obabarin
Bash script as Cron job to run at reboot
Mon Oct 15, 2018 11:32 am
Dear,
I created the following bash script for data logging from uart port using Grabserial which works find from the terminal.
#!/bin/sh
sleep 2
grabserial -v -d /dev/ttyAMA0 -T -b 115200 -e 3600 -Q -o "/media/pi/E27F-7413/PiData/file-%d-%m-%Y-%H.%M.%S.txt" -a
I will want this script to run immediately after my Rpi3 has boot up, this I tried to achieve by adding cron jobs. But I could not getting it working. The various cron jobs I have tried are follows and none worked.
# @reboot sudo /home/pi/Documents/Grabber/./grab.sh
# @reboot sudo /home/pi/Documents/Grabber/grab.sh
# @reboot /bin/sh sudo /home/pi/Documents/Grabber/grab.sh
# @reboot /bin/sh /home/pi/Documents/Grabber/grab.sh
# @reboot /usr/bin/sh sudo /home/pi/Documents/Grabber/grab.sh
@reboot /usr/bin/sh /home/pi/Documents/Grabber/grab.sh
*I do remove the # before running/rebooting the RPi*
I have been able to successfully run cron jobs of C/C++ programs before now. I simply followed the examples of my previous exercises. The following programs had been tested to work successfully.
# @reboot sudo /home/pi/Documents/myC/./uartStart
# @reboot sudo /home/pi/Documents/myC/./tictocuart
Any useful suggestions please?
NB- in the terminal window, I can successfully run the script using
DirkS
Re: Bash script as Cron job to run at reboot
Mon Oct 15, 2018 11:39 am
I see your script uses a mounted drive.
Is the drive mounted at the time the script is executed? If not it will probably fail.
For a quick test I would set the output to a local directory (e.g. /home/pi)
obabarin
Mon Oct 15, 2018 3:03 pm
Thanks for the tip. I changed the directory to save files to local memory other than external, and then tried all the previous commands. None seems to work for me. Any other suggestions please?
RaTTuS
Mon Oct 15, 2018 3:06 pm
don't use cron
use a systemd .service file
Covfefe
obabarin
Mon Oct 15, 2018 6:11 pm
don't use cron
Thanks for the suggestion. I tried out using the systemd, but it keeps restarting the script. I can't seem to find an option for not restarting. None of the parameters- no, always, no-success, on-failure, on-normal, on-abort seems to work appropiately.
DirkS
Mon Oct 15, 2018 7:18 pm
Instead of just saying 'it doesn't work' give us something to go on, such as (error) messages.
Redirect stdout an stderr to a file. Something like
command >/home/pi/output.txt 2>&1
Also post your systemd service file.
obabarin
Tue Oct 16, 2018 9:59 am
All right @DirkS.
Here is the journalctl out of the pigrab.service:
-- Logs begin at Thu 2016-11-03 18:16:42 CET, end at Tue 2018-10-16 11:50:44 CEST. --
Oct 16 11:46:02 raspberrypi systemd[1]: Started serial data logger with grabserial.
Oct 16 11:46:09 raspberrypi pigrab.sh[2728]: Opening serial port /dev/ttyAMA0
Oct 16 11:46:09 raspberrypi pigrab.sh[2728]: 115200:8N1:xonxoff=0:rtscts=0
Oct 16 11:46:09 raspberrypi pigrab.sh[2728]: Program set to restart after 3600 seconds.
Oct 16 11:46:09 raspberrypi pigrab.sh[2728]: Printing absolute timing information for each line
Oct 16 11:46:09 raspberrypi pigrab.sh[2728]: Saving data to '/home/pi/file-16-10-2018-11.46.09.txt'
Oct 16 11:46:09 raspberrypi pigrab.sh[2728]: Keeping quiet on stdout
Oct 16 11:46:09 raspberrypi pigrab.sh[2728]: Use Control-C to stop...
Oct 16 11:46:09 raspberrypi pigrab.sh[2728]: Traceback (most recent call last):
Oct 16 11:46:09 raspberrypi pigrab.sh[2728]: File "/usr/local/bin/grabserial", line 4, in <module>
Oct 16 11:46:09 raspberrypi pigrab.sh[2728]: __import__('pkg_resources').run_script('grabserial==1.9.8', 'grabserial')
Oct 16 11:46:09 raspberrypi pigrab.sh[2728]: File "/usr/lib/python2.7/dist-packages/pkg_resources/__init__.py", line 739, in run_script
Oct 16 11:46:09 raspberrypi pigrab.sh[2728]: self.require(requires)[0].run_script(script_name, ns)
Oct 16 11:46:09 raspberrypi pigrab.sh[2728]: File "/usr/lib/python2.7/dist-packages/pkg_resources/__init__.py", line 1501, in run_script
Oct 16 11:46:09 raspberrypi pigrab.sh[2728]: exec(script_code, namespace, namespace)
Oct 16 11:46:09 raspberrypi pigrab.sh[2728]: File "/usr/local/lib/python2.7/dist-packages/grabserial-1.9.8-py2.7.egg/EGG-INFO/scripts/grabserial", line 588, in <module>
Oct 16 11:46:09 raspberrypi pigrab.sh[2728]: File "/usr/local/lib/python2.7/dist-packages/grabserial-1.9.8-py2.7.egg/EGG-INFO/scripts/grabserial", line 500, in grab
Oct 16 11:46:09 raspberrypi pigrab.sh[2728]: TypeError: encode() argument 1 must be string, not None
Oct 16 11:46:09 raspberrypi systemd[1]: pigrab.service: Main process exited, code=exited, status=1/FAILURE
Oct 16 11:46:09 raspberrypi systemd[1]: pigrab.service: Unit entered failed state.
Oct 16 11:46:09 raspberrypi systemd[1]: pigrab.service: Failed with result 'exit-code'.
And also is my bash script
#! /bin/sh
sleep 5
grabserial -v -d /dev/ttyAMA0 -T -b 115200 -e 3600 -Q -o "/home/pi/file-%d-%m-%Y-%H.%M.%S.txt" -a
DirkS
Tue Oct 16, 2018 11:29 am
There's your problem. grabserial crashes on line 500 (https://github.com/tbird20d/grabserial/ ... erial#L500)
Seems to be a problem with 'sys'stdout.encoding'.
Looks like the behaviour is different between running in the foreground or from cron / system service file.
ATM I have no idea how to fix it; you may want to contact the developer.
obabarin
Tue Oct 16, 2018 8:39 pm
Thanks for the comments. The developer is yet to respond.
But I found a work around here https://www.raspberrypi.org/forums/view ... 6#p485866 . Though this comes with some inconvenience.
