I can't get Bluetooth to work again at all until I reboot the computer completely. This makes using Bluetooth practically useless because it only works well for a few minutes before crashing.
There's some info from dmesg if this explains anything:
[ 14.618685] Bluetooth: Core ver 2.22
[ 14.618737] NET: Registered protocol family 31
[ 14.618740] Bluetooth: HCI device and connection manager initialized
[ 14.618755] Bluetooth: HCI socket layer initialized
[ 14.618762] Bluetooth: L2CAP socket layer initialized
[ 14.618781] Bluetooth: SCO socket layer initialized
[ 14.627959] Bluetooth: HCI UART driver ver 2.3
[ 14.627972] Bluetooth: HCI UART protocol H4 registered
[ 14.627975] Bluetooth: HCI UART protocol Three-wire (H5) registered
[ 14.628132] Bluetooth: HCI UART protocol Broadcom registered
[ 14.907265] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 14.907274] Bluetooth: BNEP filters: protocol multicast
[ 14.907287] Bluetooth: BNEP socket layer initialized
[ 14.970709] Bluetooth: RFCOMM TTY layer initialized
[ 14.970732] Bluetooth: RFCOMM socket layer initialized
[ 14.970754] Bluetooth: RFCOMM ver 1.11
[ 15.308325] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[ 16.631612] Under-voltage detected! (0x00050005)
[ 20.791614] Voltage normalised (0x00000000)
[ 63.603946] input: 00:14:BE:88:20:0D as /devices/virtual/input/input3
[ 97.524635] Under-voltage detected! (0x00050005)
[ 101.683557] Voltage normalised (0x00000000)
[ 229.558435] Bluetooth: hci0 hardware error 0x00
[ 233.782282] Bluetooth: hci0 command 0x1003 tx timeout
[ 235.861674] Bluetooth: hci0 command 0x1001 tx timeout
[ 237.941013] Bluetooth: hci0 command 0x1009 tx timeout
[ 242.099949] Bluetooth: hci0 hardware error 0x00
[ 244.179325] Bluetooth: hci0 command 0x1003 tx timeout
[ 246.258826] Bluetooth: hci0 command 0x1001 tx timeout
[ 248.338198] Bluetooth: hci0 command 0x1009 tx timeout
[ 251.937790] swap_info_get: Unused swap offset entry 00007350
[ 251.937801] BUG: Bad page map in process vlc pte:0039a800 pmd:27e10835
[ 251.937817] addr:71618000 vm_flags:00000075 anon_vma: (null) mapping:b567d21c index:7d9
[ 251.937842] file:swrast_dri.so fault:ext4_filemap_fault mmap:ext4_file_mmap readpage:ext4_readpage
[ 251.937852] CPU: 0 PID: 1267 Comm: vlc Tainted: G C 4.14.90-v7+ #1183
[ 251.937854] Hardware name: BCM2835
[ 251.937875] [<8010ff30>] (unwind_backtrace) from [<8010c174>] (show_stack+0x20/0x24)
[ 251.937885] [<8010c174>] (show_stack) from [<8078b864>] (dump_stack+0xd4/0x118)
[ 251.937898] [<8078b864>] (dump_stack) from [<80255b6c>] (print_bad_pte+0x150/0x1b4)
[ 251.937906] [<80255b6c>] (print_bad_pte) from [<80257ee0>] (unmap_page_range+0x5a0/0x668)
[ 251.937914] [<80257ee0>] (unmap_page_range) from [<80257ff4>] (unmap_single_vma+0x4c/0x54)
[ 251.937920] [<80257ff4>] (unmap_single_vma) from [<802582a0>] (unmap_vmas+0x64/0x78)
[ 251.937930] [<802582a0>] (unmap_vmas) from [<8025cc60>] (unmap_region+0x8c/0xc8)
[ 251.937938] [<8025cc60>] (unmap_region) from [<8025f100>] (do_munmap+0x240/0x368)
[ 251.937946] [<8025f100>] (do_munmap) from [<8025f864>] (vm_munmap+0x68/0x88)
