darkbladerxs
Issue starting scripts at system startup
Thu Jan 17, 2019 4:24 pm
Ok guys, I'm facing an other problem with the raspberry:
I've created two scripts main.py and send.py that are executed through the lxterminal by the system at the raspberry startup using a .sh file. The problem is that on the raspberry 3A+ the two scripts only start when I move the mouse or I press a keyboard button, while trying the same script on a raspberry 3B+ they automatically start. I don't know if this is caused by a the different software version between the two raspberries or something else, but I can't understand why the same script automatically starts only on the 3B+ system.
Do you have any idea on how to solve this?
Botspot
Re: Issue starting scripts at system startup
Fri Jan 18, 2019 8:13 pm
What process is supposed to start those scripts on system startup?
And are both Raspberries sequentially sharing the same SD card?
Want to make your own Raspbian image?
  • Hard way: Mess with confusing terminal commands.
  • Easy way: Let Pi-Power-Tools do it all for you!
Boot your image in a VM, Flash from the Internet at top speed, Mount (to drop files in), Edit partitions, Shrink/Expand, Repair, and more. Enjoy! :)
https://github.com/Botspot/Pi-Power-Tools
