Zofiel
SSD randomly remount in readonly
Sat Jan 26, 2019 7:14 am
Hit team,
My RPI 3B randomly remount in readonly. I have the latest stretch, i tried a rpi-update but the fail persist.
I have an m.2 ssd (WD green) with a x850 hat (with a msata adaptor)
Sometimes after some hours running the problem appear, other times after days. the smartctl test says that the ssd is ok.
Any help? thanks in advance
dmesg:
Linux raspberrypi 4.14.94-v7+ #1193 SMP Tue Jan 22 15:34:30 GMT 2019 armv7l
The programs included with the Debian GNU/Linux system are free software;
the exact distribution terms for each program are described in the
individual files in /usr/share/doc/*/copyright.
Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
permitted by applicable law.
Last login: Fri Jan 25 19:45:57 2019 from 192.168.1.199
[email protected]:~ $ dmesg
[    0.000000] Booting Linux on physical CPU 0x0
[    0.000000] Linux version 4.14.94-v7+ ([email protected]) (gcc version 4.9.3 (crosstool-NG crosstool-ng-1.22.0-88-g8460611)) #1193 SMP Tue Jan 22 15:34:30 GMT 2019
[    0.000000] CPU: ARMv7 Processor [410fd034] revision 4 (ARMv7), cr=10c5383d
[    0.000000] CPU: div instructions available: patching division code
[    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[    0.000000] OF: fdt: Machine model: Raspberry Pi 3 Model B Rev 1.2
[    0.000000] Memory policy: Data cache writealloc
[    0.000000] cma: Reserved 8 MiB at 0x3dc00000
[    0.000000] On node 0 totalpages: 255488
[    0.000000] free_area_init_node: node 0, pgdat 80c85780, node_mem_map bd336000
[    0.000000]   Normal zone: 2246 pages used for memmap
[    0.000000]   Normal zone: 0 pages reserved
[    0.000000]   Normal zone: 255488 pages, LIFO batch:31
[    0.000000] percpu: Embedded 17 pages/cpu @be59d000 s38720 r8192 d22720 u69632
[    0.000000] pcpu-alloc: s38720 r8192 d22720 u69632 alloc=17*4096
[    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 253242
[    0.000000] Kernel command line: 8250.nr_uarts=0 bcm2708_fb.fbwidth=656 bcm2708_fb.fbheight=416 bcm2708_fb.fbdepth=16 bcm2708_fb.fbswap=1 vc_mem.mem_base=0x3f000000 vc_mem.mem_size=0x3f600000  dwc_otg.lpm_enable=0 console=ttyS0,115200 console=tty1 root=PARTUUID=b3ee2769-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
[    0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[    0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[    0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[    0.000000] Memory: 990964K/1021952K available (7168K kernel code, 577K rwdata, 2080K rodata, 1024K init, 698K bss, 22796K reserved, 8192K cma-reserved)
[    0.000000] Virtual kernel memory layout:
                   vector  : 0xffff0000 - 0xffff1000   (   4 kB)
                   fixmap  : 0xffc00000 - 0xfff00000   (3072 kB)
                   vmalloc : 0xbe800000 - 0xff800000   (1040 MB)
                   lowmem  : 0x80000000 - 0xbe600000   ( 998 MB)
                   modules : 0x7f000000 - 0x80000000   (  16 MB)
                     .text : 0x80008000 - 0x80800000   (8160 kB)
                     .init : 0x80b00000 - 0x80c00000   (1024 kB)
                     .data : 0x80c00000 - 0x80c906b4   ( 578 kB)
                      .bss : 0x80c97ef8 - 0x80d468f0   ( 699 kB)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[    0.000000] ftrace: allocating 25296 entries in 75 pages
[    0.000000] Hierarchical RCU implementation.
[    0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
[    0.000000] arch_timer: cp15 timer(s) running at 19.20MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x46d987e47, max_idle_ns: 440795202767 ns
[    0.000007] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 4398046511078ns
[    0.000023] Switching to timer-based delay loop, resolution 52ns
[    0.000282] Console: colour dummy device 80x30
[    0.000833] console [tty1] enabled
[    0.000872] Calibrating delay loop (skipped), value calculated using timer frequency.. 38.40 BogoMIPS (lpj=192000)
[    0.000913] pid_max: default: 32768 minimum: 301
[    0.001253] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
[    0.001287] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
[    0.002293] Disabling memory control group subsystem
[    0.002390] CPU: Testing write buffer coherency: ok
[    0.002843] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[    0.003277] Setting up static identity map for 0x100000 - 0x10003c
[    0.003418] Hierarchical SRCU implementation.
[    0.004133] smp: Bringing up secondary CPUs ...
[    0.004984] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[    0.005868] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
[    0.006730] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
[    0.006835] smp: Brought up 1 node, 4 CPUs
[    0.006910] SMP: Total of 4 processors activated (153.60 BogoMIPS).
[    0.006932] CPU: All CPU(s) started in HYP mode.
[    0.006950] CPU: Virtualization extensions available.
[    0.007943] devtmpfs: initialized
[    0.018055] random: get_random_u32 called from bucket_table_alloc+0xfc/0x24c with crng_init=0
[    0.018767] VFP support v0.3: implementor 41 architecture 3 part 40 variant 3 rev 4
[    0.019019] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[    0.019064] futex hash table entries: 1024 (order: 4, 65536 bytes)
[    0.019655] pinctrl core: initialized pinctrl subsystem
[    0.020486] NET: Registered protocol family 16
[    0.023122] DMA: preallocated 1024 KiB pool for atomic coherent allocations
[    0.027875] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[    0.027908] hw-breakpoint: maximum watchpoint size is 8 bytes.
[    0.028156] Serial: AMBA PL011 UART driver
[    0.029851] bcm2835-mbox 3f00b880.mailbox: mailbox enabled
[    0.030375] uart-pl011 3f201000.serial: could not find pctldev for node /soc/[email protected]/uart0_pins, deferring probe
[    0.061775] bcm2835-dma 3f007000.dma: DMA legacy API manager at be813000, dmachans=0x1
[    0.063259] SCSI subsystem initialized
[    0.063499] usbcore: registered new interface driver usbfs
[    0.063569] usbcore: registered new interface driver hub
[    0.063677] usbcore: registered new device driver usb
[    0.070086] raspberrypi-firmware soc:firmware: Attached to firmware from 2019-01-22 16:51
[    0.071460] clocksource: Switched to clocksource arch_sys_counter
[    0.149076] VFS: Disk quotas dquot_6.6.0
[    0.149196] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[    0.149406] FS-Cache: Loaded
[    0.149625] CacheFiles: Loaded
[    0.158394] NET: Registered protocol family 2
[    0.159152] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[    0.159283] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)[    0.159486] TCP: Hash tables configured (established 8192 bind 8192)
[    0.159635] UDP hash table entries: 512 (order: 2, 16384 bytes)
[    0.159696] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[    0.159944] NET: Registered protocol family 1
[    0.160433] RPC: Registered named UNIX socket transport module.
