EGL 1.4 is correct, the very latest version is only 1.5 so no chance of you seeing 2.1.
CC = gcc
es2g:es2g.c
$(CC) -o es2g es2g.c -I/opt/vc/include -L/opt/vc/lib -lm
gcc -o es2g es2g.c -I/opt/vc/include -L/opt/vc/lib -lm
/tmp/ccziHapx.o: In function `create_gear':
es2g.c:(.text+0x1424): undefined reference to `glGenBuffers'
es2g.c:(.text+0x1438): undefined reference to `glBindBuffer'
es2g.c:(.text+0x146c): undefined reference to `glBufferData'
/tmp/ccziHapx.o: In function `draw_gear':
es2g.c:(.text+0x1d7c): undefined reference to `glUniformMatrix4fv'
es2g.c:(.text+0x1dd8): undefined reference to `glUniformMatrix4fv'
es2g.c:(.text+0x1df0): undefined reference to `glUniform4fv'
es2g.c:(.text+0x1e04): undefined reference to `glBindBuffer'
es2g.c:(.text+0x1e28): undefined reference to `glVertexAttribPointer'
es2g.c:(.text+0x1e4c): undefined reference to `glVertexAttribPointer'
es2g.c:(.text+0x1e54): undefined reference to `glEnableVertexAttribArray'
es2g.c:(.text+0x1e5c): undefined reference to `glEnableVertexAttribArray'
es2g.c:(.text+0x1ea4): undefined reference to `glDrawArrays'
es2g.c:(.text+0x1ecc): undefined reference to `glDisableVertexAttribArray'
es2g.c:(.text+0x1ed4): undefined reference to `glDisableVertexAttribArray'
/tmp/ccziHapx.o: In function `gears_draw':
es2g.c:(.text+0x1f40): undefined reference to `glClearColor'
es2g.c:(.text+0x1f48): undefined reference to `glClear'
es2g.c:(.text+0x20bc): undefined reference to `glutSwapBuffers'
/tmp/ccziHapx.o: In function `gears_reshape':
es2g.c:(.text+0x2180): undefined reference to `glViewport'
/tmp/ccziHapx.o: In function `gears_idle':
es2g.c:(.text+0x2274): undefined reference to `glutGet'
es2g.c:(.text+0x2324): undefined reference to `glutPostRedisplay'
/tmp/ccziHapx.o: In function `gears_init':
es2g.c:(.text+0x2440): undefined reference to `glEnable'
es2g.c:(.text+0x2448): undefined reference to `glEnable'
es2g.c:(.text+0x2458): undefined reference to `glCreateShader'
es2g.c:(.text+0x2470): undefined reference to `glShaderSource'
es2g.c:(.text+0x2478): undefined reference to `glCompileShader'
es2g.c:(.text+0x248c): undefined reference to `glGetShaderInfoLog'
es2g.c:(.text+0x24ac): undefined reference to `glCreateShader'
es2g.c:(.text+0x24c4): undefined reference to `glShaderSource'
es2g.c:(.text+0x24cc): undefined reference to `glCompileShader'
es2g.c:(.text+0x24e0): undefined reference to `glGetShaderInfoLog'
es2g.c:(.text+0x24f4): undefined reference to `glCreateProgram'
es2g.c:(.text+0x2504): undefined reference to `glAttachShader'
es2g.c:(.text+0x2510): undefined reference to `glAttachShader'
es2g.c:(.text+0x2520): undefined reference to `glBindAttribLocation'
es2g.c:(.text+0x2530): undefined reference to `glBindAttribLocation'
es2g.c:(.text+0x2538): undefined reference to `glLinkProgram'
es2g.c:(.text+0x254c): undefined reference to `glGetProgramInfoLog'
es2g.c:(.text+0x2564): undefined reference to `glUseProgram'
es2g.c:(.text+0x2570): undefined reference to `glGetUniformLocation'
es2g.c:(.text+0x258c): undefined reference to `glGetUniformLocation'
es2g.c:(.text+0x25a8): undefined reference to `glGetUniformLocation'
es2g.c:(.text+0x25c4): undefined reference to `glGetUniformLocation'
es2g.c:(.text+0x25ec): undefined reference to `glUniform4fv'
/tmp/ccziHapx.o: In function `main':
es2g.c:(.text+0x26fc): undefined reference to `glutInit'
es2g.c:(.text+0x2708): undefined reference to `glutInitWindowSize'
es2g.c:(.text+0x2710): undefined reference to `glutInitDisplayMode'
es2g.c:(.text+0x2718): undefined reference to `glutCreateWindow'
es2g.c:(.text+0x2720): undefined reference to `glutIdleFunc'
es2g.c:(.text+0x2728): undefined reference to `glutReshapeFunc'
es2g.c:(.text+0x2730): undefined reference to `glutDisplayFunc'
es2g.c:(.text+0x2738): undefined reference to `glutSpecialFunc'
es2g.c:(.text+0x2740): undefined reference to `glutMainLoop'
collect2: error: ld returned 1 exit status
Makefile:3: recipe for target 'es2g' failed
make: *** [es2g] Error 1
name of display: :0.0
display: :0 screen: 0
direct rendering: Yes
server glx vendor string: SGI
server glx version string: 1.4
server glx extensions:
GLX_ARB_create_context, GLX_ARB_create_context_profile,
GLX_ARB_fbconfig_float, GLX_ARB_framebuffer_sRGB, GLX_ARB_multisample,
GLX_EXT_create_context_es2_profile, GLX_EXT_create_context_es_profile,
GLX_EXT_fbconfig_packed_float, GLX_EXT_framebuffer_sRGB,
GLX_EXT_import_context, GLX_EXT_libglvnd, GLX_EXT_texture_from_pixmap,
GLX_EXT_visual_info, GLX_EXT_visual_rating, GLX_MESA_copy_sub_buffer,
GLX_OML_swap_method, GLX_SGIS_multisample, GLX_SGIX_fbconfig,
GLX_SGIX_pbuffer, GLX_SGIX_visual_select_group, GLX_SGI_make_current_read
client glx vendor string: Mesa Project and SGI
client glx version string: 1.4
client glx extensions:
GLX_ARB_create_context_robustness, GLX_ARB_fbconfig_float,
GLX_ARB_framebuffer_sRGB, GLX_ARB_get_proc_address, GLX_ARB_multisample,
GLX_EXT_buffer_age, GLX_EXT_create_context_es2_profile,
GLX_EXT_create_context_es_profile, GLX_EXT_fbconfig_packed_float,
GLX_EXT_framebuffer_sRGB, GLX_EXT_import_context,
GLX_EXT_texture_from_pixmap, GLX_EXT_visual_info, GLX_EXT_visual_rating,
GLX_INTEL_swap_event, GLX_MESA_copy_sub_buffer,
GLX_MESA_multithread_makecurrent, GLX_MESA_query_renderer,
GLX_MESA_swap_control, GLX_OML_swap_method, GLX_OML_sync_control,
GLX_SGIS_multisample, GLX_SGIX_fbconfig, GLX_SGIX_pbuffer,
GLX_SGIX_visual_select_group, GLX_SGI_make_current_read,
GLX_SGI_swap_control, GLX_SGI_video_sync
GLX version: 1.4
GLX extensions:
GLX_EXT_import_context, GLX_EXT_texture_from_pixmap, GLX_EXT_visual_info,
Extended renderer info (GLX_MESA_query_renderer):
Vendor: VMware, Inc. (0xffffffff)
Device: llvmpipe (LLVM 3.9, 128 bits) (0xffffffff)
Version: 13.0.6
Accelerated: no
Video memory: 875MB
Unified memory: no
Preferred profile: core (0x1)
Max core profile version: 3.3
Max compat profile version: 3.0
Max GLES1 profile version: 1.1
Max GLES[23] profile version: 3.0
OpenGL vendor string: VMware, Inc.
OpenGL renderer string: Gallium 0.4 on llvmpipe (LLVM 3.9, 128 bits)
OpenGL core profile version string: 3.3 (Core Profile) Mesa 13.0.6
OpenGL core profile shading language version string: 3.30
OpenGL core profile context flags: (none)
OpenGL core profile profile mask: core profile
OpenGL core profile extensions:
GL_AMD_conservative_depth, GL_AMD_draw_buffers_blend,
GL_AMD_seamless_cubemap_per_texture, GL_AMD_shader_stencil_export,
GL_AMD_shader_trinary_minmax, GL_AMD_vertex_shader_layer,
GL_AMD_vertex_shader_viewport_index, GL_ANGLE_texture_compression_dxt3,
GL_ANGLE_texture_compression_dxt5, GL_ARB_ES2_compatibility,
GL_ARB_ES3_compatibility, GL_ARB_arrays_of_arrays, GL_ARB_base_instance,
GL_ARB_blend_func_extended, GL_ARB_buffer_storage,
GL_ARB_clear_buffer_object, GL_ARB_clip_control,
GL_ARB_compressed_texture_pixel_storage,
GL_ARB_conditional_render_inverted, GL_ARB_conservative_depth,
GL_ARB_copy_buffer, GL_ARB_copy_image, GL_ARB_cull_distance,
GL_ARB_debug_output, GL_ARB_depth_buffer_float, GL_ARB_depth_clamp,
