RPi3 Freeze
Posted: Mon Dec 10, 2018 3:49 pm
by wg141124
Hey, for some time I've been facing problem of my rpi3 freezing in the middle of the night. I'm using Raspbian (lite I guess), recently Pi-hole (problem occurred before I installed it) and Deluge (+ deluge-web) which was launch last night in which freeze occurred. I'm using static IP at ethernet and wlan. Also I have hamachi (ham0). There is log:
Dec 10 02:20:30 rpi3 CRON[22433]: (root) CMD (   PATH="$PATH:/usr/local/bin/" pihole updatechecker local)
Dec 10 02:30:01 rpi3 CRON[22488]: (root) CMD (   PATH="$PATH:/usr/local/bin/" pihole updatechecker local)
Dec 10 02:31:55 rpi3 systemd[1]: Starting Daily apt download activities...
Dec 10 02:32:55 rpi3 systemd[1]: Started Daily apt download activities.
Dec 10 02:32:55 rpi3 systemd[1]: apt-daily.timer: Adding 7h 40min 23.055667s random time.
Dec 10 02:32:55 rpi3 systemd[1]: apt-daily.timer: Adding 4h 9min 50.916862s random time.
Dec 10 02:39:08 rpi3 CRON[22594]: (root) CMD (  [ -x /usr/lib/php/sessionclean ] && if [ ! -d /run/systemd/system ]; then /usr/lib/php/sessionclean; fi)
Dec 10 02:39:31 rpi3 systemd[1]: Starting Clean php session files...
Dec 10 02:39:48 rpi3 systemd[1]: Started Clean php session files.
Dec 10 02:40:01 rpi3 CRON[22649]: (root) CMD (   PATH="$PATH:/usr/local/bin/" pihole updatechecker local)
Dec 10 02:18:01 rpi3 fake-hwclock[99]: Mon 10 Dec 01:17:59 UTC 2018
Dec 10 02:18:01 rpi3 kernel: [    0.000000] Booting Linux on physical CPU 0x0
Dec 10 02:18:01 rpi3 kernel: [    0.000000] Linux version 4.14.79-v7+ ([email protected]) (gcc version 4.9.3 (crosstool-NG crosstool-ng-1.22.0-88-g8460611)) #1159 SMP Sun Nov 4 17:50:20 GMT 2018
Dec 10 02:18:01 rpi3 kernel: [    0.000000] CPU: ARMv7 Processor [410fd034] revision 4 (ARMv7), cr=10c5383d
Dec 10 02:18:01 rpi3 systemd[1]: Started Restore / save the current clock.
Dec 10 02:18:01 rpi3 kernel: [    0.000000] CPU: div instructions available: patching division code
Dec 10 02:18:01 rpi3 kernel: [    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
Dec 10 02:18:01 rpi3 kernel: [    0.000000] OF: fdt: Machine model: Raspberry Pi 3 Model B Rev 1.2
Dec 10 02:18:01 rpi3 systemd[1]: Time has been changed
Dec 10 02:18:01 rpi3 kernel: [    0.000000] Memory policy: Data cache writealloc
Dec 10 02:18:01 rpi3 kernel: [    0.000000] cma: Reserved 8 MiB at 0x3dc00000
Dec 10 02:18:01 rpi3 kernel: [    0.000000] On node 0 totalpages: 255488
Dec 10 02:18:01 rpi3 systemd[1]: Starting Flush Journal to Persistent Storage...
Dec 10 02:18:01 rpi3 kernel: [    0.000000] free_area_init_node: node 0, pgdat 80c85280, node_mem_map bd336000
Dec 10 02:18:01 rpi3 kernel: [    0.000000]   Normal zone: 2246 pages used for memmap
Dec 10 02:18:01 rpi3 systemd[1]: Started Load/Save Random Seed.
Dec 10 02:18:01 rpi3 kernel: [    0.000000]   Normal zone: 0 pages reserved
Dec 10 02:18:01 rpi3 kernel: [    0.000000]   Normal zone: 255488 pages, LIFO batch:31
Dec 10 02:18:01 rpi3 kernel: [    0.000000] percpu: Embedded 17 pages/cpu @be59d000 s38720 r8192 d22720 u69632
Dec 10 02:18:01 rpi3 kernel: [    0.000000] pcpu-alloc: s38720 r8192 d22720 u69632 alloc=17*4096
Dec 10 02:18:01 rpi3 systemd[1]: Started Apply Kernel Variables.
Dec 10 02:18:01 rpi3 kernel: [    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
Dec 10 02:18:01 rpi3 kernel: [    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 253242
Dec 10 02:18:01 rpi3 kernel: [    0.000000] Kernel command line: 8250.nr_uarts=0 bcm2708_fb.fbwidth=1920 bcm2708_fb.fbheight=1080 bcm2708_fb.fbdepth=16 bcm2708_fb.fbswap=1 vc_mem.mem_base=0x3f000000 vc_mem.mem_size=0x3f600000  dwc_otg.lpm_enable=0 console=ttyS0,115200 console=tty1 root=PARTUUID=627092a8-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
Dec 10 02:18:01 rpi3 kernel: [    0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
Dec 10 02:18:01 rpi3 systemd[1]: Started Flush Journal to Persistent Storage.
Dec 10 02:18:01 rpi3 kernel: [    0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
Dec 10 02:18:01 rpi3 kernel: [    0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
Dec 10 02:18:01 rpi3 kernel: [    0.000000] Memory: 990964K/1021952K available (7168K kernel code, 576K rwdata, 2076K rodata, 1024K init, 698K bss, 22796K reserved, 8192K cma-reserved)
Dec 10 02:18:01 rpi3 systemd[1]: Started Create Static Device Nodes in /dev.
Dec 10 02:18:01 rpi3 kernel: [    0.000000] Virtual kernel memory layout:
Dec 10 02:18:01 rpi3 kernel: [    0.000000]     vector  : 0xffff0000 - 0xffff1000   (   4 kB)
Dec 10 02:18:01 rpi3 kernel: [    0.000000]     fixmap  : 0xffc00000 - 0xfff00000   (3072 kB)
Dec 10 02:18:01 rpi3 kernel: [    0.000000]     vmalloc : 0xbe800000 - 0xff800000   (1040 MB)
Dec 10 02:18:01 rpi3 systemd[1]: Starting udev Kernel Device Manager...
Dec 10 02:18:01 rpi3 kernel: [    0.000000]     lowmem  : 0x80000000 - 0xbe600000   ( 998 MB)
Dec 10 02:18:01 rpi3 kernel: [    0.000000]     modules : 0x7f000000 - 0x80000000   (  16 MB)
Dec 10 02:18:01 rpi3 kernel: [    0.000000]       .text : 0x80008000 - 0x80800000   (8160 kB)
Dec 10 02:18:01 rpi3 kernel: [    0.000000]       .init : 0x80b00000 - 0x80c00000   (1024 kB)
Dec 10 02:18:01 rpi3 systemd[1]: Started udev Coldplug all Devices.
Dec 10 02:18:01 rpi3 kernel: [    0.000000]       .data : 0x80c00000 - 0x80c9017c   ( 577 kB)
Dec 10 02:18:01 rpi3 kernel: [    0.000000]        .bss : 0x80c97f04 - 0x80d468b0   ( 699 kB)
Dec 10 02:18:01 rpi3 systemd[1]: Started udev Kernel Device Manager.
Dec 10 02:18:01 rpi3 systemd[1]: Started Set the console keyboard layout.
Dec 10 02:18:01 rpi3 kernel: [    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
Dec 10 02:18:01 rpi3 kernel: [    0.000000] ftrace: allocating 25287 entries in 75 pages
Dec 10 02:18:01 rpi3 kernel: [    0.000000] Hierarchical RCU implementation.
Dec 10 02:18:01 rpi3 kernel: [    0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
Dec 10 02:18:01 rpi3 systemd[1]: Reached target Local File Systems (Pre).
Dec 10 02:18:01 rpi3 kernel: [    0.000000] arch_timer: cp15 timer(s) running at 19.20MHz (phys).
Dec 10 02:18:01 rpi3 kernel: [    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x46d987e47, max_idle_ns: 440795202767 ns
Dec 10 02:18:01 rpi3 kernel: [    0.000007] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 4398046511078ns
Dec 10 02:18:01 rpi3 systemd[1]: Starting Show Plymouth Boot Screen...
Dec 10 02:18:01 rpi3 kernel: [    0.000023] Switching to timer-based delay loop, resolution 52ns
Dec 10 02:18:01 rpi3 kernel: [    0.000271] Console: colour dummy device 80x30
Dec 10 02:18:01 rpi3 kernel: [    0.000814] console [tty1] enabled
Dec 10 02:18:01 rpi3 kernel: [    0.000851] Calibrating delay loop (skipped), value calculated using timer frequency.. 38.40 BogoMIPS (lpj=192000)
Dec 10 02:18:01 rpi3 kernel: [    0.000891] pid_max: default: 32768 minimum: 301
Dec 10 02:18:01 rpi3 systemd[1]: Received SIGRTMIN+20 from PID 178 (plymouthd).