[    0.160457] RPC: Registered udp transport module.
[    0.160477] RPC: Registered tcp transport module.
[    0.160497] RPC: Registered tcp NFSv4.1 backchannel transport module.[    0.162103] hw perfevents: enabled with armv7_cortex_a7 PMU driver, 7 counters available
[    0.164910] workingset: timestamp_bits=14 max_order=18 bucket_order=4[    0.172900] FS-Cache: Netfs 'nfs' registered for caching
[    0.173527] NFS: Registering the id_resolver key type
[    0.173578] Key type id_resolver registered
[    0.173598] Key type id_legacy registered
[    0.173628] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    0.175592] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 251)
[    0.175752] io scheduler noop registered
[    0.175774] io scheduler deadline registered (default)
[    0.175961] io scheduler cfq registered
[    0.175983] io scheduler mq-deadline registered
[    0.176003] io scheduler kyber registered
[    0.178805] BCM2708FB: allocated DMA memory fdd10000
[    0.178853] BCM2708FB: allocated DMA channel 0 @ be813000
[    0.183955] Console: switching to colour frame buffer device 82x26
[    0.189656] bcm2835-rng 3f104000.rng: hwrng registered
[    0.191126] vc-mem: phys_addr:0x00000000 mem_base=0x3f000000 mem_size:0x3f600000(1014 MiB)
[    0.194354] vc-sm: Videocore shared memory driver
[    0.195977] gpiomem-bcm2835 3f200000.gpiomem: Initialised: Registers at 0x3f200000
[    0.208151] brd: module loaded
[    0.218186] loop: module loaded
[    0.219541] Loading iSCSI transport class v2.0-870.
[    0.221606] libphy: Fixed MDIO Bus: probed
[    0.223035] usbcore: registered new interface driver lan78xx
[    0.224412] usbcore: registered new interface driver smsc95xx
[    0.225677] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[    0.252403] dwc_otg 3f980000.usb: base=0xf0980000
[    0.453875] Core Release: 2.80a
[    0.455146] Setting default values for core params
[    0.456473] Finished setting default values for core params
[    0.658050] Using Buffer DMA mode
[    0.659374] Periodic Transfer Interrupt Enhancement - disabled
[    0.660763] Multiprocessor Interrupt Enhancement - disabled
[    0.662158] OTG VER PARAM: 0, OTG VER FLAG: 0
[    0.663527] Dedicated Tx FIFOs mode
[    0.665227] WARN::dwc_otg_hcd_init:1046: FIQ DMA bounce buffers: virt = 0xbdd04000 dma = 0xfdd04000 len=9024
[    0.667903] FIQ FSM acceleration enabled for :
               Non-periodic Split Transactions
               Periodic Split Transactions
               High-Speed Isochronous Endpoints
               Interrupt/Control Split Transaction hack enabled
[    0.674270] dwc_otg: Microframe scheduler enabled
[    0.674319] WARN::hcd_init_fiq:459: FIQ on core 1 at 0x805ed1d4
[    0.675638] WARN::hcd_init_fiq:460: FIQ ASM at 0x805ed53c length 36
[    0.676937] WARN::hcd_init_fiq:486: MPHI regs_base at 0xf0006000
[    0.678300] dwc_otg 3f980000.usb: DWC OTG Controller
[    0.679636] dwc_otg 3f980000.usb: new USB bus registered, assigned bus number 1
[    0.681008] dwc_otg 3f980000.usb: irq 62, io mem 0x00000000
[    0.682398] Init: Port Power? op_state=1
[    0.683714] Init: Power Port (0)
[    0.685185] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[    0.686529] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    0.687863] usb usb1: Product: DWC OTG Controller
[    0.689168] usb usb1: Manufacturer: Linux 4.14.94-v7+ dwc_otg_hcd
[    0.690488] usb usb1: SerialNumber: 3f980000.usb
[    0.692402] hub 1-0:1.0: USB hub found
[    0.693704] hub 1-0:1.0: 1 port detected
[    0.695407] dwc_otg: FIQ enabled
[    0.695413] dwc_otg: NAK holdoff enabled
[    0.695417] dwc_otg: FIQ split-transaction FSM enabled
[    0.695427] Module dwc_common_port init
[    0.695683] usbcore: registered new interface driver usb-storage
[    0.697076] mousedev: PS/2 mouse device common for all mice
[    0.698398] IR NEC protocol handler initialized
[    0.699660] IR RC5(x/sz) protocol handler initialized
[    0.700939] IR RC6 protocol handler initialized
[    0.702240] IR JVC protocol handler initialized
[    0.703456] IR Sony protocol handler initialized
[    0.704674] IR SANYO protocol handler initialized
[    0.705889] IR Sharp protocol handler initialized
[    0.707052] IR MCE Keyboard/mouse protocol handler initialized
[    0.708232] IR XMP protocol handler initialized
[    0.710073] bcm2835-wdt 3f100000.watchdog: Broadcom BCM2835 watchdog timer
[    0.711575] bcm2835-cpufreq: min=600000 max=1200000
[    0.713155] sdhci: Secure Digital Host Controller Interface driver
[    0.714392] sdhci: Copyright(c) Pierre Ossman
[    0.715953] mmc-bcm2835 3f300000.mmc: could not get clk, deferring probe
[    0.717524] sdhost-bcm2835 3f202000.mmc: could not get clk, deferring probe
[    0.718897] sdhci-pltfm: SDHCI platform and OF driver helper
[    0.721600] ledtrig-cpu: registered to indicate activity on CPUs
[    0.723082] hidraw: raw HID events driver (C) Jiri Kosina
[    0.724591] usbcore: registered new interface driver usbhid
[    0.725925] usbhid: USB HID core driver
[    0.727803] vchiq: vchiq_init_state: slot_zero = bdd80000, is_master = 0
[    0.730510] [vc_sm_connected_init]: start
[    0.733978] vc_vchi_sm_init: failed to open VCHI service (-1)
[    0.733985] [vc_sm_connected_init]: failed to initialize shared memory service
[    0.736826] [vc_sm_connected_init]: end - returning -1
[    0.738957] Initializing XFRM netlink socket
[    0.740425] NET: Registered protocol family 17
[    0.742027] Key type dns_resolver registered
[    0.743918] Registering SWP/SWPB emulation handler
[    0.745930] registered taskstats version 1
[    0.753304] uart-pl011 3f201000.serial: cts_event_workaround enabled
[    0.754851] 3f201000.serial: ttyAMA0 at MMIO 0x3f201000 (irq = 87, base_baud = 0) is a PL011 rev2
[    0.759517] mmc-bcm2835 3f300000.mmc: mmc_debug:0 mmc_debug2:0
[    0.761020] mmc-bcm2835 3f300000.mmc: DMA channel allocated
[    0.822127] sdhost: log_buf @ bdd07000 (fdd07000)
[    0.858772] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
[    0.861775] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[    0.864697] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[    0.868794] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
[    0.901483] mmc0: sdhost-bcm2835 loaded - DMA enabled (>1)
[    0.903773] of_cfs_init
[    0.905117] of_cfs_init: OK
[    0.906794] Waiting for root device PARTUUID=b3ee2769-02...
