omiez
Is this normal?
Fri Nov 09, 2012 7:10 pm
Hello
I connected my Usb Hdd, so far i can see that it is mounted on reboot but i see something strange when i call the command "mount".
/dev/sda on /media/Omiez type ntfs (ro,nosuid,nodev,relatime,uid=1000,gid=1000,fmask=0177,dmask=077,nls=utf8,errors=continue,mft_zone_multiplier=1,uhelper=udisk
Is there an error ? If yes how can i solve?
Nr.1 Raspberry Pi Mod.B Rev.2 256Mb Ram (Raspbian)
Raspberry Pi Mod.B Rev.2 512Mb Ram (Maybe i´ll get one)
flyinghappy
Re: Is this normal?
Fri Nov 09, 2012 7:33 pm
It is basically just telling you how the device is mounted and information about the drive. In this case, it is mounted read-only (ro), relatime is writing of file access times only when the file is being modified, nodev - Don't interpret block special devices on the filesystem, nosuid - Block the operation of suid, and sgid bits.
Pi with ArchLinux running a minidlna/samba home server
omiez
Re: Is this normal?
Fri Nov 09, 2012 8:09 pm
I want to have full access to the device without loosing access after reboot.
How can i do this?
I saw that i can´t even make a new folder and i want to use the hdd as storage for torrents.