GL_ARB_direct_state_access, GL_ARB_draw_buffers,
GL_ARB_draw_buffers_blend, GL_ARB_draw_elements_base_vertex,
GL_ARB_draw_indirect, GL_ARB_draw_instanced, GL_ARB_enhanced_layouts,
GL_ARB_explicit_attrib_location, GL_ARB_explicit_uniform_location,
GL_ARB_fragment_coord_conventions, GL_ARB_fragment_layer_viewport,
GL_ARB_fragment_shader, GL_ARB_framebuffer_object,
GL_ARB_framebuffer_sRGB, GL_ARB_get_program_binary,
GL_ARB_get_texture_sub_image, GL_ARB_gpu_shader_fp64,
GL_ARB_half_float_pixel, GL_ARB_half_float_vertex,
GL_ARB_instanced_arrays, GL_ARB_internalformat_query,
GL_ARB_internalformat_query2, GL_ARB_invalidate_subdata,
GL_ARB_map_buffer_alignment, GL_ARB_map_buffer_range, GL_ARB_multi_bind,
GL_ARB_multi_draw_indirect, GL_ARB_occlusion_query2,
GL_ARB_pixel_buffer_object, GL_ARB_point_sprite,
GL_ARB_program_interface_query, GL_ARB_provoking_vertex,
GL_ARB_robustness, GL_ARB_sampler_objects, GL_ARB_seamless_cube_map,
GL_ARB_seamless_cubemap_per_texture, GL_ARB_separate_shader_objects,
GL_ARB_shader_bit_encoding, GL_ARB_shader_objects,
GL_ARB_shader_stencil_export, GL_ARB_shader_subroutine,
GL_ARB_shader_texture_lod, GL_ARB_shading_language_420pack,
GL_ARB_shading_language_packing, GL_ARB_stencil_texturing, GL_ARB_sync,
GL_ARB_texture_buffer_object, GL_ARB_texture_buffer_object_rgb32,
GL_ARB_texture_buffer_range, GL_ARB_texture_compression_rgtc,
GL_ARB_texture_cube_map_array, GL_ARB_texture_float,
GL_ARB_texture_gather, GL_ARB_texture_mirror_clamp_to_edge,
GL_ARB_texture_multisample, GL_ARB_texture_non_power_of_two,
GL_ARB_texture_query_levels, GL_ARB_texture_rectangle, GL_ARB_texture_rg,
GL_ARB_texture_rgb10_a2ui, GL_ARB_texture_stencil8,
GL_ARB_texture_storage, GL_ARB_texture_storage_multisample,
GL_ARB_texture_swizzle, GL_ARB_texture_view, GL_ARB_timer_query,
GL_ARB_transform_feedback2, GL_ARB_transform_feedback3,
GL_ARB_transform_feedback_instanced, GL_ARB_uniform_buffer_object,
GL_ARB_vertex_array_bgra, GL_ARB_vertex_array_object,
GL_ARB_vertex_attrib_64bit, GL_ARB_vertex_attrib_binding,
GL_ARB_vertex_shader, GL_ARB_vertex_type_10f_11f_11f_rev,
GL_ARB_vertex_type_2_10_10_10_rev, GL_ARB_viewport_array,
GL_ATI_blend_equation_separate, GL_ATI_texture_float,
GL_ATI_texture_mirror_once, GL_EXT_abgr, GL_EXT_blend_equation_separate,
GL_EXT_draw_buffers2, GL_EXT_draw_instanced, GL_EXT_framebuffer_blit,
GL_EXT_framebuffer_multisample, GL_EXT_framebuffer_multisample_blit_scaled,
GL_EXT_framebuffer_sRGB, GL_EXT_packed_depth_stencil, GL_EXT_packed_float,
GL_EXT_pixel_buffer_object, GL_EXT_polygon_offset_clamp,
GL_EXT_provoking_vertex, GL_EXT_shader_integer_mix, GL_EXT_texture_array,
GL_EXT_texture_compression_dxt1, GL_EXT_texture_compression_rgtc,
GL_EXT_texture_compression_s3tc, GL_EXT_texture_integer,
GL_EXT_texture_mirror_clamp, GL_EXT_texture_sRGB,
GL_EXT_texture_sRGB_decode, GL_EXT_texture_shared_exponent,
GL_EXT_texture_snorm, GL_EXT_texture_swizzle, GL_EXT_timer_query,
GL_EXT_transform_feedback, GL_EXT_vertex_array_bgra,
GL_IBM_multimode_draw_arrays, GL_KHR_context_flush_control, GL_KHR_debug,
GL_MESA_pack_invert, GL_MESA_shader_integer_functions,
GL_MESA_texture_signed_rgba, GL_MESA_ycbcr_texture,
GL_NV_conditional_render, GL_NV_depth_clamp, GL_NV_packed_depth_stencil,
GL_OES_EGL_image, GL_S3_s3tc
OpenGL version string: 3.0 Mesa 13.0.6
OpenGL shading language version string: 1.30
OpenGL context flags: (none)
OpenGL extensions:
GL_AMD_shader_trinary_minmax, GL_ANGLE_texture_compression_dxt3,
GL_ANGLE_texture_compression_dxt5, GL_APPLE_packed_pixels,
GL_APPLE_vertex_array_object, GL_ARB_ES2_compatibility,
GL_ARB_color_buffer_float, GL_ARB_compressed_texture_pixel_storage,
GL_ARB_depth_texture, GL_ARB_draw_buffers, GL_ARB_draw_buffers_blend,
GL_ARB_draw_elements_base_vertex, GL_ARB_draw_instanced,
GL_ARB_fragment_coord_conventions, GL_ARB_fragment_program,
GL_ARB_fragment_program_shadow, GL_ARB_fragment_shader,
GL_ARB_framebuffer_object, GL_ARB_framebuffer_sRGB,
GL_ARB_get_program_binary, GL_ARB_get_texture_sub_image,
GL_ARB_multisample, GL_ARB_multitexture, GL_ARB_occlusion_query,
GL_ARB_occlusion_query2, GL_ARB_pixel_buffer_object,
GL_ARB_point_parameters, GL_ARB_point_sprite,
GL_ARB_shader_stencil_export, GL_ARB_shader_texture_lod,
GL_ARB_shading_language_100, GL_ARB_shading_language_420pack,
GL_ARB_shading_language_packing, GL_ARB_shadow, GL_ARB_stencil_texturing,
GL_ARB_sync, GL_ARB_texture_border_clamp, GL_ARB_texture_compression,
GL_ARB_texture_compression_rgtc, GL_ARB_texture_cube_map,
GL_ARB_texture_cube_map_array, GL_ARB_texture_env_add,
GL_ARB_texture_env_combine, GL_ARB_texture_env_crossbar,
GL_ARB_texture_env_dot3, GL_ARB_texture_float, GL_ARB_texture_gather,
GL_ARB_texture_mirror_clamp_to_edge, GL_ARB_texture_mirrored_repeat,
GL_ARB_transform_feedback_instanced, GL_ARB_transpose_matrix,
GL_ARB_uniform_buffer_object, GL_ARB_vertex_array_bgra,
GL_ARB_vertex_array_object, GL_ARB_vertex_attrib_binding,
GL_ARB_vertex_buffer_object, GL_ARB_vertex_program, GL_ARB_vertex_shader,
GL_ARB_vertex_type_10f_11f_11f_rev, GL_ARB_vertex_type_2_10_10_10_rev,
GL_ARB_window_pos, GL_ATI_blend_equation_separate, GL_ATI_draw_buffers,
GL_ATI_fragment_shader, GL_ATI_separate_stencil,
GL_ATI_texture_compression_3dc, GL_ATI_texture_env_combine3,
GL_ATI_texture_float, GL_ATI_texture_mirror_once, GL_EXT_abgr,
GL_EXT_bgra, GL_EXT_blend_color, GL_EXT_blend_equation_separate,
GL_EXT_blend_func_separate, GL_EXT_blend_minmax, GL_EXT_blend_subtract,
GL_EXT_compiled_vertex_array, GL_EXT_copy_texture, GL_EXT_draw_buffers2,
GL_EXT_draw_instanced, GL_EXT_draw_range_elements, GL_EXT_fog_coord,
GL_EXT_framebuffer_blit, GL_EXT_framebuffer_multisample,
GL_EXT_framebuffer_multisample_blit_scaled, GL_EXT_framebuffer_object,
GL_EXT_framebuffer_sRGB, GL_EXT_gpu_program_parameters,
GL_EXT_multi_draw_arrays, GL_EXT_packed_depth_stencil,
GL_EXT_packed_float, GL_EXT_packed_pixels, GL_EXT_pixel_buffer_object,
GL_EXT_point_parameters, GL_EXT_polygon_offset,
GL_EXT_polygon_offset_clamp, GL_EXT_provoking_vertex,
GL_EXT_rescale_normal, GL_EXT_secondary_color,
GL_EXT_separate_specular_color, GL_EXT_shader_integer_mix,
GL_EXT_shadow_funcs, GL_EXT_stencil_two_side, GL_EXT_stencil_wrap,
GL_EXT_subtexture, GL_EXT_texture, GL_EXT_texture3D,
GL_EXT_texture_array, GL_EXT_texture_compression_dxt1,
GL_EXT_texture_compression_latc, GL_EXT_texture_compression_rgtc,
GL_EXT_texture_compression_s3tc, GL_EXT_texture_cube_map,
GL_EXT_texture_edge_clamp, GL_EXT_texture_env_add,
GL_EXT_texture_env_combine, GL_EXT_texture_env_dot3,
GL_EXT_texture_integer, GL_EXT_texture_lod_bias,
GL_EXT_texture_mirror_clamp, GL_EXT_texture_object,
GL_EXT_texture_rectangle, GL_EXT_texture_sRGB, GL_EXT_texture_sRGB_decode,
GL_EXT_texture_shared_exponent, GL_EXT_texture_snorm,
GL_EXT_texture_swizzle, GL_EXT_timer_query, GL_EXT_transform_feedback,
GL_EXT_vertex_array, GL_EXT_vertex_array_bgra,
GL_IBM_multimode_draw_arrays, GL_IBM_rasterpos_clip,
GL_IBM_texture_mirrored_repeat, GL_INGR_blend_func_separate,
GL_KHR_context_flush_control, GL_KHR_debug, GL_MESA_pack_invert,