[    0.923088] Indeed it is in host mode hprt0 = 00021501
[    0.990672] random: fast init done
[    1.047770] mmc1: new high speed SDIO card at address 0001
[    1.141490] usb 1-1: new high-speed USB device number 2 using dwc_otg[    1.142852] Indeed it is in host mode hprt0 = 00001101
[    1.401735] usb 1-1: New USB device found, idVendor=0424, idProduct=9514
[    1.403050] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[    1.404864] hub 1-1:1.0: USB hub found
[    1.406185] hub 1-1:1.0: 5 ports detected
[    1.721488] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
[    1.851724] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00
[    1.852969] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[    1.856699] smsc95xx v1.0.6
[    1.944825] smsc95xx 1-1.1:1.0 eth0: register 'smsc95xx' at usb-3f980000.usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:45:35:95
[    2.241488] usb 1-1.5: new full-speed USB device number 4 using dwc_otg
[    2.374694] usb 1-1.5: New USB device found, idVendor=0658, idProduct=0200
[    2.376192] usb 1-1.5: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[    2.941478] usb 1-1.2: new high-speed USB device number 5 using dwc_otg
[    3.073051] usb 1-1.2: New USB device found, idVendor=0850, idProduct=0003
[    3.074599] usb 1-1.2: New USB device strings: Mfr=2, Product=3, SerialNumber=1
[    3.076138] usb 1-1.2: Product: X850 V3.0
[    3.077647] usb 1-1.2: Manufacturer: SupTronics
[    3.079133] usb 1-1.2: SerialNumber: 2018102000BD
[    3.081175] usb 1-1.2: The driver for the USB controller dwc_otg_hcd does not support scatter-gather which is
[    3.084110] usb 1-1.2: required by the UAS driver. Please try an other USB controller if you wish to use UAS.
[    3.087145] usb-storage 1-1.2:1.0: USB Mass Storage device detected
[    3.089368] scsi host0: usb-storage 1-1.2:1.0
[    4.156325] scsi 0:0:0:0: Direct-Access     WDC WDS1 20G1G0B-00RC30   0    PQ: 0 ANSI: 6
[    4.160327] sd 0:0:0:0: [sda] 234441648 512-byte logical blocks: (120 GB/112 GiB)
[    4.164004] sd 0:0:0:0: [sda] Write Protect is off
[    4.165634] sd 0:0:0:0: [sda] Mode Sense: 43 00 00 00
[    4.166075] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[    4.171609]  sda: sda1 sda2
[    4.175125] sd 0:0:0:0: [sda] Attached SCSI disk
[    4.216595] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null)
[    4.219871] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
[    4.226639] devtmpfs: mounted
[    4.231583] Freeing unused kernel memory: 1024K
[    4.541811] systemd[1]: System time before build time, advancing clock.
[    4.626749] NET: Registered protocol family 10
[    4.629706] Segment Routing with IPv6
[    4.639060] ip_tables: (C) 2000-2006 Netfilter Core Team
[    4.653941] random: systemd: uninitialized urandom read (16 bytes read)
[    4.661031] systemd[1]: systemd 232 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD +IDN)
[    4.666586] systemd[1]: Detected architecture arm.
[    4.678996] systemd[1]: Set hostname to <raspberrypi>.
[    4.707516] random: systemd: uninitialized urandom read (16 bytes read)
[    4.743115] random: systemd-cryptse: uninitialized urandom read (16 bytes read)
[    5.147982] systemd[1]: Created slice User and Session Slice.
[    5.163684] systemd[1]: Listening on Journal Socket.
[    5.167388] systemd[1]: Reached target Swap.
[    5.171001] systemd[1]: Listening on udev Control Socket.
[    5.175269] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[    5.180653] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
[    5.184583] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[    6.016583] EXT4-fs (sda2): re-mounted. Opts: (null)
[    6.108818] systemd-journald[101]: Received request to flush runtime journal from PID 1
[    6.536600] random: crng init done
[    6.536621] random: 7 urandom warning(s) missed due to ratelimiting
[    6.555011] snd_bcm2835: module is from the staging directory, the quality is unknown, you have been warned.
[    6.570530] bcm2835_alsa bcm2835_alsa: card created with 8 channels
[    6.717452] brcmfmac: F1 signature read @0x18000000=0x1541a9a6
[    6.728187] brcmfmac: brcmf_fw_map_chip_to_name: using brcm/brcmfmac43430-sdio.bin for chip 0x00a9a6(43430) rev 0x000001
[    6.728518] usbcore: registered new interface driver brcmfmac
[    6.750691] usbcore: registered new interface driver uas
[    6.805988] sd 0:0:0:0: Attached scsi generic sg0 type 0
[    6.807314] cdc_acm 1-1.5:1.0: ttyACM0: USB ACM device
[    6.808488] usbcore: registered new interface driver cdc_acm
[    6.808499] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[    6.986017] brcmfmac: brcmf_c_preinit_dcmds: Firmware version = wl0: Oct 23 2017 03:55:53 version 7.45.98.38 (r674442 CY) FWID 01-e58d219f
[    6.986930] brcmfmac: brcmf_c_preinit_dcmds: CLM version = API: 12.2 Data: 7.11.15 Compiler: 1.24.2 ClmImport: 1.24.1 Creation: 2014-05-26 10:53:55 Inc Data: 9.10.39 Inc Compiler: 1.29.4 Inc ClmImport: 1.36.3 Creation: 2017-10-23 03:47:14
[    8.009038] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[    8.009053] brcmfmac: power management disabled
[    8.140280] Adding 1048572k swap on /var/swap.  Priority:-2 extents:16 across:1695740k FS
[    8.392705] smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup
[    9.909007] smsc95xx 1-1.1:1.0 eth0: link up, 100Mbps, full-duplex, lpa 0xCDE1
[  174.322698] tun: Universal TUN/TAP device driver, 1.6
[  892.933176] systemd[1]: apt-daily-upgrade.timer: Adding 37min 13.420075s random time.
