Joel77364
How to control Raspberry Pi's GPIO pins from separate PC
Thu Feb 28, 2019 7:44 am
In my application I want to turn on certain GPIO pins that are on the Raspberry Pi from my PC's C++ script. My PC is currently running on Windows 10 and my Raspberry Pi on Raspbian.
The general idea I had was to write python scripts on the Raspberry Pi itself and run them somehow from my PC when needed. Although, I am not sure how to do this or if it's possible in C++.
I know I can ssh into my Raspberry Pi and run scripts manually but the idea of this application is automation. I am able to connect my PC to the Raspberry Pi either by Ethernet or USB cables.
I have seen USB to GPIO modules that would probably work better although for now I am stuck with my Raspberry Pi.
Any knowledge or resources on how to do this is greatly appreciated.
Re: How to control Raspberry Pi's GPIO pins from separate PC
Thu Feb 28, 2019 9:43 am
pigpiod and the matching python pigpio can do this.
Languages using left-hand whitespace for syntax are ridiculous
DMs sent on Twitter/LinkedIn will be answered next month.
The use of crystal balls and mind reading is prohibited.
neilgl
Thu Feb 28, 2019 12:58 pm
Maybe you could have a python script on the pi to listen for and act on mqtt messages (topics) e.g. "turn on GPIO 17"
You can send those messages from your PC in C++, or type them into a Command Prompt for testing
