windows 10 network mapping
Posted: Sat Oct 13, 2018 12:36 am
by approxdec
hello everyone.
in a windows 10 to RPi network connection [ethernet, B+, raspian stretch]
is it usual to expose the /pi directory in the "Map Network Drive' / "Browse for Folder" dialogue ?
i can't remember my first view before network fiddlin' .
have i exposed this myself and if so how do NOT expose it?
thanks
joe
Re: windows 10 network mapping
Posted: Sat Oct 13, 2018 12:45 pm
by hortimech
I take it you have a part of your smb.conf that starts '[homes]', is so, remove it along with the lines associated with it.
If unsure post your smb.conf
Posted: Sat Oct 13, 2018 12:55 pm
by LTolledo
set
browsable = no
in your smb.conf
Posted: Sat Oct 13, 2018 4:23 pm
by DirkS
set
browsable = no
in your smb.conf
Indeed. And it needs to go into the [homes] section.
Posted: Sat Oct 13, 2018 6:56 pm
by hortimech
Well yes, you could that, but it is probably just papering over the problem, hiding it doesn't mean it isn't there. Most rpi's have a user called rpi, so you can navigate to the users home directory with the UNC. So if you don't want your home directory to be available via Samba, do not share it.
Posted: Sat Oct 13, 2018 8:20 pm
by DirkS
Again acting as a 'clarifier': this means you have to remove / deactivate the [homes] section
Posted: Sat Oct 13, 2018 10:10 pm
by LTolledo
if you dont want your RPi visible in any way in the network... then run these set of commands
sudo apt remove --purge samba samba-common-bin
sudo apt clean
sudo apt autoremove
Posted: Sat Oct 13, 2018 10:27 pm
by DirkS
sudo apt clean
sudo apt autoremove
OP is just 'complaining' about the visibility of the 'pi' directory, not any of the other shares,
Posted: Sat Oct 13, 2018 11:22 pm
by approxdec
thank you everyone for your replies.
i need to work through each to make sure i get it.
and sorry i did not reply earlier - my post took quite a while
before it was visible to me.
Posted: Sun Oct 14, 2018 8:47 am
by hortimech
sudo apt clean
sudo apt autoremove
You forgot Avahi, nfs etc
Posted: Sun Oct 14, 2018 8:49 am
by hortimech
I said basically that in my first post in this thread.