GL_MESA_shader_integer_functions, GL_MESA_texture_signed_rgba,
GL_MESA_window_pos, GL_MESA_ycbcr_texture, GL_NV_blend_square,
GL_NV_conditional_render, GL_NV_depth_clamp, GL_NV_fog_distance,
GL_NV_light_max_exponent, GL_NV_packed_depth_stencil,
GL_NV_primitive_restart, GL_NV_texgen_reflection,
GL_NV_texture_env_combine4, GL_NV_texture_rectangle, GL_OES_EGL_image,
GL_OES_read_format, GL_S3_s3tc, GL_SGIS_generate_mipmap,
GL_SGIS_texture_border_clamp, GL_SGIS_texture_edge_clamp,
GL_SGIS_texture_lod, GL_SUN_multi_draw_arrays
OpenGL ES profile version string: OpenGL ES 3.0 Mesa 13.0.6
OpenGL ES profile shading language version string: OpenGL ES GLSL ES 3.00
OpenGL ES profile extensions:
GL_ANGLE_texture_compression_dxt3, GL_ANGLE_texture_compression_dxt5,
GL_APPLE_texture_max_level, GL_EXT_base_instance,
GL_EXT_blend_func_extended, GL_EXT_blend_minmax,
GL_EXT_clip_cull_distance, GL_EXT_color_buffer_float, GL_EXT_copy_image,
GL_EXT_discard_framebuffer, GL_EXT_draw_buffers,
GL_EXT_draw_buffers_indexed, GL_EXT_draw_elements_base_vertex,
GL_EXT_map_buffer_range, GL_EXT_multi_draw_arrays,
GL_EXT_polygon_offset_clamp, GL_EXT_read_format_bgra,
GL_EXT_separate_shader_objects, GL_EXT_shader_integer_mix,
GL_EXT_texture_border_clamp, GL_EXT_texture_compression_dxt1,
GL_EXT_texture_format_BGRA8888, GL_EXT_texture_rg,
GL_EXT_texture_sRGB_decode, GL_EXT_texture_type_2_10_10_10_REV,
GL_EXT_unpack_subimage, GL_KHR_context_flush_control, GL_KHR_debug,
GL_MESA_shader_integer_functions, GL_NV_draw_buffers,
GL_NV_fbo_color_attachments, GL_NV_read_buffer, GL_NV_read_depth,
GL_NV_read_depth_stencil, GL_NV_read_stencil, GL_OES_EGL_image,
GL_OES_EGL_image_external, GL_OES_EGL_sync,
GL_OES_compressed_ETC1_RGB8_texture, GL_OES_copy_image, GL_OES_depth24,
GL_OES_depth_texture, GL_OES_depth_texture_cube_map,
GL_OES_draw_buffers_indexed, GL_OES_draw_elements_base_vertex,
GL_OES_element_index_uint, GL_OES_fbo_render_mipmap,
GL_OES_get_program_binary, GL_OES_mapbuffer, GL_OES_packed_depth_stencil,
GL_OES_rgb8_rgba8, GL_OES_standard_derivatives, GL_OES_stencil8,
GL_OES_surfaceless_context, GL_OES_texture_3D,
GL_OES_texture_border_clamp, GL_OES_texture_float,
GL_OES_texture_float_linear, GL_OES_texture_half_float,
GL_OES_texture_half_float_linear, GL_OES_texture_npot,
GL_OES_texture_stencil8, GL_OES_vertex_array_object
240 GLX Visuals
visual x bf lv rg d st colorbuffer sr ax dp st accumbuffer ms cav
id dep cl sp sz l ci b ro r g b a F gb bf th cl r g b a ns b eat
0x021 24 tc 0 32 0 r y . 8 8 8 8 . . 0 24 8 0 0 0 0 0 0 None
0x16e 24 tc 0 32 0 r . . 8 8 8 8 . . 0 0 0 0 0 0 0 0 0 None
0x16f 24 tc 0 32 0 r . . 8 8 8 8 . . 0 0 0 16 16 16 16 0 0 Slow
0x170 24 tc 0 32 0 r y . 8 8 8 8 . . 0 0 0 0 0 0 0 0 0 None
0x171 24 tc 0 32 0 r y . 8 8 8 8 . . 0 0 0 16 16 16 16 0 0 Slow
0x172 24 tc 0 32 0 r y . 8 8 8 8 . . 0 0 0 0 0 0 0 0 0 None
0x173 24 tc 0 32 0 r y . 8 8 8 8 . . 0 0 0 16 16 16 16 0 0 Slow
0x174 24 tc 0 32 0 r . . 8 8 8 8 . . 0 16 0 0 0 0 0 0 0 None
0x175 24 tc 0 32 0 r . . 8 8 8 8 . . 0 16 0 16 16 16 16 0 0 Slow
0x176 24 tc 0 32 0 r y . 8 8 8 8 . . 0 16 0 0 0 0 0 0 0 None
0x177 24 tc 0 32 0 r y . 8 8 8 8 . . 0 16 0 16 16 16 16 0 0 Slow
0x178 24 tc 0 32 0 r y . 8 8 8 8 . . 0 16 0 0 0 0 0 0 0 None
0x179 24 tc 0 32 0 r y . 8 8 8 8 . . 0 16 0 16 16 16 16 0 0 Slow
0x17a 24 tc 0 32 0 r . . 8 8 8 8 . . 0 24 0 0 0 0 0 0 0 None
0x17b 24 tc 0 32 0 r . . 8 8 8 8 . . 0 24 0 16 16 16 16 0 0 Slow
0x17c 24 tc 0 32 0 r y . 8 8 8 8 . . 0 24 0 0 0 0 0 0 0 None
0x17d 24 tc 0 32 0 r y . 8 8 8 8 . . 0 24 0 16 16 16 16 0 0 Slow
0x17e 24 tc 0 32 0 r y . 8 8 8 8 . . 0 24 0 0 0 0 0 0 0 None
0x17f 24 tc 0 32 0 r y . 8 8 8 8 . . 0 24 0 16 16 16 16 0 0 Slow
0x180 24 tc 0 32 0 r . . 8 8 8 8 . . 0 24 8 0 0 0 0 0 0 None
0x181 24 tc 0 32 0 r . . 8 8 8 8 . . 0 24 8 16 16 16 16 0 0 Slow
0x182 24 tc 0 32 0 r y . 8 8 8 8 . . 0 24 8 16 16 16 16 0 0 Slow
0x183 24 tc 0 32 0 r y . 8 8 8 8 . . 0 24 8 16 16 16 16 0 0 Slow
0x184 24 tc 0 32 0 r . . 8 8 8 8 . . 0 32 0 0 0 0 0 0 0 None
0x185 24 tc 0 32 0 r . . 8 8 8 8 . . 0 32 0 16 16 16 16 0 0 Slow
0x186 24 tc 0 32 0 r y . 8 8 8 8 . . 0 32 0 0 0 0 0 0 0 None
0x187 24 tc 0 32 0 r y . 8 8 8 8 . . 0 32 0 16 16 16 16 0 0 Slow
0x188 24 tc 0 32 0 r y . 8 8 8 8 . . 0 32 0 0 0 0 0 0 0 None
0x189 24 tc 0 32 0 r y . 8 8 8 8 . . 0 32 0 16 16 16 16 0 0 Slow
0x18a 24 tc 0 24 0 r . . 8 8 8 0 . . 0 0 0 0 0 0 0 0 0 None
0x18b 24 tc 0 24 0 r . . 8 8 8 0 . . 0 0 0 16 16 16 0 0 0 Slow
0x18c 24 tc 0 24 0 r y . 8 8 8 0 . . 0 0 0 0 0 0 0 0 0 None
0x18d 24 tc 0 24 0 r y . 8 8 8 0 . . 0 0 0 16 16 16 0 0 0 Slow
0x18e 24 tc 0 24 0 r y . 8 8 8 0 . . 0 0 0 0 0 0 0 0 0 None
0x18f 24 tc 0 24 0 r y . 8 8 8 0 . . 0 0 0 16 16 16 0 0 0 Slow
0x190 24 tc 0 24 0 r . . 8 8 8 0 . . 0 16 0 0 0 0 0 0 0 None
0x191 24 tc 0 24 0 r . . 8 8 8 0 . . 0 16 0 16 16 16 0 0 0 Slow
0x192 24 tc 0 24 0 r y . 8 8 8 0 . . 0 16 0 0 0 0 0 0 0 None
0x193 24 tc 0 24 0 r y . 8 8 8 0 . . 0 16 0 16 16 16 0 0 0 Slow
0x194 24 tc 0 24 0 r y . 8 8 8 0 . . 0 16 0 0 0 0 0 0 0 None
0x195 24 tc 0 24 0 r y . 8 8 8 0 . . 0 16 0 16 16 16 0 0 0 Slow
0x196 24 tc 0 24 0 r . . 8 8 8 0 . . 0 24 0 0 0 0 0 0 0 None
0x197 24 tc 0 24 0 r . . 8 8 8 0 . . 0 24 0 16 16 16 0 0 0 Slow
0x198 24 tc 0 24 0 r y . 8 8 8 0 . . 0 24 0 0 0 0 0 0 0 None
0x199 24 tc 0 24 0 r y . 8 8 8 0 . . 0 24 0 16 16 16 0 0 0 Slow
0x19a 24 tc 0 24 0 r y . 8 8 8 0 . . 0 24 0 0 0 0 0 0 0 None
0x19b 24 tc 0 24 0 r y . 8 8 8 0 . . 0 24 0 16 16 16 0 0 0 Slow
0x19c 24 tc 0 24 0 r . . 8 8 8 0 . . 0 24 8 0 0 0 0 0 0 None
0x19d 24 tc 0 24 0 r . . 8 8 8 0 . . 0 24 8 16 16 16 0 0 0 Slow
0x19e 24 tc 0 24 0 r y . 8 8 8 0 . . 0 24 8 0 0 0 0 0 0 None
0x19f 24 tc 0 24 0 r y . 8 8 8 0 . . 0 24 8 16 16 16 0 0 0 Slow
0x1a0 24 tc 0 24 0 r y . 8 8 8 0 . . 0 24 8 0 0 0 0 0 0 None
0x1a1 24 tc 0 24 0 r y . 8 8 8 0 . . 0 24 8 16 16 16 0 0 0 Slow
0x1a2 24 tc 0 24 0 r . . 8 8 8 0 . . 0 32 0 0 0 0 0 0 0 None
0x1a3 24 tc 0 24 0 r . . 8 8 8 0 . . 0 32 0 16 16 16 0 0 0 Slow
0x1a4 24 tc 0 24 0 r y . 8 8 8 0 . . 0 32 0 0 0 0 0 0 0 None
0x1a5 24 tc 0 24 0 r y . 8 8 8 0 . . 0 32 0 16 16 16 0 0 0 Slow
0x1a6 24 tc 0 24 0 r y . 8 8 8 0 . . 0 32 0 0 0 0 0 0 0 None
0x1a7 24 tc 0 24 0 r y . 8 8 8 0 . . 0 32 0 16 16 16 0 0 0 Slow
0x1a8 24 tc 0 32 0 r . . 8 8 8 8 . s 0 0 0 0 0 0 0 0 0 None
0x1a9 24 tc 0 32 0 r . . 8 8 8 8 . s 0 0 0 16 16 16 16 0 0 Slow
0x1aa 24 tc 0 32 0 r y . 8 8 8 8 . s 0 0 0 0 0 0 0 0 0 None
0x1ab 24 tc 0 32 0 r y . 8 8 8 8 . s 0 0 0 16 16 16 16 0 0 Slow
0x1ac 24 tc 0 32 0 r y . 8 8 8 8 . s 0 0 0 0 0 0 0 0 0 None
0x1ad 24 tc 0 32 0 r y . 8 8 8 8 . s 0 0 0 16 16 16 16 0 0 Slow
0x1ae 24 tc 0 32 0 r . . 8 8 8 8 . s 0 16 0 0 0 0 0 0 0 None
0x1af 24 tc 0 32 0 r . . 8 8 8 8 . s 0 16 0 16 16 16 16 0 0 Slow
0x1b0 24 tc 0 32 0 r y . 8 8 8 8 . s 0 16 0 0 0 0 0 0 0 None
0x1b1 24 tc 0 32 0 r y . 8 8 8 8 . s 0 16 0 16 16 16 16 0 0 Slow
0x1b2 24 tc 0 32 0 r y . 8 8 8 8 . s 0 16 0 0 0 0 0 0 0 None
0x1b3 24 tc 0 32 0 r y . 8 8 8 8 . s 0 16 0 16 16 16 16 0 0 Slow
0x1b4 24 tc 0 32 0 r . . 8 8 8 8 . s 0 24 0 0 0 0 0 0 0 None
0x1b5 24 tc 0 32 0 r . . 8 8 8 8 . s 0 24 0 16 16 16 16 0 0 Slow
