issue with enter key and screen program
Posted: Sat Dec 15, 2018 5:48 pm
by werefol
hi guys i'm starting with this raspbian thing and trying to learn about it but i encountered this issue when inside an instance of the screen program, i'm trying to test some fona commands but typing the command and when i want to test the command by pressing enter key, it just return the propmt to start and does nothing but that, don't know what could be or if i am doing something wrong, hope you can understand me and can help me, if you guys want me to explain it a bit better i would try to! thanks in advance to those who can help me
Re: issue with enter key and screen program
Posted: Mon Dec 17, 2018 9:48 am
by neilgl
Yes please explain more. What command do you type in?
Posted: Tue Dec 18, 2018 1:08 pm
by werefol
i opened a screen instance and typed AT, when i press enter key the promp positioned at the beggining of the current line and does nothing, i mean it doesn't send the command i'm typing, i don't know why it's happening that.
Posted: Tue Dec 18, 2018 1:51 pm
by pcmanbob
From this statement I assume you are attempting to communicate with a GSM module, if this is in fact what you are doing then sending AT with no other commands will not get any response AT just means "attention" your GSM module will then be expecting a command to follow.
https://www.developershome.com/sms/atCommandsIntro.asp
Posted: Tue Dec 18, 2018 2:09 pm
by werefol
i tried it already and the first time i followed the tutorial to set up the fona it worked as expected, i typed AT and i got an OK response back, but now every time i open up a terminal, the enter key does nothing but to position the prompt to the beggining of the current line, i already tried with screen and picocom and does exactly the same i change the keyboard config already to test if the keyboard config was messing this up but it didin't work =/
Posted: Tue Dec 18, 2018 3:52 pm
by pcmanbob
Then I suggest you look at your project and compare it to the tutorial you were following and see what you are doing differently, it might also be worth checking all connections between the pi and your GSM module.
Posted: Wed Dec 19, 2018 12:09 am
by werefol
already did that like 100 times, is really desperate that things doesn't work as expected to...
i am now try to do it in python, passing the command to the port and then the read method of the port send back the string of the command that i'm sending, as a response instead of the expected response that i'm waiting =/
https://imgur.com/a/NHluYpz
here in this image you can see the command that i am sending and what i am receiving from it
Posted: Wed Dec 19, 2018 12:45 am
by DougieLawson
Have you disabled the serial console in sudo raspi-config or in the preferences GUI?
Posted: Wed Dec 19, 2018 12:34 pm
by pcmanbob
Seeing as you say you had it working the first time you followed the tutorial what are you doing differently this time ?
what hardware or software have you changed between the first time and now ?
Posted: Wed Dec 19, 2018 1:08 pm
by werefol
i didn't change anything neither the hardware nor the software, i followed the tutorial just fine over and over again, i formatted the raspbian os to a new one and had a fresh start to see what's happening and if any opf the downloaded software i am installing is the source of the problem and trying everything i'm finding on the web is really frustating =(
Posted: Wed Dec 19, 2018 1:11 pm
by werefol
i am actually triying that my friend and see how that goes, i'll tell you when i finish testing it ty
Posted: Wed Dec 19, 2018 2:23 pm
by werefol
look guys in these 2 images i am running the process and i'll show you the active ports in the system for the communication that i need to stablish
https://imgur.com/T1frBtq
https://imgur.com/iTylQz2
i am currently using a SIM808 gsm module
i have few questions that i hope you can answer me guys so:
How do i know if the module is correctly connected?
How do i know which serial port is the module using(or a command to list the serial ports and their guests)?
i suppose that the read method of the serial library is returning the same command as a string and not a real response to the command, because i am connecting to the wrong serial port but i dont really know what can be? hope you guys can help with this
Posted: Wed Dec 19, 2018 7:30 pm
by rhubarbdog
Unplug your GSM. Wait 1 minute, plug it back in type
dmesg | tail
that should indicate which device file the modem has connected to
Posted: Wed Dec 19, 2018 9:24 pm
by werefol
dmesg | tail
this is what i got back executing what you suggest
https://imgur.com/ZLjQISn
what should i watch here? it seems like there's only information about internet ports
