I've been browsing and experimenting for hours but I can't find the solution to my problem. I'm running a Raspberry Pi 3 with Raspbian 9 (Stretch). The IP address should be static. With wifi I am connected to the internet, but as soon as I plug in my ethernet cable, the connection is lost. I can still reach the device locally.
This is my dhcpcd.conf:
# A sample configuration for dhcpcd.
# See dhcpcd.conf(5) for details.
# Allow users of this group to interact with dhcpcd via the control socket.
#controlgroup wheel
# Inform the DHCP server of our hostname for DDNS.
hostname
# Use the hardware address of the interface for the Client ID.
clientid
# or
# Use the same DUID + IAID as set in DHCPv6 for DHCPv4 ClientID as per RFC43$# Some non-RFC compliant DHCP servers do not reply with this set.
# In this case, comment out duid and enable clientid above.
#duid
# Persist interface configuration when dhcpcd exits.
persistent
# Rapid commit support.
# Safe to enable by default because it requires the equivalent option set
# on the server to actually work.
option rapid_commit
# A list of options to request from the DHCP server.
option domain_name_servers, domain_name, domain_search, host_name
option classless_static_routes
# Most distributions have NTP support.
option ntp_servers
# Respect the network MTU. This is applied to DHCP routes.
option interface_mtu
# A ServerID is required by RFC2131.
require dhcp_server_identifier
# Generate Stable Private IPv6 Addresses instead of hardware based ones
slaac private
# Example static IP configuration:
interface eth0
static ip_address=192.168.2.55/24
#static ip6_address=fd51:42f8:caae:d92e::ff/64
static routers=192.168.2.254
static domain_name_servers=192.168.2.254
# It is possible to fall back to a static IP if DHCP fails:
# define static profile
#profile static_eth0
#static ip_address=192.168.1.23/24
#static routers=192.168.1.1
#static domain_name_servers=192.168.1.1
# fallback to static profile on eth0
#interface eth0
#fallback static_eth0
Kernel IP routing table
Destination Gateway Genmask Flags Metric Ref Use Iface
0.0.0.0 192.168.2.254 0.0.0.0 UG 202 0 0 eth0
0.0.0.0 192.168.2.254 0.0.0.0 UG 303 0 0 wlan0
192.168.2.0 0.0.0.0 255.255.255.0 U 202 0 0 eth0
192.168.2.0 0.0.0.0 255.255.255.0 U 303 0 0 wlan0
Many thanks in advance!
