I'm new to the Raspberry Pi world and was very pleased to get it all setup and sharing files with Linux Mint and Win 7 PCs using Samba instructions at https://www.raspberrypi.org/documentati ... s/samba.md
However when using Leafpad on the Pi to edit a text file on a networked PC, the remote file opens ok and edits proceed as normal, but immediately after a 'Save' the Leafpad window is cleared and File Manager reports the text file has 0 bytes. Opening the file in Geany confirms it is now empty.
This behaviour occurs with files on a remote Linux PC and a Win 7 PC. Comparable tests with Geany work correctly with no data loss. As a double-check I installed gedit on the Pi and it functions properly. It is only Leafpad that causes data loss.
I've searched the Raspbian forum but not found any other reports, but I did find this Github thread https://github.com/stevenhoneyman/l3afpad/issues/13 describing a similar situation (Nov 2015) but no resolution.
The xed and Geany editors in Linux Mint, and Notepad++ in Win 7 edit remote text files on the Pi correctly, which I suppose is the more conventional way of working. However, as this issue is pretty serious I wondered if there was a solution or workaround?
At the moment I've made Geany the default text editor.
Thanks.
System: Pi 3B+ with latest Raspbian 9.6
