Cr4z33
(HDMI) Very poor 1080p image quality!
Sat Dec 08, 2018 6:40 am
I need to run a Raspberry Pi 3 B+ at 1080p connected by HDMI, but both on a Samsung 4K monitor (U28E850R) and a Samsung 4K TV (UE55NU7170UXZT) the overall picture quality is very disappointing. :|
White colour looks almost light blue and the overall sharpness is very poor...
The same (hiqh quality/high speed) HDMI cable has been tested with other 1080p/2160p devices to be sure it is 100% OK so at this point I was wondering if I could do (perhaps in config.txt?) anything to improve overall image quality at 1080p?
This is my current config.txt:
# For more options and information see
# http://rpf.io/configtxt
# Some settings may impact device functionality. See link above for details
# uncomment if you get no picture on HDMI for a default "safe" mode
#hdmi_safe=1
disable_overscan=1
# uncomment the following to adjust overscan. Use positive numbers if console
# goes off screen, and negative if there is too much border
overscan_left=40
overscan_right=40
overscan_top=22
overscan_bottom=10
# uncomment to force a console size. By default it will be display's size minus
# overscan.
#framebuffer_width=1280
#framebuffer_height=720
hdmi_force_hotplug=1
# uncomment to force a specific HDMI mode (this will force VGA)
hdmi_group=1
hdmi_mode=16
# uncomment to force a HDMI mode rather than DVI. This can make audio work in
# DMT (computer monitor) modes
#hdmi_drive=2
# uncomment to increase signal to HDMI, if you have interference, blanking, or
# no display
#config_hdmi_boost=4
# uncomment for composite PAL
#sdtv_mode=2
#uncomment to overclock the arm. 700 MHz is the default.
#arm_freq=800
# Uncomment some or all of these to enable the optional hardware interfaces
#dtparam=i2c_arm=on
#dtparam=i2s=on
#dtparam=spi=on
# Uncomment this to enable the lirc-rpi module
#dtoverlay=lirc-rpi
# Additional overlays and parameters are documented /boot/overlays/README
dtparam=audio=on
[pi0]
dtoverlay=dwc2
[all]
start_x=1
gpu_mem=128
dtoverlay=googlevoicehat-soundcard
Imperf3kt
Re: (HDMI) Very poor 1080p image quality!
Sun Dec 09, 2018 7:55 pm
Have you checked the settings on the monitor?
White looking blue would indicate you have it set to cool color.
55:55:44:44:4C
52:4C:52:42:41
DirkS
Sun Dec 09, 2018 8:44 pm
And check the actual HDMI settings on the Pi with
tvservice -s
FTrevorGowen
Sun Dec 09, 2018 11:31 pm
tvservice -s
+1
I also note that you appear to be forcing a display setting rather than letting the Pi detect a "best setting". There's nothing wrong in doing that, but usually only after you've used other tvservice commands to check what preferred or native options the display uses (and are detected by the Pi). FWIW, you may find these notes/examples of interest:
http://www.cpmspectrepi.uk/raspberry_pi ... tings.html
Trev.
Still running Raspbian Jessie on some older Pi's (an A, B1, B2, B+, P2B, 3xP0, P0W) but Stretch on my 2xP3A+, P3B+, P3B, B+, A+ and a B2. See: https://www.cpmspectrepi.uk/raspberry_pi/raspiidx.htm