[  892.933834] systemd[1]: apt-daily.timer: Adding 13min 55.135513s random time.
[  894.311877] systemd[1]: apt-daily-upgrade.timer: Adding 20min 42.655934s random time.
[  894.312989] systemd[1]: apt-daily.timer: Adding 4h 28min 13.226825s random time.
[  894.662956] systemd[1]: apt-daily-upgrade.timer: Adding 19min 25.474976s random time.
[  894.663655] systemd[1]: apt-daily.timer: Adding 4h 23min 45.224618s random time.
[  895.054712] systemd[1]: apt-daily-upgrade.timer: Adding 24min 29.624446s random time.
[  895.055367] systemd[1]: apt-daily.timer: Adding 10h 13min 27.099633s random time.
[  895.483844] systemd[1]: apt-daily-upgrade.timer: Adding 13min 35.918182s random time.
[  895.484502] systemd[1]: apt-daily.timer: Adding 3h 42min 24.144050s random time.
[  899.873238] systemd[1]: apt-daily-upgrade.timer: Adding 48min 42.918898s random time.
[  899.873925] systemd[1]: apt-daily.timer: Adding 3h 59min 34.409015s random time.
[22116.338792] INFO: task jbd2/sda2-8:72 blocked for more than 120 seconds.
[22116.338804]       Tainted: G         C      4.14.94-v7+ #1193
[22116.338809] "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message.
[22116.338816] jbd2/sda2-8     D    0    72      2 0x00000000
[22116.338863] [<807a2690>] (__schedule) from [<807a2cf8>] (schedule+0x50/0xa8)
[22116.338882] [<807a2cf8>] (schedule) from [<8014b6cc>] (io_schedule+0x20/0x40)
[22116.338900] [<8014b6cc>] (io_schedule) from [<807a3668>] (bit_wait_io+0x1c/0x70)
[22116.338917] [<807a3668>] (bit_wait_io) from [<807a32f8>] (__wait_on_bit+0x94/0xd0)
[22116.338935] [<807a32f8>] (__wait_on_bit) from [<807a33bc>] (out_of_line_wait_on_bit+0x88/0x90)
[22116.338953] [<807a33bc>] (out_of_line_wait_on_bit) from [<802c3e2c>] (__wait_on_buffer+0x40/0x44)
[22116.338973] [<802c3e2c>] (__wait_on_buffer) from [<8037cd28>] (jbd2_journal_commit_transaction+0x1340/0x17f0)
[22116.338992] [<8037cd28>] (jbd2_journal_commit_transaction) from [<803822e8>] (kjournald2+0x110/0x2c0)
[22116.339009] [<803822e8>] (kjournald2) from [<8013ddd4>] (kthread+0x13c/0x16c)
[22116.339028] [<8013ddd4>] (kthread) from [<801080ac>] (ret_from_fork+0x14/0x28)
[22116.339071] INFO: task mysqld:674 blocked for more than 120 seconds.
[22116.339078]       Tainted: G         C      4.14.94-v7+ #1193
[22116.339082] "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message.
[22116.339087] mysqld          D    0   674      1 0x00000080
[22116.339112] [<807a2690>] (__schedule) from [<807a2cf8>] (schedule+0x50/0xa8)
[22116.339127] [<807a2cf8>] (schedule) from [<80381990>] (jbd2_log_wait_commit+0xac/0x134)
[22116.339142] [<80381990>] (jbd2_log_wait_commit) from [<803831f8>] (jbd2_complete_transaction+0x90/0xf8)
[22116.339160] [<803831f8>] (jbd2_complete_transaction) from [<8032b1cc>] (ext4_sync_file+0x25c/0x3d4)
[22116.339181] [<8032b1cc>] (ext4_sync_file) from [<802c1b50>] (vfs_fsync_range+0x68/0xc8)
[22116.339199] [<802c1b50>] (vfs_fsync_range) from [<802c1c38>] (do_fsync+0x4c/0x74)
[22116.339216] [<802c1c38>] (do_fsync) from [<802c1f10>] (SyS_fsync+0x1c/0x20)
[22116.339233] [<802c1f10>] (SyS_fsync) from [<80108198>] (__sys_trace_return+0x0/0x10)
[22239.218957] INFO: task jbd2/sda2-8:72 blocked for more than 120 seconds.
[22239.218969]       Tainted: G         C      4.14.94-v7+ #1193
[22239.218974] "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message.
[22239.218982] jbd2/sda2-8     D    0    72      2 0x00000000
[22239.219030] [<807a2690>] (__schedule) from [<807a2cf8>] (schedule+0x50/0xa8)
[22239.219049] [<807a2cf8>] (schedule) from [<8014b6cc>] (io_schedule+0x20/0x40)
[22239.219067] [<8014b6cc>] (io_schedule) from [<807a3668>] (bit_wait_io+0x1c/0x70)
[22239.219085] [<807a3668>] (bit_wait_io) from [<807a32f8>] (__wait_on_bit+0x94/0xd0)
[22239.219103] [<807a32f8>] (__wait_on_bit) from [<807a33bc>] (out_of_line_wait_on_bit+0x88/0x90)
[22239.219121] [<807a33bc>] (out_of_line_wait_on_bit) from [<802c3e2c>] (__wait_on_buffer+0x40/0x44)
[22239.219142] [<802c3e2c>] (__wait_on_buffer) from [<8037cd28>] (jbd2_journal_commit_transaction+0x1340/0x17f0)
[22239.219160] [<8037cd28>] (jbd2_journal_commit_transaction) from [<803822e8>] (kjournald2+0x110/0x2c0)
[22239.219178] [<803822e8>] (kjournald2) from [<8013ddd4>] (kthread+0x13c/0x16c)
[22239.219198] [<8013ddd4>] (kthread) from [<801080ac>] (ret_from_fork+0x14/0x28)
[22239.219250] INFO: task mysqld:674 blocked for more than 120 seconds.
[22239.219256]       Tainted: G         C      4.14.94-v7+ #1193
[22239.219261] "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message.
