Raspberry Pi start-up problems
Posted: Fri Nov 16, 2012 12:41 pm
by Rob_Skipper
I've got a really strange problem with my Raspberry Pi. If I boot it with HDMI monitor, it start and connect to my network. Without monitor plugin, it will not connect to my network, and I'm not sure if it starts? (How can I check?)
Somebody with the same problem and an solution?
Rob
Re: Raspberry Pi start-up problems
Posted: Fri Nov 16, 2012 1:08 pm
by MaxK1
Composite monitor/TV?
Posted: Fri Nov 16, 2012 1:19 pm
by redhawk
If network doesn't start enter the following command: ifconfig does eth0 show errors or missing IP address??
Try:
ifdown eth0
ifup eth0
is your network up and running??
Other than that try measuring the voltage at TP1/TP2, what readings are you getting??
Richard S.
Posted: Fri Nov 16, 2012 1:36 pm
by Rob_Skipper
HDMI
Network is ok, with attached monitor (HDMI) it will start and connect to the network. Without the monitor, nothing.
And typing wil not work without monitor, if I attached it, everything works perfect.
I think that it will not start at all? (Red LED is burning)
