Connect to Kindle with file manager
Posted: Thu Oct 11, 2018 10:46 pm
by rquint
If you plug a Kindle e-reader into a Ubuntu box (using a USB cable) the Kindle is mounted as removable media in Nautilus automatically. On a PI running Stretch I can't figure out how to do the same thing with the default file manager. I have all the auto-mount options enabled in Edit|Preferences|Volume Management. Am I missing something?
Re: Connect to Kindle with file manager
Posted: Thu Oct 11, 2018 11:00 pm
by klricks
In filemanager menu [Go] --> [Network]
Posted: Thu Oct 11, 2018 11:06 pm
by rquint
No, that doesn't work. All I see there are my Ubuntu box and other machines on a Windows network using Samba.
Posted: Fri Oct 12, 2018 12:01 am
by PhatFil
does a cli lsusb list the kindle when connected?
Posted: Fri Oct 12, 2018 12:06 am
by rquint
No, there is nothing from lsusb and there is nothing in the output of dmesg that seems relevant either. Again, for reference, when plugged into the Ubuntu box lsusb lists the Kindle as one of the connected devices. Could this be an Android issue? I tried plugging in a Kindle Fire and a Barnes & Noble Nook with the same results. And just to check, plugging in a flash drive worked as expected.
Posted: Fri Oct 12, 2018 12:34 am
by PhatFil
hmm swap over the usb cable? clean the usb port( pi and kindle) with a cotton bud and isopropanol or similar solvent?
fwiw i just plugged my kindle into a pi-0w with a very dodgy usb/nic hub and the result of lsusb was..
pi@RasPi0W:~ $ lsusb
Bus 001 Device 011: ID 1949:0004 Lab126, Inc. Amazon Kindle 3/4/Paperwhite
Bus 001 Device 002: ID 1a40:0101 Terminus Technology Inc. Hub
pi@RasPi0W:~ $
Posted: Fri Oct 12, 2018 12:43 am
by rquint
You got it. I think it was lack of power. I pulled one of my dongles (Bluetooth, which I don't need right now) and voila! I'll have to use a powered hub when I connect the Kindle.
Posted: Fri Oct 12, 2018 1:00 am
by PhatFil
good news..
perhaps the kindle was drawing too much power as it was attempting to also recharge its battery, mine was fresh off a charge up so handy to plug into a pi to test.. perhaps a fully charged kindle will work with your btooth adaptor too..
