Etcher does not work; it corrupted my SD card. My 64-gig. SD card became only 43 megabytes.fruitoftheloom wrote: ↑Fri Jan 11, 2019 4:39 am
Just use standalone Raspbian Stretch with Desktop and create a card using Etcher...
WCHD wrote: ↑Sat Jan 12, 2019 3:57 pmEtcher does not work; it corrupted my SD card. My 64-gig. SD card became only 43 megabytes.fruitoftheloom wrote: ↑Fri Jan 11, 2019 4:39 am
1. Raspberry Pi 3 model BHawaiianPi wrote: ↑Fri Jan 11, 2019 9:15 amLike others, I also recommend you download the latest Raspbian image and write it to your card with the Etcher image writing utility.
- Which model of Raspberry Pi?
- Which version of NOOBS?
- What SD card are you using (capacity, brand, model)?
- What are you using for a power supply?
- What kind of monitor or display are you using?
Download Raspbian here: https://www.raspberrypi.org/downloads/raspbian/
Download Etcher here: https://www.balena.io/etcher/
You don't have to format the card before writing an image, and you don't even have to extract the image file (Etcher will do that for you). Just run Etcher, select the Raspbian .zip file you downloaded, choose your SD card (usually it will be selected by default), and write.
If you still want help with NOOBS, answer the questions above.
Either your SD card is fake, or faulty, or you have not understood the disk layout.
Windows can see all partitions, it will invite you to reformat the EXT4 partition (because it's an alien filesystem). DO NOT accept that offer from Windows to format anything.
1. 7-ZIPprocount wrote: ↑Fri Jan 11, 2019 10:58 amIn addition to HawaiianPi's questions:NOOBS was designed to be easier to burn an OS image to an SD card for new users who are more used to a Windows environment. Mostly it works just fine, but occasionally:
- How did you unzip NOOBS (Native Windows tools, or 7zip or ...)
- What cable do you use to connect to your monitor - HDMI or composite?
Nowadays Etcher has made the process of flashing an image a lot easier and avoids all of the above issues.
- formatting an SD card to FAT32 becomes problematic due to the size of the SD card.
- unzipping noobs.zip becomes problematic due to the large size of the zip file requiring a newer zip format. (Try installing noobs-lite.zip instead).
- some users manage to format the SD card without an MBR, causing later problems with NOOBS not being able to find its files.
If you want the features of NOOBS, you should take a look at PINN, which is like NOOBS on steroids.
It has a an Etcher image which makes it as easy to install as Raspbian using Etcher.
It supports all of NOOBS' features but additionally:So PINN is a lot more than just an OS installer and boot manager, as it now is more of an OS management and administration tool as well.
- Has over 50 different operating systems you can install from the internet with just the click of a button (more being added all the time)
- Backup, restore, re-install or replace any of your OSes without affecting any others you may have installed
- Can clone an entire SD card (using the equivalent of Raspbian's SD card copier), but offline
- Can easily **** your OS if it becomes corrupted
- Allows restore of your login password in case it is forgotten
- Works with TV remotes using the CEC protocol for use with Media centres or Gaming OSes
- Allows OS customisations on OS installation using "flavours" (a bit like piBakery)
- Allows ProjectSpaces to be created (like WDPiDrive) to install multiple versions of the same OS, or to defer OS installation
- Only uses 64MB of your precious SD card.
PINN is still in active development and its self-update feature means you will always have the latest version whenever you want.
Check out the link in my signature for the full version history, links to the comprehensive documentation and download links.
But anyway, the answers to HawaiianPi's and my questions above will help people support you better for both NOOBS or PINN.
Why do you want NOOBS ?
Well, the first link does take you to the main PINN thread on this forum. At the end of the first post, you will find links to the documentation and source code on Github, and to the download file on Sourceforge.WCHD wrote: ↑Sat Jan 12, 2019 11:24 pmOh yeah, PINN! I'll try.procount wrote: ↑Fri Jan 11, 2019 10:58 amIf you want the features of NOOBS, you should take a look at PINN, which is like NOOBS on steroids.
EDIT: Can't download: redirects me back to the forum
Because the OP wants a new level of masochism. NOOBS or PINN are only useful if you have more than one OS on a single (large SDCard) and want to be able to switch OS without removing and inserting a new SDCard. Other than that NOOBS has no value left now that Etcher is the easy way to write bootable SDCards on Windows.
