gokulnarayanan
None of the gpios are working in my rpi 3B .
Thu Dec 13, 2018 10:52 am
my Rpi 3 was communicating with arduino through UART. Sudddenly it stopped working . Later on when i did the gpio test I found out that none of my gpios are usable.
This is what i got on the terminal when i did the gpio test. Kindly help me troubleshoot this.
pi@raspberrypi:~ $ sudo chmod +x ./gpiotest
pi@raspberrypi:~ $ ./gpiotest
This program checks the Pi's (user) gpios.
The program reads and writes all the gpios. Make sure NOTHING
is connected to the gpios during this test.
The program uses the pigpio daemon which must be running.
To start the daemon use the command sudo pigpiod.
Press the ENTER key to continue or ctrl-C to abort...
Testing...
Write 1 to gpio 2 failed.
Pull up on gpio 2 failed.
Write 1 to gpio 3 failed.
Pull up on gpio 3 failed.
Write 1 to gpio 4 failed.
Pull up on gpio 4 failed.
Write 1 to gpio 5 failed.
Pull up on gpio 5 failed.
Write 1 to gpio 6 failed.
Pull up on gpio 6 failed.
Write 1 to gpio 7 failed.
Pull up on gpio 7 failed.
Write 1 to gpio 8 failed.
Pull up on gpio 8 failed.
Write 1 to gpio 9 failed.
Pull up on gpio 9 failed.
Write 1 to gpio 10 failed.
Pull up on gpio 10 failed.
Write 1 to gpio 11 failed.
Pull up on gpio 11 failed.
Write 1 to gpio 12 failed.
Pull up on gpio 12 failed.
Write 1 to gpio 13 failed.
Pull up on gpio 13 failed.
Write 1 to gpio 14 failed.
Pull up on gpio 14 failed.
Write 1 to gpio 15 failed.
Pull up on gpio 15 failed.
Write 1 to gpio 16 failed.
Pull up on gpio 16 failed.
Write 1 to gpio 17 failed.
Pull up on gpio 17 failed.
Write 1 to gpio 18 failed.
Pull up on gpio 18 failed.
Write 1 to gpio 19 failed.
Pull up on gpio 19 failed.
Write 1 to gpio 20 failed.
Pull up on gpio 20 failed.
Write 1 to gpio 21 failed.
Pull up on gpio 21 failed.
Write 1 to gpio 22 failed.
Pull up on gpio 22 failed.
Write 1 to gpio 23 failed.
Pull up on gpio 23 failed.
Write 1 to gpio 24 failed.
Pull up on gpio 24 failed.
Pull up on gpio 25 failed.
Pull up on gpio 26 failed.
Pull up on gpio 27 failed.
Skipped non-user gpios: 0 1 28 29 30 31
Tested user gpios: 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27
Failed user gpios: 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27
what might be the reason for this problem?
pcmanbob
Re: None of the gpios are working in my rpi 3B .
Thu Dec 13, 2018 4:15 pm
Hi.
First question is if you had your pi using serial through UART to talk to an arduino what voltage was the arduino powered by ?
If it was 5v then the arduino would be using 5v on its serial port, but the pi gpio is 3.3v and is not 5v tolerant, so if you did not have voltage level shifting between the 2 devices it is likely that you have damaged your pi gpio.
gokulnarayanan
Fri Dec 14, 2018 4:29 am
HI
thank you for the response
I was using pro mini 3.3V . So that miight not be the problem.
The wifi is working fine .How come just one bank is not working.
Previously when i connected 5v to the rx pin just two pins(RX and TX) got damaged.
But now somehow all the gpios have become unusable even though I was using 3.3V pro mini.
Last edited by gokulnarayanan on Fri Dec 14, 2018 5:42 am, edited 1 time in total.
rhubarbdog
Fri Dec 14, 2018 5:36 am
Get an LED with a 330 ohm or bigger series resistor. Wire it direct to 3v3 pin1 and ground pin6 if it doesn't light swap the wires. If it still doesn't light i can't help buy a new pi?
gokulnarayanan
Fri Dec 14, 2018 5:48 am
The Tx pin is at 3.3V when the SD card is not inserted. However on boot up it shows 0V.
