LegendOfPi
Official RPI 7" touchscreen display support for community Operating Systems
Mon Nov 26, 2018 1:23 pm
The official 7" touchscreen only seems to work with raspbian. How can I use the display with android, RetroPie, or other OSes?
Re: Official RPI 7" touchscreen display support for community Operating Systems
Mon Nov 26, 2018 1:41 pm
I would expect this to work - the running of the LCD and touchscreen is done by the GPU firmware, and there is a custom framebuffer driver in our Linux kernel tree to create a FB based on that. If the LCD is attached that is the display that is used. If your distro of choice doesn;t work with the LCD, then not sure what they have done to break it.
LegendOfPi
Mon Nov 26, 2018 2:49 pm
The display only turns on and works with Raspbian and not any of the other OSes I have tried. All I changed between OSes is the flashed micro SD card.
Mon Nov 26, 2018 4:02 pm
Sorry, cannot really help then. You'll need to approach the originators of the ones that don't work to fix their stuff.
LegendOfPi
Mon Nov 26, 2018 4:04 pm
Ok, I will. Thank you for your response.
Mon Nov 26, 2018 4:51 pm
Retropie (collection of various software) latest is based of Raspbian Stretch so that should work OK ;)
Retired disgracefully.....
LegendOfPi
Mon Nov 26, 2018 5:34 pm
Ok. I will try it again when I can.
hansotten
Mon Nov 26, 2018 7:24 pm
It can be done without Raspbian, in Ultibo it works fine.
http://duinorasp.hansotten.com for Raspberry Pi and Arduino and ESP8266
http://retro.hansotten.nl for retrocomputing with the 6502 cpu
