hal9008
Recover MYSQL data
Tue Jan 08, 2019 1:44 pm
Hello.
Few days ago I posted a message in this forum about a problem with some updates here -->viewtopic.php?t=230257. I was able to solve the problem.
BUT... The problem of the other post was caused by a failure of the hard disk (the operating system of my raspberry is in a USB hard disk). One day the system were not able to boot.
Now I have another disk and the information of the other disk is recovered (all the files). I installed the operating system in the new disk and the raspberry is working... But the problem is .... How can I put the old mysql databases in my new system. I want to take some of the databases but i haven't got the *.sql files. I only have the /var/lib/mysql folder (And i think that all the information in this folder is in good condition). ¿How can i convert the databases that there are in this folder to a .sql file to import in the new system?
Regards.
pfletch101
Re: Recover MYSQL data
Tue Jan 08, 2019 9:33 pm
The first thing I would try is shutting down MySQL, copying the contents of the data folder from the old system into /var/lib/mysql on the new system, and restarting MySQL. There should be a good chance that all your old data will now be there and accessible.
Tue Jan 08, 2019 9:59 pm
One step more than that run sudo /usr/bin/mysqld_safe which attempts to recover tables from journals and logs.
This is a doctor free zone.
hal9008
Thu Jan 10, 2019 12:03 am
I still can't recover the databases.
If i put all the folder /var/lib/mysql recovered in the folder of the new installation of mysql, the service mysql cant start. If I try to start mysql service, it says the following.
[email protected]:/var/lib# sudo service mysql start
Job for mysql.service failed. See 'systemctl status mysql.service' and 'journalctl -xn' for details.
[email protected]:/var/lib# systemctl status mysql.service
● mysql.service - LSB: Start and stop the mysql database server daemon
   Loaded: loaded (/etc/init.d/mysql)
   Active: failed (Result: exit-code) since Wed 2019-01-09 23:56:23 UTC; 38s ago
  Process: 583 ExecStop=/etc/init.d/mysql stop (code=exited, status=0/SUCCESS)
  Process: 650 ExecStart=/etc/init.d/mysql start (code=exited, status=1/FAILURE)
Jan 09 23:56:23 raspberrypi mysql[650]: Starting MySQL database server: mysqld . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . failed!
Jan 09 23:56:23 raspberrypi systemd[1]: mysql.service: control process exited, code=exited status=1
Jan 09 23:56:23 raspberrypi systemd[1]: Failed to start LSB: Start and stop the mysql database server daemon.
Jan 09 23:56:23 raspberrypi systemd[1]: Unit mysql.service entered failed state.
[email protected]:/var/lib# journalctl -xn
-- Logs begin at Wed 2019-01-09 23:06:58 UTC, end at Wed 2019-01-09 23:56:23 UTC. --
Jan 09 23:56:23 raspberrypi /etc/init.d/mysql[1392]: 0 processes alive and '/usr/bin/mysqladmin --defaults-file=/etc/mysql/debian.cnf ping' resulted in
Jan 09 23:56:23 raspberrypi /etc/init.d/mysql[1392]: [61B blob data]
Jan 09 23:56:23 raspberrypi /etc/init.d/mysql[1392]: error: 'Can't connect to local MySQL server through socket '/var/run/mysqld/mysqld.sock' (2)'
Jan 09 23:56:23 raspberrypi /etc/init.d/mysql[1392]: Check that mysqld is running and that the socket: '/var/run/mysqld/mysqld.sock' exists!
-- Subject: Unit mysql.service has failed
-- Defined-By: systemd
-- Support: http://lists.freedesktop.org/mailman/listinfo/systemd-devel
-- Unit mysql.service has failed.
-- The result is failed.
Jan 09 23:56:23 raspberrypi sudo[629]: pam_unix(sudo:session): session closed for user root
So I try to copy only the folders with the name of the databases that i want to recover in /var/lib/mysql of the new installation. If i did that, i can start the service, enter in the database and see the tables, but if I try to export the sql file I have an error.