Dec 10 02:18:01 rpi3 kernel: [    0.001225] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
Dec 10 02:18:01 rpi3 kernel: [    0.001259] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
Dec 10 02:18:01 rpi3 kernel: [    0.002217] Disabling memory control group subsystem
Dec 10 02:18:01 rpi3 kernel: [    0.002313] CPU: Testing write buffer coherency: ok
Dec 10 02:18:01 rpi3 kernel: [    0.002745] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
Dec 10 02:18:01 rpi3 kernel: [    0.003166] Setting up static identity map for 0x100000 - 0x10003c
Dec 10 02:18:01 rpi3 kernel: [    0.003304] Hierarchical SRCU implementation.
Dec 10 02:18:01 rpi3 kernel: [    0.003992] smp: Bringing up secondary CPUs ...
Dec 10 02:18:01 rpi3 systemd[1]: Started Show Plymouth Boot Screen.
Dec 10 02:18:01 rpi3 systemd[1]: Reached target Encrypted Volumes.
Dec 10 02:18:01 rpi3 systemd[1]: Reached target Paths.
Dec 10 02:18:01 rpi3 kernel: [    0.004788] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
Dec 10 02:18:01 rpi3 kernel: [    0.005627] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
Dec 10 02:18:01 rpi3 systemd[1]: Started Forward Password Requests to Plymouth Directory Watch.
Dec 10 02:18:01 rpi3 kernel: [    0.006450] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
Dec 10 02:18:01 rpi3 kernel: [    0.006554] smp: Brought up 1 node, 4 CPUs
Dec 10 02:18:01 rpi3 kernel: [    0.006627] SMP: Total of 4 processors activated (153.60 BogoMIPS).
Dec 10 02:18:01 rpi3 kernel: [    0.006648] CPU: All CPU(s) started in HYP mode.
Dec 10 02:18:01 rpi3 systemd[1]: Found device /dev/serial1.
Dec 10 02:18:01 rpi3 kernel: [    0.006666] CPU: Virtualization extensions available.
Dec 10 02:18:01 rpi3 kernel: [    0.007615] devtmpfs: initialized
Dec 10 02:18:01 rpi3 kernel: [    0.017758] random: get_random_u32 called from bucket_table_alloc+0xfc/0x24c with crng_init=0
Dec 10 02:18:01 rpi3 systemd[1]: Found device /dev/disk/by-partuuid/627092a8-01.
Dec 10 02:18:01 rpi3 kernel: [    0.018443] VFP support v0.3: implementor 41 architecture 3 part 40 variant 3 rev 4
Dec 10 02:18:01 rpi3 kernel: [    0.018691] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
Dec 10 02:18:01 rpi3 kernel: [    0.018736] futex hash table entries: 1024 (order: 4, 65536 bytes)
Dec 10 02:18:01 rpi3 kernel: [    0.019308] pinctrl core: initialized pinctrl subsystem
Dec 10 02:18:01 rpi3 systemd[1]: Starting File System Check on /dev/disk/by-partuuid/627092a8-01...
Dec 10 02:18:01 rpi3 kernel: [    0.020110] NET: Registered protocol family 16
Dec 10 02:18:01 rpi3 kernel: [    0.022718] DMA: preallocated 1024 KiB pool for atomic coherent allocations
Dec 10 02:18:01 rpi3 kernel: [    0.027510] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
Dec 10 02:18:01 rpi3 kernel: [    0.027542] hw-breakpoint: maximum watchpoint size is 8 bytes.
Dec 10 02:18:01 rpi3 kernel: [    0.027768] Serial: AMBA PL011 UART driver
Dec 10 02:18:01 rpi3 systemd[1]: Started File System Check Daemon to report status.
Dec 10 02:18:01 rpi3 kernel: [    0.029443] bcm2835-mbox 3f00b880.mailbox: mailbox enabled
Dec 10 02:18:01 rpi3 kernel: [    0.029923] uart-pl011 3f201000.serial: could not find pctldev for node /soc/[email protected]/uart0_pins, deferring probe
Dec 10 02:18:01 rpi3 mtp-probe: checking bus 1, device 3: "/sys/devices/platform/soc/3f980000.usb/usb1/1-1/1-1.1"
Dec 10 02:18:01 rpi3 kernel: [    0.061640] bcm2835-dma 3f007000.dma: DMA legacy API manager at be813000, dmachans=0x1
Dec 10 02:18:01 rpi3 kernel: [    0.063092] SCSI subsystem initialized
Dec 10 02:18:01 rpi3 kernel: [    0.063328] usbcore: registered new interface driver usbfs
Dec 10 02:18:01 rpi3 kernel: [    0.063398] usbcore: registered new interface driver hub
Dec 10 02:18:01 rpi3 mtp-probe: bus: 1, device: 3 was not an MTP device
Dec 10 02:18:01 rpi3 kernel: [    0.063503] usbcore: registered new device driver usb
Dec 10 02:18:01 rpi3 kernel: [    0.070093] raspberrypi-firmware soc:firmware: Attached to firmware from 2018-11-04 16:32
Dec 10 02:18:01 rpi3 kernel: [    0.071436] clocksource: Switched to clocksource arch_sys_counter
Dec 10 02:18:01 rpi3 systemd[1]: Listening on Load/Save RF Kill Switch Status /dev/rfkill Watch.
Dec 10 02:18:01 rpi3 kernel: [    0.148361] VFS: Disk quotas dquot_6.6.0
Dec 10 02:18:01 rpi3 kernel: [    0.148474] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
Dec 10 02:18:01 rpi3 kernel: [    0.148678] FS-Cache: Loaded
Dec 10 02:18:01 rpi3 kernel: [    0.148892] CacheFiles: Loaded
Dec 10 02:18:01 rpi3 systemd[1]: Reached target Sound Card.
Dec 10 02:18:01 rpi3 kernel: [    0.157784] NET: Registered protocol family 2
Dec 10 02:18:01 rpi3 kernel: [    0.158523] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
Dec 10 02:18:01 rpi3 kernel: [    0.158652] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
Dec 10 02:18:01 rpi3 systemd-fsck[219]: fsck.fat 4.1 (2017-01-24)
Dec 10 02:18:01 rpi3 kernel: [    0.158855] TCP: Hash tables configured (established 8192 bind 8192)
Dec 10 02:18:01 rpi3 kernel: [    0.159001] UDP hash table entries: 512 (order: 2, 16384 bytes)
Dec 10 02:18:01 rpi3 kernel: [    0.159063] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
Dec 10 02:18:01 rpi3 kernel: [    0.159309] NET: Registered protocol family 1
Dec 10 02:18:01 rpi3 kernel: [    0.159781] RPC: Registered named UNIX socket transport module.
Dec 10 02:18:01 rpi3 kernel: [    0.159805] RPC: Registered udp transport module.
Dec 10 02:18:01 rpi3 kernel: [    0.159825] RPC: Registered tcp transport module.
Dec 10 02:18:01 rpi3 kernel: [    0.159844] RPC: Registered tcp NFSv4.1 backchannel transport module.
Dec 10 02:18:01 rpi3 systemd-fsck[219]: 0x41: Dirty bit is set. Fs was not properly unmounted and some data may be corrupt.
Dec 10 02:18:01 rpi3 systemd-fsck[219]:  Automatically removing dirty bit.
Dec 10 02:18:01 rpi3 kernel: [    0.161347] hw perfevents: enabled with armv7_cortex_a7 PMU driver, 7 counters available
Dec 10 02:18:01 rpi3 kernel: [    0.164130] workingset: timestamp_bits=14 max_order=18 bucket_order=4
Dec 10 02:18:01 rpi3 kernel: [    0.172125] FS-Cache: Netfs 'nfs' registered for caching
Dec 10 02:18:01 rpi3 systemd-fsck[219]: Performing changes.
Dec 10 02:18:01 rpi3 kernel: [    0.172746] NFS: Registering the id_resolver key type
Dec 10 02:18:01 rpi3 kernel: [    0.172796] Key type id_resolver registered
Dec 10 02:18:01 rpi3 kernel: [    0.172816] Key type id_legacy registered
Dec 10 02:18:01 rpi3 kernel: [    0.172845] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
Dec 10 02:18:01 rpi3 systemd-fsck[219]: /dev/mmcblk0p1: 178 files, 45082/87078 clusters
Dec 10 02:18:01 rpi3 kernel: [    0.174775] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 251)
Dec 10 02:18:01 rpi3 systemd[1]: Started File System Check on /dev/disk/by-partuuid/627092a8-01.
Dec 10 02:18:01 rpi3 kernel: [    0.174933] io scheduler noop registered
Dec 10 02:18:01 rpi3 kernel: [    0.174955] io scheduler deadline registered (default)
Dec 10 02:18:01 rpi3 kernel: [    0.175139] io scheduler cfq registered
Dec 10 02:18:01 rpi3 kernel: [    0.175160] io scheduler mq-deadline registered
Dec 10 02:18:01 rpi3 kernel: [    0.175181] io scheduler kyber registered
Dec 10 02:18:01 rpi3 systemd[1]: Mounting /boot...
