reboot don't work
Posted: Wed Dec 05, 2018 9:23 pm
by po220
hi
I'm using A PI3B+ with SSD on USB.
Raspbian lite.
When I reboot the raspberry with
sudo reboot
or
sudo shutdown -r now
ssh connexion is closed but I don't find again the connexion. Rasp stay invible. I must restart Raspberry with power stop/start.
How can I restart my rasp ?
Thanks in advance
Re: reboot don't work
Posted: Wed Dec 05, 2018 9:30 pm
by Roken
Are you booting to a desktop/UI (e.g. retro)? If so, have you tried rebooting with a monitor/display connected. I find my RetroPi failes to boot unless it has an active display.
Posted: Wed Dec 05, 2018 9:54 pm
by po220
no, I'm using raspbian lite without display ; only ssh
Posted: Wed Dec 05, 2018 10:00 pm
by n67
This is a known problem. Apparently, it boils down to "Not all USB hard disks are completely compatible with the 'boot from USB' functionality of the Pi".
One of the other frequent posters here routinely reports that while he can boot from SSD from a cold power-on, rebooting (without power cycling) does not work.
My own recommendation is to skip the "Boot directly from USB" idea and just do it the old-fashioned way. Boot from SD card with the rootfs on USB. That always works. And as far as I'm concerned, is every bit as useful as the "pure boot from USB". Others will argue otherwise, but their arguments are not convincing.
Posted: Wed Dec 05, 2018 11:08 pm
by W. H. Heydt
If you connect to a Pi using ssh, when you reboot it, yes, the connection will be dropped. The ssh daemon on the Pi gets shut down along with everything else.
After the reboot, you have to re-establish the connection. If you're using PuTTY, use the mouse on the icon at the upper left and select "restart session". You should re-connect and then you can log in again. If you're doing ssh from a terminal window, just repeat the local ssh command and you should re-connect and be able to log in again.
Posted: Wed Dec 05, 2018 11:20 pm
by po220
The problem is that connection don't re-establish afer shut down of the ssh deamon. the Pi is not visible, no restart, no Ethernet visibility.
I can't re-connect ssh.
thanks n67, I do not understand everything but I will study your answer (add a sd just for boot)