[22239.219266] mysqld          D    0   674      1 0x00000080
[22239.219291] [<807a2690>] (__schedule) from [<807a2cf8>] (schedule+0x50/0xa8)
[22239.219306] [<807a2cf8>] (schedule) from [<80381990>] (jbd2_log_wait_commit+0xac/0x134)
[22239.219322] [<80381990>] (jbd2_log_wait_commit) from [<803831f8>] (jbd2_complete_transaction+0x90/0xf8)
[22239.219342] [<803831f8>] (jbd2_complete_transaction) from [<8032b1cc>] (ext4_sync_file+0x25c/0x3d4)
[22239.219364] [<8032b1cc>] (ext4_sync_file) from [<802c1b50>] (vfs_fsync_range+0x68/0xc8)
[22239.219382] [<802c1b50>] (vfs_fsync_range) from [<802c1c38>] (do_fsync+0x4c/0x74)
[22239.219399] [<802c1c38>] (do_fsync) from [<802c1f10>] (SyS_fsync+0x1c/0x20)
[22239.219417] [<802c1f10>] (SyS_fsync) from [<80108198>] (__sys_trace_return+0x0/0x10)
[22290.839484] sd 0:0:0:0: timing out command, waited 360s
[22290.839516] sd 0:0:0:0: [sda] tag#0 UNKNOWN(0x2003) Result: hostbyte=0x00 driverbyte=0x08
[22290.839529] sd 0:0:0:0: [sda] tag#0 Sense Key : 0x4 [current]
[22290.839540] sd 0:0:0:0: [sda] tag#0 ASC=0x44 ASCQ=0x0
[22290.839555] sd 0:0:0:0: [sda] tag#0 CDB: opcode=0x35 35 00 00 00 00 00 00 00 00 00
[22290.839581] print_req_error: I/O error, dev sda, sector 1701424
[22290.839659] Aborting journal on device sda2-8.
[22290.841520] EXT4-fs error (device sda2) in ext4_do_update_inode:5180: Journal has aborted
[22362.099151] INFO: task mysqld:669 blocked for more than 120 seconds.
[22362.099163]       Tainted: G         C      4.14.94-v7+ #1193
[22362.099169] "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message.
[22362.099176] mysqld          D    0   669      1 0x00000080
[22362.099223] [<807a2690>] (__schedule) from [<807a2cf8>] (schedule+0x50/0xa8)
[22362.099243] [<807a2cf8>] (schedule) from [<8014b6cc>] (io_schedule+0x20/0x40)
[22362.099261] [<8014b6cc>] (io_schedule) from [<807a3668>] (bit_wait_io+0x1c/0x70)
[22362.099278] [<807a3668>] (bit_wait_io) from [<807a32f8>] (__wait_on_bit+0x94/0xd0)
[22362.099296] [<807a32f8>] (__wait_on_bit) from [<807a33bc>] (out_of_line_wait_on_bit+0x88/0x90)
[22362.099314] [<807a33bc>] (out_of_line_wait_on_bit) from [<802c3e2c>] (__wait_on_buffer+0x40/0x44)
[22362.099332] [<802c3e2c>] (__wait_on_buffer) from [<802c8044>] (__block_write_begin_int+0x510/0x850)
[22362.099348] [<802c8044>] (__block_write_begin_int) from [<802c83b8>] (__block_write_begin+0x34/0x3c)
[22362.099366] [<802c83b8>] (__block_write_begin) from [<8033d96c>] (ext4_da_write_begin+0x184/0x45c)
[22362.099386] [<8033d96c>] (ext4_da_write_begin) from [<8021f338>] (generic_perform_write+0xb8/0x1b0)
[22362.099404] [<8021f338>] (generic_perform_write) from [<80221c30>] (__generic_file_write_iter+0x19c/0x1f8)
[22362.099423] [<80221c30>] (__generic_file_write_iter) from [<8032946c>] (ext4_file_write_iter+0x188/0x454)
[22362.099443] [<8032946c>] (ext4_file_write_iter) from [<8028be48>] (__vfs_write+0xe0/0x138)
[22362.099462] [<8028be48>] (__vfs_write) from [<8028c068>] (vfs_write+0xb4/0x1bc)
[22362.099478] [<8028c068>] (vfs_write) from [<8028c2b8>] (SyS_write+0x54/0xb0)
[22362.099497] [<8028c2b8>] (SyS_write) from [<80108198>] (__sys_trace_return+0x0/0x10)
[22362.099509] INFO: task mysqld:674 blocked for more than 120 seconds.
[22362.099515]       Tainted: G         C      4.14.94-v7+ #1193
[22362.099520] "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message.
[22362.099525] mysqld          D    0   674      1 0x00000080
[22362.099550] [<807a2690>] (__schedule) from [<807a2cf8>] (schedule+0x50/0xa8)
[22362.099566] [<807a2cf8>] (schedule) from [<80381990>] (jbd2_log_wait_commit+0xac/0x134)
[22362.099583] [<80381990>] (jbd2_log_wait_commit) from [<803831f8>] (jbd2_complete_transaction+0x90/0xf8)
[22362.099600] [<803831f8>] (jbd2_complete_transaction) from [<8032b1cc>] (ext4_sync_file+0x25c/0x3d4)
[22362.099620] [<8032b1cc>] (ext4_sync_file) from [<802c1b50>] (vfs_fsync_range+0x68/0xc8)
[22362.099637] [<802c1b50>] (vfs_fsync_range) from [<802c1c38>] (do_fsync+0x4c/0x74)
[22362.099655] [<802c1c38>] (do_fsync) from [<802c1f10>] (SyS_fsync+0x1c/0x20)
[22362.099672] [<802c1f10>] (SyS_fsync) from [<80108198>] (__sys_trace_return+0x0/0x10)
[22484.979271] INFO: task jbd2/sda2-8:72 blocked for more than 120 seconds.
[22484.979283]       Tainted: G         C      4.14.94-v7+ #1193
[22484.979288] "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message.
[22484.979296] jbd2/sda2-8     D    0    72      2 0x00000000
[22484.979343] [<807a2690>] (__schedule) from [<807a2cf8>] (schedule+0x50/0xa8)
[22484.979363] [<807a2cf8>] (schedule) from [<8014b6cc>] (io_schedule+0x20/0x40)
[22484.979380] [<8014b6cc>] (io_schedule) from [<807a3668>] (bit_wait_io+0x1c/0x70)
[22484.979398] [<807a3668>] (bit_wait_io) from [<807a32f8>] (__wait_on_bit+0x94/0xd0)
[22484.979415] [<807a32f8>] (__wait_on_bit) from [<807a33bc>] (out_of_line_wait_on_bit+0x88/0x90)
[22484.979435] [<807a33bc>] (out_of_line_wait_on_bit) from [<802c3e2c>] (__wait_on_buffer+0x40/0x44)
[22484.979454] [<802c3e2c>] (__wait_on_buffer) from [<80383628>] (jbd2_write_superblock+0x1c8/0x244)
[22484.979470] [<80383628>] (jbd2_write_superblock) from [<80383718>] (jbd2_journal_update_sb_errno+0x74/0x78)
[22484.979485] [<80383718>] (jbd2_journal_update_sb_errno) from [<80383404>] (__journal_abort_soft+0xa8/0xe8)
[22484.979500] [<80383404>] (__journal_abort_soft) from [<8038345c>] (jbd2_journal_abort+0x18/0x1c)
[22484.979517] [<8038345c>] (jbd2_journal_abort) from [<8037cd0c>] (jbd2_journal_commit_transaction+0x1324/0x17f0)
[22484.979535] [<8037cd0c>] (jbd2_journal_commit_transaction) from [<803822e8>] (kjournald2+0x110/0x2c0)
[22484.979552] [<803822e8>] (kjournald2) from [<8013ddd4>] (kthread+0x13c/0x16c)
[22484.979572] [<8013ddd4>] (kthread) from [<801080ac>] (ret_from_fork+0x14/0x28)
[22484.979596] INFO: task rs:main Q:Reg:334 blocked for more than 120 seconds.
