viral666
Cannot login to my pi via Putty...
Sun Oct 21, 2018 1:26 pm
Hello everyone!
I have been trying to login with putty and even though i seem to have intalled rasbian correctly and seem to have done everything correctly it will not let me connect.
I login as "pi" and use the password "raspberry" . I have used all the different ips available and the problem isnt solved :/
img: https://pasteboard.co/HJtTIW2.png
Re: Cannot login to my pi via Putty...
Sun Oct 21, 2018 2:23 pm
Have you enabled ssh?
Pull the plug, pull the SDCard. Insert the SDCard in your Windows system and create F:\ssh.txt on it. Eject it safely, put it back in your RPi. Boot the RPi and it will automagically enable ssh for you.
Note:Having anything remotely humorous in your signature is completely banned on this forum.
B.Goode
Sun Oct 21, 2018 2:32 pm
Presumably so, else the target would not be connecting and requesting login credentials as shown in the screenshot...
@viral666 - how did you determine that 192.168.obscured.obscured was the appropriate IP address for your RPi?
Maybe the system you are failing to log in to is not actually your RPi? That would explain the rejected login. pi:raspberry is correct for an unmodified installation of Raspbian.
mooblie
Sun Oct 21, 2018 5:16 pm
Remember some people mis-spell "raspberry" as "rasberry"...
viral666
Sun Oct 21, 2018 8:37 pm
you mean "ssh." ? i have done that.
mooblie wrote: Remember some people mis-spell "raspberry" as "rasberry"...
In my case I spell it correctly!
B.Goode wrote:
it is the only one that prompts me to login, maybe it is wrong... :/
GUYS, IS THIS CORRECT? http://prntscr.com/l8qjsf
B.Goode
Sun Oct 21, 2018 8:40 pm
Irrelevant.
Nothing to do with your interactive login details being rejected.
viral666
Sun Oct 21, 2018 8:53 pm
Irrelevant.
Isnt this done via wifi? if this is wrong maybe the pi isnt even connected and im trying to connect to a wrong address???
(Idk is what i said makes sense.. i am new to this...)
tel7
Sun Oct 21, 2018 10:05 pm
Hi viral,
Please humour me by trying this:
- Connect directly to your Pi
- Start Terminal
- Type: passwd <Enter>
- Type: raspberry <Enter>
- Paste what comes up into your next post.
- After that, if you are not back to the command prompt, you should be able to get there by pressing Ctrl-D a couple of times.
This should tell us if your password is what you think it is. Then we can tell you how to change it if you don't already know how.
Terry
DirkS
Sun Oct 21, 2018 10:44 pm
Do you mean
- Type: pi<Enter>
- Type: raspberry<Enter>
tel7
Sun Oct 21, 2018 11:06 pm
Technically, yes I do mean that Dirks, although I had hoped it was obvious, and just added the spaces for clarity, but it may not be obvious to some, and my "clarity" could backfire, so good point.
Thanks.
Terry
tel7
Tue Oct 23, 2018 8:39 pm
How did you get on with this, viral?