Dec 10 02:18:01 rpi3 kernel: [    0.177894] BCM2708FB: allocated DMA memory fdd10000
Dec 10 02:18:01 rpi3 kernel: [    0.177939] BCM2708FB: allocated DMA channel 0 @ be813000
Dec 10 02:18:01 rpi3 kernel: [    0.208059] Console: switching to colour frame buffer device 240x67
Dec 10 02:18:01 rpi3 kernel: [    0.227307] bcm2835-rng 3f104000.rng: hwrng registered
Dec 10 02:18:01 rpi3 systemd[1]: Mounted /boot.
Dec 10 02:18:01 rpi3 systemd[1]: Reached target Local File Systems.
Dec 10 02:18:01 rpi3 systemd[1]: Starting Set console font and keymap...
Dec 10 02:18:01 rpi3 systemd[1]: Starting Preprocess NFS configuration...
Dec 10 02:18:01 rpi3 systemd[1]: Starting Create Volatile Files and Directories...
Dec 10 02:18:01 rpi3 systemd[1]: Starting Raise network interfaces...
Dec 10 02:18:01 rpi3 systemd[1]: Starting Tell Plymouth To Write Out Runtime Data...
Dec 10 02:18:01 rpi3 systemd[1]: Started Set console font and keymap.
Dec 10 02:18:01 rpi3 systemd[1]: Started Preprocess NFS configuration.
Dec 10 02:18:01 rpi3 systemd[1]: Reached target NFS client services.
Dec 10 02:18:01 rpi3 systemd[1]: Reached target Remote File Systems (Pre).
Dec 10 02:18:01 rpi3 systemd[1]: Reached target Remote File Systems.
Dec 10 02:18:01 rpi3 systemd[1]: Started Tell Plymouth To Write Out Runtime Data.
Dec 10 02:18:01 rpi3 systemd[1]: Started Create Volatile Files and Directories.
Dec 10 02:18:01 rpi3 systemd[1]: Starting Network Time Synchronization...
Dec 10 02:18:01 rpi3 systemd[1]: Starting Update UTMP about System Boot/Shutdown...
Dec 10 02:18:01 rpi3 systemd[1]: Started Update UTMP about System Boot/Shutdown.
Dec 10 02:18:01 rpi3 systemd[1]: Started Raise network interfaces.
Dec 10 02:18:01 rpi3 systemd[1]: Started Network Time Synchronization.
Dec 10 02:18:01 rpi3 systemd[1]: Reached target System Initialization.
Dec 10 02:18:01 rpi3 systemd[1]: Started Daily Cleanup of Temporary Directories.
Dec 10 02:18:01 rpi3 systemd[1]: Listening on Avahi mDNS/DNS-SD Stack Activation Socket.
Dec 10 02:18:01 rpi3 systemd[1]: Listening on D-Bus System Message Bus Socket.
Dec 10 02:18:01 rpi3 kernel: [    0.227530] vc-mem: phys_addr:0x00000000 mem_base=0x3f000000 mem_size:0x3f600000(1014 MiB)
Dec 10 02:18:01 rpi3 kernel: [    0.228147] vc-sm: Videocore shared memory driver
Dec 10 02:18:01 rpi3 kernel: [    0.228503] gpiomem-bcm2835 3f200000.gpiomem: Initialised: Registers at 0x3f200000
Dec 10 02:18:01 rpi3 systemd[1]: Listening on triggerhappy.socket.
Dec 10 02:18:01 rpi3 kernel: [    0.238181] brd: module loaded
Dec 10 02:18:01 rpi3 kernel: [    0.247006] loop: module loaded
Dec 10 02:18:01 rpi3 kernel: [    0.247102] Loading iSCSI transport class v2.0-870.
Dec 10 02:18:01 rpi3 kernel: [    0.247838] libphy: Fixed MDIO Bus: probed
Dec 10 02:18:01 rpi3 systemd[1]: Reached target Sockets.
Dec 10 02:18:01 rpi3 kernel: [    0.248013] usbcore: registered new interface driver lan78xx
Dec 10 02:18:01 rpi3 kernel: [    0.248160] usbcore: registered new interface driver smsc95xx
Dec 10 02:18:01 rpi3 systemd[1]: Reached target Basic System.
Dec 10 02:18:01 rpi3 kernel: [    0.248268] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
Dec 10 02:18:01 rpi3 kernel: [    0.276260] dwc_otg 3f980000.usb: base=0xf0980000
Dec 10 02:18:01 rpi3 kernel: [    0.476540] Core Release: 2.80a
Dec 10 02:18:01 rpi3 kernel: [    0.476608] Setting default values for core params
Dec 10 02:18:01 rpi3 systemd[1]: Starting System Logging Service...
Dec 10 02:18:01 rpi3 kernel: [    0.476718] Finished setting default values for core params
Dec 10 02:18:01 rpi3 kernel: [    0.677062] Using Buffer DMA mode
Dec 10 02:18:01 rpi3 kernel: [    0.677129] Periodic Transfer Interrupt Enhancement - disabled
Dec 10 02:18:01 rpi3 systemd[1]: Starting LSB: Autogenerate and use a swap file...
Dec 10 02:18:01 rpi3 kernel: [    0.677226] Multiprocessor Interrupt Enhancement - disabled
Dec 10 02:18:01 rpi3 kernel: [    0.677320] OTG VER PARAM: 0, OTG VER FLAG: 0
Dec 10 02:18:01 rpi3 kernel: [    0.677403] Dedicated Tx FIFOs mode
Dec 10 02:18:01 rpi3 kernel: [    0.677863] WARN::dwc_otg_hcd_init:1046: FIQ DMA bounce buffers: virt = 0xbdd04000 dma = 0xfdd04000 len=9024
Dec 10 02:18:01 rpi3 systemd[1]: Started D-Bus System Message Bus.
Dec 10 02:18:01 rpi3 kernel: [    0.678039] FIQ FSM acceleration enabled for :
Dec 10 02:18:01 rpi3 kernel: [    0.678039] Non-periodic Split Transactions
Dec 10 02:18:01 rpi3 kernel: [    0.678039] Periodic Split Transactions
Dec 10 02:18:01 rpi3 kernel: [    0.678039] High-Speed Isochronous Endpoints
Dec 10 02:18:01 rpi3 liblogging-stdlog:  [origin software="rsyslogd" swVersion="8.24.0" x-pid="321" x-info="http://www.rsyslog.com"] start
Dec 10 02:18:01 rpi3 kernel: [    0.678039] Interrupt/Control Split Transaction hack enabled
Dec 10 02:18:01 rpi3 kernel: [    0.678376] dwc_otg: Microframe scheduler enabled
Dec 10 02:18:01 rpi3 kernel: [    0.678426] WARN::hcd_init_fiq:459: FIQ on core 1 at 0x805ea470
Dec 10 02:18:01 rpi3 kernel: [    0.678531] WARN::hcd_init_fiq:460: FIQ ASM at 0x805ea7d8 length 36
Dec 10 02:18:01 rpi3 kernel: [    0.678642] WARN::hcd_init_fiq:486: MPHI regs_base at 0xf0006000
Dec 10 02:18:01 rpi3 kernel: [    0.678788] dwc_otg 3f980000.usb: DWC OTG Controller
Dec 10 02:18:01 rpi3 kernel: [    0.678900] dwc_otg 3f980000.usb: new USB bus registered, assigned bus number 1
Dec 10 02:18:01 rpi3 kernel: [    0.679045] dwc_otg 3f980000.usb: irq 62, io mem 0x00000000
Dec 10 02:18:01 rpi3 kernel: [    0.683639] Init: Port Power? op_state=1
Dec 10 02:18:01 rpi3 kernel: [    0.688144] Init: Power Port (0)
Dec 10 02:18:01 rpi3 kernel: [    0.692805] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
Dec 10 02:18:01 rpi3 kernel: [    0.697316] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Dec 10 02:18:01 rpi3 kernel: [    0.701831] usb usb1: Product: DWC OTG Controller
Dec 10 02:18:01 rpi3 kernel: [    0.706295] usb usb1: Manufacturer: Linux 4.14.79-v7+ dwc_otg_hcd
Dec 10 02:18:01 rpi3 kernel: [    0.710768] usb usb1: SerialNumber: 3f980000.usb
Dec 10 02:18:01 rpi3 kernel: [    0.715822] hub 1-0:1.0: USB hub found
Dec 10 02:18:01 rpi3 kernel: [    0.720280] hub 1-0:1.0: 1 port detected
Dec 10 02:18:01 rpi3 kernel: [    0.725222] dwc_otg: FIQ enabled
Dec 10 02:18:01 rpi3 kernel: [    0.725227] dwc_otg: NAK holdoff enabled
Dec 10 02:18:01 rpi3 kernel: [    0.725232] dwc_otg: FIQ split-transaction FSM enabled
Dec 10 02:18:01 rpi3 kernel: [    0.725242] Module dwc_common_port init
Dec 10 02:18:01 rpi3 kernel: [    0.725480] usbcore: registered new interface driver usb-storage
Dec 10 02:18:01 rpi3 kernel: [    0.730144] mousedev: PS/2 mouse device common for all mice
Dec 10 02:18:01 rpi3 kernel: [    0.734741] IR NEC protocol handler initialized
Dec 10 02:18:01 rpi3 kernel: [    0.739207] IR RC5(x/sz) protocol handler initialized
Dec 10 02:18:01 rpi3 kernel: [    0.743650] IR RC6 protocol handler initialized
