samuelo
C++ Wrapper for Raspicam Access through MMAL
Fri Oct 19, 2018 12:27 pm
Hi everyone,
I got my Raspberry Pi Camera V2 NOIR to work using the OpenCV VideoCapture class (and therefore through the v4l2 API). However, I would like to have more control over the camera (e.g. set sensor mode independent from resolution) and access it through MMAL. I tried to use raspicam_cv but it doesn't seem to be working at all. I tried:
- Raspicam v0.1.6 from sourceforge (https://sourceforge.net/projects/raspicam/files/?)
- this version: https://github.com/cedricve/raspicam
This results in the following error:
mmal: mmal_vc_port_enable: failed to enable port vc.ril.camera:out:1(I420): ENOMEM
mmal: mmal_port_enable: failed to enable port vc.ril.camera:out:1(I420)(0x4a59d0) (ENOMEM)
camera video callback2 erroropen Failed to create camera component/home/pi/Downloads/raspicam/src/private/private_impl.cpp 103
My questions now:
1.) Are these versions stable and should work fine without any modifications? ( -> the problem has something to do with my setup/external factors )
2.) If not, is there an up-to-date version of a c++ MMAL wrapper available? (I already browsed the repositories by 6by9 but they seem similarly outdated)
Also:
  • When I run raspivid everything works fine so my camera shouldn't be the problem...
  • I tried debugging myself and modifying the source code to resemble the structure of raspividYUV (https://github.com/raspberrypi/userland ... piVidYUV.c). There are a few differences in the order of calls to mmal_port_enable, mmal_component_enable... Unfortunately this didn't give any better results :-/
  • my GPU memory is at 256
  • There should be no other instance running (I did sudo modprobe -r bcm2835-v4l2 after enabling it)
It would be great if someone could help me out :)
Thanks and have a nice weekend everyone,
samuelo
