The composite video's gone all funny
Posted: Wed Oct 31, 2018 12:37 pm
by FreezeTile
Here's a Halloween horror for you - I'm trying to get composite video working on my Pi so I can use it on an old CRT TV, but when I plug it in, all I get is this.
Any ideas?
Re: The composite video's gone all funny
Posted: Wed Oct 31, 2018 1:07 pm
by DougieLawson
Wrong mode or your signal and ground are swapped.
The RPi defaults to NTSC 480i unless you tell it to do otherwise.
Posted: Wed Oct 31, 2018 1:20 pm
by rpiMike
Set sdtv_mode=2 in /boot/config.txt for PAL
https://www.raspberrypi.org/documentati ... t/video.md
Posted: Wed Oct 31, 2018 3:32 pm
by FreezeTile
DougieLawson wrote: Wrong mode or your signal and ground are swapped.
rpiMike wrote: Set sdtv_mode=2 in /boot/config.txt for PAL
The cable I bought was advertised as being compatible with the Pi, so that can't be the problem. I tried changing the config file:
Screenshot 2018-10-31 at 15.17.36.png (120.73 KiB) Viewed 312 times
but I'm still getting the same fuzzy picture. What now?
Posted: Wed Oct 31, 2018 3:36 pm
by DougieLawson
Check that cable with a continuity checker (or a multimeter on resistance).
https://www.raspberrypi-spy.co.uk/2014/ ... ideo-jack/
Posted: Wed Oct 31, 2018 6:39 pm
by Burngate
Composite video has sync pulses that are blacker-than-black
That first picture is showing white sync pulses - the broad vertical white stripe is the line sync, the narrow horizontal white stripe is the vertical sync
So your cable isn't compatible, whatever the advert says.
Posted: Wed Oct 31, 2018 9:22 pm
by drgeoff
+1. Absolutely, definitely, certainly, without a doubt the cable is not wired appropriately for the TRRS socket on a RPi.
Posted: Wed Oct 31, 2018 9:25 pm
by FreezeTile
Bugger! >:-(
Oh well.
