erg
read only sd card after a mishap "[solved]"
Fri Nov 23, 2018 1:11 pm
Hi all,
situation as follows: raspberry pi broke in half (no comment), now trying to fsck or reformat the card and it's read-only:
fdisk: cannot open /dev/mmcblk0: Read-only file system
device notifier shows three partitions, /root, /boot, and /SETTINGS
trying to check /boot partition on the card - the only one I can mount, gives that:
fsck.vfat /dev/mmcblk0p6
fsck.fat 4.1
open: Read-only file system
What to do?
epoch1970
Re: read only sd card after a mishap
Fri Nov 23, 2018 1:18 pm
Buy another one, it's dead.
erg
Fri Nov 23, 2018 1:27 pm
Right, could you elaborate, please?
I'm not an expert on those things so it puzzles me how come I can see the partitions, even open one of them and see the files and the card is broken?
I can see the /boot partition (vfat I guess)
mattmiller
Fri Nov 23, 2018 1:42 pm
SD cards can go into a read-only mode at end-of-life
So you'll need a new card
erg
Fri Nov 23, 2018 4:02 pm
ok then. I see. Only, why would that happen? It's less than a year that I was using it....
epoch1970
Fri Nov 23, 2018 4:12 pm
When that Pi broke in half (...), the SD lost power at the wrong moment or received some other injury, and it went into degraded mode.
erg
Fri Nov 23, 2018 4:30 pm
Thanks for that explanation. Tough luck.