0x1b6 24 tc 0 32 0 r y . 8 8 8 8 . s 0 24 0 0 0 0 0 0 0 None
0x1b7 24 tc 0 32 0 r y . 8 8 8 8 . s 0 24 0 16 16 16 16 0 0 Slow
0x1b8 24 tc 0 32 0 r y . 8 8 8 8 . s 0 24 0 0 0 0 0 0 0 None
0x1b9 24 tc 0 32 0 r y . 8 8 8 8 . s 0 24 0 16 16 16 16 0 0 Slow
0x1ba 24 tc 0 32 0 r . . 8 8 8 8 . s 0 24 8 0 0 0 0 0 0 None
0x1bb 24 tc 0 32 0 r . . 8 8 8 8 . s 0 24 8 16 16 16 16 0 0 Slow
0x1bc 24 tc 0 32 0 r y . 8 8 8 8 . s 0 24 8 0 0 0 0 0 0 None
0x1bd 24 tc 0 32 0 r y . 8 8 8 8 . s 0 24 8 16 16 16 16 0 0 Slow
0x1be 24 tc 0 32 0 r y . 8 8 8 8 . s 0 24 8 0 0 0 0 0 0 None
0x1bf 24 tc 0 32 0 r y . 8 8 8 8 . s 0 24 8 16 16 16 16 0 0 Slow
0x1c0 24 tc 0 32 0 r . . 8 8 8 8 . s 0 32 0 0 0 0 0 0 0 None
0x1c1 24 tc 0 32 0 r . . 8 8 8 8 . s 0 32 0 16 16 16 16 0 0 Slow
0x1c2 24 tc 0 32 0 r y . 8 8 8 8 . s 0 32 0 0 0 0 0 0 0 None
0x1c3 24 tc 0 32 0 r y . 8 8 8 8 . s 0 32 0 16 16 16 16 0 0 Slow
0x1c4 24 tc 0 32 0 r y . 8 8 8 8 . s 0 32 0 0 0 0 0 0 0 None
0x1c5 24 tc 0 32 0 r y . 8 8 8 8 . s 0 32 0 16 16 16 16 0 0 Slow
0x1c6 24 tc 0 24 0 r . . 8 8 8 0 . s 0 0 0 0 0 0 0 0 0 None
0x1c7 24 tc 0 24 0 r . . 8 8 8 0 . s 0 0 0 16 16 16 0 0 0 Slow
0x1c8 24 tc 0 24 0 r y . 8 8 8 0 . s 0 0 0 0 0 0 0 0 0 None
0x1c9 24 tc 0 24 0 r y . 8 8 8 0 . s 0 0 0 16 16 16 0 0 0 Slow
0x1ca 24 tc 0 24 0 r y . 8 8 8 0 . s 0 0 0 0 0 0 0 0 0 None
0x1cb 24 tc 0 24 0 r y . 8 8 8 0 . s 0 0 0 16 16 16 0 0 0 Slow
0x1cc 24 tc 0 24 0 r . . 8 8 8 0 . s 0 16 0 0 0 0 0 0 0 None
0x1cd 24 tc 0 24 0 r . . 8 8 8 0 . s 0 16 0 16 16 16 0 0 0 Slow
0x1ce 24 tc 0 24 0 r y . 8 8 8 0 . s 0 16 0 0 0 0 0 0 0 None
0x1cf 24 tc 0 24 0 r y . 8 8 8 0 . s 0 16 0 16 16 16 0 0 0 Slow
0x1d0 24 tc 0 24 0 r y . 8 8 8 0 . s 0 16 0 0 0 0 0 0 0 None
0x1d1 24 tc 0 24 0 r y . 8 8 8 0 . s 0 16 0 16 16 16 0 0 0 Slow
0x1d2 24 tc 0 24 0 r . . 8 8 8 0 . s 0 24 0 0 0 0 0 0 0 None
0x1d3 24 tc 0 24 0 r . . 8 8 8 0 . s 0 24 0 16 16 16 0 0 0 Slow
0x1d4 24 tc 0 24 0 r y . 8 8 8 0 . s 0 24 0 0 0 0 0 0 0 None
0x1d5 24 tc 0 24 0 r y . 8 8 8 0 . s 0 24 0 16 16 16 0 0 0 Slow
0x1d6 24 tc 0 24 0 r y . 8 8 8 0 . s 0 24 0 0 0 0 0 0 0 None
0x1d7 24 tc 0 24 0 r y . 8 8 8 0 . s 0 24 0 16 16 16 0 0 0 Slow
0x1d8 24 tc 0 24 0 r . . 8 8 8 0 . s 0 24 8 0 0 0 0 0 0 None
0x1d9 24 tc 0 24 0 r . . 8 8 8 0 . s 0 24 8 16 16 16 0 0 0 Slow
0x1da 24 tc 0 24 0 r y . 8 8 8 0 . s 0 24 8 0 0 0 0 0 0 None
0x1db 24 tc 0 24 0 r y . 8 8 8 0 . s 0 24 8 16 16 16 0 0 0 Slow
0x1dc 24 tc 0 24 0 r y . 8 8 8 0 . s 0 24 8 0 0 0 0 0 0 None
0x1dd 24 tc 0 24 0 r y . 8 8 8 0 . s 0 24 8 16 16 16 0 0 0 Slow
0x1de 24 tc 0 24 0 r . . 8 8 8 0 . s 0 32 0 0 0 0 0 0 0 None
0x1df 24 tc 0 24 0 r . . 8 8 8 0 . s 0 32 0 16 16 16 0 0 0 Slow
0x1e0 24 tc 0 24 0 r y . 8 8 8 0 . s 0 32 0 0 0 0 0 0 0 None
0x1e1 24 tc 0 24 0 r y . 8 8 8 0 . s 0 32 0 16 16 16 0 0 0 Slow
0x1e2 24 tc 0 24 0 r y . 8 8 8 0 . s 0 32 0 0 0 0 0 0 0 None
0x1e3 24 tc 0 24 0 r y . 8 8 8 0 . s 0 32 0 16 16 16 0 0 0 Slow
0x1e4 24 dc 0 32 0 r . . 8 8 8 8 . . 0 0 0 0 0 0 0 0 0 None
0x1e5 24 dc 0 32 0 r . . 8 8 8 8 . . 0 0 0 16 16 16 16 0 0 Slow
0x1e6 24 dc 0 32 0 r y . 8 8 8 8 . . 0 0 0 0 0 0 0 0 0 None
0x1e7 24 dc 0 32 0 r y . 8 8 8 8 . . 0 0 0 16 16 16 16 0 0 Slow
0x1e8 24 dc 0 32 0 r y . 8 8 8 8 . . 0 0 0 0 0 0 0 0 0 None
0x1e9 24 dc 0 32 0 r y . 8 8 8 8 . . 0 0 0 16 16 16 16 0 0 Slow
0x1ea 24 dc 0 32 0 r . . 8 8 8 8 . . 0 16 0 0 0 0 0 0 0 None
0x1eb 24 dc 0 32 0 r . . 8 8 8 8 . . 0 16 0 16 16 16 16 0 0 Slow
0x1ec 24 dc 0 32 0 r y . 8 8 8 8 . . 0 16 0 0 0 0 0 0 0 None
0x1ed 24 dc 0 32 0 r y . 8 8 8 8 . . 0 16 0 16 16 16 16 0 0 Slow
0x1ee 24 dc 0 32 0 r y . 8 8 8 8 . . 0 16 0 0 0 0 0 0 0 None
0x1ef 24 dc 0 32 0 r y . 8 8 8 8 . . 0 16 0 16 16 16 16 0 0 Slow
0x1f0 24 dc 0 32 0 r . . 8 8 8 8 . . 0 24 0 0 0 0 0 0 0 None
0x1f1 24 dc 0 32 0 r . . 8 8 8 8 . . 0 24 0 16 16 16 16 0 0 Slow
0x1f2 24 dc 0 32 0 r y . 8 8 8 8 . . 0 24 0 0 0 0 0 0 0 None
0x1f3 24 dc 0 32 0 r y . 8 8 8 8 . . 0 24 0 16 16 16 16 0 0 Slow
0x1f4 24 dc 0 32 0 r y . 8 8 8 8 . . 0 24 0 0 0 0 0 0 0 None
0x1f5 24 dc 0 32 0 r y . 8 8 8 8 . . 0 24 0 16 16 16 16 0 0 Slow
0x1f6 24 dc 0 32 0 r . . 8 8 8 8 . . 0 24 8 0 0 0 0 0 0 None
0x1f7 24 dc 0 32 0 r . . 8 8 8 8 . . 0 24 8 16 16 16 16 0 0 Slow
0x1f8 24 dc 0 32 0 r y . 8 8 8 8 . . 0 24 8 0 0 0 0 0 0 None
0x1f9 24 dc 0 32 0 r y . 8 8 8 8 . . 0 24 8 16 16 16 16 0 0 Slow
0x1fa 24 dc 0 32 0 r y . 8 8 8 8 . . 0 24 8 0 0 0 0 0 0 None
0x1fb 24 dc 0 32 0 r y . 8 8 8 8 . . 0 24 8 16 16 16 16 0 0 Slow
0x1fc 24 dc 0 32 0 r . . 8 8 8 8 . . 0 32 0 0 0 0 0 0 0 None
0x1fd 24 dc 0 32 0 r . . 8 8 8 8 . . 0 32 0 16 16 16 16 0 0 Slow
0x1fe 24 dc 0 32 0 r y . 8 8 8 8 . . 0 32 0 0 0 0 0 0 0 None
0x1ff 24 dc 0 32 0 r y . 8 8 8 8 . . 0 32 0 16 16 16 16 0 0 Slow
0x200 24 dc 0 32 0 r y . 8 8 8 8 . . 0 32 0 0 0 0 0 0 0 None
0x201 24 dc 0 32 0 r y . 8 8 8 8 . . 0 32 0 16 16 16 16 0 0 Slow
0x202 24 dc 0 24 0 r . . 8 8 8 0 . . 0 0 0 0 0 0 0 0 0 None
0x203 24 dc 0 24 0 r . . 8 8 8 0 . . 0 0 0 16 16 16 0 0 0 Slow
0x204 24 dc 0 24 0 r y . 8 8 8 0 . . 0 0 0 0 0 0 0 0 0 None
0x205 24 dc 0 24 0 r y . 8 8 8 0 . . 0 0 0 16 16 16 0 0 0 Slow
0x206 24 dc 0 24 0 r y . 8 8 8 0 . . 0 0 0 0 0 0 0 0 0 None
0x207 24 dc 0 24 0 r y . 8 8 8 0 . . 0 0 0 16 16 16 0 0 0 Slow
0x208 24 dc 0 24 0 r . . 8 8 8 0 . . 0 16 0 0 0 0 0 0 0 None
0x209 24 dc 0 24 0 r . . 8 8 8 0 . . 0 16 0 16 16 16 0 0 0 Slow
0x20a 24 dc 0 24 0 r y . 8 8 8 0 . . 0 16 0 0 0 0 0 0 0 None
0x20b 24 dc 0 24 0 r y . 8 8 8 0 . . 0 16 0 16 16 16 0 0 0 Slow
0x20c 24 dc 0 24 0 r y . 8 8 8 0 . . 0 16 0 0 0 0 0 0 0 None
0x20d 24 dc 0 24 0 r y . 8 8 8 0 . . 0 16 0 16 16 16 0 0 0 Slow
0x20e 24 dc 0 24 0 r . . 8 8 8 0 . . 0 24 0 0 0 0 0 0 0 None
0x20f 24 dc 0 24 0 r . . 8 8 8 0 . . 0 24 0 16 16 16 0 0 0 Slow
0x210 24 dc 0 24 0 r y . 8 8 8 0 . . 0 24 0 0 0 0 0 0 0 None
0x211 24 dc 0 24 0 r y . 8 8 8 0 . . 0 24 0 16 16 16 0 0 0 Slow
0x212 24 dc 0 24 0 r y . 8 8 8 0 . . 0 24 0 0 0 0 0 0 0 None
0x213 24 dc 0 24 0 r y . 8 8 8 0 . . 0 24 0 16 16 16 0 0 0 Slow
0x214 24 dc 0 24 0 r . . 8 8 8 0 . . 0 24 8 0 0 0 0 0 0 None
0x215 24 dc 0 24 0 r . . 8 8 8 0 . . 0 24 8 16 16 16 0 0 0 Slow
0x216 24 dc 0 24 0 r y . 8 8 8 0 . . 0 24 8 0 0 0 0 0 0 None
0x217 24 dc 0 24 0 r y . 8 8 8 0 . . 0 24 8 16 16 16 0 0 0 Slow
0x218 24 dc 0 24 0 r y . 8 8 8 0 . . 0 24 8 0 0 0 0 0 0 None
0x219 24 dc 0 24 0 r y . 8 8 8 0 . . 0 24 8 16 16 16 0 0 0 Slow
0x21a 24 dc 0 24 0 r . . 8 8 8 0 . . 0 32 0 0 0 0 0 0 0 None
0x21b 24 dc 0 24 0 r . . 8 8 8 0 . . 0 32 0 16 16 16 0 0 0 Slow
0x21c 24 dc 0 24 0 r y . 8 8 8 0 . . 0 32 0 0 0 0 0 0 0 None
0x21d 24 dc 0 24 0 r y . 8 8 8 0 . . 0 32 0 16 16 16 0 0 0 Slow
0x21e 24 dc 0 24 0 r y . 8 8 8 0 . . 0 32 0 0 0 0 0 0 0 None
0x21f 24 dc 0 24 0 r y . 8 8 8 0 . . 0 32 0 16 16 16 0 0 0 Slow
0x220 24 dc 0 32 0 r . . 8 8 8 8 . s 0 0 0 0 0 0 0 0 0 None
0x221 24 dc 0 32 0 r . . 8 8 8 8 . s 0 0 0 16 16 16 16 0 0 Slow
0x222 24 dc 0 32 0 r y . 8 8 8 8 . s 0 0 0 0 0 0 0 0 0 None
0x223 24 dc 0 32 0 r y . 8 8 8 8 . s 0 0 0 16 16 16 16 0 0 Slow
0x224 24 dc 0 32 0 r y . 8 8 8 8 . s 0 0 0 0 0 0 0 0 0 None
0x225 24 dc 0 32 0 r y . 8 8 8 8 . s 0 0 0 16 16 16 16 0 0 Slow