Dec 10 02:18:01 rpi3 kernel: [    0.748042] IR JVC protocol handler initialized
Dec 10 02:18:01 rpi3 kernel: [    0.752389] IR Sony protocol handler initialized
Dec 10 02:18:01 rpi3 kernel: [    0.756710] IR SANYO protocol handler initialized
Dec 10 02:18:01 rpi3 kernel: [    0.761026] IR Sharp protocol handler initialized
Dec 10 02:18:01 rpi3 kernel: [    0.765339] IR MCE Keyboard/mouse protocol handler initialized
Dec 10 02:18:01 rpi3 kernel: [    0.769643] IR XMP protocol handler initialized
Dec 10 02:18:01 rpi3 kernel: [    0.774616] bcm2835-wdt 3f100000.watchdog: Broadcom BCM2835 watchdog timer
Dec 10 02:18:01 rpi3 kernel: [    0.779165] bcm2835-cpufreq: min=600000 max=1200000
Dec 10 02:18:01 rpi3 kernel: [    0.783817] sdhci: Secure Digital Host Controller Interface driver
Dec 10 02:18:01 rpi3 kernel: [    0.788144] sdhci: Copyright(c) Pierre Ossman
Dec 10 02:18:01 rpi3 kernel: [    0.792852] mmc-bcm2835 3f300000.mmc: could not get clk, deferring probe
Dec 10 02:18:01 rpi3 kernel: [    0.797582] sdhost-bcm2835 3f202000.mmc: could not get clk, deferring probe
Dec 10 02:18:01 rpi3 kernel: [    0.802144] sdhci-pltfm: SDHCI platform and OF driver helper
Dec 10 02:18:01 rpi3 kernel: [    0.808037] ledtrig-cpu: registered to indicate activity on CPUs
Dec 10 02:18:01 rpi3 kernel: [    0.812723] hidraw: raw HID events driver (C) Jiri Kosina
Dec 10 02:18:01 rpi3 kernel: [    0.817377] usbcore: registered new interface driver usbhid
Dec 10 02:18:01 rpi3 kernel: [    0.821872] usbhid: USB HID core driver
Dec 10 02:18:01 rpi3 kernel: [    0.826891] vchiq: vchiq_init_state: slot_zero = bdd80000, is_master = 0
Dec 10 02:18:01 rpi3 kernel: [    0.832857] [vc_sm_connected_init]: start
Dec 10 02:18:01 rpi3 kernel: [    0.837472] vc_vchi_sm_init: failed to open VCHI service (-1)
Dec 10 02:18:01 rpi3 kernel: [    0.837479] [vc_sm_connected_init]: failed to initialize shared memory service
Dec 10 02:18:01 rpi3 kernel: [    0.846367] [vc_sm_connected_init]: end - returning -1
Dec 10 02:18:01 rpi3 kernel: [    0.851544] Initializing XFRM netlink socket
Dec 10 02:18:01 rpi3 kernel: [    0.855993] NET: Registered protocol family 17
Dec 10 02:18:01 rpi3 kernel: [    0.860509] Key type dns_resolver registered
Dec 10 02:18:01 rpi3 kernel: [    0.865401] Registering SWP/SWPB emulation handler
Dec 10 02:18:01 rpi3 kernel: [    0.870405] registered taskstats version 1
Dec 10 02:18:01 rpi3 kernel: [    0.880628] uart-pl011 3f201000.serial: cts_event_workaround enabled
Dec 10 02:18:01 rpi3 kernel: [    0.885267] 3f201000.serial: ttyAMA0 at MMIO 0x3f201000 (irq = 87, base_baud = 0) is a PL011 rev2
Dec 10 02:18:01 rpi3 kernel: [    0.891660] mmc-bcm2835 3f300000.mmc: mmc_debug:0 mmc_debug2:0
Dec 10 02:18:01 rpi3 kernel: [    0.896238] mmc-bcm2835 3f300000.mmc: DMA channel allocated
Dec 10 02:18:01 rpi3 kernel: [    0.941553] Indeed it is in host mode hprt0 = 00021501
Dec 10 02:18:01 rpi3 kernel: [    1.006913] sdhost: log_buf @ bdd07000 (fdd07000)
Dec 10 02:18:01 rpi3 kernel: [    1.033666] random: fast init done
Dec 10 02:18:01 rpi3 kernel: [    1.052276] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
Dec 10 02:18:01 rpi3 kernel: [    1.058405] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
Dec 10 02:18:01 rpi3 kernel: [    1.064466] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
Dec 10 02:18:01 rpi3 kernel: [    1.071646] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
Dec 10 02:18:01 rpi3 kernel: [    1.091457] mmc0: sdhost-bcm2835 loaded - DMA enabled (>1)
Dec 10 02:18:01 rpi3 kernel: [    1.096854] of_cfs_init
Dec 10 02:18:01 rpi3 kernel: [    1.101293] of_cfs_init: OK
Dec 10 02:18:01 rpi3 kernel: [    1.106080] Waiting for root device PARTUUID=627092a8-02...
Dec 10 02:18:01 rpi3 kernel: [    1.151464] usb 1-1: new high-speed USB device number 2 using dwc_otg
Dec 10 02:18:01 rpi3 kernel: [    1.155958] Indeed it is in host mode hprt0 = 00001101
Dec 10 02:18:01 rpi3 kernel: [    1.227496] mmc0: host does not support reading read-only switch, assuming write-enable
Dec 10 02:18:01 rpi3 kernel: [    1.234655] mmc0: new high speed SDXC card at address 0001
Dec 10 02:18:01 rpi3 kernel: [    1.239675] mmcblk0: mmc0:0001 ED4QT 119 GiB
Dec 10 02:18:01 rpi3 kernel: [    1.245665]  mmcblk0: p1 p2
Dec 10 02:18:01 rpi3 kernel: [    1.256003] EXT4-fs (mmcblk0p2): INFO: recovery required on readonly filesystem
Dec 10 02:18:01 rpi3 kernel: [    1.260496] EXT4-fs (mmcblk0p2): write access will be enabled during recovery
Dec 10 02:18:01 rpi3 kernel: [    1.284626] mmc1: new high speed SDIO card at address 0001
Dec 10 02:18:01 rpi3 kernel: [    1.391741] usb 1-1: New USB device found, idVendor=0424, idProduct=9514
Dec 10 02:18:01 rpi3 kernel: [    1.396317] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
Dec 10 02:18:01 rpi3 kernel: [    1.401480] hub 1-1:1.0: USB hub found
Dec 10 02:18:01 rpi3 kernel: [    1.406079] hub 1-1:1.0: 5 ports detected
Dec 10 02:18:01 rpi3 kernel: [    1.731474] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
Dec 10 02:18:01 rpi3 kernel: [    1.861704] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00
Dec 10 02:18:01 rpi3 kernel: [    1.866270] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
Dec 10 02:18:01 rpi3 kernel: [    1.873475] smsc95xx v1.0.6
Dec 10 02:18:01 rpi3 kernel: [    1.964813] smsc95xx 1-1.1:1.0 eth0: register 'smsc95xx' at usb-3f980000.usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:4d:bc:96
Dec 10 02:18:01 rpi3 kernel: [   22.519288] EXT4-fs (mmcblk0p2): orphan cleanup on readonly fs
Dec 10 02:18:01 rpi3 kernel: [   22.524208] EXT4-fs (mmcblk0p2): 1 orphan inode deleted
Dec 10 02:18:01 rpi3 kernel: [   22.528917] EXT4-fs (mmcblk0p2): recovery complete
Dec 10 02:18:01 rpi3 kernel: [   22.672778] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
Dec 10 02:18:01 rpi3 kernel: [   22.677597] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
Dec 10 02:18:01 rpi3 kernel: [   22.690320] devtmpfs: mounted
Dec 10 02:18:01 rpi3 kernel: [   22.698370] Freeing unused kernel memory: 1024K
Dec 10 02:18:01 rpi3 kernel: [   23.260465] NET: Registered protocol family 10
Dec 10 02:18:01 rpi3 kernel: [   23.266573] Segment Routing with IPv6
Dec 10 02:18:01 rpi3 kernel: [   23.281962] ip_tables: (C) 2000-2006 Netfilter Core Team
Dec 10 02:18:01 rpi3 kernel: [   23.305202] random: systemd: uninitialized urandom read (16 bytes read)
Dec 10 02:18:01 rpi3 kernel: [   23.380678] random: systemd: uninitialized urandom read (16 bytes read)
Dec 10 02:18:01 rpi3 kernel: [   23.420287] random: systemd-gpt-aut: uninitialized urandom read (16 bytes read)
Dec 10 02:18:01 rpi3 kernel: [   24.219900] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
Dec 10 02:18:01 rpi3 kernel: [   25.092599] snd_bcm2835: module is from the staging directory, the quality is unknown, you have been warned.
