read only sd card after a mishap "[solved]"
Posted: Fri Nov 23, 2018 1:11 pm
by erg
Hi all,
situation as follows: raspberry pi broke in half (no comment), now trying to fsck or reformat the card and it's read-only:
fdisk: cannot open /dev/mmcblk0: Read-only file system
device notifier shows three partitions, /root, /boot, and /SETTINGS
trying to check /boot partition on the card - the only one I can mount, gives that:
fsck.vfat /dev/mmcblk0p6
fsck.fat 4.1
open: Read-only file system
What to do?
Re: read only sd card after a mishap
Posted: Fri Nov 23, 2018 1:18 pm
by epoch1970
Buy another one, it's dead.
Posted: Fri Nov 23, 2018 1:27 pm
by erg
Right, could you elaborate, please?
I'm not an expert on those things so it puzzles me how come I can see the partitions, even open one of them and see the files and the card is broken?
I can see the /boot partition (vfat I guess)
Posted: Fri Nov 23, 2018 1:42 pm
by mattmiller
SD cards can go into a read-only mode at end-of-life
So you'll need a new card
Posted: Fri Nov 23, 2018 4:02 pm
by erg
ok then. I see. Only, why would that happen? It's less than a year that I was using it....
Posted: Fri Nov 23, 2018 4:12 pm
by epoch1970
When that Pi broke in half (...), the SD lost power at the wrong moment or received some other injury, and it went into degraded mode.
Posted: Fri Nov 23, 2018 4:30 pm
by erg
Thanks for that explanation. Tough luck.
