Broken upgrades
Posted: Fri Nov 09, 2012 1:13 pm
by apoth
I'm suffering with the below error, apt-get -f install and dpkg --configure -a fail in a similar fashion. Any ideas how I can fix it? Force reinstalling perl?
sudo aptitude upgrade
The following packages will be upgraded:
  debian-reference-common debian-reference-en elinks elinks-data libgif4
  libio-socket-ssl-perl libsystemd-login0 libvpx-dev libvpx1
The following partially installed packages will be configured:
  ccache lightdm man-db
9 packages upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
Need to get 0 B/3,598 kB of archives. After unpacking 20.5 kB will be freed.
Do you want to continue? [Y/n/?]
debconf: Perl may be unconfigured (Can't locate IO/File.pm in @INC (@INC contains: /etc/perl /usr/local/lib/perl/5.14.2 /usr/local/share/perl/5.14.2 /usr/lib/perl5 /usr/share/perl5 /usr/lib/perl/5.14 /usr/share/perl/5.14 /usr/local/lib/site_perl .) at /usr/share/perl/5.14/FileHandle.pm line 9.
Compilation failed in require at (eval 1) line 3.
BEGIN failed--compilation aborted at (eval 1) line 3.
) -- aborting
dpkg: error processing passwd (--configure):
 package passwd is not ready for configuration
 cannot configure (current status `half-installed')
 passwd
E: Sub-process /usr/bin/dpkg returned an error code (1)
A package failed to install.  Trying to recover:
Setting up man-db (2.6.2-1) ...
Can't locate POSIX.pm in @INC (@INC contains: /etc/perl /usr/local/lib/perl/5.14.2 /usr/local/share/perl/5.14.2 /usr/lib/perl5 /usr/share/perl5 /usr/lib/perl/5.14 /usr/share/perl/5.14 /usr/local/lib/site_perl .) at /usr/share/perl5/Debconf/Template.pm line 7.
BEGIN failed--compilation aborted at /usr/share/perl5/Debconf/Template.pm line 7.
Compilation failed in require at /usr/share/perl5/Debconf/Question.pm line 8.
BEGIN failed--compilation aborted at /usr/share/perl5/Debconf/Question.pm line 8.
Compilation failed in require at /usr/share/perl5/Debconf/Config.pm line 7.
BEGIN failed--compilation aborted at /usr/share/perl5/Debconf/Config.pm line 7.
Compilation failed in require at /usr/share/perl5/Debconf/Log.pm line 10.
Compilation failed in require at /usr/share/perl5/Debconf/Db.pm line 7.
BEGIN failed--compilation aborted at /usr/share/perl5/Debconf/Db.pm line 7.
Compilation failed in require at /usr/share/debconf/frontend line 6.
BEGIN failed--compilation aborted at /usr/share/debconf/frontend line 6.
dpkg: error processing man-db (--configure):
 subprocess installed post-installation script returned error exit status 2
Setting up ccache (3.1.7-1) ...
Updating symlinks in /usr/lib/ccache ...
Can't locate File/Glob.pm in @INC (@INC contains: /etc/perl /usr/local/lib/perl/5.14.2 /usr/local/share/perl/5.14.2 /usr/lib/perl5 /usr/share/perl5 /usr/lib/perl/5.14 /usr/share/perl/5.14 /usr/local/lib/site_perl .) at /usr/sbin/update-ccache-symlinks line 35.
BEGIN failed--compilation aborted at /usr/sbin/update-ccache-symlinks line 35.
dpkg: error processing ccache (--configure):
Setting up lightdm (1.2.2-4) ...
dpkg: error processing lightdm (--configure):
 man-db
 ccache
 lightdm