Dec 10 02:18:01 rpi3 kernel: [   25.100186] bcm2835_alsa bcm2835_alsa: card created with 8 channels
Dec 10 02:18:01 rpi3 kernel: [   25.297119] brcmfmac: F1 signature read @0x18000000=0x1541a9a6
Dec 10 02:18:01 rpi3 kernel: [   25.306949] brcmfmac: brcmf_fw_map_chip_to_name: using brcm/brcmfmac43430-sdio.bin for chip 0x00a9a6(43430) rev 0x000001
Dec 10 02:18:01 rpi3 kernel: [   25.307207] usbcore: registered new interface driver brcmfmac
Dec 10 02:18:01 rpi3 kernel: [   25.551923] brcmfmac: brcmf_c_preinit_dcmds: Firmware version = wl0: Oct 23 2017 03:55:53 version 7.45.98.38 (r674442 CY) FWID 01-e58d219f
Dec 10 02:18:01 rpi3 kernel: [   25.552691] brcmfmac: brcmf_c_preinit_dcmds: CLM version = API: 12.2 Data: 7.11.15 Compiler: 1.24.2 ClmImport: 1.24.1 Creation: 2014-05-26 10:53:55 Inc Data: 9.10.39 Inc Compiler: 1.29.4 Inc ClmImport: 1.36.3 Creation: 2017-10-23 03:47:14
Dec 10 02:18:01 rpi3 systemd[1]: Starting Disable WiFi if country not set...
Dec 10 02:18:01 rpi3 systemd[1]: Starting LSB: Switch to ondemand cpu governor (unless shift key is pressed)...
Dec 10 02:18:01 rpi3 systemd[1]: Starting Configure Bluetooth Modems connected by UART...
Dec 10 02:18:01 rpi3 systemd[1]: Starting Avahi mDNS/DNS-SD Stack...
Dec 10 02:18:01 rpi3 systemd[1]: Starting Save/Restore Sound Card State...
Dec 10 02:18:01 rpi3 systemd[1]: Starting LSB: pihole-FTL daemon...
Dec 10 02:18:01 rpi3 systemd[1]: Starting dhcpcd on all interfaces...
Dec 10 02:18:01 rpi3 systemd[1]: Started Regular background program processing daemon.
Dec 10 02:18:01 rpi3 systemd[1]: Starting Login Service...
Dec 10 02:18:01 rpi3 cron[344]: (CRON) INFO (pidfile fd = 3)
Dec 10 02:18:01 rpi3 systemd[1]: Starting triggerhappy global hotkey daemon...
Dec 10 02:18:01 rpi3 systemd[1]: Reached target System Time Synchronized.
Dec 10 02:18:01 rpi3 systemd[1]: Started Clean PHP session files every 30 mins.
Dec 10 02:18:01 rpi3 systemd[1]: apt-daily.timer: Adding 1h 25min 819.102ms random time.
Dec 10 02:18:01 rpi3 systemd[1]: Started Daily apt download activities.
Dec 10 02:18:01 rpi3 systemd[1]: apt-daily-upgrade.timer: Adding 38min 2.379658s random time.
Dec 10 02:18:01 rpi3 systemd[1]: Started Daily apt upgrade and clean activities.
Dec 10 02:18:01 rpi3 systemd[1]: Reached target Timers.
Dec 10 02:18:01 rpi3 thd[353]: Found socket passed from systemd
Dec 10 02:18:01 rpi3 cron[344]: (CRON) INFO (Running @reboot jobs)
Dec 10 02:18:01 rpi3 systemd[1]: Started System Logging Service.
Dec 10 02:18:01 rpi3 systemd[1]: Started triggerhappy global hotkey daemon.
Dec 10 02:18:01 rpi3 avahi-daemon[336]: Found user 'avahi' (UID 108) and group 'avahi' (GID 112).
Dec 10 02:18:01 rpi3 avahi-daemon[336]: Successfully dropped root privileges.
Dec 10 02:18:01 rpi3 systemd[1]: Started Disable WiFi if country not set.
Dec 10 02:18:01 rpi3 avahi-daemon[336]: avahi-daemon 0.6.32 starting up.
Dec 10 02:18:01 rpi3 dhcpcd[343]: dev: loaded udev
Dec 10 02:18:01 rpi3 systemd[1]: Started Save/Restore Sound Card State.
Dec 10 02:18:01 rpi3 pihole-FTL[342]: Not running
Dec 10 02:18:01 rpi3 kernel: [   26.634181] random: crng init done
Dec 10 02:18:01 rpi3 kernel: [   26.634192] random: 7 urandom warning(s) missed due to ratelimiting
Dec 10 02:18:01 rpi3 dhcpcd[343]: forked to background, child pid 372
Dec 10 02:18:01 rpi3 systemd[1]: Started dhcpcd on all interfaces.
Dec 10 02:18:01 rpi3 kernel: [   26.643054] uart-pl011 3f201000.serial: no DMA platform data
Dec 10 02:18:01 rpi3 avahi-daemon[336]: Successfully called chroot().
Dec 10 02:18:01 rpi3 avahi-daemon[336]: Successfully dropped remaining capabilities.
Dec 10 02:18:01 rpi3 avahi-daemon[336]: No service file found in /etc/avahi/services.
Dec 10 02:18:01 rpi3 avahi-daemon[336]: Network interface enumeration completed.
Dec 10 02:18:01 rpi3 avahi-daemon[336]: Server startup complete. Host name is rpi3.local. Local service cookie is 1922606383.
Dec 10 02:18:01 rpi3 CRON[393]: (root) CMD (/usr/sbin/logrotate /etc/pihole/logrotate)
Dec 10 02:18:01 rpi3 systemd[1]: Started Avahi mDNS/DNS-SD Stack.
Dec 10 02:18:01 rpi3 CRON[402]: (root) CMD (   PATH="$PATH:/usr/local/bin/" pihole updatechecker remote reboot)
Dec 10 02:18:01 rpi3 raspi-config[331]: Checking if shift key is held down:Error opening '/dev/input/event*': No such file or directory
Dec 10 02:18:01 rpi3 systemd[1]: Started Login Service.
Dec 10 02:18:01 rpi3 systemd[1]: Reached target Network.
Dec 10 02:18:01 rpi3 systemd[1]: Starting Lighttpd Daemon...
Dec 10 02:18:01 rpi3 raspi-config[331]:  No. Switching to ondemand scaling governor.
Dec 10 02:18:01 rpi3 dphys-swapfile[322]: Starting dphys-swapfile swapfile setup ...
Dec 10 02:18:01 rpi3 systemd[1]: Starting OpenBSD Secure Shell server...
Dec 10 02:18:01 rpi3 systemd[1]: Starting Permit User Sessions...
Dec 10 02:18:01 rpi3 systemd[1]: Reached target Network is Online.
Dec 10 02:18:01 rpi3 systemd[1]: Starting LSB: Start/stop logmein-hamachi engine...
Dec 10 02:18:01 rpi3 systemd[1]: Starting Samba NMB Daemon...
Dec 10 02:18:01 rpi3 pihole-FTL[342]: chown: cannot access '/etc/pihole/dhcp.leases': No such file or directory
Dec 10 02:18:01 rpi3 systemd[1]: Starting /etc/rc.local Compatibility...
Dec 10 02:18:01 rpi3 systemd[1]: Starting LSB: Start or stop the Deluge BitTorrent daemon....
Dec 10 02:18:01 rpi3 systemd[1]: Starting Load/Save RF Kill Switch Status...
Dec 10 02:18:01 rpi3 systemd[1]: Started LSB: Switch to ondemand cpu governor (unless shift key is pressed).
Dec 10 02:18:01 rpi3 logmein-hamachi[415]: Starting LogMeIn Hamachi VPN tunneling engine logmein-hamachi
Dec 10 02:18:01 rpi3 logmein-hamachi[415]: starting - success
Dec 10 02:18:01 rpi3 systemd[1]: Started Permit User Sessions.
Dec 10 02:18:01 rpi3 systemd[1]: Started LSB: Start/stop logmein-hamachi engine.
Dec 10 02:18:01 rpi3 systemd[1]: Started Load/Save RF Kill Switch Status.