[22484.979602]       Tainted: G         C      4.14.94-v7+ #1193
[22484.979607] "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message.
[22484.979612] rs:main Q:Reg   D    0   334      1 0x00000000
[22484.979637] [<807a2690>] (__schedule) from [<807a2cf8>] (schedule+0x50/0xa8)
[22484.979652] [<807a2cf8>] (schedule) from [<8014b6cc>] (io_schedule+0x20/0x40)
[22484.979668] [<8014b6cc>] (io_schedule) from [<807a3668>] (bit_wait_io+0x1c/0x70)
[22484.979684] [<807a3668>] (bit_wait_io) from [<807a32f8>] (__wait_on_bit+0x94/0xd0)
[22484.979701] [<807a32f8>] (__wait_on_bit) from [<807a33bc>] (out_of_line_wait_on_bit+0x88/0x90)
[22484.979716] [<807a33bc>] (out_of_line_wait_on_bit) from [<802c3e2c>] (__wait_on_buffer+0x40/0x44)
[22484.979732] [<802c3e2c>] (__wait_on_buffer) from [<802c99e8>] (__sync_dirty_buffer+0xe8/0x114)
[22484.979748] [<802c99e8>] (__sync_dirty_buffer) from [<80369910>] (ext4_commit_super+0x224/0x2d0)
[22484.979764] [<80369910>] (ext4_commit_super) from [<8036a050>] (__ext4_std_error+0x74/0xec)
[22484.979780] [<8036a050>] (__ext4_std_error) from [<8033aad0>] (ext4_mark_iloc_dirty+0x68c/0x7e8)
[22484.979796] [<8033aad0>] (ext4_mark_iloc_dirty) from [<8033aefc>] (ext4_mark_inode_dirty+0x74/0x1e0)
[22484.979813] [<8033aefc>] (ext4_mark_inode_dirty) from [<8033e8d4>] (ext4_da_write_end+0xe8/0x304)
[22484.979831] [<8033e8d4>] (ext4_da_write_end) from [<8021f398>] (generic_perform_write+0x118/0x1b0)
[22484.979849] [<8021f398>] (generic_perform_write) from [<80221c30>] (__generic_file_write_iter+0x19c/0x1f8)
[22484.979869] [<80221c30>] (__generic_file_write_iter) from [<8032946c>] (ext4_file_write_iter+0x188/0x454)
[22484.979890] [<8032946c>] (ext4_file_write_iter) from [<8028be48>] (__vfs_write+0xe0/0x138)
[22484.979908] [<8028be48>] (__vfs_write) from [<8028c068>] (vfs_write+0xb4/0x1bc)
[22484.979924] [<8028c068>] (vfs_write) from [<8028c2b8>] (SyS_write+0x54/0xb0)
[22484.979941] [<8028c2b8>] (SyS_write) from [<80108000>] (ret_fast_syscall+0x0/0x28)
[22484.979969] INFO: task mysqld:669 blocked for more than 120 seconds.
[22484.979976]       Tainted: G         C      4.14.94-v7+ #1193
[22484.979981] "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message.
[22484.979985] mysqld          D    0   669      1 0x00000080
[22484.980009] [<807a2690>] (__schedule) from [<807a2cf8>] (schedule+0x50/0xa8)
[22484.980024] [<807a2cf8>] (schedule) from [<8014b6cc>] (io_schedule+0x20/0x40)
[22484.980040] [<8014b6cc>] (io_schedule) from [<807a3668>] (bit_wait_io+0x1c/0x70)
[22484.980056] [<807a3668>] (bit_wait_io) from [<807a32f8>] (__wait_on_bit+0x94/0xd0)
[22484.980073] [<807a32f8>] (__wait_on_bit) from [<807a33bc>] (out_of_line_wait_on_bit+0x88/0x90)
[22484.980088] [<807a33bc>] (out_of_line_wait_on_bit) from [<802c3e2c>] (__wait_on_buffer+0x40/0x44)
[22484.980103] [<802c3e2c>] (__wait_on_buffer) from [<802c8044>] (__block_write_begin_int+0x510/0x850)
[22484.980118] [<802c8044>] (__block_write_begin_int) from [<802c83b8>] (__block_write_begin+0x34/0x3c)
[22484.980134] [<802c83b8>] (__block_write_begin) from [<8033d96c>] (ext4_da_write_begin+0x184/0x45c)
[22484.980149] [<8033d96c>] (ext4_da_write_begin) from [<8021f338>] (generic_perform_write+0xb8/0x1b0)
[22484.980165] [<8021f338>] (generic_perform_write) from [<80221c30>] (__generic_file_write_iter+0x19c/0x1f8)
[22484.980182] [<80221c30>] (__generic_file_write_iter) from [<8032946c>] (ext4_file_write_iter+0x188/0x454)
[22484.980200] [<8032946c>] (ext4_file_write_iter) from [<8028be48>] (__vfs_write+0xe0/0x138)
[22484.980217] [<8028be48>] (__vfs_write) from [<8028c068>] (vfs_write+0xb4/0x1bc)
[22484.980233] [<8028c068>] (vfs_write) from [<8028c2b8>] (SyS_write+0x54/0xb0)
[22484.980250] [<8028c2b8>] (SyS_write) from [<80108198>] (__sys_trace_return+0x0/0x10)
[22484.980260] INFO: task mysqld:674 blocked for more than 120 seconds.
[22484.980266]       Tainted: G         C      4.14.94-v7+ #1193
[22484.980271] "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message.
