MrEngman
rpi-update error
Thu Nov 29, 2018 12:54 pm
Just tried updating to Raspbian 4.14.83 using rpi-update and got the following error.
 *** Raspberry Pi firmware updater by Hexxeh, enhanced by AndrewS and Dom
 *** Performing self-update
 *** Relaunching after update
This update bumps to rpi-4.14.y linux tree
Be aware there could be compatibility issues with some drivers
Discussion here:
https://www.raspberrypi.org/forums/viewtopic.php?f=29&t=197689
 *** Downloading specific firmware revision (this will take a few minutes)
  % Total    % Received % Xferd  Average Speed   Time    Time     Time  Current
                                 Dload  Upload   Total   Spent    Left  Speed
100   168    0   168    0     0    360      0 --:--:-- --:--:-- --:--:--   372
100 53.0M  100 53.0M    0     0   352k      0  0:02:33  0:02:33 --:--:-- 44798
 *** Updating firmware
 *** Updating kernel modules
 *** depmod 4.14.83+
 *** depmod 4.14.83-v7+
 *** Updating VideoCore libraries
 *** Using HardFP libraries
 *** Updating SDK
cp: cannot stat ‘//root/.rpi-firmware/vc/sdk/*’: No such file or directory
Got it first on a Pi 0 and then on a Pi 1B+. Obviously a minor issue with // at the start of the directory tree but checking the directory I got
pi@Pi-0-d:~ $ sudo ls -Al //root/.rpi-firmware/vc/
total 4
drwxrwxr-x 3 root root 4096 Nov 29 11:29 hardfp
So no sdk directory as it says.
Is this an error with rpi-update or something else?
I usually update a variety of Pi to the latest firmware version using rpi-update to check wifi drivers I compile and don't usually see any errors
christiantf
Re: rpi-update error
Thu Nov 29, 2018 1:26 pm
Confirm the problem with two Rasperry Pi 2 today.
Yesterday, on a Pi 3B+ it worked.
The download size on the Pi2 was 53.0M in size, on the Pi3+ it was 56.1M.
Pi 3 (yesterday - OK):
 *** depmod 4.14.82+
rpi-update *** depmod 4.14.82-v7+
Pi 2 (today - NOK):
 *** depmod 4.14.83+
 *** Updating SDK
cp: cannot stat '//root/.rpi-firmware/vc/sdk/*': No such file or directory
MrEngman
Thu Nov 29, 2018 1:31 pm
Had a look at rpi-update and found this line in the code
SKIP_SDK=${SKIP_SDK:-0}
Added SKIP_SDK=1 to the rpi-update command and the error no longer appeared. e.g.
sudo SKIP_SDK=1 rpi-update
Would be helpful if someone can explain the initial issue I had with the sdk directory not existing.
HawaiianPi
Thu Nov 29, 2018 8:33 pm
The rpi-update command loads the Testing branch kernel and firmware, which may by buggy or unstable. Unless you actually want to test possibly buggy and unstable software to report errors, don't rpi-update.
The proper way to upgrade Raspbian to the latest stable kernel and firmware is:
sudo apt update && sudo apt full-upgrade -y
If you DO want to test the newest firmware and report bugs, see here:
https://www.raspbian.org/RaspbianBugs
code_exec
Thu Nov 29, 2018 8:47 pm
 *** depmod 4.14.82+
Pi 2 (today - NOK):
 *** depmod 4.14.83+
 *** Updating SDK
rpi-update installs the very latest bootloader which may be unstable and buggy.
You can install the latest stable bootloader files for the Pi.
To do this directly on the Pi:
wget https://archive.raspberrypi.org/debian/pool/main/r/raspberrypi-firmware/raspberrypi-bootloader_1.20181112-1_armhf.deb
sudo dpkg -i raspberrypi-bootloader_1.20181112-1_armhf.deb
To do this on another PC:
sudo mount /dev/mmcblk0p2 /mnt
sudo mount /dev/mmcblk0p1 /mnt/boot
sudo dpkg-deb -x raspberrypi-bootloader_1.20181112-1_armhf.deb /mnt
sudo umount /mnt/boot
sudo umount /mnt
Replace /dev/mmcblk0 with the device name of the microSD card, which can be found out by running sudo fdisk -l
Ubuntu 18.04 LTS desktop images for the Raspberry Pi 3.
https://github.com/CodeExecution/Ubuntu-ARM64-RPi
MrEngman
Thu Nov 29, 2018 9:17 pm
I am well aware of the use of rpi-update and the problems that could occur. I have been using it since it was first introduced years ago and I always update my Pi's with it whenever a new update is available. I use rpi-update to update the kernel to allow me to test the wifi drivers I compile with the latest kernel versions.
This was a rather different problem than what I would normally expect. If there is a problem using rpi-update I would normally expect it to occur after updating the kernel and rebooting, not while actually running rpi-update itself.
Anyway all is fixed now. Seems the kernel updates were missing some relevant data.