Dec 10 02:18:01 rpi3 deluged[421]: Starting Deluge BitTorrent Daemon: deluged Not starting Deluge BitTorrent Daemon deluged, disabled in /etc/default/deluged.
Dec 10 02:18:01 rpi3 systemd[1]: Started LSB: Start or stop the Deluge BitTorrent daemon..
Dec 10 02:18:01 rpi3 dhcpcd-run-hooks[448]: wlan0: starting wpa_supplicant
Dec 10 02:18:01 rpi3 systemd[1]: Started /etc/rc.local Compatibility.
Dec 10 02:18:01 rpi3 systemd[1]: Starting Hold until boot process finishes up...
Dec 10 02:18:01 rpi3 systemd[1]: Starting Terminate Plymouth Boot Screen...
Dec 10 02:18:01 rpi3 systemd[1]: Received SIGRTMIN+21 from PID 178 (plymouthd).
Dec 10 02:18:01 rpi3 systemd[1]: Started Terminate Plymouth Boot Screen.
Dec 10 02:18:01 rpi3 systemd[1]: Started Hold until boot process finishes up.
Dec 10 02:18:01 rpi3 systemd[1]: Started Getty on tty1.
Dec 10 02:18:01 rpi3 systemd[1]: Reached target Login Prompts.
Dec 10 02:18:01 rpi3 dphys-swapfile[322]: want /var/swap=100MByte, checking existing: keeping it
Dec 10 02:18:01 rpi3 dphys-swapfile[322]: done.
Dec 10 02:18:01 rpi3 kernel: [   27.253369] Adding 102396k swap on /var/swap.  Priority:-2 extents:1 across:102396k SSFS
Dec 10 02:18:01 rpi3 systemd[1]: Started LSB: Autogenerate and use a swap file.
Dec 10 02:18:05 rpi3 kernel: [   30.983389] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
Dec 10 02:18:05 rpi3 kernel: [   30.983407] brcmfmac: power management disabled
Dec 10 02:18:05 rpi3 kernel: [   31.077355] tun: Universal TUN/TAP device driver, 1.6
Dec 10 02:18:05 rpi3 avahi-daemon[336]: Joining mDNS multicast group on interface ham0.IPv4 with address 25.50.220.41.
Dec 10 02:18:05 rpi3 avahi-daemon[336]: New relevant interface ham0.IPv4 for mDNS.
Dec 10 02:18:05 rpi3 avahi-daemon[336]: Registering new address record for 25.50.220.41 on ham0.IPv4.
Dec 10 02:18:05 rpi3 kernel: [   31.139817] Bluetooth: Core ver 2.22
Dec 10 02:18:05 rpi3 kernel: [   31.139894] NET: Registered protocol family 31
Dec 10 02:18:05 rpi3 kernel: [   31.139900] Bluetooth: HCI device and connection manager initialized
Dec 10 02:18:05 rpi3 kernel: [   31.139923] Bluetooth: HCI socket layer initialized
Dec 10 02:18:05 rpi3 kernel: [   31.139937] Bluetooth: L2CAP socket layer initialized
Dec 10 02:18:05 rpi3 kernel: [   31.139978] Bluetooth: SCO socket layer initialized
Dec 10 02:18:05 rpi3 systemd[1]: Started OpenBSD Secure Shell server.
Dec 10 02:18:05 rpi3 btuart[333]: bcm43xx_init
Dec 10 02:18:05 rpi3 kernel: [   31.186216] Bluetooth: HCI UART driver ver 2.3
Dec 10 02:18:05 rpi3 kernel: [   31.186225] Bluetooth: HCI UART protocol H4 registered
Dec 10 02:18:05 rpi3 kernel: [   31.186228] Bluetooth: HCI UART protocol Three-wire (H5) registered
Dec 10 02:18:05 rpi3 kernel: [   31.186346] Bluetooth: HCI UART protocol Broadcom registered
Dec 10 02:18:05 rpi3 btuart[333]: Flash firmware /lib/firmware/brcm/BCM43430A1.hcd
Dec 10 02:18:05 rpi3 btuart[333]: Set BDADDR UART: b8:27:eb:e7:16:3c
Dec 10 02:18:05 rpi3 btuart[333]: Set Controller UART speed to 921600 bit/s
Dec 10 02:18:05 rpi3 btuart[333]: Device setup complete
Dec 10 02:18:05 rpi3 systemd[1]: Started Configure Bluetooth Modems connected by UART.
Dec 10 02:18:05 rpi3 systemd[1]: Created slice system-bthelper.slice.
Dec 10 02:18:05 rpi3 systemd[1]: Starting Bluetooth service...
Dec 10 02:18:06 rpi3 dhcpcd[372]: eth0: waiting for carrier
Dec 10 02:18:06 rpi3 dhcpcd[372]: wlan0: waiting for carrier
Dec 10 02:18:06 rpi3 dhcpcd[372]: wlan0: carrier acquired
Dec 10 02:18:06 rpi3 kernel: [   31.472656] smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup
Dec 10 02:18:06 rpi3 dhcpcd[372]: DUID 00:01:00:01:23:c5:a2:4a:b5:27:ce:18:a2:g4
Dec 10 02:18:06 rpi3 dhcpcd[372]: wlan0: IAID eb:18:e9:c3
Dec 10 02:18:06 rpi3 dhcpcd[372]: wlan0: adding address fe80::7549:f983:b4d4:70f2
Dec 10 02:18:06 rpi3 dhcpcd[372]: wlan0: probing address 192.168.2.23/24
Dec 10 02:18:06 rpi3 bluetoothd[514]: Bluetooth daemon 5.43
Dec 10 02:18:06 rpi3 dhcpcd[372]: ham0: IAID 19:39:e4:33
Dec 10 02:18:06 rpi3 dhcpcd[372]: wlan0: carrier lost
Dec 10 02:18:06 rpi3 systemd[1]: Started Bluetooth service.
Dec 10 02:18:06 rpi3 systemd[1]: Started Raspberry Pi bluetooth helper.
Dec 10 02:18:06 rpi3 systemd[1]: Reached target Bluetooth.
Dec 10 02:18:06 rpi3 dhcpcd[372]: wlan0: deleting address fe80::7549:f983:b4d4:70f2
Dec 10 02:18:06 rpi3 bluetoothd[514]: Starting SDP server
Dec 10 02:18:06 rpi3 kernel: [   31.650037] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
Dec 10 02:18:06 rpi3 kernel: [   31.650045] Bluetooth: BNEP filters: protocol multicast
Dec 10 02:18:06 rpi3 kernel: [   31.650058] Bluetooth: BNEP socket layer initialized
Dec 10 02:18:06 rpi3 bluetoothd[514]: Bluetooth management interface 1.14 initialized
Dec 10 02:18:06 rpi3 bluetoothd[514]: Failed to obtain handles for "Service Changed" characteristic
Dec 10 02:18:06 rpi3 dbus[323]: [system] Activating via systemd: service name='org.freedesktop.hostname1' unit='dbus-org.freedesktop.hostname1.service'
Dec 10 02:18:06 rpi3 bluetoothd[514]: Sap driver initialization failed.
Dec 10 02:18:06 rpi3 bluetoothd[514]: sap-server: Operation not permitted (1)
Dec 10 02:18:06 rpi3 systemd[1]: Starting Hostname Service...
Dec 10 02:18:06 rpi3 dhcpcd[372]: ham0: soliciting a DHCP lease
Dec 10 02:18:06 rpi3 dhcpcd[372]: ham0: soliciting an IPv6 router
Dec 10 02:18:06 rpi3 dhcpcd[372]: ham0: new hardware address: 7e:b6:57:80:02:2e
Dec 10 02:18:06 rpi3 dhcpcd[372]: ham0: carrier lost
Dec 10 02:18:06 rpi3 bluetoothd[514]: Failed to set privacy: Rejected (0x0b)
Dec 10 02:18:06 rpi3 dhcpcd[372]: ham0: new hardware address: 7a:79:19:39:e4:33
Dec 10 02:18:06 rpi3 dhcpcd[372]: ham0: carrier acquired
Dec 10 02:18:06 rpi3 dhcpcd[372]: eth0: carrier acquired
Dec 10 02:18:06 rpi3 dhcpcd[372]: eth0: IAID eb:4d:bc:96
Dec 10 02:18:06 rpi3 dhcpcd[372]: eth0: adding address fe80::eea8:2245:76ax:6ccd
Dec 10 02:18:06 rpi3 dhcpcd[372]: eth0: probing address 192.168.1.2/24
Dec 10 02:18:06 rpi3 kernel: [   32.046319] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
Dec 10 02:18:06 rpi3 dhcpcd[372]: wlan0: adding address fe80::b83f:f240:c64e:78b8
Dec 10 02:18:07 rpi3 avahi-daemon[336]: Joining mDNS multicast group on interface ham0.IPv6 with address 2620:9b::1939:e433.
Dec 10 02:18:07 rpi3 avahi-daemon[336]: New relevant interface ham0.IPv6 for mDNS.