0x226 24 dc 0 32 0 r . . 8 8 8 8 . s 0 16 0 0 0 0 0 0 0 None
0x227 24 dc 0 32 0 r . . 8 8 8 8 . s 0 16 0 16 16 16 16 0 0 Slow
0x228 24 dc 0 32 0 r y . 8 8 8 8 . s 0 16 0 0 0 0 0 0 0 None
0x229 24 dc 0 32 0 r y . 8 8 8 8 . s 0 16 0 16 16 16 16 0 0 Slow
0x22a 24 dc 0 32 0 r y . 8 8 8 8 . s 0 16 0 0 0 0 0 0 0 None
0x22b 24 dc 0 32 0 r y . 8 8 8 8 . s 0 16 0 16 16 16 16 0 0 Slow
0x22c 24 dc 0 32 0 r . . 8 8 8 8 . s 0 24 0 0 0 0 0 0 0 None
0x22d 24 dc 0 32 0 r . . 8 8 8 8 . s 0 24 0 16 16 16 16 0 0 Slow
0x22e 24 dc 0 32 0 r y . 8 8 8 8 . s 0 24 0 0 0 0 0 0 0 None
0x22f 24 dc 0 32 0 r y . 8 8 8 8 . s 0 24 0 16 16 16 16 0 0 Slow
0x230 24 dc 0 32 0 r y . 8 8 8 8 . s 0 24 0 0 0 0 0 0 0 None
0x231 24 dc 0 32 0 r y . 8 8 8 8 . s 0 24 0 16 16 16 16 0 0 Slow
0x232 24 dc 0 32 0 r . . 8 8 8 8 . s 0 24 8 0 0 0 0 0 0 None
0x233 24 dc 0 32 0 r . . 8 8 8 8 . s 0 24 8 16 16 16 16 0 0 Slow
0x234 24 dc 0 32 0 r y . 8 8 8 8 . s 0 24 8 0 0 0 0 0 0 None
0x235 24 dc 0 32 0 r y . 8 8 8 8 . s 0 24 8 16 16 16 16 0 0 Slow
0x236 24 dc 0 32 0 r y . 8 8 8 8 . s 0 24 8 0 0 0 0 0 0 None
0x237 24 dc 0 32 0 r y . 8 8 8 8 . s 0 24 8 16 16 16 16 0 0 Slow
0x238 24 dc 0 32 0 r . . 8 8 8 8 . s 0 32 0 0 0 0 0 0 0 None
0x239 24 dc 0 32 0 r . . 8 8 8 8 . s 0 32 0 16 16 16 16 0 0 Slow
0x23a 24 dc 0 32 0 r y . 8 8 8 8 . s 0 32 0 0 0 0 0 0 0 None
0x23b 24 dc 0 32 0 r y . 8 8 8 8 . s 0 32 0 16 16 16 16 0 0 Slow
0x23c 24 dc 0 32 0 r y . 8 8 8 8 . s 0 32 0 0 0 0 0 0 0 None
0x23d 24 dc 0 32 0 r y . 8 8 8 8 . s 0 32 0 16 16 16 16 0 0 Slow
0x23e 24 dc 0 24 0 r . . 8 8 8 0 . s 0 0 0 0 0 0 0 0 0 None
0x23f 24 dc 0 24 0 r . . 8 8 8 0 . s 0 0 0 16 16 16 0 0 0 Slow
0x240 24 dc 0 24 0 r y . 8 8 8 0 . s 0 0 0 0 0 0 0 0 0 None
0x241 24 dc 0 24 0 r y . 8 8 8 0 . s 0 0 0 16 16 16 0 0 0 Slow
0x242 24 dc 0 24 0 r y . 8 8 8 0 . s 0 0 0 0 0 0 0 0 0 None
0x243 24 dc 0 24 0 r y . 8 8 8 0 . s 0 0 0 16 16 16 0 0 0 Slow
0x244 24 dc 0 24 0 r . . 8 8 8 0 . s 0 16 0 0 0 0 0 0 0 None
0x245 24 dc 0 24 0 r . . 8 8 8 0 . s 0 16 0 16 16 16 0 0 0 Slow
0x246 24 dc 0 24 0 r y . 8 8 8 0 . s 0 16 0 0 0 0 0 0 0 None
0x247 24 dc 0 24 0 r y . 8 8 8 0 . s 0 16 0 16 16 16 0 0 0 Slow
0x248 24 dc 0 24 0 r y . 8 8 8 0 . s 0 16 0 0 0 0 0 0 0 None
0x249 24 dc 0 24 0 r y . 8 8 8 0 . s 0 16 0 16 16 16 0 0 0 Slow
0x24a 24 dc 0 24 0 r . . 8 8 8 0 . s 0 24 0 0 0 0 0 0 0 None
0x24b 24 dc 0 24 0 r . . 8 8 8 0 . s 0 24 0 16 16 16 0 0 0 Slow
0x24c 24 dc 0 24 0 r y . 8 8 8 0 . s 0 24 0 0 0 0 0 0 0 None
0x24d 24 dc 0 24 0 r y . 8 8 8 0 . s 0 24 0 16 16 16 0 0 0 Slow
0x24e 24 dc 0 24 0 r y . 8 8 8 0 . s 0 24 0 0 0 0 0 0 0 None
0x24f 24 dc 0 24 0 r y . 8 8 8 0 . s 0 24 0 16 16 16 0 0 0 Slow
0x250 24 dc 0 24 0 r . . 8 8 8 0 . s 0 24 8 0 0 0 0 0 0 None
0x251 24 dc 0 24 0 r . . 8 8 8 0 . s 0 24 8 16 16 16 0 0 0 Slow
0x252 24 dc 0 24 0 r y . 8 8 8 0 . s 0 24 8 0 0 0 0 0 0 None
0x253 24 dc 0 24 0 r y . 8 8 8 0 . s 0 24 8 16 16 16 0 0 0 Slow
0x254 24 dc 0 24 0 r y . 8 8 8 0 . s 0 24 8 0 0 0 0 0 0 None
0x255 24 dc 0 24 0 r y . 8 8 8 0 . s 0 24 8 16 16 16 0 0 0 Slow
0x256 24 dc 0 24 0 r . . 8 8 8 0 . s 0 32 0 0 0 0 0 0 0 None
0x257 24 dc 0 24 0 r . . 8 8 8 0 . s 0 32 0 16 16 16 0 0 0 Slow
0x258 24 dc 0 24 0 r y . 8 8 8 0 . s 0 32 0 0 0 0 0 0 0 None
0x259 24 dc 0 24 0 r y . 8 8 8 0 . s 0 32 0 16 16 16 0 0 0 Slow
0x25a 24 dc 0 24 0 r y . 8 8 8 0 . s 0 32 0 0 0 0 0 0 0 None
0x25b 24 dc 0 24 0 r y . 8 8 8 0 . s 0 32 0 16 16 16 0 0 0 Slow
0x041 32 tc 0 32 0 r y . 8 8 8 8 . . 0 24 8 0 0 0 0 0 0 None
300 GLXFBConfigs:
0x042 24 tc 0 32 0 r . . 8 8 8 8 . . 0 0 0 0 0 0 0 0 0 None
0x043 24 tc 0 32 0 r . . 8 8 8 8 . . 0 0 0 16 16 16 16 0 0 Slow
0x044 24 tc 0 32 0 r y . 8 8 8 8 . . 0 0 0 0 0 0 0 0 0 None
0x045 24 tc 0 32 0 r y . 8 8 8 8 . . 0 0 0 16 16 16 16 0 0 Slow
0x046 24 tc 0 32 0 r y . 8 8 8 8 . . 0 0 0 0 0 0 0 0 0 None
0x047 24 tc 0 32 0 r y . 8 8 8 8 . . 0 0 0 16 16 16 16 0 0 Slow
0x048 24 tc 0 32 0 r . . 8 8 8 8 . . 0 16 0 0 0 0 0 0 0 None
0x049 24 tc 0 32 0 r . . 8 8 8 8 . . 0 16 0 16 16 16 16 0 0 Slow
0x04a 24 tc 0 32 0 r y . 8 8 8 8 . . 0 16 0 0 0 0 0 0 0 None
0x04b 24 tc 0 32 0 r y . 8 8 8 8 . . 0 16 0 16 16 16 16 0 0 Slow
0x04c 24 tc 0 32 0 r y . 8 8 8 8 . . 0 16 0 0 0 0 0 0 0 None
0x04d 24 tc 0 32 0 r y . 8 8 8 8 . . 0 16 0 16 16 16 16 0 0 Slow
0x04e 24 tc 0 32 0 r . . 8 8 8 8 . . 0 24 0 0 0 0 0 0 0 None
0x04f 24 tc 0 32 0 r . . 8 8 8 8 . . 0 24 0 16 16 16 16 0 0 Slow
0x050 24 tc 0 32 0 r y . 8 8 8 8 . . 0 24 0 0 0 0 0 0 0 None
0x051 24 tc 0 32 0 r y . 8 8 8 8 . . 0 24 0 16 16 16 16 0 0 Slow
0x052 24 tc 0 32 0 r y . 8 8 8 8 . . 0 24 0 0 0 0 0 0 0 None
0x053 24 tc 0 32 0 r y . 8 8 8 8 . . 0 24 0 16 16 16 16 0 0 Slow
0x054 24 tc 0 32 0 r . . 8 8 8 8 . . 0 24 8 0 0 0 0 0 0 None
0x055 24 tc 0 32 0 r . . 8 8 8 8 . . 0 24 8 16 16 16 16 0 0 Slow
0x056 24 tc 0 32 0 r y . 8 8 8 8 . . 0 24 8 0 0 0 0 0 0 None
0x057 24 tc 0 32 0 r y . 8 8 8 8 . . 0 24 8 16 16 16 16 0 0 Slow
0x058 32 tc 0 32 0 r y . 8 8 8 8 . . 0 24 8 0 0 0 0 0 0 None
0x059 24 tc 0 32 0 r y . 8 8 8 8 . . 0 24 8 16 16 16 16 0 0 Slow
0x05a 24 tc 0 32 0 r . . 8 8 8 8 . . 0 32 0 0 0 0 0 0 0 None
0x05b 24 tc 0 32 0 r . . 8 8 8 8 . . 0 32 0 16 16 16 16 0 0 Slow
0x05c 24 tc 0 32 0 r y . 8 8 8 8 . . 0 32 0 0 0 0 0 0 0 None
0x05d 24 tc 0 32 0 r y . 8 8 8 8 . . 0 32 0 16 16 16 16 0 0 Slow
0x05e 24 tc 0 32 0 r y . 8 8 8 8 . . 0 32 0 0 0 0 0 0 0 None
0x05f 24 tc 0 32 0 r y . 8 8 8 8 . . 0 32 0 16 16 16 16 0 0 Slow
0x060 24 tc 0 24 0 r . . 8 8 8 0 . . 0 0 0 0 0 0 0 0 0 None
0x061 24 tc 0 24 0 r . . 8 8 8 0 . . 0 0 0 16 16 16 0 0 0 Slow
0x062 24 tc 0 24 0 r y . 8 8 8 0 . . 0 0 0 0 0 0 0 0 0 None
0x063 24 tc 0 24 0 r y . 8 8 8 0 . . 0 0 0 16 16 16 0 0 0 Slow
0x064 24 tc 0 24 0 r y . 8 8 8 0 . . 0 0 0 0 0 0 0 0 0 None
0x065 24 tc 0 24 0 r y . 8 8 8 0 . . 0 0 0 16 16 16 0 0 0 Slow
0x066 24 tc 0 24 0 r . . 8 8 8 0 . . 0 16 0 0 0 0 0 0 0 None
0x067 24 tc 0 24 0 r . . 8 8 8 0 . . 0 16 0 16 16 16 0 0 0 Slow
0x068 24 tc 0 24 0 r y . 8 8 8 0 . . 0 16 0 0 0 0 0 0 0 None
0x069 24 tc 0 24 0 r y . 8 8 8 0 . . 0 16 0 16 16 16 0 0 0 Slow
0x06a 24 tc 0 24 0 r y . 8 8 8 0 . . 0 16 0 0 0 0 0 0 0 None
0x06b 24 tc 0 24 0 r y . 8 8 8 0 . . 0 16 0 16 16 16 0 0 0 Slow
0x06c 24 tc 0 24 0 r . . 8 8 8 0 . . 0 24 0 0 0 0 0 0 0 None
0x06d 24 tc 0 24 0 r . . 8 8 8 0 . . 0 24 0 16 16 16 0 0 0 Slow
0x06e 24 tc 0 24 0 r y . 8 8 8 0 . . 0 24 0 0 0 0 0 0 0 None
0x06f 24 tc 0 24 0 r y . 8 8 8 0 . . 0 24 0 16 16 16 0 0 0 Slow
0x070 24 tc 0 24 0 r y . 8 8 8 0 . . 0 24 0 0 0 0 0 0 0 None
0x071 24 tc 0 24 0 r y . 8 8 8 0 . . 0 24 0 16 16 16 0 0 0 Slow
0x072 24 tc 0 24 0 r . . 8 8 8 0 . . 0 24 8 0 0 0 0 0 0 None
0x073 24 tc 0 24 0 r . . 8 8 8 0 . . 0 24 8 16 16 16 0 0 0 Slow
0x074 24 tc 0 24 0 r y . 8 8 8 0 . . 0 24 8 0 0 0 0 0 0 None
0x075 24 tc 0 24 0 r y . 8 8 8 0 . . 0 24 8 16 16 16 0 0 0 Slow
0x076 24 tc 0 24 0 r y . 8 8 8 0 . . 0 24 8 0 0 0 0 0 0 None
0x077 24 tc 0 24 0 r y . 8 8 8 0 . . 0 24 8 16 16 16 0 0 0 Slow
0x078 24 tc 0 24 0 r . . 8 8 8 0 . . 0 32 0 0 0 0 0 0 0 None
0x079 24 tc 0 24 0 r . . 8 8 8 0 . . 0 32 0 16 16 16 0 0 0 Slow
0x07a 24 tc 0 24 0 r y . 8 8 8 0 . . 0 32 0 0 0 0 0 0 0 None
