lucas.rocha
Wlan0 - Eth0 Bridge WITH DHCP AP
Tue Nov 20, 2018 12:10 pm
I have some devices connected via eth0 to my Raspberry Pi 3 B+ with the up to date Raspbian.
I would like to:
1. Make my RPi a wi-fi hotspot (DHCP) in order to be able to connect to the devices at Eth0 from my laptop via wi-fi... of course I can use a bridge however this is my problem. :x
The devices have IP addresses eg 192.168.1.XX so my network has to be (Wlan)192.168.0.X.
Its works with brigde, but without DHPC, I would like to connect at device with DHCP.
like this:
Laptop (DHCP) -----> wifi ------> RaspPi AP (Wlan0 192.168.0.1) ----> Device(Eth0 192.168.1.10)
Some idea?
SurferTim
Re: Wlan0 - Eth0 Bridge WITH DHCP AP
Tue Nov 20, 2018 12:29 pm
lucas.rocha wrote: 1. Make my RPi a wi-fi hotspot (DHCP) in order to be able to connect to the devices at Eth0 from my laptop via wi-fi... of course I can use a bridge however this is my problem. :x
A bridge will have the same networks on both eth0 and wlan0. Do you want to use a bridge or a NAT AP? A bridge normally does not have a DHCP server on the RPi, but it can be set up as a DHCP server if your laptop doesn't have one.
https://www.raspberrypi.org/documentati ... s-point.md
lucas.rocha
Wed Nov 21, 2018 2:40 pm
So, this is my problem, I can't connect in the device (this device have a internal webserver) if the rasppi or the device are not in the same network.
I would like to connect in my device from my Laptop...I really confused with this.
See the img bellow to understand.
SurferTim
Wed Nov 21, 2018 2:56 pm
You should have set up the RPi as a bridge, and used one subnet on both interfaces. Like 192.168.1.x/24.
Ernst
Wed Nov 21, 2018 2:58 pm
No problem if you are using a bridge with a 192.168.1.x address on the bridge interface.
Important to remember, the AP does not have an IP address.
The Ethernet port does not have an IP address, it is the bridge address which is needed to connect to your raspberry.
Set your laptop IP address to 192.168.1.x, connect to the AP, and then talk to 192.168.1.10.
andr3wz
Thu Jan 31, 2019 7:15 pm
Hi SurferTim, I followed your procedure for creating the bridge.
I have configured a static IP for the interface but even if it tells me that the link is up I can not access the internet.
I'm connected to the wifi network radiated by the 4g router and I want to share this connection via eth.
The pi3 is connected to a router via cable.
Please help me.