[email protected]:/var/lib# mysql
Welcome to the MySQL monitor.  Commands end with ; or \g.
Your MySQL connection id is 45
Server version: 5.5.62-0+deb8u1 (Raspbian)
Copyright (c) 2000, 2018, Oracle and/or its affiliates. All rights reserved.
Oracle is a registered trademark of Oracle Corporation and/or its
affiliates. Other names may be trademarks of their respective
owners.
Type 'help;' or '\h' for help. Type '\c' to clear the current input statement.
mysql> show databases;
| Database           |
| information_schema |
| flopy.es           |
| mysql              |
| performance_schema |
4 rows in set (0.00 sec)
mysql> use flopy.es;
Reading table information for completion of table and column names
You can turn off this feature to get a quicker startup with -A
Database changed
mysql> show tables;
| Tables_in_flopy.es           |
| flopyescommentmeta           |
| flopyescomments              |
| flopyeslinks                 |
| flopyesoptions               |
| flopyespostmeta              |
| flopyesposts                 |
| flopyesterm_relationships    |
| flopyesterm_taxonomy         |
| flopyestermmeta              |
| flopyesterms                 |
| flopyesusermeta              |
| flopyesusers                 |
| oc_clndr_share_calendar      |
| oc_clndr_share_event         |
| oc_contacts_addressbooks     |
| oc_contacts_cards            |
| oc_contacts_cards_properties |
| oc_documents_invite          |
| oc_documents_member          |
| oc_documents_revisions       |
| oc_documents_session         |
| oc_file_map                  |
| oc_files_trash               |
| oc_files_trashsize           |
| oc_files_versions            |
| oc_gallery_sharing           |
| oc_group_admin               |
| oc_group_user                |
| oc_groups                    |
| oc_jobs                      |
| oc_lucene_status             |
| oc_mimetypes                 |
| oc_permissions               |
| oc_pictures_images_cache     |
| oc_preferences               |
| oc_privatedata               |
| oc_properties                |
| oc_share                     |
| oc_storages                  |
| oc_users                     |
| oc_vcategory                 |
| oc_vcategory_to_object       |
42 rows in set (0.00 sec)
mysql> quit;
Bye
[email protected]:/var/lib# sudo mysqldump flopy.es > flopyes.sql
mysqldump: Got error: 1033: Incorrect information in file: './[email protected]/flopyescommentmeta.frm' when using LOCK TABLES
I try to use mysqldump as this:
[email protected]:/var/lib# mysqldump --user=root --password=myspassword flopy.es > /home/pi/flopy.sql
mysqldump: Got error: 1045: Access denied for user 'root'@'localhost' (using password: YES) when trying to connect
But as you can see i still can't download the sql file. I put in the configuration of the new database the same user and password of the old database. I try this in my raspberry and in a laptop with linux mint, but in both computers I can't recover any file.
Any idea to solve this??
pfletch101
Thu Jan 10, 2019 1:13 am
I am out of ideas. This is, of course, why you should keep serial backups of important data on media other than your working disks. I have never had to recover a MySQL installation from scratch, since I have always ben able to revert to the most recent database backups (which will be no more than a day or two old for important data). For really vital and irretrievable data, I also keep separate journals of additions and changes, so that data entered since the last backup can be recovered.
Andyroo
Thu Jan 10, 2019 1:32 am
You may be able to run a SELECT * across each table and save the result to file and then import the data to another database.
Long winded but it may get you some data out...
erkc29
Thu Jan 10, 2019 6:08 am
I hope this post might help you: MySQL Database Repair
Andyroo
Thu Jan 10, 2019 11:53 am
Tut tut - that’s basically an advert for Data Retainers service.
A better link is to the actual guide https://mariadb.com/kb/en/library/myisamchk/ - and I totally forgot it :oops:
This does depend on the data being in ISAM tables and not InnoDB/XtraDB format though - I would stick to the SELECT commands.