0x07b 24 tc 0 24 0 r y . 8 8 8 0 . . 0 32 0 16 16 16 0 0 0 Slow
0x07c 24 tc 0 24 0 r y . 8 8 8 0 . . 0 32 0 0 0 0 0 0 0 None
0x07d 24 tc 0 24 0 r y . 8 8 8 0 . . 0 32 0 16 16 16 0 0 0 Slow
0x07e 24 tc 0 32 0 r . . 8 8 8 8 . s 0 0 0 0 0 0 0 0 0 None
0x07f 24 tc 0 32 0 r . . 8 8 8 8 . s 0 0 0 16 16 16 16 0 0 Slow
0x080 24 tc 0 32 0 r y . 8 8 8 8 . s 0 0 0 0 0 0 0 0 0 None
0x081 24 tc 0 32 0 r y . 8 8 8 8 . s 0 0 0 16 16 16 16 0 0 Slow
0x082 24 tc 0 32 0 r y . 8 8 8 8 . s 0 0 0 0 0 0 0 0 0 None
0x083 24 tc 0 32 0 r y . 8 8 8 8 . s 0 0 0 16 16 16 16 0 0 Slow
0x084 24 tc 0 32 0 r . . 8 8 8 8 . s 0 16 0 0 0 0 0 0 0 None
0x085 24 tc 0 32 0 r . . 8 8 8 8 . s 0 16 0 16 16 16 16 0 0 Slow
0x086 24 tc 0 32 0 r y . 8 8 8 8 . s 0 16 0 0 0 0 0 0 0 None
0x087 24 tc 0 32 0 r y . 8 8 8 8 . s 0 16 0 16 16 16 16 0 0 Slow
0x088 24 tc 0 32 0 r y . 8 8 8 8 . s 0 16 0 0 0 0 0 0 0 None
0x089 24 tc 0 32 0 r y . 8 8 8 8 . s 0 16 0 16 16 16 16 0 0 Slow
0x08a 24 tc 0 32 0 r . . 8 8 8 8 . s 0 24 0 0 0 0 0 0 0 None
0x08b 24 tc 0 32 0 r . . 8 8 8 8 . s 0 24 0 16 16 16 16 0 0 Slow
0x08c 24 tc 0 32 0 r y . 8 8 8 8 . s 0 24 0 0 0 0 0 0 0 None
0x08d 24 tc 0 32 0 r y . 8 8 8 8 . s 0 24 0 16 16 16 16 0 0 Slow
0x08e 24 tc 0 32 0 r y . 8 8 8 8 . s 0 24 0 0 0 0 0 0 0 None
0x08f 24 tc 0 32 0 r y . 8 8 8 8 . s 0 24 0 16 16 16 16 0 0 Slow
0x090 24 tc 0 32 0 r . . 8 8 8 8 . s 0 24 8 0 0 0 0 0 0 None
0x091 24 tc 0 32 0 r . . 8 8 8 8 . s 0 24 8 16 16 16 16 0 0 Slow
0x092 24 tc 0 32 0 r y . 8 8 8 8 . s 0 24 8 0 0 0 0 0 0 None
0x093 24 tc 0 32 0 r y . 8 8 8 8 . s 0 24 8 16 16 16 16 0 0 Slow
0x094 24 tc 0 32 0 r y . 8 8 8 8 . s 0 24 8 0 0 0 0 0 0 None
0x095 24 tc 0 32 0 r y . 8 8 8 8 . s 0 24 8 16 16 16 16 0 0 Slow
0x096 24 tc 0 32 0 r . . 8 8 8 8 . s 0 32 0 0 0 0 0 0 0 None
0x097 24 tc 0 32 0 r . . 8 8 8 8 . s 0 32 0 16 16 16 16 0 0 Slow
0x098 24 tc 0 32 0 r y . 8 8 8 8 . s 0 32 0 0 0 0 0 0 0 None
0x099 24 tc 0 32 0 r y . 8 8 8 8 . s 0 32 0 16 16 16 16 0 0 Slow
0x09a 24 tc 0 32 0 r y . 8 8 8 8 . s 0 32 0 0 0 0 0 0 0 None
0x09b 24 tc 0 32 0 r y . 8 8 8 8 . s 0 32 0 16 16 16 16 0 0 Slow
0x09c 24 tc 0 24 0 r . . 8 8 8 0 . s 0 0 0 0 0 0 0 0 0 None
0x09d 24 tc 0 24 0 r . . 8 8 8 0 . s 0 0 0 16 16 16 0 0 0 Slow
0x09e 24 tc 0 24 0 r y . 8 8 8 0 . s 0 0 0 0 0 0 0 0 0 None
0x09f 24 tc 0 24 0 r y . 8 8 8 0 . s 0 0 0 16 16 16 0 0 0 Slow
0x0a0 24 tc 0 24 0 r y . 8 8 8 0 . s 0 0 0 0 0 0 0 0 0 None
0x0a1 24 tc 0 24 0 r y . 8 8 8 0 . s 0 0 0 16 16 16 0 0 0 Slow
0x0a2 24 tc 0 24 0 r . . 8 8 8 0 . s 0 16 0 0 0 0 0 0 0 None
0x0a3 24 tc 0 24 0 r . . 8 8 8 0 . s 0 16 0 16 16 16 0 0 0 Slow
0x0a4 24 tc 0 24 0 r y . 8 8 8 0 . s 0 16 0 0 0 0 0 0 0 None
0x0a5 24 tc 0 24 0 r y . 8 8 8 0 . s 0 16 0 16 16 16 0 0 0 Slow
0x0a6 24 tc 0 24 0 r y . 8 8 8 0 . s 0 16 0 0 0 0 0 0 0 None
0x0a7 24 tc 0 24 0 r y . 8 8 8 0 . s 0 16 0 16 16 16 0 0 0 Slow
0x0a8 24 tc 0 24 0 r . . 8 8 8 0 . s 0 24 0 0 0 0 0 0 0 None
0x0a9 24 tc 0 24 0 r . . 8 8 8 0 . s 0 24 0 16 16 16 0 0 0 Slow
0x0aa 24 tc 0 24 0 r y . 8 8 8 0 . s 0 24 0 0 0 0 0 0 0 None
0x0ab 24 tc 0 24 0 r y . 8 8 8 0 . s 0 24 0 16 16 16 0 0 0 Slow
0x0ac 24 tc 0 24 0 r y . 8 8 8 0 . s 0 24 0 0 0 0 0 0 0 None
0x0ad 24 tc 0 24 0 r y . 8 8 8 0 . s 0 24 0 16 16 16 0 0 0 Slow
0x0ae 24 tc 0 24 0 r . . 8 8 8 0 . s 0 24 8 0 0 0 0 0 0 None
0x0af 24 tc 0 24 0 r . . 8 8 8 0 . s 0 24 8 16 16 16 0 0 0 Slow
0x0b0 24 tc 0 24 0 r y . 8 8 8 0 . s 0 24 8 0 0 0 0 0 0 None
0x0b1 24 tc 0 24 0 r y . 8 8 8 0 . s 0 24 8 16 16 16 0 0 0 Slow
0x0b2 24 tc 0 24 0 r y . 8 8 8 0 . s 0 24 8 0 0 0 0 0 0 None
0x0b3 24 tc 0 24 0 r y . 8 8 8 0 . s 0 24 8 16 16 16 0 0 0 Slow
0x0b4 24 tc 0 24 0 r . . 8 8 8 0 . s 0 32 0 0 0 0 0 0 0 None
0x0b5 24 tc 0 24 0 r . . 8 8 8 0 . s 0 32 0 16 16 16 0 0 0 Slow
0x0b6 24 tc 0 24 0 r y . 8 8 8 0 . s 0 32 0 0 0 0 0 0 0 None
0x0b7 24 tc 0 24 0 r y . 8 8 8 0 . s 0 32 0 16 16 16 0 0 0 Slow
0x0b8 24 tc 0 24 0 r y . 8 8 8 0 . s 0 32 0 0 0 0 0 0 0 None
0x0b9 24 tc 0 24 0 r y . 8 8 8 0 . s 0 32 0 16 16 16 0 0 0 Slow
0x0ba 0 tc 0 16 0 r . . 5 6 5 0 . . 0 0 0 0 0 0 0 0 0 None
0x0bb 0 tc 0 16 0 r . . 5 6 5 0 . . 0 0 0 16 16 16 0 0 0 Slow
0x0bc 0 tc 0 16 0 r y . 5 6 5 0 . . 0 0 0 0 0 0 0 0 0 None
0x0bd 0 tc 0 16 0 r y . 5 6 5 0 . . 0 0 0 16 16 16 0 0 0 Slow
0x0be 0 tc 0 16 0 r y . 5 6 5 0 . . 0 0 0 0 0 0 0 0 0 None
0x0bf 0 tc 0 16 0 r y . 5 6 5 0 . . 0 0 0 16 16 16 0 0 0 Slow
0x0c0 0 tc 0 16 0 r . . 5 6 5 0 . . 0 16 0 0 0 0 0 0 0 None
0x0c1 0 tc 0 16 0 r . . 5 6 5 0 . . 0 16 0 16 16 16 0 0 0 Slow
0x0c2 0 tc 0 16 0 r y . 5 6 5 0 . . 0 16 0 0 0 0 0 0 0 None
0x0c3 0 tc 0 16 0 r y . 5 6 5 0 . . 0 16 0 16 16 16 0 0 0 Slow
0x0c4 0 tc 0 16 0 r y . 5 6 5 0 . . 0 16 0 0 0 0 0 0 0 None
0x0c5 0 tc 0 16 0 r y . 5 6 5 0 . . 0 16 0 16 16 16 0 0 0 Slow
0x0c6 0 tc 0 16 0 r . . 5 6 5 0 . . 0 24 0 0 0 0 0 0 0 None
0x0c7 0 tc 0 16 0 r . . 5 6 5 0 . . 0 24 0 16 16 16 0 0 0 Slow
0x0c8 0 tc 0 16 0 r y . 5 6 5 0 . . 0 24 0 0 0 0 0 0 0 None
0x0c9 0 tc 0 16 0 r y . 5 6 5 0 . . 0 24 0 16 16 16 0 0 0 Slow
0x0ca 0 tc 0 16 0 r y . 5 6 5 0 . . 0 24 0 0 0 0 0 0 0 None
0x0cb 0 tc 0 16 0 r y . 5 6 5 0 . . 0 24 0 16 16 16 0 0 0 Slow
0x0cc 0 tc 0 16 0 r . . 5 6 5 0 . . 0 24 8 0 0 0 0 0 0 None
0x0cd 0 tc 0 16 0 r . . 5 6 5 0 . . 0 24 8 16 16 16 0 0 0 Slow
0x0ce 0 tc 0 16 0 r y . 5 6 5 0 . . 0 24 8 0 0 0 0 0 0 None
0x0cf 0 tc 0 16 0 r y . 5 6 5 0 . . 0 24 8 16 16 16 0 0 0 Slow
0x0d0 0 tc 0 16 0 r y . 5 6 5 0 . . 0 24 8 0 0 0 0 0 0 None
0x0d1 0 tc 0 16 0 r y . 5 6 5 0 . . 0 24 8 16 16 16 0 0 0 Slow
0x0d2 0 tc 0 16 0 r . . 5 6 5 0 . . 0 32 0 0 0 0 0 0 0 None
0x0d3 0 tc 0 16 0 r . . 5 6 5 0 . . 0 32 0 16 16 16 0 0 0 Slow
0x0d4 0 tc 0 16 0 r y . 5 6 5 0 . . 0 32 0 0 0 0 0 0 0 None
0x0d5 0 tc 0 16 0 r y . 5 6 5 0 . . 0 32 0 16 16 16 0 0 0 Slow
0x0d6 0 tc 0 16 0 r y . 5 6 5 0 . . 0 32 0 0 0 0 0 0 0 None
0x0d7 0 tc 0 16 0 r y . 5 6 5 0 . . 0 32 0 16 16 16 0 0 0 Slow
0x0d8 24 dc 0 32 0 r . . 8 8 8 8 . . 0 0 0 0 0 0 0 0 0 None
0x0d9 24 dc 0 32 0 r . . 8 8 8 8 . . 0 0 0 16 16 16 16 0 0 Slow
0x0da 24 dc 0 32 0 r y . 8 8 8 8 . . 0 0 0 0 0 0 0 0 0 None
0x0db 24 dc 0 32 0 r y . 8 8 8 8 . . 0 0 0 16 16 16 16 0 0 Slow
0x0dc 24 dc 0 32 0 r y . 8 8 8 8 . . 0 0 0 0 0 0 0 0 0 None
0x0dd 24 dc 0 32 0 r y . 8 8 8 8 . . 0 0 0 16 16 16 16 0 0 Slow
0x0de 24 dc 0 32 0 r . . 8 8 8 8 . . 0 16 0 0 0 0 0 0 0 None
0x0df 24 dc 0 32 0 r . . 8 8 8 8 . . 0 16 0 16 16 16 16 0 0 Slow
0x0e0 24 dc 0 32 0 r y . 8 8 8 8 . . 0 16 0 0 0 0 0 0 0 None
0x0e1 24 dc 0 32 0 r y . 8 8 8 8 . . 0 16 0 16 16 16 16 0 0 Slow
0x0e2 24 dc 0 32 0 r y . 8 8 8 8 . . 0 16 0 0 0 0 0 0 0 None
0x0e3 24 dc 0 32 0 r y . 8 8 8 8 . . 0 16 0 16 16 16 16 0 0 Slow
0x0e4 24 dc 0 32 0 r . . 8 8 8 8 . . 0 24 0 0 0 0 0 0 0 None
0x0e5 24 dc 0 32 0 r . . 8 8 8 8 . . 0 24 0 16 16 16 16 0 0 Slow
0x0e6 24 dc 0 32 0 r y . 8 8 8 8 . . 0 24 0 0 0 0 0 0 0 None
0x0e7 24 dc 0 32 0 r y . 8 8 8 8 . . 0 24 0 16 16 16 16 0 0 Slow
0x0e8 24 dc 0 32 0 r y . 8 8 8 8 . . 0 24 0 0 0 0 0 0 0 None
0x0e9 24 dc 0 32 0 r y . 8 8 8 8 . . 0 24 0 16 16 16 16 0 0 Slow
0x0ea 24 dc 0 32 0 r . . 8 8 8 8 . . 0 24 8 0 0 0 0 0 0 None
0x0eb 24 dc 0 32 0 r . . 8 8 8 8 . . 0 24 8 16 16 16 16 0 0 Slow