[22484.980276] mysqld          D    0   674      1 0x00000080
[22484.980300] [<807a2690>] (__schedule) from [<807a2cf8>] (schedule+0x50/0xa8)
[22484.980315] [<807a2cf8>] (schedule) from [<80381990>] (jbd2_log_wait_commit+0xac/0x134)
[22484.980330] [<80381990>] (jbd2_log_wait_commit) from [<803831f8>] (jbd2_complete_transaction+0x90/0xf8)
[22484.980347] [<803831f8>] (jbd2_complete_transaction) from [<8032b1cc>] (ext4_sync_file+0x25c/0x3d4)
[22484.980366] [<8032b1cc>] (ext4_sync_file) from [<802c1b50>] (vfs_fsync_range+0x68/0xc8)
[22484.980383] [<802c1b50>] (vfs_fsync_range) from [<802c1c38>] (do_fsync+0x4c/0x74)
[22484.980401] [<802c1c38>] (do_fsync) from [<802c1f10>] (SyS_fsync+0x1c/0x20)
[22484.980418] [<802c1f10>] (SyS_fsync) from [<80108198>] (__sys_trace_return+0x0/0x10)
[22650.869912] sd 0:0:0:0: timing out command, waited 360s
[22650.869944] sd 0:0:0:0: [sda] tag#0 UNKNOWN(0x2003) Result: hostbyte=0x00 driverbyte=0x08
[22650.869957] sd 0:0:0:0: [sda] tag#0 Sense Key : 0x4 [current]
[22650.869979] sd 0:0:0:0: [sda] tag#0 ASC=0x44 ASCQ=0x0
[22650.869994] sd 0:0:0:0: [sda] tag#0 CDB: opcode=0x35 35 00 00 00 00 00 00 00 00 00
[22650.870019] print_req_error: I/O error, dev sda, sector 1671168
[22650.870034] Buffer I/O error on dev sda2, logical block 196608, lost sync page write
[22650.870127] JBD2: Error -5 detected when updating journal superblock for sda2-8.
[22650.870975] EXT4-fs error (device sda2) in ext4_do_update_inode:5180: Journal has aborted
[23010.880496] sd 0:0:0:0: timing out command, waited 360s
[23010.880527] sd 0:0:0:0: [sda] tag#0 UNKNOWN(0x2003) Result: hostbyte=0x00 driverbyte=0x08
[23010.880540] sd 0:0:0:0: [sda] tag#0 Sense Key : 0x4 [current]
[23010.880552] sd 0:0:0:0: [sda] tag#0 ASC=0x44 ASCQ=0x0
[23010.880567] sd 0:0:0:0: [sda] tag#0 CDB: opcode=0x35 35 00 00 00 00 00 00 00 00 00
[23010.880593] print_req_error: I/O error, dev sda, sector 98304
[23010.880608] Buffer I/O error on dev sda2, logical block 0, lost sync page write
[23010.880696] EXT4-fs (sda2): previous I/O error to superblock detected[23370.901056] sd 0:0:0:0: timing out command, waited 360s
[23370.901087] sd 0:0:0:0: [sda] tag#0 UNKNOWN(0x2003) Result: hostbyte=0x00 driverbyte=0x08
[23370.901101] sd 0:0:0:0: [sda] tag#0 Sense Key : 0x4 [current]
[23370.901112] sd 0:0:0:0: [sda] tag#0 ASC=0x44 ASCQ=0x0
[23370.901127] sd 0:0:0:0: [sda] tag#0 CDB: opcode=0x35 35 00 00 00 00 00 00 00 00 00
[23370.901153] print_req_error: I/O error, dev sda, sector 98304
[23370.901169] Buffer I/O error on dev sda2, logical block 0, lost sync page write
[23370.901226] EXT4-fs (sda2): previous I/O error to superblock detected[23370.901255] EXT4-fs error (device sda2): ext4_journal_check_start:61: Detected aborted journal
[23370.903860] EXT4-fs (sda2): Remounting filesystem read-only
[23730.941625] sd 0:0:0:0: timing out command, waited 360s
[23730.941656] sd 0:0:0:0: [sda] tag#0 UNKNOWN(0x2003) Result: hostbyte=0x00 driverbyte=0x08
[23730.941669] sd 0:0:0:0: [sda] tag#0 Sense Key : 0x4 [current]
[23730.941680] sd 0:0:0:0: [sda] tag#0 ASC=0x44 ASCQ=0x0
[23730.941696] sd 0:0:0:0: [sda] tag#0 CDB: opcode=0x35 35 00 00 00 00 00 00 00 00 00
[23730.941722] print_req_error: I/O error, dev sda, sector 98304
[23730.941737] Buffer I/O error on dev sda2, logical block 0, lost sync page write
[23730.941789] EXT4-fs error (device sda2): ext4_journal_check_start:61: Detected aborted journal
[23730.947110] EXT4-fs (sda2): previous I/O error to superblock detected[24090.972251] sd 0:0:0:0: timing out command, waited 360s
[24090.972283] sd 0:0:0:0: [sda] tag#0 UNKNOWN(0x2003) Result: hostbyte=0x00 driverbyte=0x08
[24090.972296] sd 0:0:0:0: [sda] tag#0 Sense Key : 0x4 [current]
[24090.972307] sd 0:0:0:0: [sda] tag#0 ASC=0x44 ASCQ=0x0
[24090.972322] sd 0:0:0:0: [sda] tag#0 CDB: opcode=0x35 35 00 00 00 00 00 00 00 00 00
[24090.972348] print_req_error: I/O error, dev sda, sector 98304
[24090.972362] Buffer I/O error on dev sda2, logical block 0, lost sync page write
[24090.972407] EXT4-fs error (device sda2): ext4_journal_check_start:61: Detected aborted journal
[24090.972413] EXT4-fs (sda2): previous I/O error to superblock detected[24450.992782] sd 0:0:0:0: timing out command, waited 360s
[24450.992813] sd 0:0:0:0: [sda] tag#0 UNKNOWN(0x2003) Result: hostbyte=0x00 driverbyte=0x08
[24450.992826] sd 0:0:0:0: [sda] tag#0 Sense Key : 0x4 [current]
[24450.992838] sd 0:0:0:0: [sda] tag#0 ASC=0x44 ASCQ=0x0
[24450.992853] sd 0:0:0:0: [sda] tag#0 CDB: opcode=0x35 35 00 00 00 00 00 00 00 00 00
[24450.992878] print_req_error: I/O error, dev sda, sector 98304
[24450.992893] Buffer I/O error on dev sda2, logical block 0, lost sync page write
[24450.992937] EXT4-fs error (device sda2): ext4_journal_check_start:61: Detected aborted journal
[24450.992943] EXT4-fs (sda2): previous I/O error to superblock detected[24811.003332] sd 0:0:0:0: timing out command, waited 360s
[24811.003366] sd 0:0:0:0: [sda] tag#0 UNKNOWN(0x2003) Result: hostbyte=0x00 driverbyte=0x08
[24811.003380] sd 0:0:0:0: [sda] tag#0 Sense Key : 0x4 [current]
