pgielen wrote: ↑Sun Feb 24, 2019 6:55 pm
There is something seriously wrong with the way Raspberry Pi saves passwords. If I change the default password (raspberry) for user 'pi', then, after a random period of time, the RPi will change the new password by itself into something unknown.
Actually, there is something seriously wrong with your system. I've been using Raspberry Pi computers for many years (since the R2 model B in late 2012) and I have NEVER had a password change on it's own with any version of Raspbian, or any other OS that I've tried. I've also been using various versions of Linux as my primary OS for almost two decades, and I've never had that happen on any version of Linux on any computer.
Whatever your problem is, it has nothing to do with Raspbian or Linux in general. So why don't you give us details about how you configure and use your system so that we can try and figure out what is failing. The more details your offer, the more quickly we'll get the to bottom of this.
As I see it there are two main possibilities.
- The password is getting changed, which would involve another person (they don't change themselves).
- The password isn't getting changed, but something else is failing and preventing login.
Option #1 could be someone else messing with your system, or something you are doing with software (like using sudo in /home/pi).
Option #2 could be a hardware failure, or just improper operation (bad or inadequate power supply, bad SD card, not shutting down before disconnecting power).
