darkstormplayz
Permission denied error even when using sudo.
Tue Dec 18, 2018 12:50 pm
So I am trying to delete all the text within a TXT file using this command
echo " " > _autoplaylist.txt
I then get a
-bash: _autoplaylist.txt: Permission Denied
error I get the same error even using sudo.
Plase help.
ChipTechno
Re: Permission denied error even when using sudo.
Tue Dec 18, 2018 2:01 pm
Do you own the file ? Can you post the result of
ls -l _autoplaylist.txt
Try
chown pi;pi _autoplaylist.txt
and
chmod 775 _autoplaylist.txt
and run your command again.
Paeryn
Tue Dec 18, 2018 4:45 pm
Also, are you in a directory where you have write permission? Typically any directory outside of your home directory (and it's sub-directories) are not writable by a normal user.
Just putting sudo in front of the command won't have any effect on whether the redirection can happen, sudo only runs echo as root, the redirection is done by the calling shell before the command is run and so is still being done as the user. Basically the shell opens (or creates) the file _autoplaylist.txt first and then runs sudo echo " " with its output set to the file rather than the terminal.
If you need to have the redirection applied with root permission (really don't do this unless you have to or know what you are doing, it generally isn't the correct way)
sudo sh -c 'echo " " > _autoplaylist.txt'
She who travels light — forgot something.
jahboater
Tue Dec 18, 2018 4:53 pm
Once you have the permissions sorted out, you can save some typing:
> _autoplaylist.txt
is all you need:
pi@pi3:~ $ ls -l myfile
-rw-r--r-- 1 pi pi 362212 Dec 18 16:57 myfile
pi@pi3:~ $ >myfile
-rw-r--r-- 1 pi pi 0 Dec 18 16:57 myfile
pi@pi3:~ $
hortimech
Tue Dec 18, 2018 5:13 pm
Try:
[code}
sh -c 'echo | sudo tee -a _autoplaylist.txt'
[/code]
hortimech
Tue Dec 18, 2018 5:14 pm
And, of course it should have been
n67
Tue Dec 18, 2018 5:19 pm
I see this "sudo tee -a" hack a lot on this board. Gosh, is it ugly. There's so many better ways...
"L'enfer, c'est les autres"
G fytc hsqr rum umpbq rm qyw rm rfc kmbq md rfgq dmpsk:
Epmu Sn!
J lnacjrw njbruh-carppnanm vxm rb mnuncrwp vh yxbcb!
mfa298
Tue Dec 18, 2018 5:42 pm
the "sudo tee" trick isn't that bad a method although the version above won't do much. The -a for tee is append to file so that will just add a blank line to the end of the file. Personally I find it less ugly than the "sudo sh -c 'echo > file'" method that is the usual alternative. The other benefit with tee is it works with heredocs for multiline additions ("sudo tee /myfile << _EOF" and then the lines to add ending with _EOF)
Roken
Tue Dec 18, 2018 7:44 pm
Do you possibly have the immutable flag set?
sudo chattr -i path/to/file
PeterO
Tue Dec 18, 2018 8:22 pm
If you aren't going to help why do you post replies to questions ?
PeterO
n67
Tue Dec 18, 2018 9:08 pm
PeterO
Like you did?
Epmu Sn!
mfa298
Tue Dec 18, 2018 9:13 pm
PeterO
Like you did?
I suspect PeterO was suggesting that maybe if there are so many better ways you should be helpful and list them and maybe a line about why they're better. As with most things Unix there are multiple ways of doing a task sometimes it's down to personal preference sometimes people may just have not seen a better way of doing something (for me I like sudo tee as it works on most systems I use - some of the other hacks are Linux only)
Paeryn
Wed Dec 19, 2018 2:15 am
I don't like the tee method because tee will write its input to the file and to stdout. Granted for something short on the command line the user probably won't mind. It all depends on what you are used to and what is most convenient for the task at hand.
rhubarbdog
Wed Dec 19, 2018 7:37 pm
Try making the file executable. That's what your trying when you type ./_autoplay-list
Have you used
ls -l _autoplay-list
to detetmine who owns it and what the permission are.
code_exec
Wed Dec 19, 2018 8:26 pm
I then get a
Plase help.
Try:
chmod +x _autoplaylist.txt
n67
Wed Dec 19, 2018 9:42 pm
It is unlikely that this is a "make it executable" problem, given that:
1) It is a TXT file (according to the OP)
2) He is trying to delete all the text from the file.
Epmu Sn!
Thu Dec 20, 2018 7:58 am
If you aren't going to help why do you post replies to questions?
For the purposes of deleting the contents of a file, this should work (unlike my keyboard, which is being annoying today):
sudo truncate -s 0 _autoplaylist.txt
I'm not sure of the file's ownership in this particular case. Normally sudo etc wouldn't be needed, but it looks like it might be here.
Thu Dec 20, 2018 3:57 pm
Has anyone asked the OP where the file exists? Is it on a mounted filesystem? Is it on NTFS without ntfs-3g (for example) which would make the filesystem read-only? Is it on a shared (CIFS or NFS) filesystem that may be mounted read-only?
We've got none of that context information from the OP.
