flamner
raspbian stretch lite wpa_supplicant.conf
Wed Oct 03, 2018 6:31 am
not working... Hi I tried to setup wifi connection on my pi zero W, I don't have wired keyboard, so the only way is ti prepare wpa_supplicant.conf and ssh file and put it on sd card. I did it on raspbian jessie and it worked like a charm, but now it's not. After boot raspbian delete those files, and wifi not work. Any solutions?? :(
ShiftPlusOne
Re: raspbian stretch lite wpa_supplicant.conf
Thu Oct 04, 2018 2:26 pm
What does your wpa_supplicant.conf file look like?
flamner
Sat Oct 06, 2018 5:30 am
country=PL
update_config=1
network={
    ssid="NAME"
    scan_ssid=1
    psk="PASSWD"
    key_mgmt=WPA-PSK
flamner
Sat Oct 06, 2018 11:19 am
In raspbian jessie lite everything works fine
DirkS
Sat Oct 06, 2018 12:14 pm
How did you verify that it is not working in Stretch?
dgordon42
Sat Oct 06, 2018 4:36 pm
country=PL
update_config=1
network={
    ssid="NAME"
    scan_ssid=1
    psk="PASSWD"
    key_mgmt=WPA-PSK
Try it without the "scan_ssid=1" line.
Hope this helps,
Dave.
Sat Oct 06, 2018 5:59 pm
You need the scan_ssid=1 line if the AP hides its SSID. It shouldn't have any effect on a visible network.
Does the AP use WPA/WPA2 or some other WiFi security like WEP?
This is a doctor free zone.
flamner
Mon Oct 08, 2018 4:24 am
I tried the same wpa_supplicant.conf file on jessie and stretch.
WPA-PSK/WPA2-PSK
HawaiianPi
Mon Oct 08, 2018 7:48 am
I see nothing wrong with that wpa_supplicant.conf file (other than you shouldn't be hiding your SSID). In fact, I copied and pasted it into Notepad, added my network info, saved it to a freshly imaged Raspbian Stretch micro SD card, and booted it in my Pi Zero W. It works as expected.
Generally problems like this are in the formatting or encoding of the file. Things like hidden control characters or curly quotes, which are sometimes introduced by the editor used, will invalidate the file. However, you say it works in Jessie, so... ¯\_(ツ)_/¯
Try this Raspbian Lite image I have pre-configured for USB Gadget mode.
2018-06-27-raspbian-stretch-lite_Pi0-USB.zip
SHA-256: fb92d04adfca58b61ecbaedc4d748947ddb3c4121321f64cc3d49f75d296266e
Use Etcher to write it to your card and copy your wpa_supplicant.conf file to the FAT32 "boot" partition.
Unplug your power supply from the Pi Zero W and connect a normal micro USB data cable to the data port on your Pi Zero W (leave nothing connected to the power port). Insert the micro SD card and plug the other end of the micro USB cable into a USB port on your main (Windows/Mac/linux) PC.
The Pi Zero W will start to boot and after a minute or two a new USB Ethernet/RNDIS Gadget network adapter will get installed.
If you have a MacOS or Linux PC you should then be able to SSH into [email protected] For Windows you will need to install an mDNS/Zeroconf network service, and the simplest way to do that is to install Apple's Bonjour print service (then you'll be able to SSH into [email protected] with Windows).
With fully up to date Windows 10 you can SSH from cmd.exe or Windows Power Shell. Otherwise install and use the PuTTY application.
Once you are logged in to your Pi0W, try the following commands.
sudo cat /etc/wpa_supplicant/wpa_supplicant.conf
ifconfig
cat /sys/firmware/devicetree/base/model;echo
The first will show you the contents of the wpa_supplicant.conf file (see if that is the same as your file).
The second will show if WLAN0 has a valid IP address (you should be able to SSH into that IP as well).
The third command will display the model and version of your Pi (if it doesn't say it's a Pi Zero W, something is wrong).
ShiftPlusOne
Mon Oct 08, 2018 9:28 am
Some more commands to help diagnose what's going on:
rfkill list all
lsmod
wpa_cli -i wlan0 status
wpa_cli -i wlan0 scan && sleep 5
wpa_cli -i wlan0 scan_results
sudo journalctl -b0 -u dhcpcd
pgrep -a wpa_supplicant
macgyverapi
Sun Feb 17, 2019 3:36 pm
Also Note: you won't be able to connect to 5G networks on the first bootup.
HawaiianPi
Mon Feb 18, 2019 8:04 pm
The Pi Zero W doesn't support 5GHz (much less 5G, which is a mobile broadband standard), so it won't connect to that on any boot.
The Raspberry Pi 3B+ connects to 5GHz on first boot (or any other boot) with a properly configured wpa_supplicant.conf file.
Not really sure what you were trying to imply... :?