Dec 10 02:18:07 rpi3 avahi-daemon[336]: Registering new address record for 2620:9b::1939:e433 on ham0.*.
Dec 10 02:18:07 rpi3 dhcpcd[372]: eth0: soliciting an IPv6 router
Dec 10 02:18:07 rpi3 systemd[1]: Started Lighttpd Daemon.
Dec 10 02:18:07 rpi3 dhcpcd[372]: wlan0: soliciting an IPv6 router
Dec 10 02:18:07 rpi3 dbus[323]: [system] Successfully activated service 'org.freedesktop.hostname1'
Dec 10 02:18:07 rpi3 systemd[1]: Started Hostname Service.
Dec 10 02:18:07 rpi3 dhcpcd[372]: eth0: carrier lost
Dec 10 02:18:07 rpi3 dhcpcd[372]: eth0: deleting address fe80::eea8:2245:76ax:6ccd
Dec 10 02:18:08 rpi3 avahi-daemon[336]: Joining mDNS multicast group on interface wlan0.IPv6 with address fe80::b83f:f240:c64e:78b8.
Dec 10 02:18:08 rpi3 avahi-daemon[336]: New relevant interface wlan0.IPv6 for mDNS.
Dec 10 02:18:08 rpi3 avahi-daemon[336]: Registering new address record for fe80::b83f:f240:c64e:78b8 on wlan0.*.
Dec 10 02:18:08 rpi3 dhcpcd[372]: wlan0: Router Advertisement from fe80::aa0c:63ff:fe0d:e62c
Dec 10 02:18:08 rpi3 dhcpcd[372]: wlan0: adding address fda8:c63:de6:2c00:c71a:bba4:d79d:fa1c/64
Dec 10 02:18:08 rpi3 dhcpcd[372]: wlan0: adding route to fda8:c63:de6:2c00::/64
Dec 10 02:18:08 rpi3 dhcpcd[372]: eth0: carrier acquired
Dec 10 02:18:08 rpi3 kernel: [   33.635897] smsc95xx 1-1.1:1.0 eth0: link up, 100Mbps, full-duplex, lpa 0xCDE1
Dec 10 02:18:08 rpi3 dhcpcd[372]: eth0: IAID eb:4d:bc:96
Dec 10 02:18:08 rpi3 dhcpcd[372]: eth0: adding address fe80::eea8:2245:76ax:6ccd
Dec 10 02:18:08 rpi3 dhcpcd[372]: eth0: probing address 192.168.1.2/24
Dec 10 02:18:08 rpi3 dhcpcd[372]: eth0: soliciting an IPv6 router
Dec 10 02:18:09 rpi3 avahi-daemon[336]: Leaving mDNS multicast group on interface wlan0.IPv6 with address fe80::b83f:f240:c64e:78b8.
Dec 10 02:18:09 rpi3 avahi-daemon[336]: Joining mDNS multicast group on interface wlan0.IPv6 with address fda8:c63:de6:2c00:c71a:bba4:d79d:fa1c.
Dec 10 02:18:09 rpi3 avahi-daemon[336]: Registering new address record for fda8:c63:de6:2c00:c71a:bba4:d79d:fa1c on wlan0.*.
Dec 10 02:18:09 rpi3 avahi-daemon[336]: Withdrawing address record for fe80::b83f:f240:c64e:78b8 on wlan0.
Dec 10 02:18:10 rpi3 avahi-daemon[336]: Joining mDNS multicast group on interface eth0.IPv6 with address fe80::eea8:2245:76ax:6ccd.
Dec 10 02:18:10 rpi3 avahi-daemon[336]: New relevant interface eth0.IPv6 for mDNS.
Dec 10 02:18:10 rpi3 avahi-daemon[336]: Registering new address record for fe80::eea8:2245:76ax:6ccd on eth0.*.
Dec 10 02:18:11 rpi3 dhcpcd[372]: wlan0: using static address 192.168.2.23/24
Dec 10 02:18:11 rpi3 avahi-daemon[336]: Joining mDNS multicast group on interface wlan0.IPv4 with address 192.168.2.23.
Dec 10 02:18:11 rpi3 dhcpcd[372]: wlan0: adding route to 192.168.8.0/24
Dec 10 02:18:11 rpi3 dhcpcd[372]: wlan0: adding default route via 192.168.8.1
Dec 10 02:18:11 rpi3 avahi-daemon[336]: New relevant interface wlan0.IPv4 for mDNS.
Dec 10 02:18:11 rpi3 avahi-daemon[336]: Registering new address record for 192.168.2.23 on wlan0.IPv4.
Dec 10 02:18:11 rpi3 dhcpcd[372]: ham0: probing for an IPv4LL address
Dec 10 02:18:13 rpi3 dhcpcd[372]: eth0: using static address 192.168.1.2/24
Dec 10 02:18:13 rpi3 dhcpcd[372]: eth0: adding route to 192.168.1.0/24
Dec 10 02:18:13 rpi3 avahi-daemon[336]: Joining mDNS multicast group on interface eth0.IPv4 with address 192.168.1.2.
Dec 10 02:18:13 rpi3 avahi-daemon[336]: New relevant interface eth0.IPv4 for mDNS.
Dec 10 02:18:13 rpi3 avahi-daemon[336]: Registering new address record for 192.168.1.2 on eth0.IPv4.
Dec 10 02:18:13 rpi3 systemd[1]: Started Samba NMB Daemon.
Dec 10 02:18:13 rpi3 systemd[1]: Starting Samba SMB Daemon...
Dec 10 02:18:13 rpi3 systemd[1]: smbd.service: Supervising process 626 which is not our child. We'll most likely not notice when it exits.
Dec 10 02:18:14 rpi3 systemd[1]: Started Samba SMB Daemon.
Dec 10 02:18:16 rpi3 systemd[1]: Created slice User Slice of pihole.
Dec 10 02:18:16 rpi3 systemd[1]: Started Session c1 of user pihole.
Dec 10 02:18:16 rpi3 systemd[1]: Starting User Manager for UID 999...
Dec 10 02:18:16 rpi3 systemd[637]: Listening on GnuPG cryptographic agent and passphrase cache.
Dec 10 02:18:16 rpi3 systemd[637]: Listening on GnuPG cryptographic agent and passphrase cache (restricted).
Dec 10 02:18:16 rpi3 systemd[637]: Listening on GnuPG cryptographic agent (access for web browsers).
Dec 10 02:18:16 rpi3 systemd[637]: Reached target Paths.
Dec 10 02:18:16 rpi3 systemd[637]: Reached target Timers.
Dec 10 02:18:16 rpi3 systemd[637]: Listening on GnuPG cryptographic agent (ssh-agent emulation).
Dec 10 02:18:16 rpi3 systemd[637]: Reached target Sockets.
Dec 10 02:18:16 rpi3 systemd[637]: Reached target Basic System.
Dec 10 02:18:16 rpi3 systemd[637]: Reached target Default.
Dec 10 02:18:16 rpi3 systemd[637]: Startup finished in 62ms.
Dec 10 02:18:16 rpi3 systemd[1]: Started User Manager for UID 999.
Dec 10 02:18:16 rpi3 pihole-FTL[342]: FTL started!
Dec 10 02:18:16 rpi3 systemd[1]: Started LSB: pihole-FTL daemon.
Dec 10 02:18:16 rpi3 systemd[1]: Reached target Multi-User System.
Dec 10 02:18:16 rpi3 systemd[1]: Reached target Graphical Interface.
Dec 10 02:18:16 rpi3 systemd[1]: Starting Update UTMP about System Runlevel Changes...
Dec 10 02:18:16 rpi3 systemd[1]: Started Update UTMP about System Runlevel Changes.
Dec 10 02:18:16 rpi3 systemd[1]: Startup finished in 23.083s (kernel) + 18.811s (userspace) = 41.895s.
Dec 10 02:18:17 rpi3 dhcpcd[372]: ham0: using IPv4LL address 169.254.197.169
Dec 10 02:18:17 rpi3 avahi-daemon[336]: Registering new address record for 169.254.197.169 on ham0.IPv4.
Dec 10 02:18:17 rpi3 dhcpcd[372]: ham0: adding route to 169.254.0.0/16
Dec 10 02:18:19 rpi3 dhcpcd[372]: ham0: no IPv6 Routers available
Dec 10 02:18:22 rpi3 dhcpcd[372]: eth0: no IPv6 Routers available
Dec 10 16:09:58 rpi3 systemd[1]: Time has been changed
Dec 10 16:09:58 rpi3 systemd[637]: Time has been changed
Dec 10 16:09:58 rpi3 systemd-timesyncd[271]: Synchronized to time server 193.219.28.147:123 (2.debian.pool.ntp.org).
Dec 10 16:09:58 rpi3 systemd[1]: apt-daily.timer: Adding 9h 41min 49.039001s random time.
Dec 10 16:09:58 rpi3 systemd[1]: apt-daily-upgrade.timer: Adding 46min 38.911771s random time.