0x0ec 24 dc 0 32 0 r y . 8 8 8 8 . . 0 24 8 0 0 0 0 0 0 None
0x0ed 24 dc 0 32 0 r y . 8 8 8 8 . . 0 24 8 16 16 16 16 0 0 Slow
0x0ee 24 dc 0 32 0 r y . 8 8 8 8 . . 0 24 8 0 0 0 0 0 0 None
0x0ef 24 dc 0 32 0 r y . 8 8 8 8 . . 0 24 8 16 16 16 16 0 0 Slow
0x0f0 24 dc 0 32 0 r . . 8 8 8 8 . . 0 32 0 0 0 0 0 0 0 None
0x0f1 24 dc 0 32 0 r . . 8 8 8 8 . . 0 32 0 16 16 16 16 0 0 Slow
0x0f2 24 dc 0 32 0 r y . 8 8 8 8 . . 0 32 0 0 0 0 0 0 0 None
0x0f3 24 dc 0 32 0 r y . 8 8 8 8 . . 0 32 0 16 16 16 16 0 0 Slow
0x0f4 24 dc 0 32 0 r y . 8 8 8 8 . . 0 32 0 0 0 0 0 0 0 None
0x0f5 24 dc 0 32 0 r y . 8 8 8 8 . . 0 32 0 16 16 16 16 0 0 Slow
0x0f6 24 dc 0 24 0 r . . 8 8 8 0 . . 0 0 0 0 0 0 0 0 0 None
0x0f7 24 dc 0 24 0 r . . 8 8 8 0 . . 0 0 0 16 16 16 0 0 0 Slow
0x0f8 24 dc 0 24 0 r y . 8 8 8 0 . . 0 0 0 0 0 0 0 0 0 None
0x0f9 24 dc 0 24 0 r y . 8 8 8 0 . . 0 0 0 16 16 16 0 0 0 Slow
0x0fa 24 dc 0 24 0 r y . 8 8 8 0 . . 0 0 0 0 0 0 0 0 0 None
0x0fb 24 dc 0 24 0 r y . 8 8 8 0 . . 0 0 0 16 16 16 0 0 0 Slow
0x0fc 24 dc 0 24 0 r . . 8 8 8 0 . . 0 16 0 0 0 0 0 0 0 None
0x0fd 24 dc 0 24 0 r . . 8 8 8 0 . . 0 16 0 16 16 16 0 0 0 Slow
0x0fe 24 dc 0 24 0 r y . 8 8 8 0 . . 0 16 0 0 0 0 0 0 0 None
0x0ff 24 dc 0 24 0 r y . 8 8 8 0 . . 0 16 0 16 16 16 0 0 0 Slow
0x100 24 dc 0 24 0 r y . 8 8 8 0 . . 0 16 0 0 0 0 0 0 0 None
0x101 24 dc 0 24 0 r y . 8 8 8 0 . . 0 16 0 16 16 16 0 0 0 Slow
0x102 24 dc 0 24 0 r . . 8 8 8 0 . . 0 24 0 0 0 0 0 0 0 None
0x103 24 dc 0 24 0 r . . 8 8 8 0 . . 0 24 0 16 16 16 0 0 0 Slow
0x104 24 dc 0 24 0 r y . 8 8 8 0 . . 0 24 0 0 0 0 0 0 0 None
0x105 24 dc 0 24 0 r y . 8 8 8 0 . . 0 24 0 16 16 16 0 0 0 Slow
0x106 24 dc 0 24 0 r y . 8 8 8 0 . . 0 24 0 0 0 0 0 0 0 None
0x107 24 dc 0 24 0 r y . 8 8 8 0 . . 0 24 0 16 16 16 0 0 0 Slow
0x108 24 dc 0 24 0 r . . 8 8 8 0 . . 0 24 8 0 0 0 0 0 0 None
0x109 24 dc 0 24 0 r . . 8 8 8 0 . . 0 24 8 16 16 16 0 0 0 Slow
0x10a 24 dc 0 24 0 r y . 8 8 8 0 . . 0 24 8 0 0 0 0 0 0 None
0x10b 24 dc 0 24 0 r y . 8 8 8 0 . . 0 24 8 16 16 16 0 0 0 Slow
0x10c 24 dc 0 24 0 r y . 8 8 8 0 . . 0 24 8 0 0 0 0 0 0 None
0x10d 24 dc 0 24 0 r y . 8 8 8 0 . . 0 24 8 16 16 16 0 0 0 Slow
0x10e 24 dc 0 24 0 r . . 8 8 8 0 . . 0 32 0 0 0 0 0 0 0 None
0x10f 24 dc 0 24 0 r . . 8 8 8 0 . . 0 32 0 16 16 16 0 0 0 Slow
0x110 24 dc 0 24 0 r y . 8 8 8 0 . . 0 32 0 0 0 0 0 0 0 None
0x111 24 dc 0 24 0 r y . 8 8 8 0 . . 0 32 0 16 16 16 0 0 0 Slow
0x112 24 dc 0 24 0 r y . 8 8 8 0 . . 0 32 0 0 0 0 0 0 0 None
0x113 24 dc 0 24 0 r y . 8 8 8 0 . . 0 32 0 16 16 16 0 0 0 Slow
0x114 24 dc 0 32 0 r . . 8 8 8 8 . s 0 0 0 0 0 0 0 0 0 None
0x115 24 dc 0 32 0 r . . 8 8 8 8 . s 0 0 0 16 16 16 16 0 0 Slow
0x116 24 dc 0 32 0 r y . 8 8 8 8 . s 0 0 0 0 0 0 0 0 0 None
0x117 24 dc 0 32 0 r y . 8 8 8 8 . s 0 0 0 16 16 16 16 0 0 Slow
0x118 24 dc 0 32 0 r y . 8 8 8 8 . s 0 0 0 0 0 0 0 0 0 None
0x119 24 dc 0 32 0 r y . 8 8 8 8 . s 0 0 0 16 16 16 16 0 0 Slow
0x11a 24 dc 0 32 0 r . . 8 8 8 8 . s 0 16 0 0 0 0 0 0 0 None
0x11b 24 dc 0 32 0 r . . 8 8 8 8 . s 0 16 0 16 16 16 16 0 0 Slow
0x11c 24 dc 0 32 0 r y . 8 8 8 8 . s 0 16 0 0 0 0 0 0 0 None
0x11d 24 dc 0 32 0 r y . 8 8 8 8 . s 0 16 0 16 16 16 16 0 0 Slow
0x11e 24 dc 0 32 0 r y . 8 8 8 8 . s 0 16 0 0 0 0 0 0 0 None
0x11f 24 dc 0 32 0 r y . 8 8 8 8 . s 0 16 0 16 16 16 16 0 0 Slow
0x120 24 dc 0 32 0 r . . 8 8 8 8 . s 0 24 0 0 0 0 0 0 0 None
0x121 24 dc 0 32 0 r . . 8 8 8 8 . s 0 24 0 16 16 16 16 0 0 Slow
0x122 24 dc 0 32 0 r y . 8 8 8 8 . s 0 24 0 0 0 0 0 0 0 None
0x123 24 dc 0 32 0 r y . 8 8 8 8 . s 0 24 0 16 16 16 16 0 0 Slow
0x124 24 dc 0 32 0 r y . 8 8 8 8 . s 0 24 0 0 0 0 0 0 0 None
0x125 24 dc 0 32 0 r y . 8 8 8 8 . s 0 24 0 16 16 16 16 0 0 Slow
0x126 24 dc 0 32 0 r . . 8 8 8 8 . s 0 24 8 0 0 0 0 0 0 None
0x127 24 dc 0 32 0 r . . 8 8 8 8 . s 0 24 8 16 16 16 16 0 0 Slow
0x128 24 dc 0 32 0 r y . 8 8 8 8 . s 0 24 8 0 0 0 0 0 0 None
0x129 24 dc 0 32 0 r y . 8 8 8 8 . s 0 24 8 16 16 16 16 0 0 Slow
0x12a 24 dc 0 32 0 r y . 8 8 8 8 . s 0 24 8 0 0 0 0 0 0 None
0x12b 24 dc 0 32 0 r y . 8 8 8 8 . s 0 24 8 16 16 16 16 0 0 Slow
0x12c 24 dc 0 32 0 r . . 8 8 8 8 . s 0 32 0 0 0 0 0 0 0 None
0x12d 24 dc 0 32 0 r . . 8 8 8 8 . s 0 32 0 16 16 16 16 0 0 Slow
0x12e 24 dc 0 32 0 r y . 8 8 8 8 . s 0 32 0 0 0 0 0 0 0 None
0x12f 24 dc 0 32 0 r y . 8 8 8 8 . s 0 32 0 16 16 16 16 0 0 Slow
0x130 24 dc 0 32 0 r y . 8 8 8 8 . s 0 32 0 0 0 0 0 0 0 None
0x131 24 dc 0 32 0 r y . 8 8 8 8 . s 0 32 0 16 16 16 16 0 0 Slow
0x132 24 dc 0 24 0 r . . 8 8 8 0 . s 0 0 0 0 0 0 0 0 0 None
0x133 24 dc 0 24 0 r . . 8 8 8 0 . s 0 0 0 16 16 16 0 0 0 Slow
0x134 24 dc 0 24 0 r y . 8 8 8 0 . s 0 0 0 0 0 0 0 0 0 None
0x135 24 dc 0 24 0 r y . 8 8 8 0 . s 0 0 0 16 16 16 0 0 0 Slow
0x136 24 dc 0 24 0 r y . 8 8 8 0 . s 0 0 0 0 0 0 0 0 0 None
0x137 24 dc 0 24 0 r y . 8 8 8 0 . s 0 0 0 16 16 16 0 0 0 Slow
0x138 24 dc 0 24 0 r . . 8 8 8 0 . s 0 16 0 0 0 0 0 0 0 None
0x139 24 dc 0 24 0 r . . 8 8 8 0 . s 0 16 0 16 16 16 0 0 0 Slow
0x13a 24 dc 0 24 0 r y . 8 8 8 0 . s 0 16 0 0 0 0 0 0 0 None
0x13b 24 dc 0 24 0 r y . 8 8 8 0 . s 0 16 0 16 16 16 0 0 0 Slow
0x13c 24 dc 0 24 0 r y . 8 8 8 0 . s 0 16 0 0 0 0 0 0 0 None
0x13d 24 dc 0 24 0 r y . 8 8 8 0 . s 0 16 0 16 16 16 0 0 0 Slow
0x13e 24 dc 0 24 0 r . . 8 8 8 0 . s 0 24 0 0 0 0 0 0 0 None
0x13f 24 dc 0 24 0 r . . 8 8 8 0 . s 0 24 0 16 16 16 0 0 0 Slow
0x140 24 dc 0 24 0 r y . 8 8 8 0 . s 0 24 0 0 0 0 0 0 0 None
0x141 24 dc 0 24 0 r y . 8 8 8 0 . s 0 24 0 16 16 16 0 0 0 Slow
0x142 24 dc 0 24 0 r y . 8 8 8 0 . s 0 24 0 0 0 0 0 0 0 None
0x143 24 dc 0 24 0 r y . 8 8 8 0 . s 0 24 0 16 16 16 0 0 0 Slow
0x144 24 dc 0 24 0 r . . 8 8 8 0 . s 0 24 8 0 0 0 0 0 0 None
0x145 24 dc 0 24 0 r . . 8 8 8 0 . s 0 24 8 16 16 16 0 0 0 Slow
0x146 24 dc 0 24 0 r y . 8 8 8 0 . s 0 24 8 0 0 0 0 0 0 None
0x147 24 dc 0 24 0 r y . 8 8 8 0 . s 0 24 8 16 16 16 0 0 0 Slow
0x148 24 dc 0 24 0 r y . 8 8 8 0 . s 0 24 8 0 0 0 0 0 0 None
0x149 24 dc 0 24 0 r y . 8 8 8 0 . s 0 24 8 16 16 16 0 0 0 Slow
0x14a 24 dc 0 24 0 r . . 8 8 8 0 . s 0 32 0 0 0 0 0 0 0 None
0x14b 24 dc 0 24 0 r . . 8 8 8 0 . s 0 32 0 16 16 16 0 0 0 Slow
0x14c 24 dc 0 24 0 r y . 8 8 8 0 . s 0 32 0 0 0 0 0 0 0 None
0x14d 24 dc 0 24 0 r y . 8 8 8 0 . s 0 32 0 16 16 16 0 0 0 Slow
0x14e 24 dc 0 24 0 r y . 8 8 8 0 . s 0 32 0 0 0 0 0 0 0 None
0x14f 24 dc 0 24 0 r y . 8 8 8 0 . s 0 32 0 16 16 16 0 0 0 Slow
0x150 0 dc 0 16 0 r . . 5 6 5 0 . . 0 0 0 0 0 0 0 0 0 None
0x151 0 dc 0 16 0 r . . 5 6 5 0 . . 0 0 0 16 16 16 0 0 0 Slow
0x152 0 dc 0 16 0 r y . 5 6 5 0 . . 0 0 0 0 0 0 0 0 0 None
0x153 0 dc 0 16 0 r y . 5 6 5 0 . . 0 0 0 16 16 16 0 0 0 Slow
0x154 0 dc 0 16 0 r y . 5 6 5 0 . . 0 0 0 0 0 0 0 0 0 None
0x155 0 dc 0 16 0 r y . 5 6 5 0 . . 0 0 0 16 16 16 0 0 0 Slow
0x156 0 dc 0 16 0 r . . 5 6 5 0 . . 0 16 0 0 0 0 0 0 0 None
0x157 0 dc 0 16 0 r . . 5 6 5 0 . . 0 16 0 16 16 16 0 0 0 Slow
0x158 0 dc 0 16 0 r y . 5 6 5 0 . . 0 16 0 0 0 0 0 0 0 None
0x159 0 dc 0 16 0 r y . 5 6 5 0 . . 0 16 0 16 16 16 0 0 0 Slow
0x15a 0 dc 0 16 0 r y . 5 6 5 0 . . 0 16 0 0 0 0 0 0 0 None
0x15b 0 dc 0 16 0 r y . 5 6 5 0 . . 0 16 0 16 16 16 0 0 0 Slow
0x15c 0 dc 0 16 0 r . . 5 6 5 0 . . 0 24 0 0 0 0 0 0 0 None