[ 251.937954] [<8025f864>] (vm_munmap) from [<8025f8b0>] (SyS_munmap+0x2c/0x30)
[ 251.937964] [<8025f8b0>] (SyS_munmap) from [<80108000>] (ret_fast_syscall+0x0/0x28)
[ 251.937970] Disabling lock debugging due to kernel taint
[ 251.937975] swap_info_get: Bad swap file entry 09dc021e
[ 251.937979] BUG: Bad page map in process vlc pte:ee010f10 pmd:27e10835
[ 251.937986] addr:71621000 vm_flags:00000075 anon_vma: (null) mapping:b567d21c index:7e2
[ 251.937997] file:swrast_dri.so fault:ext4_filemap_fault mmap:ext4_file_mmap readpage:ext4_readpage
[ 251.938033] CPU: 0 PID: 1267 Comm: vlc Tainted: G B C 4.14.90-v7+ #1183
[ 251.938036] Hardware name: BCM2835
[ 251.938044] [<8010ff30>] (unwind_backtrace) from [<8010c174>] (show_stack+0x20/0x24)
[ 251.938050] [<8010c174>] (show_stack) from [<8078b864>] (dump_stack+0xd4/0x118)
[ 251.938057] [<8078b864>] (dump_stack) from [<80255b6c>] (print_bad_pte+0x150/0x1b4)
[ 251.938064] [<80255b6c>] (print_bad_pte) from [<80257ee0>] (unmap_page_range+0x5a0/0x668)
[ 251.938072] [<80257ee0>] (unmap_page_range) from [<80257ff4>] (unmap_single_vma+0x4c/0x54)
[ 251.938078] [<80257ff4>] (unmap_single_vma) from [<802582a0>] (unmap_vmas+0x64/0x78)
[ 251.938085] [<802582a0>] (unmap_vmas) from [<8025cc60>] (unmap_region+0x8c/0xc8)
[ 251.938093] [<8025cc60>] (unmap_region) from [<8025f100>] (do_munmap+0x240/0x368)
[ 251.938100] [<8025f100>] (do_munmap) from [<8025f864>] (vm_munmap+0x68/0x88)
[ 251.938108] [<8025f864>] (vm_munmap) from [<8025f8b0>] (SyS_munmap+0x2c/0x30)
[ 251.938116] [<8025f8b0>] (SyS_munmap) from [<80108000>] (ret_fast_syscall+0x0/0x28)
[ 251.938119] BUG: Bad page map in process vlc pte:ec510f1f pmd:27e10835
[ 251.938126] addr:71622000 vm_flags:00000075 anon_vma: (null) mapping:b567d21c index:7e3
[ 251.938137] file:swrast_dri.so fault:ext4_filemap_fault mmap:ext4_file_mmap readpage:ext4_readpage
[ 251.938158] CPU: 0 PID: 1267 Comm: vlc Tainted: G B C 4.14.90-v7+ #1183
[ 251.938160] Hardware name: BCM2835
[ 251.938167] [<8010ff30>] (unwind_backtrace) from [<8010c174>] (show_stack+0x20/0x24)
[ 251.938173] [<8010c174>] (show_stack) from [<8078b864>] (dump_stack+0xd4/0x118)
[ 251.938181] [<8078b864>] (dump_stack) from [<80255b6c>] (print_bad_pte+0x150/0x1b4)
[ 251.938188] [<80255b6c>] (print_bad_pte) from [<80257240>] (_vm_normal_page+0x80/0xcc)
[ 251.938194] [<80257240>] (_vm_normal_page) from [<80257c18>] (unmap_page_range+0x2d8/0x668)
[ 251.938201] [<80257c18>] (unmap_page_range) from [<80257ff4>] (unmap_single_vma+0x4c/0x54)
[ 251.938208] [<80257ff4>] (unmap_single_vma) from [<802582a0>] (unmap_vmas+0x64/0x78)
[ 251.938215] [<802582a0>] (unmap_vmas) from [<8025cc60>] (unmap_region+0x8c/0xc8)
[ 251.938222] [<8025cc60>] (unmap_region) from [<8025f100>] (do_munmap+0x240/0x368)
[ 251.938229] [<8025f100>] (do_munmap) from [<8025f864>] (vm_munmap+0x68/0x88)
[ 251.938237] [<8025f864>] (vm_munmap) from [<8025f8b0>] (SyS_munmap+0x2c/0x30)
[ 251.938244] [<8025f8b0>] (SyS_munmap) from [<80108000>] (ret_fast_syscall+0x0/0x28)
[ 251.938248] BUG: Bad page map in process vlc pte:ec410f1f pmd:27e10835
