry Pi and that's now at 6 months!
Unfortunately that's just the way of the hardware!
Gordon
thradtke
Re: USB redux
Wed Jan 22, 2014 4:32 pm
Ok, thanks.
Also thanks to both of you for your work on it.
Rocket Scientist.
ericbruggema
Re: USB redux
Sun Feb 09, 2014 1:05 pm
I have the same problem, after starting raspivid
raspivid -o test.h264 t 100000
after a couple of minutes it tells me
Message from syslogd@raspberrypi at feb 9 12:55:17 ...
kernel: [ 257.xxxxxxx ] Disabling IRQ 32
All usb devices are stopped (without using a hub, one wifi one bluetooth for keyboard/mouse)
Specs:
- Model B 512MB
- 32GB microsdhc with converter to sd
- PiCam 1.3
- Castcom wifi
- Logitech K400r keyboard + touchpad
Its better to start a project for the 10th time then stop after the first fail!!!!
Re: USB redux
Sun Feb 09, 2014 3:31 pm
That might be a power supply problem. I was getting ethernet drop outs when running the camera, even though the power supply was robust. Turned out to be a bad USB cable. Might be worth checking either cable or supply. Try testing the voltage at tp1,2.