Dec 10 16:09:58 rpi3 systemd[1]: Starting Clean php session files...
Dec 10 16:09:58 rpi3 systemd[1]: Starting Daily apt download activities...
Dec 10 16:10:00 rpi3 systemd[1]: Started Clean php session files.
Dec 10 16:10:02 rpi3 systemd[1]: Started Daily apt download activities.
Dec 10 16:10:02 rpi3 systemd[1]: apt-daily.timer: Adding 1h 51min 21.169704s random time.
Dec 10 16:10:02 rpi3 systemd[1]: apt-daily.timer: Adding 6h 42min 15.269322s random time.
Dec 10 16:10:02 rpi3 systemd[1]: Starting Daily apt upgrade and clean activities...
Dec 10 16:10:04 rpi3 systemd[1]: Started Daily apt upgrade and clean activities.
Dec 10 16:10:04 rpi3 systemd[1]: apt-daily-upgrade.timer: Adding 34min 14.666577s random time.
Dec 10 16:10:04 rpi3 systemd[1]: apt-daily-upgrade.timer: Adding 17min 23.107047s random time.
Dec 10 16:10:16 rpi3 CRON[833]: (root) CMD (   PATH="$PATH:/usr/local/bin/" pihole updatechecker local)
Dec 10 16:10:26 rpi3 systemd[1]: Created slice User Slice of pi.
Dec 10 16:10:26 rpi3 systemd[1]: Starting User Manager for UID 1000...
Dec 10 16:10:26 rpi3 systemd[1]: Started Session c2 of user pi.
Dec 10 16:10:27 rpi3 systemd[842]: Listening on GnuPG cryptographic agent and passphrase cache (restricted).
Dec 10 16:10:27 rpi3 systemd[842]: Reached target Paths.
Dec 10 16:10:27 rpi3 systemd[842]: Listening on GnuPG cryptographic agent and passphrase cache.
Dec 10 16:10:27 rpi3 systemd[842]: Reached target Timers.
Dec 10 16:10:27 rpi3 systemd[842]: Listening on GnuPG cryptographic agent (ssh-agent emulation).
Dec 10 16:10:27 rpi3 systemd[842]: Listening on GnuPG cryptographic agent (access for web browsers).
Dec 10 16:10:27 rpi3 systemd[842]: Reached target Sockets.
Dec 10 16:10:27 rpi3 systemd[842]: Reached target Basic System.
Dec 10 16:10:27 rpi3 systemd[842]: Reached target Default.
Dec 10 16:10:27 rpi3 systemd[842]: Startup finished in 57ms.
Dec 10 16:10:27 rpi3 systemd[1]: Started User Manager for UID 1000.
Re: RPi3 Freeze
Posted: Tue Dec 11, 2018 2:17 pm
by wg141124
Help me out guys
Re: RPi3 Freeze
Posted: Tue Dec 11, 2018 2:25 pm
by jamesh
Nothing obvious in the log that I spotted. You are using a swap file, which is probably unnecessary.
What are you actually running overnight?
What version of Raspbian are you using?
Do you have anything plugged in?
Re: RPi3 Freeze
Posted: Tue Dec 11, 2018 2:58 pm
by wg141124
There is Deluge running in the night. Raspbian is probably latest. Nothing plugged in, just AC and ethernet cable connecting pi to PC.
Re: RPi3 Freeze
Posted: Tue Dec 11, 2018 3:54 pm
by davidcoton
OK, let's sort that "probably" first, then we know where we are.
Start your Pi, connect to ethernet (with internet access), and get a command line prompt. Type these commands:
sudo apt update
sudo apt full-upgrade
If you are really lucky, that will solve the problem. If not, at least you can delete "probably" which will make troubleshooting easier.
Re: RPi3 Freeze
Posted: Tue Dec 11, 2018 6:38 pm
by wg141124
I mean I did an update recently but when I was posting it my device couldn't start, that's why 'probably'. Let's see...
Linux rpi3 4.14.79-v7+ #1159 SMP Sun Nov 4 17:50:20 GMT 2018 armv7l GNU/Linux
To be sure I will do the upgrade like you asked
Re: RPi3 Freeze
Posted: Tue Dec 11, 2018 6:39 pm
by wg141124
File system?
[email protected]:~ $ sudo apt update
Err:1 http://raspbian.raspberrypi.org/raspbian stretch InRelease
  Temporary failure resolving 'raspbian.raspberrypi.org'
Err:2 http://archive.raspberrypi.org/debian stretch InRelease
  Temporary failure resolving 'archive.raspberrypi.org'
Reading package lists... Done
Building dependency tree
All packages are up to date.
W: chown to _apt:root of directory /var/lib/apt/lists/partial failed - SetupAPTPartialDirectory (30: Read-only file system)
W: chmod 0700 of directory /var/lib/apt/lists/partial failed - SetupAPTPartialDirectory (30: Read-only file system)
W: Not using locking for read only lock file /var/lib/apt/lists/lock
W: Problem unlinking the file /var/lib/apt/lists/partial/.apt-acquire-privs-test.16HZi4 - IsAccessibleBySandboxUser (30: Read-only file system)
W: Problem unlinking the file /var/lib/apt/lists/partial/.apt-acquire-privs-test.akxiro - IsAccessibleBySandboxUser (30: Read-only file system)
W: Problem unlinking the file /var/lib/apt/lists/partial/raspbian.raspberrypi.org_raspbian_dists_stretch_InRelease - PrepareFiles (30: Read-only file system)
W: Problem unlinking the file /var/lib/apt/lists/partial/archive.raspberrypi.org_debian_dists_stretch_InRelease - PrepareFiles (30: Read-only file system)
W: Failed to fetch http://raspbian.raspberrypi.org/raspbian/dists/stretch/InRelease  Temporary failure resolving 'raspbian.raspberrypi.org'
W: Failed to fetch http://archive.raspberrypi.org/debian/dists/stretch/InRelease  Temporary failure resolving 'archive.raspberrypi.org'
W: Some index files failed to download. They have been ignored, or old ones used instead.
W: Problem unlinking the file /var/cache/apt/pkgcache.bin - RemoveCaches (30: Read-only file system)
W: Problem unlinking the file /var/cache/apt/srcpkgcache.bin - RemoveCaches (30: Read-only file system)
[email protected]:~ $ sudo apt full-upgrade
Calculating upgrade... Done
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
W: Not using locking for read only lock file /var/lib/dpkg/lock
W: chown to _apt:root of directory /var/cache/apt/archives/partial failed - SetupAPTPartialDirectory (30: Read-only file system)
W: chmod 0700 of directory /var/cache/apt/archives/partial failed - SetupAPTPartialDirectory (30: Read-only file system)
W: Not using locking for read only lock file /var/cache/apt/archives/lock
Re: RPi3 Freeze
Posted: Wed Dec 12, 2018 5:04 am
by rhubarbdog
Is your internet working.
Don't use a swap partition with sdcard. It breaks them
Re: RPi3 Freeze
Posted: Wed Dec 12, 2018 7:43 am
by Joel_Mckay
@wg141124
Check the drive free space, and list your device mounts.
df -h
mount
The Read-Only errors can be caused by ignoring a partitions "ro" flag, OS error/crash forced re-mount into safe mode, and or the Flash memory is quietly failing. I suspect with a write-heavy server running that your flash simply has begun to fail, and if you have free space on a "rw" mount this is probably the case.
Sometimes, I found upgrading to Stretch was an unclean process for our systems, and required importing the selected package list into a fresh Raspbian image install.
Also, weird DNS errors are common in systems where the router (mostly UPnP or Samba related exploits), and or ISP is fiddling with the network traffic.
I would recommend Google 8.8.8.8 or Cloadflare 1.1.1.1 if you can't get a VPN tunnel service.
https://www.cloudflare.com/learning/dns ... s-1.1.1.1/
https://developers.google.com/speed/pub ... docs/using
I observe P2P traffic attracts all the wrong kinds of network load from commercial IP hitman, bots, and or ISP NOC sand-boxing network access. File-sharing clients are a primary source of Trojans/Worms people tend to either download or have remotely exploited.
We included pglcmd on our clubs OS, as we know students are curious about studying the global network ecosystem. Yet with ipv6 YMMV. ;-)
https://sourceforge.net/projects/peerguardian/
Cheers,
J
Re: RPi3 Freeze
Posted: Wed Dec 12, 2018 2:11 pm
by wg141124
All right so you are saying that it has to be the "swap partition"' fault. I mean maybe Pi-hole or Deluge installed it automatically. How can I fix it?
Re: RPi3 Freeze
Posted: Wed Dec 12, 2018 2:16 pm
by jamesh
It doesn't HAVE to be the swap, but we do not recommend swap partitions on the SD carad as it wears them out. And the issues you are seeing could well be down to a failing SD card.
Re: RPi3 Freeze
Posted: Wed Dec 12, 2018 5:41 pm
by wg141124
So how can it be done anyway as I want my sd card to be in a good condition. And how can I fix the read only file system
