stromberg
Pi Zero W built in wifi doesn't work , wifi dongle does
Thu Jan 17, 2019 1:17 am
I have been searching around for a good time trying to solve this issue but seem to find different issues around this one but not exactly what I am experiencing.
I have a Raspberry Pi Zero W v1.1
I have installed the 2018-11-13-raspbian-stretch-lite version.
My wpa_supplicant.conf file has correct information
I am able to connect to my wifi with a WIFI dongle attached to the Pi Zero W, however with just power plugged into the Pi Zero W it can not connect to the wifi.
I am able to SSH into my Pi Zero W from the wifi dongle.
I am able to SSH into my Pi Zero W over USB.
When I run ifconfig while SSH over USB I only get lo and usb0.
When I run ifconfig while SSH over wifi dongle I only get lo and wlan0 but no other wlan.
Like I said I have been trying to find the right search term and topic to look for and I've been at a loss. I've tried just about everything it feels like but then again there are some things I've probably missed.
I tried to lay out what I have and what I have done but honestly I am at a stand still at this point...
Any help is greatly appreciated.
davidcoton
Re: Pi Zero W built in wifi doesn't work , wifi dongle does
Thu Jan 17, 2019 10:56 am
stromberg wrote:My wpa_supplicant.conf file has correct information
You may be right, but post it here (edit out the passphrase) just in case.
Also, what does
cat /proc/device-tree/model
return? (Some Pis have excaped production with the wrong hardware version programmed.)
Signature retired
stromberg
Thu Jan 17, 2019 12:04 pm
I am able to connect to wifi through my dongle on the pi zero w, so I didn't post it
however it is :
country=US
update_config=1
network={
	ssid="SSID"
	psk="PASSWORD"
	key_mgmt=WPA-PSK
Also, what does
cat /proc/device-tree/model returns:
[email protected]:~ $ cat /proc/device-tree/model
Raspberry Pi Zero W Rev 1.1
DirkS
Thu Jan 17, 2019 12:19 pm
Also, what does
And your wpa_supplicant (as @davidcoton requested)?
And while you're at it you could also post your /boot/config.txt
davidcoton
Thu Jan 17, 2019 1:21 pm
It's embedded within the quote of my post :evil:
However it looks correct, unless the SSID is hidden by the router.
Signature retired
klricks
Thu Jan 17, 2019 1:47 pm
Is your WIFI 2.4GHz? The built in WIFI of the RPi Zero W does not do 5GHz.
stromberg
Thu Jan 17, 2019 6:08 pm
Ultimately what I'm trying to get to is I believe the wifi hardware built in to the pi zero itself does not work.
I have connected to both 2.4 and 5 through my dongle, however with just the pi zero plugged into power there is no wifi. Even over USB to be able to SSH in there is no wlan0 on the Device list.
I have tried to edit the wpa_supplicant to connect both 2.4 and 5 without the dongle but no luck
I can connect to my wifi in my home, as long as I have the dongle, but not with built in wifi.
mattmiller
Thu Jan 17, 2019 9:59 pm
Unless you buy or borrow another PiZeroW,, I don't think you'll be able to find out whether its hardware fault with your one or an incompatibility with your router.
Might be worth taking it around a friends/relations house and seeing if it doesn't work there either
stromberg
Thu Jan 17, 2019 11:31 pm
I decided to just order another one and I'll go from there.
At least then I'll have something to compare and contrast off of
Thanks for the help
