FriendlyFire
[Raspbian 9 (stretch)] Is opencv installed by default ? If so how do you use it!
Thu Oct 11, 2018 10:39 pm
As the title states, I'm on Stretch (on a Pi zero W btw). I need to do some fairly simple image processing, and was happy to find out it has a default install of opencv2.4.9, as that should be enough.
I just can't seem to get any code to find it. I'm working in C++, and get the error "Package opencv was not found in the pkg-config search path". Which is fair enough because although pkg-config was already installed, when I checked I found it's search path was blank. Trying to find where opencv was installed turned out to be totally fruitless.
I then decided to test in python, because it seems like the Pi comes setup for python specifically, and >>import cv2 fails as well!
Using >>sudo apt-get remove libopencv* I get the option to remove the opencv packages. So it sure seems like they are on here, but I can't figure out how to find/use them. And the only things I can find online, or this forum, talk about installing opencv from scratch. Haven't seen any that explained how to find the native install.
Am I missing something obvious? Is there a secret trick to using the installed opencv package? Should I just remove it and reinstall it "properly"?
Thanks for any help!
topguy
Re: [Raspbian 9 (stretch)] Is opencv installed by default ? If so how do you use it!
Fri Oct 12, 2018 11:25 am
At minimum you need to do a "sudo apt install libopencv-dev". Check your pkg-config after that.
But you can get a newer OpenCV if you build it yourself, and there should be a bunch of guides on the net for that.
Fri Oct 12, 2018 12:34 pm
Try this link, it might help.
https://blog.piwheels.org/new-opencv-builds/
sora03
Fri Oct 12, 2018 1:11 pm
if you are using python then install opencv with pip:
$ pip install opencv-python
FLOSS enthusiast, Debian user (linux-libre)
FriendlyFire
Fri Oct 12, 2018 11:10 pm
Appreciate the help from everyone, but this fixed the issue, thanks topguy! Never thought about it being built, but not installed.
topguy
Sat Oct 13, 2018 3:44 pm
I'ts not really about that..
Most libraries have a standard package that includes the compiled library ( .so files ). All other software already compiled will just load this library file dynamically if they need it.
The "-dev" or developer package includes typically the additional header files ( .h/.hpp ) needed to compile new programs that also will load the ".so" files when runned.
So if you want to use a library in your programming you need to have both the "libsomething" and "libsomthing-dev" packages installed. But you usually need only to run "apt install libsomething-dev" because the other package will be a dependency and will also be installed automatically.
