gordon77
installing opencv in python3 ? [SOLVED]
Sun Jan 27, 2019 4:34 pm
With the impending end to python2 I want to find a good/quick method to install opencv in python3.
I tried ths https://www.pyimagesearch.com/2018/09/1 ... ll-opencv/
If I use the option1 I get
  File "/home/pi/eyes4d.py", line 3, in <module>
    import cv2
  File "/usr/local/lib/python3.5/dist-packages/cv2/__init__.py", line 3, in <module>
    from .cv2 import *
ImportError: libcblas.so.3: cannot open shared object file: No such file or directory
If I try option 2 I get no module cv2 found
Anyone know what's going wrong ?
gordon77
Re: installing opencv in python3 ?
Mon Jan 28, 2019 9:04 am
I fixed it by running...
sudo apt-get install libcblas-dev
sudo apt-get install libhdf5-dev
sudo apt-get install libhdf5-serial-dev
sudo apt-get install libatlas-base-dev
sudo apt-get install libjasper-dev
sudo apt-get install libqtgui4
sudo apt-get install libqt4-test
some were already installed
gordon77
Re: installing opencv in python3 ? [SOLVED]
Mon Jan 28, 2019 9:29 am
this does the whole installation...
sudo pip3 install opencv-python
mattmiller
Mon Jan 28, 2019 9:47 am
Could I ask what version of OpenCV does this give you?
mattmiller
Mon Jan 28, 2019 5:08 pm
mm-not too much behind - saves having to spend hours compiling it
It may be the thing that gets me to move over to Python3 :)
gordon77
Mon Jan 28, 2019 6:03 pm
Same here. Compiling it for python3 was very time consuming.
hofo
Fri Oct 04, 2019 12:22 pm
I'm using a Raspberry PI 3b+ and installed all the packages mentioned above after I got the same error.
Now I get this error:
import cv2
ImportError                               Traceback (most recent call last)
ImportError: numpy.core.multiarray failed to import
<ipython-input-1-c8ec22b3e787> in <module>
----> 1 import cv2
/usr/local/lib/python3.5/dist-packages/cv2/__init__.py in <module>
      1 import importlib
      2
----> 3 from .cv2 import *
      4 from .data import *
      5
Is there a solution for this?
hofo
gordon77
Mon Oct 21, 2019 12:36 pm
Try...
sudo apt-get install python3-opencv