[24811.003392] sd 0:0:0:0: [sda] tag#0 ASC=0x44 ASCQ=0x0
[24811.003407] sd 0:0:0:0: [sda] tag#0 CDB: opcode=0x35 35 00 00 00 00 00 00 00 00 00
[24811.003432] print_req_error: I/O error, dev sda, sector 98304
[24811.003448] Buffer I/O error on dev sda2, logical block 0, lost sync page write
[24811.003490] EXT4-fs error (device sda2): ext4_journal_check_start:61: Detected aborted journal
[24811.003496] EXT4-fs (sda2): previous I/O error to superblock detected[25171.033848] sd 0:0:0:0: timing out command, waited 360s
[25171.033881] sd 0:0:0:0: [sda] tag#0 UNKNOWN(0x2003) Result: hostbyte=0x00 driverbyte=0x08
[25171.033895] sd 0:0:0:0: [sda] tag#0 Sense Key : 0x4 [current]
[25171.033906] sd 0:0:0:0: [sda] tag#0 ASC=0x44 ASCQ=0x0
[25171.033921] sd 0:0:0:0: [sda] tag#0 CDB: opcode=0x35 35 00 00 00 00 00 00 00 00 00
[25171.033948] print_req_error: I/O error, dev sda, sector 98304
[25171.033963] Buffer I/O error on dev sda2, logical block 0, lost sync page write
[25171.034057] EXT4-fs error (device sda2) in ext4_da_write_end:3187: IO failure
[25171.035952] EXT4-fs (sda2): previous I/O error to superblock detected[25531.064346] sd 0:0:0:0: timing out command, waited 360s
[25531.064376] sd 0:0:0:0: [sda] tag#0 UNKNOWN(0x2003) Result: hostbyte=0x00 driverbyte=0x08
[25531.064390] sd 0:0:0:0: [sda] tag#0 Sense Key : 0x4 [current]
[25531.064401] sd 0:0:0:0: [sda] tag#0 ASC=0x44 ASCQ=0x0
[25531.064416] sd 0:0:0:0: [sda] tag#0 CDB: opcode=0x35 35 00 00 00 00 00 00 00 00 00
[25531.064442] print_req_error: I/O error, dev sda, sector 98304
[25531.064457] Buffer I/O error on dev sda2, logical block 0, lost sync page write
[25531.064585] EXT4-fs (sda2): previous I/O error to superblock detected[25891.084797] sd 0:0:0:0: timing out command, waited 360s
[25891.084832] sd 0:0:0:0: [sda] tag#0 UNKNOWN(0x2003) Result: hostbyte=0x00 driverbyte=0x08
[25891.084847] sd 0:0:0:0: [sda] tag#0 Sense Key : 0x4 [current]
[25891.084859] sd 0:0:0:0: [sda] tag#0 ASC=0x44 ASCQ=0x0
[25891.084874] sd 0:0:0:0: [sda] tag#0 CDB: opcode=0x35 35 00 00 00 00 00 00 00 00 00
[25891.084899] print_req_error: I/O error, dev sda, sector 98304
[25891.084914] Buffer I/O error on dev sda2, logical block 0, lost sync page write
[25891.084978] EXT4-fs error (device sda2) in ext4_da_write_end:3187: IO failure
[25891.086833] EXT4-fs (sda2): previous I/O error to superblock detected[26251.105268] sd 0:0:0:0: timing out command, waited 360s
[26251.105301] sd 0:0:0:0: [sda] tag#0 UNKNOWN(0x2003) Result: hostbyte=0x00 driverbyte=0x08
[26251.105314] sd 0:0:0:0: [sda] tag#0 Sense Key : 0x4 [current]
[26251.105325] sd 0:0:0:0: [sda] tag#0 ASC=0x44 ASCQ=0x0
[26251.105341] sd 0:0:0:0: [sda] tag#0 CDB: opcode=0x35 35 00 00 00 00 00 00 00 00 00
[26251.105367] print_req_error: I/O error, dev sda, sector 98304
[26251.105383] Buffer I/O error on dev sda2, logical block 0, lost sync page write
[26251.114858] EXT4-fs (sda2): previous I/O error to superblock detected[26611.155764] sd 0:0:0:0: timing out command, waited 360s
[26611.155796] sd 0:0:0:0: [sda] tag#0 UNKNOWN(0x2003) Result: hostbyte=0x00 driverbyte=0x08
[26611.155809] sd 0:0:0:0: [sda] tag#0 Sense Key : 0x4 [current]
[26611.155821] sd 0:0:0:0: [sda] tag#0 ASC=0x44 ASCQ=0x0
[26611.155836] sd 0:0:0:0: [sda] tag#0 CDB: opcode=0x35 35 00 00 00 00 00 00 00 00 00
[26611.155865] print_req_error: I/O error, dev sda, sector 98304
[26611.155881] Buffer I/O error on dev sda2, logical block 0, lost sync page write
[26611.155925] EXT4-fs error (device sda2): ext4_journal_check_start:61: Detected aborted journal
[26611.159537] EXT4-fs (sda2): ext4_writepages: jbd2_start: 7168 pages, ino 891722; err -30
Zofiel
Re: SSD randomly remount in readonly
Sat Jan 26, 2019 1:33 pm
Smart tests:
smartctl 6.6 2016-05-31 r4324 [armv7l-linux-4.14.94-v7+] (local build)
Copyright (C) 2002-16, Bruce Allen, Christian Franke, www.smartmontools.org
=== START OF READ SMART DATA SECTION ===
SMART Self-test log structure revision number 1
Num  Test_Description    Status                  Remaining  LifeTime(hours)  LBA_of_first_error
# 1  Extended offline    Completed without error       00%       491         -
# 2  Short offline       Completed without error       00%       484         -
# 3  Extended offline    Completed without error       00%       475         -
Botspot
Sat Jan 26, 2019 4:12 pm
Are you using the SSD as extra storage space, or is your Pi booting from it?
I'm not familiar with the x850 hat, but are you sure it is working properly?
Want to make your own Raspbian image?
  • Hard way: Mess with confusing terminal commands.
  • Easy way: Let Pi-Power-Tools do it all for you!
Boot your image in a VM, Flash from the Internet at top speed, Mount (to drop files in), Edit partitions, Shrink/Expand, Repair, and more. Enjoy! :)
https://github.com/Botspot/Pi-Power-Tools
Zofiel
Sat Jan 26, 2019 6:49 pm
I'm booting from it. I installed raspbian in the sdd, no cloning or moved from sd
I think so. The sdd is working nice for days or hours (randomly appear). I only see a warning with the hat:
I don't know if this info could be related.
Thanks a lot for your help.