[ 251.938254] addr:71623000 vm_flags:00000075 anon_vma: (null) mapping:b567d21c index:7e4
[ 251.938262] file:swrast_dri.so fault:ext4_filemap_fault mmap:ext4_file_mmap readpage:ext4_readpage
[ 251.938268] CPU: 0 PID: 1267 Comm: vlc Tainted: G B C 4.14.90-v7+ #1183
[ 251.938270] Hardware name: BCM2835
[ 251.938277] [<8010ff30>] (unwind_backtrace) from [<8010c174>] (show_stack+0x20/0x24)
[ 251.938283] [<8010c174>] (show_stack) from [<8078b864>] (dump_stack+0xd4/0x118)
[ 251.938289] [<8078b864>] (dump_stack) from [<80255b6c>] (print_bad_pte+0x150/0x1b4)
[ 251.938296] [<80255b6c>] (print_bad_pte) from [<80257240>] (_vm_normal_page+0x80/0xcc)
[ 251.938304] [<80257240>] (_vm_normal_page) from [<80257c18>] (unmap_page_range+0x2d8/0x668)
[ 251.938310] [<80257c18>] (unmap_page_range) from [<80257ff4>] (unmap_single_vma+0x4c/0x54)
[ 251.938317] [<80257ff4>] (unmap_single_vma) from [<802582a0>] (unmap_vmas+0x64/0x78)
[ 251.938324] [<802582a0>] (unmap_vmas) from [<8025cc60>] (unmap_region+0x8c/0xc8)
[ 251.938331] [<8025cc60>] (unmap_region) from [<8025f100>] (do_munmap+0x240/0x368)
[ 251.938340] [<8025f100>] (do_munmap) from [<8025f864>] (vm_munmap+0x68/0x88)
[ 251.938347] [<8025f864>] (vm_munmap) from [<8025f8b0>] (SyS_munmap+0x2c/0x30)
[ 251.938354] [<8025f8b0>] (SyS_munmap) from [<80108000>] (ret_fast_syscall+0x0/0x28)
[ 252.058824] BUG: Bad rss-counter state mm:b499b180 idx:0 val:4
[ 252.058849] BUG: Bad rss-counter state mm:b499b180 idx:2 val:-2
[ 252.337164] Bluetooth: hci0 hardware error 0x00
[ 254.416602] Bluetooth: hci0 command 0x1003 tx timeout
[ 256.496116] Bluetooth: hci0 command 0x1001 tx timeout
[ 258.575600] Bluetooth: hci0 command 0x1009 tx timeout
[ 262.574541] Bluetooth: hci0 hardware error 0x00
[ 264.654082] Bluetooth: hci0 command 0x1003 tx timeout
[ 266.733459] Bluetooth: hci0 command 0x1001 tx timeout
[ 268.812953] Bluetooth: hci0 command 0x1009 tx timeout
[ 272.811987] Bluetooth: hci0 hardware error 0x00
[ 274.891431] Bluetooth: hci0 command 0x1003 tx timeout
[ 276.970946] Bluetooth: hci0 command 0x1001 tx timeout
[ 279.050483] Bluetooth: hci0 command 0x1009 tx timeout
[ 283.049528] Bluetooth: hci0 hardware error 0x00
[ 285.129067] Bluetooth: hci0 command 0x1003 tx timeout
[ 287.208448] Bluetooth: hci0 command 0x1001 tx timeout
[ 289.287932] Bluetooth: hci0 command 0x1009 tx timeout
[ 293.286998] Bluetooth: hci0 hardware error 0x00
[ 295.366455] Bluetooth: hci0 command 0x1003 tx timeout
[ 297.446047] Bluetooth: hci0 command 0x1001 tx timeout
[ 299.525445] Bluetooth: hci0 command 0x1009 tx timeout
[ 303.524572] Bluetooth: hci0 hardware error 0x00
[ 305.604067] Bluetooth: hci0 command 0x1003 tx timeout
[ 307.683515] Bluetooth: hci0 command 0x1001 tx timeout
[ 309.763056] Bluetooth: hci0 command 0x1009 tx timeout
[ 313.762180] Bluetooth: hci0 hardware error 0x00
[ 315.841640] Bluetooth: hci0 command 0x1003 tx timeout
[ 317.921130] Bluetooth: hci0 command 0x1001 tx timeout
[ 320.000643] Bluetooth: hci0 command 0x1009 tx timeout
[ 323.999730] Bluetooth: hci0 hardware error 0x00
[ 326.079211] Bluetooth: hci0 command 0x1003 tx timeout