0x15d 0 dc 0 16 0 r . . 5 6 5 0 . . 0 24 0 16 16 16 0 0 0 Slow
0x15e 0 dc 0 16 0 r y . 5 6 5 0 . . 0 24 0 0 0 0 0 0 0 None
0x15f 0 dc 0 16 0 r y . 5 6 5 0 . . 0 24 0 16 16 16 0 0 0 Slow
0x160 0 dc 0 16 0 r y . 5 6 5 0 . . 0 24 0 0 0 0 0 0 0 None
0x161 0 dc 0 16 0 r y . 5 6 5 0 . . 0 24 0 16 16 16 0 0 0 Slow
0x162 0 dc 0 16 0 r . . 5 6 5 0 . . 0 24 8 0 0 0 0 0 0 None
0x163 0 dc 0 16 0 r . . 5 6 5 0 . . 0 24 8 16 16 16 0 0 0 Slow
0x164 0 dc 0 16 0 r y . 5 6 5 0 . . 0 24 8 0 0 0 0 0 0 None
0x165 0 dc 0 16 0 r y . 5 6 5 0 . . 0 24 8 16 16 16 0 0 0 Slow
0x166 0 dc 0 16 0 r y . 5 6 5 0 . . 0 24 8 0 0 0 0 0 0 None
0x167 0 dc 0 16 0 r y . 5 6 5 0 . . 0 24 8 16 16 16 0 0 0 Slow
0x168 0 dc 0 16 0 r . . 5 6 5 0 . . 0 32 0 0 0 0 0 0 0 None
0x169 0 dc 0 16 0 r . . 5 6 5 0 . . 0 32 0 16 16 16 0 0 0 Slow
0x16a 0 dc 0 16 0 r y . 5 6 5 0 . . 0 32 0 0 0 0 0 0 0 None
0x16b 0 dc 0 16 0 r y . 5 6 5 0 . . 0 32 0 16 16 16 0 0 0 Slow
0x16c 0 dc 0 16 0 r y . 5 6 5 0 . . 0 32 0 0 0 0 0 0 0 None
0x16d 0 dc 0 16 0 r y . 5 6 5 0 . . 0 32 0 16 16 16 0 0 0 Slow
I think you were confusing EGL with OpenGL. EGL is a library that connects the rendering libraries (OpenGL, OpenGL|ES, OpenVG) to the underlying display libraries (X, framebuffer, DispmanX etc.).ab1jx wrote: ↑Wed Jan 30, 2019 4:41 pmOK, thanks. I thought the version was dependent on firmware, but then again somebody would have to write the firmware. And Broadcom would probably not find it profitable to invest time doing that.
I was looking a little at GLFW yesterday and a guy at http://discourse.glfw.org/t/glfw-on-rpi ... pengl/1215 claims 2.1. But maybe it's not using the Broadcom hardware version. I'm not sure what the stuff he has on Github actually does, I didn't try it, don't know how to. I'm not interested in software OpenGL, that's been around 20 years or so. I want to utilize the GPU hardware.
I never said I knew what I was doing, I'm just trying to learn. But I'm only interested in the fast hardware stuff. I thought EGL was an abbreviation for OpenGL ES.Paeryn wrote: ↑Wed Jan 30, 2019 11:03 pmI think you were confusing EGL with OpenGL. EGL is a library that connects the rendering libraries (OpenGL, OpenGL|ES, OpenVG) to the underlying display libraries (X, framebuffer, DispmanX etc.).
The Broadcom libraries are EGL 1.4 and OpenGL|ES 2.0. To use OpenGL 2.1 would need the MESA drivers (or a shim), Eric Anholt's drivers are MESA based and use the RPi's hardware as much as possible, I think it is OpenGL 2.1 but with a few features missing due to the hardware not supporting them.
libGL error: MESA-LOADER: failed to retrieve device information
* failed to add service - already in use?
rtl_power, a simple FFT logger for RTL2832 based DVB-T receivers
Use: rtl_power -f freq_range [-options] [filename]
-f lower:upper:bin_size [Hz]
(bin size is a maximum, smaller more convenient bins
will be used. valid range 1Hz - 2.8MHz)
[-i integration_interval (default: 10 seconds)]
(buggy if a full sweep takes longer than the interval)
[-1 enables single-shot mode (default: off)]
[-e exit_timer (default: off/0)]
[-d device_index (default: 0)]
[-g tuner_gain (default: automatic)]
[-p ppm_error (default: 0)]
[-T enable bias-T on GPIO PIN 0 (works for rtl-sdr.com v3 dongles)]
filename (a '-' dumps samples to stdout)
(omitting the filename also uses stdout)Experimental options:
[-w window (default: rectangle)]
(hamming, blackman, blackman-harris, hann-poisson, bartlett, youssef)
[-c crop_percent (default: 0%, recommended: 20%-50%)]
(discards data at the edges, 100% discards everything)
(has no effect for bins larger than 1MHz)
[-F fir_size (default: disabled)]
(enables low-leakage downsample filter,
fir_size can be 0 or 9. 0 has bad roll off,
try with '-c 50%')
[-P enables peak hold (default: off)]
[-D enable direct sampling (default: off)]
[-O enable offset tuning (default: off)]
CSV FFT output columns:
date, time, Hz low, Hz high, Hz step, samples, dbm, dbm, ...
Examples:
rtl_power -f 88M:108M:125k fm_stations.csv
(creates 160 bins across the FM band,
individual stations should be visible)
rtl_power -f 100M:1G:1M -i 5m -1 survey.csv
(a five minute low res scan of nearly everything)
rtl_power -f ... -i 15m -1 log.csv
(integrate for 15 minutes and exit afterwards)
rtl_power -f ... -e 1h | gzip > log.csv.gz
(collect data for one hour and compress it on the fly)
Convert CSV to a waterfall graphic with:
http://kmkeen.com/tmp/heatmap.py.txt
void make_jpeg(void) { // sends img array to compression
struct jpeg_compress_struct cinfo;
struct jpeg_error_mgr jerr;
JSAMPROW row_pointer[1];
int i,j,ival;
jline = malloc(3000 * sizeof(unsigned char));
if (jline == NULL) {
printf("Error getting 3k of RAM for a jline.\n");
exit(1);
cinfo.err = jpeg_std_error(&jerr);
jpeg_create_compress(&cinfo);
opf = fopen(jpegname,"wb");
if (opf == NULL) {
printf("Error creating %s.\n",jpegname);
perror("jpeg ");
exit(1);
jpeg_stdio_dest(&cinfo, opf);
cinfo.image_width = width;
cinfo.image_height = height;
cinfo.input_components = 3;
cinfo.in_color_space = JCS_RGB;
jpeg_set_defaults(&cinfo);
jpeg_start_compress(&cinfo, TRUE);
i = 0;
while (cinfo.next_scanline < cinfo.image_height) {
for (j=0; j<width; j++) {
ival = img[(i*width)+j]; // 8 bit image value
jline[(j*3)] = colors[ival].Red;
jline[(j*3)+1] = colors[ival].Green;
jline[(j*3)+2] = colors[ival].Blue;
row_pointer[0] = jline;
(void) jpeg_write_scanlines(&cinfo, row_pointer, 1);
i++;
jpeg_finish_compress(&cinfo);
fclose(opf);
free(jline);
} // make_jpeg
void tick(int x, int y) { // draw a simple +
int xt, yt;
for (xt=x-2; xt<(x+3); xt++) { // horizontal part
if ((xt > 0) && (xt < width)) {
img[(width * y) + xt] = tickval;
for (yt=y-2; yt<(y+3); yt++) {
if ((yt>0) && (yt<height)) {
img[(width*yt) + x] = tickval;
Maybe, but you can't buy one in the US because it doesn't do ATSC so it won't work. It does DVB-T or something like that, only useful in Europe. Our TV isn't worth bothering with anyway. Not marketed here. I have an ATI HD-750 "TV Wonder" USB dongle that was a total waste of $20 or so. Can't find any drivers for it, Windows or Linux, never had it working. I have a Happauge (I think) card that plugs into a PCI slot (circa 2002) that does work, might be able to do SDR. Never got the DVB working on the rtl2832 dongles either.
pr_info("bcm2708_fb_set_par info(%p) %dx%d (%dx%d), %d, %d\n", info,
info->var.xres, info->var.yres, info->var.xres_virtual,
info->var.yres_virtual, (int)info->screen_size,
info->var.bits_per_pixel);
/* ensure last write to fbinfo is visible to GPU */
wmb();
/* inform vc about new framebuffer */
bcm_mailbox_write(MBOX_CHAN_FB, fb->dma);
/* wait for response */
bcm_mailbox_read(MBOX_CHAN_FB, &val);
Of course doing fft on the QPU's and allowing the VC4 to write to framebuffer memory is a NICE featureBecause of the DMA-interface which has no MMU between the GPU and the RAM, code executed on the GPU can access any part of the main memory! This means, an OpenCL kernel could be used to read sensitive data or write into kernel memory!
