RPi3B plus Dell P2016 20" monitor - cannot get display to work!
Posted: Thu Feb 14, 2019 2:08 pm
by theMusicMan
Hi All
OK, so I have a Dell P2016 20" monitor https://www.dell.com/ed/business/p/dell-p2016/pd and I just can't seem to get it to work with my RPi.
I bought a UGREEN 1080P Active HDMI to VGA Converter with power cable - and despite my best efforts I cannot seem to get the monitor displaying anything from the RPi.
I have connected the monitor to my Mac via Mini DP, and all works fine.
As a guess... are there any settings in the RPi config files that need changing? All suggestions appreciated. Thanks.
Re: RPi3B plus Dell P2016 20" monitor - cannot get display to work!
Posted: Thu Feb 14, 2019 2:16 pm
by k-pi
The RPi defaults to HDMI, but I think I just plug my VGA/XGA monitors in, & they get used OK.
The specs for that monitor says it has HDMI, might be worth getting a cable & trying it.
If you do use a VGA converter, you will need to redirect your sound output (to the 3.5mm jack).
(Make sure you turn on the monitor before starting the RPi.)
Edit: This is the VGA adapter that I used - https://thepihut.com/collections/raspbe ... -convertor
Posted: Thu Feb 14, 2019 2:19 pm
by theMusicMan
Hi k-pi
Alas, my model doesn't have a HDMI port, but does have a Display Port. I have tested the monitor on my Mac, and it gives an excellent image using that. I chose to get a VGA converter instead of a DP converter due to price. Think I am going to give up on using this one!
Ah well... :)
Posted: Thu Feb 14, 2019 2:31 pm
by k-pi
(See my edit above.)
Posted: Thu Feb 14, 2019 2:42 pm
by theMusicMan
Yep, I spotted one of those on Amazon when I ordered the UGREEN one yesterday, wish I had ordered that one now. Have to go through the returns process with Amazon... never an enjoyable thing, meh!
Posted: Thu Feb 14, 2019 2:49 pm
by W. H. Heydt
It might be worthwhile to hunt around to see if you can find a monitor with HDMI or DVI input and skip the VGA converter. Might even cost less than a decent converter.
Posted: Thu Feb 14, 2019 2:54 pm
by theMusicMan
Yes, I think you are right!
This particular set up was for the 2nd RPi I have which I was hoping to set up downstairs. Have a decent 24" monitor for the main RPi in my study that I may swap for downstairs and use my Mac in VNC Viewer to access the one upstairs.
