Trainer
RPI3B+ firmware update problem
Sun Mar 03, 2019 5:40 pm
I try to update my rpi3b+ firmware, kernel and kernel modules but i got some error message.
[email protected]:~ $ sudo rpi-update 152b6b8
You appear to be using a custom kernel file.
Skipping installation of new kernel, as bundled dtb files may be incompatible with your kernel.
 *** Raspberry Pi firmware updater by Hexxeh, enhanced by AndrewS and Dom
 *** Performing self-update
 *** Relaunching after update
This update bumps to rpi-4.14.y linux tree
Be aware there could be compatibility issues with some drivers
Discussion here:
https://www.raspberrypi.org/forums/viewtopic.php?f=29&t=197689
 *** Downloading specific firmware revision (this will take a few minutes)
  % Total    % Received % Xferd  Average Speed   Time    Time     Time  Current
                                 Dload  Upload   Total   Spent    Left  Speed
100   168    0   168    0     0    365      0 --:--:-- --:--:-- --:--:--   365
100 58.2M    0 58.2M    0     0  1666k      0 --:--:--  0:00:35 --:--:-- 1702k
 *** Updating firmware
*** As requested, not updating kernel
 *** As requested, not updating kernel modules
 *** Updating VideoCore libraries
 *** Using HardFP libraries
 *** Updating SDK
 *** Running ldconfig
 *** Storing current firmware revision
 *** Deleting downloaded files
 *** Syncing changes to disk
 *** If no errors appeared, your firmware was successfully updated to 152b6b858d2f6b94fa398fa4545d5e130ab24434
 *** A reboot is needed to activate the new firmware
How can i solve the problem?
Re: RPI3B+ firmware update problem
Sun Mar 03, 2019 8:15 pm
Discussion here:
 *** Updating SDK
Why are you running rpi-update it is not recommended:
https://www.raspberrypi.org/documentati ... pdating.md
adieu
Trainer
Sun Mar 03, 2019 8:28 pm
Discussion here:
 *** Updating SDK
I found it at some different sources.
Imperf3kt
Sun Mar 03, 2019 8:36 pm
rpi-update is for experimental features that might break everything.
Only use it if you know what it does, and why you need it.
Google is ubiquitous - Try it today, it's free!
https://opensource.com/life/16/10/how-ask-technical-questions
Mon Mar 04, 2019 7:20 am
Discussion here:
 *** Updating SDK
It is over 3 years since rpi-update was recommended, you should be careful about reading obsolete information. If using Google you can configure search to limit to past 6 months.
adieu
Mon Mar 04, 2019 9:46 am
To get the latesst stable firmware (assuming a fairly recent Raspbian install in the first place)
sudo apt update
sudo apt dist-upgrade
Trainer
Sat Mar 16, 2019 1:37 pm
Thank you.
I also have the problem that i don't have any /build folder in /lib/modules/4.14.72v7-aufs.
So i got a error message if i try "make".
[email protected]:~/ttyebus $ sudo make install
cp ttyebus.ko /lib/modules/4.14.72v7-aufs/kernel/drivers/tty/serial/ttyebus.ko
depmod -a
insmod /lib/modules/4.14.72v7-aufs/kernel/drivers/tty/serial/ttyebus.ko
insmod: ERROR: could not insert module /lib/modules/4.14.72v7-aufs/kernel/drivers/tty/serial/ttyebus.ko: Invalid module format
Makefile:37: recipe for target 'install' failed
make: *** [install] Error 1
I also have a problem with insmod. How can i solve it?
Sat Mar 16, 2019 1:52 pm
I have no idea why that folder has aufs on the end, you must be using a custom built kernel.
In which case, I have no idea how to help you, except to say reflashing your SD crd with the latest Raspbian is probably the easiet way to a working system.
MrEngman
Sat Mar 16, 2019 1:57 pm
Could be Berryboot.
Trainer
Sat Mar 16, 2019 2:08 pm
i try another raspbian installation with the same Problem
[email protected]:~ $ uname -r
4.14.83v7-aufs
Do you know how to solve it ?
Is it perhaps a problem because i use berryboot?
MrEngman
Sat Mar 16, 2019 3:33 pm
4.14.83v7-aufs
Yes, because BerryBoot uses it's own kernel images/modules for it's raspbian images. You cannot install updates from RPI Raspbian using apt update/upgrade.
Just reflash your SD Card with a Raspbian image from https://www.raspberrypi.org/downloads/ and it should fix your problems.
Trainer
Sat Mar 16, 2019 5:47 pm
4.14.83v7-aufs
ok, damn, i like to use berryboot :( can i use noobs or does it have the same problem?
MrEngman
Sat Mar 16, 2019 6:57 pm
4.14.83v7-aufs
Using NOOBS to install Raspbian will allow you to update Raspbian as you require using apt-get.
Since you prefer to use BerryBoot, but then ask about changing to NOOBS are you installing multiple images on your SD card? If not then just install Raspbian.
Using NOOBS to only install Raspbian can waste significant space. NOOBS is essentially just an installer and can waste several GB of space on the SD card. If you are only installing Raspbian ignore NOOBS and just install the Raspbian image you want to use.
Imperf3kt
Sat Mar 16, 2019 10:04 pm
NOOBS has also been known to cause extreme confusion for newbies when it comes to updating or switching to a newer Raspberry Pi model.
NOOBS has been continually requested to be removed from the recommended downloads, but RPF seem reluctant to comment on it.
Sat Mar 16, 2019 10:26 pm
4.14.83v7-aufs
BerryBoot is useful if you want multiple Operating Systems sharing a common kernel / firmware, though updating of Operating Systems can be problematical if one does not understand the way BB works.
NoobS / PiNN do allow multiple Operating Systems but each is reasonably independent, PiNN has more flexibility than NoobS.
The downside is it takes up hard drive space, whilst the partition scheme is weird.
I wholeheartedly believe that NoobS / BerryBoot / PiNN should be for more experienced users.
Etcher is very robust software with which to create a bootable SD Card and with the price of SD Cards makes one Operating System per SD Card a non issue:
https://www.balena.io/etcher/
adieu
Sun Mar 17, 2019 7:44 am
I did suggest that we no longer recommend Noobs, but those that must be obeyed disagreed, I cannot remember why.
Sun Mar 17, 2019 8:11 am
We will just have to keep advising to use Etcher and one OS per SD Card for newbies ;)
adieu
